model blow up in 7th year of climatological run
navin
#1 Unread post by navin »
Hi all I am trying to run a climatological simulation for 10 year. ahere is the my model configuration
Saturday - January 28, 2017 - 11:38:08 AM
Ganga Basin
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 820M
Local Root : /home/adrao/navin/roms/trunk
Header Dir : /home/adrao/navin/project/ganga_basin
Header file : basin.h
Analytical Dir: /home/adrao/navin/project/ganga_basin
Resolution, Grid 01: 0161x0094x030, Parallel Nodes: 12, Tiling: 004x003
10368400 ntimes Number of timesteps for 3-D equations.
60 ndtfast Number of timesteps for 2-D equations between
into restart fields.
to standard output.
0 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
time-averaged data.
288 nAVG Number of timesteps between the writing of
103680 ndefAVG Number of timesteps between creation of new
time-averaged file.
0 ntsDIA Starting timestep for the accumulation of output
10368 nDIA Number of timesteps between the writing of
103680 ndefDIA Number of timesteps between creation of new
diagnostic file.
5.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
1.0000E-04 rdrg Linear bottom drag coefficient (m/s).
1.0000E-03 rdrg2 Quadratic bottom drag coefficient.
1 lmd_Jwt Jerlov water type.
6.0000E+00 theta_s S-coordinate surface control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
1027.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
-1.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
3.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.6000E+02 Znudg Nudging/relaxation time scale (days)
3.6000E+02 M2nudg Nudging/relaxation time scale (days)
3.6000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
-0.278 T0 Background potential temperature (C) constant.
34.649 S0 Background salinity (PSU) constant.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
Prefix for Averages Files: ocean_avg
Prefix for Diagnostics Files: ocean_dia
Input Grid File: roms_grd.nc
Input Nonlinear Initial File: roms_ini.nc
Input Forcing File 01: roms_frc.nc
Input Climatology File: roms_clm.nc
Input Boundary File: roms_bry.nc
Tile partition information for Grid 01: 0161x0094x0030 tiling: 004x003
tile Istr Iend Jstr Jend Npts
0 1 40 1 31 37200
1 41 81 1 31 38130
2 82 122 1 31 38130
3 123 161 1 31 36270
4 1 40 32 63 38400
5 41 81 32 63 39360
6 82 122 32 63 39360
7 123 161 32 63 37440
8 1 40 64 94 37200
9 41 81 64 94 38130
10 82 122 64 94 38130
11 123 161 64 94 36270
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 40.50 0.50 31.50 RHO-points
1 40.50 81.50 0.50 31.50 RHO-points
2 81.50 122.50 0.50 31.50 RHO-points
3 122.50 161.50 0.50 31.50 RHO-points
4 0.50 40.50 31.50 63.50 RHO-points
5 40.50 81.50 31.50 63.50 RHO-points
6 81.50 122.50 31.50 63.50 RHO-points
7 122.50 161.50 31.50 63.50 RHO-points
8 0.50 40.50 63.50 94.50 RHO-points
9 40.50 81.50 63.50 94.50 RHO-points
10 81.50 122.50 63.50 94.50 RHO-points
11 122.50 161.50 63.50 94.50 RHO-points
0 1.00 40.50 0.50 31.50 U-points
1 40.50 81.50 0.50 31.50 U-points
2 81.50 122.50 0.50 31.50 U-points
3 122.50 161.00 0.50 31.50 U-points
4 1.00 40.50 31.50 63.50 U-points
5 40.50 81.50 31.50 63.50 U-points
6 81.50 122.50 31.50 63.50 U-points
7 122.50 161.00 31.50 63.50 U-points
8 1.00 40.50 63.50 94.50 U-points
9 40.50 81.50 63.50 94.50 U-points
10 81.50 122.50 63.50 94.50 U-points
11 122.50 161.00 63.50 94.50 U-points
0 0.50 40.50 1.00 31.50 V-points
1 40.50 81.50 1.00 31.50 V-points
2 81.50 122.50 1.00 31.50 V-points
3 122.50 161.50 1.00 31.50 V-points
4 0.50 40.50 31.50 63.50 V-points
5 40.50 81.50 31.50 63.50 V-points
6 81.50 122.50 31.50 63.50 V-points
7 122.50 161.50 31.50 63.50 V-points
8 0.50 40.50 63.50 94.00 V-points
9 40.50 81.50 63.50 94.00 V-points
10 81.50 122.50 63.50 94.00 V-points
11 122.50 161.50 63.50 94.00 V-points
HaloSizeI(1) = 106
HaloSizeJ(1) = 88
TileSide(1) = 47
TileSize(1) = 1786
zeta 1 Closed Chapman Imp Closed Closed
ubar 1 Closed Flather Closed Closed
vbar 1 Closed Flather Closed Closed
u 1 Closed Rad + Nud Closed Closed
v 1 Closed Rad + Nud Closed Closed
temp 1 Closed Rad + Nud Closed Closed
salt 1 Closed Rad + Nud Closed Closed
basin Ganga Basin
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
LMD_BKPP KPP bottom boundary layer mixing.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
SCORRECTION Surface salinity flux correction.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 11 (pid= 19328) is active.
Node # 0 (pid= 19317) is active.
Node # 1 (pid= 19318) is active.
Node # 2 (pid= 19319) is active.
Node # 3 (pid= 19320) is active.
Node # 4 (pid= 19321) is active.
Node # 5 (pid= 19322) is active.
Node # 6 (pid= 19323) is active.
Node # 7 (pid= 19324) is active.
Node # 8 (pid= 19325) is active.
Node # 9 (pid= 19326) is active.
Node # 10 (pid= 19327) is active.
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0001000 -0.224 -0.167 -0.394 -0.461
28 -0.0666667 -0.0004039 -0.450 -0.335 -0.921 -1.187
27 -0.1000000 -0.0009240 -0.679 -0.505 -1.590 -2.193
26 -0.1333333 -0.0016812 -0.911 -0.675 -2.415 -3.508
25 -0.1666667 -0.0027057 -1.147 -0.847 -3.414 -5.170
24 -0.2000000 -0.0040388 -1.387 -1.020 -4.615 -7.234
23 -0.2333333 -0.0057340 -1.632 -1.195 -6.054 -9.767
22 -0.2666667 -0.0078592 -1.883 -1.373 -7.774 -12.860
21 -0.3000000 -0.0104998 -2.140 -1.552 -9.832 -16.623
20 -0.3333333 -0.0137617 -2.406 -1.735 -12.297 -21.193
19 -0.3666667 -0.0177759 -2.681 -1.922 -15.254 -26.740
18 -0.4000000 -0.0227035 -2.969 -2.114 -18.809 -33.475
17 -0.4333333 -0.0287422 -3.272 -2.310 -23.092 -41.653
16 -0.4666667 -0.0361343 -3.593 -2.514 -28.262 -51.591
15 -0.5000000 -0.0451767 -3.936 -2.726 -34.512 -63.673
14 -0.5333333 -0.0562320 -4.305 -2.948 -42.081 -78.371
13 -0.5666667 -0.0697441 -4.708 -3.182 -51.258 -96.262
12 -0.6000000 -0.0862553 -5.150 -3.431 -62.400 -118.051
11 -0.6333333 -0.1064281 -5.641 -3.699 -75.940 -144.598
10 -0.6666667 -0.1310722 -6.192 -3.989 -92.407 -176.956
9 -0.7000000 -0.1611766 -6.816 -4.306 -112.451 -216.410
8 -0.7333333 -0.1979496 -7.528 -4.656 -136.862 -264.530
7 -0.7666667 -0.2428669 -8.349 -5.048 -166.607 -323.235
6 -0.8000000 -0.2977313 -9.303 -5.489 -202.867 -394.867
5 -0.8333333 -0.3647446 -10.419 -5.990 -247.082 -482.287
4 -0.8666667 -0.4465964 -11.732 -6.566 -301.016 -588.991
3 -0.9000000 -0.5465716 -13.288 -7.233 -366.818 -719.248
2 -0.9333333 -0.6686826 -15.138 -8.010 -447.117 -878.273
1 -0.9666667 -0.8178301 -17.349 -8.922 -545.123 -1072.434
0 -1.0000000 -1.0000000 -20.000 -10.000 -664.755 -1309.510
Time Splitting Weights for Grid 01: ndtfast = 60 nfast = 83
1-0.0003540175431531 0.0166666666666667-0.0003540175431531 0.0166666666666667
82 0.0038385045257688 0.0000646481340986 0.9999596164798544 0.9999993269413311
83 0.0000403835201457 0.0000006730586691 1.0000000000000000 1.0000000000000002
ndtfast, nfast = 60 83 nfast/ndtfast = 1.38333
1.000000000000 1.029032332991 0.514516166496 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.23667
Minimum X-grid spacing, DXmin = 4.07572682E+00 km
Maximum X-grid spacing, DXmax = 4.17722842E+00 km
Minimum Y-grid spacing, DYmin = 4.07742924E+00 km
Maximum Y-grid spacing, DYmax = 4.17672927E+00 km
Minimum Z-grid spacing, DZmin = 2.23555236E-01 m
Maximum Z-grid spacing, DZmax = 2.37076156E+02 m
Minimum barotropic Courant Number = 2.37124800E-02
Maximum barotropic Courant Number = 1.91894937E-01
Maximum Coriolis Courant Number = 1.68779012E-02
(Grid 01, File: roms_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 5.91923258E+00 Max = 2.74125346E+01)
- salinity
(Min = 2.85027803E+01 Max = 3.50388689E+01)
GET_2DFLD - solar shortwave radiation flux, t = 345 00:00:00
(Rec=0000012, Index=1, File: roms_frc.nc)
(Min = 4.08869648E-05 Max = 4.24838710E-05)
GET_2DFLD - sea surface temperature climatology, t = 345 00:00:00
(Min = 2.47006241E+01 Max = 2.60613308E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 345 00:00:00
(Min = -7.37848173E-06 Max = -5.43064414E-06)
GET_2DFLD - sea surface salinity climatology, t = 345 00:00:00
(Min = 2.06685009E+01 Max = 2.92665501E+01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 345 00:00:00
(Rec=0000012, Index=2, File: roms_bry.nc)
(Min = -1.60102251E-02 Max = -0.00000000E+00)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -1.15041479E-01 Max = 1.87374092E-01)
GET_NGFLD - temperature southern boundary condition, t = 345 00:00:00
(Min = 5.85967228E+00 Max = 2.86468238E+01)
GET_NGFLD - salinity southern boundary condition, t = 345 00:00:00
(Min = 2.83652836E+01 Max = 3.50455970E+01)
GET_3DFLD - potential temperature climatology, t = 345 00:00:00
(Rec=0000012, Index=1, File: roms_clm.nc)
(Min = 5.85952212E+00 Max = 2.87330165E+01)
GET_3DFLD - salinity climatology, t = 345 00:00:00
Maximum grid stiffness ratios: rx0 = 2.207350E-01 (Beckmann and Haidvogel)
rx1 = 2.429055E+00 (Haney)
Initial basin volumes: TotVolume = 1.7564687198E+13 m3
MinVolume = 3.7571549879E+06 m3
MaxVolume = 4.1353152409E+09 m3
Max/Min = 1.1006506929E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 10368400)
GET_2DFLD - solar shortwave radiation flux, t = 15 00:00:00
(Rec=0000001, Index=2, File: roms_frc.nc)
(Min = 4.54222932E-05 Max = 4.80999585E-05)
GET_2DFLD - sea surface temperature climatology, t = 15 00:00:00
(Min = 2.37934224E+01 Max = 2.50115380E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 15 00:00:00
(Min = -7.04108909E-06 Max = -5.16924856E-06)
GET_2DFLD - sea surface salinity climatology, t = 15 00:00:00
(Min = 2.58551006E+01 Max = 3.04863005E+01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 15 00:00:00
(Rec=0000001, Index=1, File: roms_bry.nc)
(Min = -1.69484566E-02 Max = -0.00000000E+00)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 15 00:00:00
(Min = -1.39568958E-01 Max = 1.08149257E-01)
GET_NGFLD - temperature southern boundary condition, t = 15 00:00:00
(Min = 5.91955336E+00 Max = 2.72979432E+01)
GET_NGFLD - salinity southern boundary condition, t = 15 00:00:00
(Min = 3.08122848E+01 Max = 3.50358070E+01)
GET_3DFLD - potential temperature climatology, t = 15 00:00:00
(Rec=0000001, Index=2, File: roms_clm.nc)
GET_3DFLD - salinity climatology, t = 15 00:00:00
0 0 00:00:00 1.388118E-15 1.960811E+03 1.960811E+03 2.023138E+13
(136,01,04) 0.000000E+00 4.306884E-08 0.000000E+00 8.479950E-07
DEF_AVG - creating average file, Grid 01: ocean_avg_0001.nc
DEF_DIAGS - creating diagnostics file, Grid 01: ocean_dia_0001.nc
1 0 00:05:00 2.632957E-07 1.960810E+03 1.960810E+03 2.023138E+13
(091,05,01) 5.663001E-05 1.569162E-04 0.000000E+00 2.645462E-03
2 0 00:10:00 9.694084E-07 1.960809E+03 1.960809E+03 2.023140E+13
(073,09,30) 1.055442E-04 2.905283E-05 2.480221E-02 5.141087E-03
634246 2202 05:50:00 8.341274E-03 1.957083E+03 1.957092E+03 2.023015E+13
(119,02,19) 4.799131E-03 4.409345E-04 1.909383E+00 1.821510E+00
634247 2202 05:55:00 8.338404E-03 1.957093E+03 1.957101E+03 2.023015E+13
(119,02,19) 6.480023E-03 2.214997E-04 2.046817E+00 1.921934E+00
WRT_RST - wrote re-start fields (Index=2,2) in record = 0000003
Node # 0 CPU: 205738.384
Node # 4 CPU: 205839.904
Node # 5 CPU: 205801.500
Node # 6 CPU: 205789.588
Node # 8 CPU: 205804.908
Node # 9 CPU: 205837.588
Node # 10 CPU: 205806.152
Node # 1 CPU: 205801.740
Node # 2 CPU: 205791.892
Node # 7 CPU: 205828.544
Node # 11 CPU: 205810.308
Node # 3 CPU: 205834.332
Total: 2469684.840
Allocation and array initialization .............. 1.208 ( 0.0000 %)
Ocean state initialization ....................... 0.092 ( 0.0000 %)
Reading of input data ............................ 172.196 ( 0.0070 %)
Processing of input data ......................... 22365.908 ( 0.9056 %)
Processing of output time averaged data .......... 147542.052 ( 5.9741 %)
Computation of vertical boundary conditions ...... 1301.524 ( 0.0527 %)
Computation of global information integrals ...... 15982.852 ( 0.6472 %)
Writing of output data ........................... 7550.128 ( 0.3057 %)
Model 2D kernel .................................. 1287717.468 (52.1410 %)
2D/3D coupling, vertical metrics ................. 26740.492 ( 1.0827 %)
Omega vertical velocity .......................... 18459.104 ( 0.7474 %)
Equation of state for seawater ................... 42313.560 ( 1.7133 %)
KPP vertical mixing parameterization ............. 236257.356 ( 9.5663 %)
3D equations right-side terms .................... 72107.784 ( 2.9197 %)
3D equations predictor step ...................... 228015.692 ( 9.2326 %)
Pressure gradient ................................ 27644.080 ( 1.1193 %)
Harmonic mixing of tracers, S-surfaces ........... 20354.304 ( 0.8242 %)
Harmonic stress tensor, S-surfaces ............... 25816.468 ( 1.0453 %)
Corrector time-step for 3D momentum .............. 165941.024 ( 6.7191 %)
Corrector time-step for tracers .................. 105744.456 ( 4.2817 %)
Total: 2452027.748 99.2850
Message Passage: 2D halo exchanges ............... 387451.528 (15.6883 %)
Message Passage: 3D halo exchanges ............... 74106.316 ( 3.0006 %)
Message Passage: 4D halo exchanges ............... 75825.684 ( 3.0703 %)
Message Passage: data broadcast .................. 3591.888 ( 0.1454 %)
Message Passage: data reduction .................. 3671.600 ( 0.1487 %)
Message Passage: data gathering .................. 2352.988 ( 0.0953 %)
Message Passage: data scattering.................. 31.268 ( 0.0013 %)
Total: 547031.272 22.1498
All percentages are with respect to total time = 2469684.840
number of time records written in RESTART file = 00002203
number of time records written in AVERAGE file = 00000042
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_srflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Monday - January 30, 2017 - 8:57:17 PM
The above run is for the northern part of bay of bengal with 1/25 degree resolution. Here model is blowing up in 7th year on 12 Feb. I am unable to understand the reason.
For the entire bay of bengal I have successfully completed the simulation with same configuration.
basin.in
The input file of the run
(105.51 KiB) Downloaded 1655 times
basin.h
activated cpp option for the run
(1.47 KiB) Downloaded 510 times
