ROMS-1D - make tools command error in cross_matrix.f(45)
bikirandas
#1 Unread post by bikirandas »
please help me resolve this issue during the make tools command.
the below is the error message
fpp -I/usr/local/include -P -free cross_matrix.F > cross_matrix.i
./mpc cross_matrix.i > cross_matrix.f
rm cross_matrix.i
ifort -c -O3 -w90 -w95 -cm -r8 -i4 cross_matrix.f
ifort: command line remark #10148: option '-w90' not supported
ifort: command line remark #10148: option '-w95' not supported
ifort: command line remark #10148: option '-cm' not supported
cross_matrix.f(45): error #5082: Syntax error, found ''' when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
& 'GENERATED FILE: DO NOT EDIT
cross_matrix.f(45): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: /) ] , : )
cross_matrix.f(45): error #6404: This name does not have a type, and must have an explicit type. [GENERATEDFILE]
cross_matrix.f(45): error #6385: The highest data type rank permitted is INTEGER(KIND=8). [GENERATEDFILE]
cross_matrix.f(45): error #6404: This name does not have a type, and must have an explicit type. [DONOTEDIT]
cross_matrix.f(45): error #6385: The highest data type rank permitted is INTEGER(KIND=8). [DONOTEDIT]
compilation aborted for cross_matrix.f (code 1)
Makedefs:8: recipe for target 'cross_matrix.o' failed
make: *** [cross_matrix.o] Error 1
cross_matrix.f
generated from cross_matrix.F
(7.06 KiB) Downloaded 258 times
cross_matrix.F
(9.62 KiB) Downloaded 250 times
bikirandas
Re: ROMS-1D - plot_att tzplot.m function missing
#2 Unread post by bikirandas »
i have compiled the roms-1d no issues in make
but i want to know from where to get tzplot function to run plot_all.m
