I want to convert sigma coordinates to depth coordinates. I had used depths.m in Preprocessing_tools to get the depths but I am getting the following error.
??? Error using ==> nc_vinfo
NC_VINFO: ncvarid - cannot find variable: sc_r
Error in ==> nc_read at 64
[vdnames,vdsizes,igrid]=nc_vinfo(fname,vname);
Error in ==> depths at 60
sc_r=nc_read(fname,'sc_r');
What we have to give for tindex? Where I get information aboput sc_r, sc_w values? How can I fix this problem? or anyother method is there to convert layers to depth values. Please help me if anyone knows.
Thanks is in advance.
With regards,
G.NageswaraRao.
finding depths of the layers
the version of depths.m you are using is old, and consistent with ROMS-2.1.
While using ROMS 2.2, for NETCDF compliancy, s-coordinate parameters have been renamed.
replace the the following in depths.m
with the new one
and it should work.
Tindex is used if you want to consider zeta evolving with time (then tindex is the i-th field in your history file). otherwise,
Jacopo
% Read in S-coordinate parameters.
Cs_r=nc_read(fname,'Cs_r');
sc_w=nc_read(fname,'sc_w');
Cs_w=nc_read(fname,'Cs_w');
sc_r=nc_read(fname,'s_rho');
sc_w=nc_read(fname,'s_w');
% If the time record is not provided, it assumes zero free-surface and %
% the grid is not evolving in time.
Thank u
Hi Jacopo,
Thank u for ur reply. I am getting the output but how to convert it into netcdf file? I had used mat2nc.m but it is writing the output in wrong format that it is writing i values in the place of k and k values in the place of i . How can I get the correct netcdf file? Please do reply.
Thanks in advance.
Thanks in advance.
I'm not sure to see your point, meanwhile keep in mind that it is a standard when writing NetCDF that the dimensions are somewhat 'reversed': if you have a matrix(i,j,k,time), in NetCDF it is supposed to be written as matrix(time,k,j,i). So, what you are having doesn't sound incorrect to me.
If this is really your point, have a look at
http://www.cgd.ucar.edu/cms/eaton/cf-me ... F-1.0.html
where BTW, it is in fact recommended
If any or all of the dimensions of a variable have the interpretations of ``date or time'' (T), ``height or depth'' (Z), ``latitude'' (Y), or ``longitude'' (X) then we recommend, but do not require (see section 1.4), those dimensions to appear in the relative order T, then Z, then Y, then X in the CDL definition corresponding to the file. All other dimensions should, whenever possible, be placed to the left of the spatiotemporal dimensions.
