Hello Everyone,
I want to run an Interannual simulation using ROMS-RUTGERS. I have created the boundary, initial,forcing and grid file from ROMS-AGRIF. I have activated mpi and during compilation no errors are there. After successful compilation oceanM is created but when I try to run the model the following error is coming
Friday - September 16, 2016 - 1:08:14 PM
At line 933 of file inp_par.f90
Fortran runtime error: Bad real number in item 1 of list input
Primary job terminated normally, but 1 process returned
Process name: [[52146,1],1]
Exit code: 2
I don't have any idea why this is happening. Please help me in this issue.
Error during mpirun
Re: Error during mpirun
Do you know how to find your inp_par.f90? It's in the $SCRATCH_DIR you set. What's on line 933 there?
