History file output fails using WRITE_WATER and river inflow
dullman
#1 Unread post by dullman »
i have encountered a problem when running ROMS version 3.7 that appears to be related to the
use of the WRITE_WATER option in conjunction with the specification of river inflow (using LuvSrc). i am using the
MASKING option and i specify the river inflow at a v-point that is masked as land (which is adjacent to
a water rho-point). when i run the model with WRITE_WATER undefined, all is well. i see the river inflow in
the vbar array at the right location. but when i define WRITE_WATER, there is an error that occurs when
the history file is first written: "error while writing variable: vbar into history NetCDF file...".
at the bottom of the output file is the following:
REASON: NetCDF: Start+count exceeds dimension bound
when i move the river point so that it is at a water v-point, this error does not occur (but the model
eventually blows up at that point as might be expected).
so it seems to me that there is something incompatible with the specification of rivers using LuvSrc and the
WRITE_WATER option.
has anyone else encountered this problem?
any suggestions?
will attach the std output below.
thanks,
dave
Model Input Parameters:  ROMS/TOMS version 3.7
                          Wednesday - September 7, 2016 - 10:33:58 AM
 OSOM-grid4
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : ifort
 Compiler command : /gpfs/runtime/opt/mvapich2/2.2a-intel/bin/mpif90
 Compiler flags   : -heap-arrays -fp-model precise -ip -O3 -free -free -free
 Input Script  :
 SVN Revision  :
 Local Root    : /gpfs_home/dullman1/ROMS/trunk
 Header Dir    : /users/dullman1/projects/OSOM
 Header file   : osom.h
 Analytical Dir: /gpfs_home/dullman1/ROMS/trunk/ROMS/Functionals
 Resolution, Grid 01: 0998x1098x015,  Parallel Nodes: 100,  Tiling: 010x010
     129600  ntimes            Number of timesteps for 3-D equations.
     20.000  dt                Timestep size (s) for 3-D equations.
         10  ndtfast           Number of timesteps for 2-D equations between
       4320  nRST              Number of timesteps between the writing of data
                                 into restart fields.
                                 to standard output.
         45  nSTA              Number of timesteps between the writing of data
                                 the stations file.
        180  nHIS              Number of timesteps between the writing fields
                                 into history file.
       4320  ndefHIS           Number of timesteps between creation of new
                                 history files.
 4.0000E+00  nl_tnu2(01)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 01: temp
 4.0000E+00  nl_tnu2(02)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 02: salt
 4.0000E+00  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: salt
 5.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 5.0000E-06  Akv_bak           Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak           Background vertical mixing coefficient (m2/s)
                                 for turbulent energy.
 5.0000E-06  Akp_bak           Background vertical mixing coefficient (m2/s)
      3.000  gls_p             GLS stability exponent.
      1.500  gls_m             GLS turbulent kinetic energy exponent.
     -1.000  gls_n             GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin          GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin          GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0          GLS stability coefficient.
 1.4400E+00  gls_c1            GLS shear production coefficient.
 1.9200E+00  gls_c2            GLS dissipation coefficient.
-4.0000E-01  gls_c3m           GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p           GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk          GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp          GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha     Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha    Factor for Zos calculation using Hsig(Awave).
      0.250  sz_alpha          Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw         Factor for Craig/Banner surface tke flux.
 3.0000E-03  rdrg2             Quadratic bottom drag coefficient.
 1.0000E-03  Zob               Bottom roughness (m).
 1.0000E-03  Zos               Surface roughness (m).
 1.0000E+01  blk_ZQ            Height (m) of surface air humidity measurement.
 1.0000E+01  blk_ZT            Height (m) of surface air temperature measurement.
 1.0000E+01  blk_ZW            Height (m) of surface winds measurement.
          2  Vtransform        S-coordinate transformation equation.
          4  Vstretching       S-coordinate stretching function.
 1.0000E+00  theta_s           S-coordinate surface control parameter.
 1.0000E+00  theta_b           S-coordinate bottom  control parameter.
      3.000  Tcline            S-coordinate surface/bottom layer width (m) used
      0.000  dstart            Time-stamp assigned to model initialization (days).
      0.000  tide_start        Reference time origin for tidal forcing (days).
20060101.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 1.0000E+00  Tnudg(01)         Nudging/relaxation time scale (days)
 1.0000E+00  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 1.0000E+00  Znudg             Nudging/relaxation time scale (days)
 1.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 1.0000E+00  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 1.5000E+01  obcfac            Factor between passive and active
     10.000  T0                Background potential temperature (C) constant.
     30.000  S0                Background salinity (PSU) constant.
          T  LuvSrc            Turning ON  momentum point Sources/Sinks.
          T  LtracerSrc(01)    Turning ON  point Sources/Sinks on tracer 01: temp
          T  LtracerSrc(02)    Turning ON  point Sources/Sinks on tracer 02: salt
          T  Hout(idUbar)      Write out 2D U-momentum component.
          T  Hout(idVbar)      Write out 2D V-momentum component.
          T  Hout(idTvar)      Write out tracer 01: temp
          T  Hout(idTvar)      Write out tracer 02: salt
          T  Hout(idMtke)      Write out turbulent kinetic energy.
          T  Hout(idMtls)      Write out turbulent generic length-scale.
             Output Restart File:  /users/dullman1/data/dullman1/OSOM/test/ocean_rst.nc
        Prefix for History Files:  /users/dullman1/data/dullman1/OSOM/test/ocean_his
            Output Stations File:  ocean_sta.nc
                 Input Grid File:  osom_grid4_mindep_smlp_mod6.nc
    Input Nonlinear Initial File:  osom_grid4_mindep_smlp_mod6_ini_hydro.nc
        Input Sources/Sinks File:  frc_rivers_osom_2006-2010.nc
           Input Forcing File 01:  osom_grid4_mindep_smlp_mod6_tidalforcing_2006.nc
           Input Forcing File 02:  frc_wind_field_OSOM_2006_new.nc
           Input Forcing File 03:  frc_bulk8_point_osom_2006.nc
             Input Boundary File:  bry_osom_grid4_mindep_smlp_mod6_2006.nc
          Station positions File:  stations_osom.in
 zeta                     1   Chapman Imp  Chapman Imp  Chapman Imp  Closed
 ubar                     1   Flather      Flather      Flather      Closed
 vbar                     1   Flather      Flather      Flather      Closed
 u                        1   Rad + Nud    Rad + Nud    Rad + Nud    Closed
 v                        1   Rad + Nud    Rad + Nud    Rad + Nud    Closed
 temp                     1   Rad + Nud    Rad + Nud    Rad + Nud    Closed
 salt                     1   Rad + Nud    Rad + Nud    Rad + Nud    Closed
 tke                      1   Radiation    Radiation    Radiation    Closed
 OSOM                OSOM-grid4
 ADD_FSOBC           Adding tidal elevation to processed OBC data.
 ADD_M2OBC           Adding tidal currents to processed OBC data.
 BULK_FLUXES         Surface bulk fluxes parameterization.
 DIFF_GRID           Horizontal diffusion coefficient scaled by grid size.
 EMINUSP             Compute Salt Flux using E-P.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 INLINE_2DIO         Processing 3D IO level by level to reduce memory needs.
 LONGWAVE_OUT        Compute outgoing longwave radiation internally.
 MIX_S_TS            Mixing of tracers along constant S-surfaces.
 NO_WRITE_GRID       Not Writing grid arrays into NetCDF ouput files.
 PERFECT_RESTART     Processing perfect restart variables.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 RAMP_TIDES          Ramping tidal forcing for one day.
 SSH_TIDES           Add tidal elevation to SSH climatology.
 STATIONS            Writing out station data.
 TS_MPDATA           Recursive flux corrected MPDATA 3D advection of tracers.
 UV_SADVECTION       Parabolic splines vertical advection of momentum.
 UV_LOGDRAG          Logarithmic bottom stress.
 UV_TIDES            Add tidal currents to 2D momentum climatologies.
 VISC_GRID           Horizontal viscosity coefficient scaled by grid size.
 WRITE_WATER         Writing data at water points only.
    15   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    14  -0.0666667  -0.0064624       -0.085      -0.110      -0.540      -0.901
    13  -0.1333333  -0.0257201       -0.181      -0.239      -1.775      -3.199
    12  -0.2000000  -0.0573871       -0.286      -0.386      -3.682      -6.852
    11  -0.2666667  -0.1008307       -0.401      -0.551      -6.227     -11.792
    10  -0.3333333  -0.1551864       -0.524      -0.733      -9.365     -17.924
     9  -0.4000000  -0.2193793       -0.656      -0.929     -13.035     -25.130
     8  -0.4666667  -0.2921503       -0.794      -1.138     -17.171     -33.273
     7  -0.5333333  -0.3720885       -0.938      -1.358     -21.696     -42.199
     6  -0.6000000  -0.4576670       -1.086      -1.587     -26.526     -51.741
     5  -0.6666667  -0.5472830       -1.238      -1.821     -31.575     -61.724
     4  -0.7333333  -0.6393009       -1.391      -2.059     -36.755     -71.969
     3  -0.8000000  -0.7320964       -1.546      -2.298     -41.976     -82.299
     2  -0.8666667  -0.8241010       -1.699      -2.536     -47.155     -92.543
     1  -0.9333333  -0.9138456       -1.851      -2.771     -52.211    -102.540
     0  -1.0000000  -1.0000000       -2.000      -3.000     -57.073    -112.145
 Time Splitting Weights for Grid 01:    ndtfast =  10    nfast =  15
  1 0.0014850648765542 0.1000000000000000 0.0014850648765542 0.1000000000000000
  2 0.0059386031399402 0.0998514935123446 0.0074236680164944 0.1998514935123445
  3 0.0133457074936657 0.0992576331983506 0.0207693755101601 0.2991091267106951
  4 0.0236484051180389 0.0979230624489840 0.0444177806281990 0.3970321891596791
  5 0.0366959666818608 0.0955582219371801 0.0811137473100598 0.4925904110968592
  6 0.0521753389587947 0.0918886252689940 0.1332890862688545 0.5844790363658532
  7 0.0695217010484137 0.0866710913731145 0.2028107873172682 0.6711501277389678
  8 0.0878091442019233 0.0797189212682732 0.2906199315191915 0.7508690490072409
  9 0.1056214752525633 0.0709380068480808 0.3962414067717548 0.8218070558553218
 10 0.1209031436506851 0.0603758593228245 0.5171445504224399 0.8821829151781463
 11 0.1307902921035067 0.0482855449577560 0.6479348425259466 0.9304684601359023
 12 0.1314219308195445 0.0352065157474053 0.7793567733454911 0.9656749758833076
 13 0.1177312353577226 0.0220643226654509 0.8970880087032138 0.9877392985487585
 14 0.0832169680811588 0.0102911991296786 0.9803049767843727 0.9980304976784371
 15 0.0196950232156274 0.0019695023215627 1.0000000000000000 0.9999999999999999
 ndtfast, nfast =   10  15   nfast/ndtfast =  1.50000
    1.000000000000 1.083803072626 0.541901536313 1.000000000000 1.000000000000
 Power filter parameters, Fgamma, gamma =  0.28400   0.00000
 Minimum X-grid spacing, DXmin =  4.04946174E-02 km
 Maximum X-grid spacing, DXmax =  4.35714366E-01 km
 Minimum Y-grid spacing, DYmin =  2.72949578E-02 km
 Maximum Y-grid spacing, DYmax =  3.88582312E-01 km
 Minimum Z-grid spacing, DZmin =  8.51699402E-02 m
 Maximum Z-grid spacing, DZmax =  1.03302185E+01 m
 Minimum barotropic Courant Number =  8.40687272E-02
 Maximum barotropic Courant Number =  5.94005231E-01
 Maximum Coriolis   Courant Number =  1.94692351E-03
 Horizontal mixing scaled by grid size, GRDMAX =  3.23731774E-01 km
                   (Grid 01, File: osom_grid4_mindep_smlp_mod6_ini_hydro.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min =  4.56679989E+00 Max =  1.23957848E+01)
                - salinity
                   (Min =  3.09658034E-09 Max =  3.36493083E+01)
    GET_NGFLD   - tidal period
                   (Min =  1.49047214E+04 Max =  9.67260838E+04)
    GET_2DFLD   - tidal elevation amplitude
                   (Min =  0.00000000E+00 Max =  7.54251636E-01)
    GET_2DFLD   - tidal elevation phase angle
                   (Min =  6.26773407E-06 Max =  6.28318498E+00)
    GET_2DFLD   - tidal current inclination angle
                   (Min =  0.00000000E+00 Max =  3.14159244E+00)
    GET_2DFLD   - tidal current phase angle
                   (Min =  0.00000000E+00 Max =  6.28318364E+00)
    GET_2DFLD   - maximum tidal current, ellipse major axis
                   (Min =  0.00000000E+00 Max =  1.49311554E+00)
    GET_2DFLD   - minimum tidal current, ellipse minor axis
                   (Min = -3.37066252E-01 Max =  2.52296461E-01)
    GET_NGFLD   - river runoff  XI-positions at RHO-points
                   (Min =  6.36000000E+02 Max =  6.37000000E+02)
    GET_NGFLD   - river runoff ETA-positions at RHO-points
                   (Min =  1.02400000E+03 Max =  1.02400000E+03)
    GET_NGFLD   - river runoff direction
                   (Min =  1.00000000E+00 Max =  1.00000000E+00)
    GET_NGFLD   - river runoff mass transport vertical profile
                   (Min =  6.66666667E-02 Max =  6.66666667E-02)
    GET_NGFLD   - river runoff mass transport,               t =     0 **:**:**
                   (Rec=0000001, Index=2, File: frc_rivers_osom_2006-2010.nc)
                   (Tmin=         -0.2917 Tmax=       1826.7083)
    GET_NGFLD   - river runoff potential temperature,        t =     0 **:**:**
                   (Min =  4.27218930E-01 Max =  4.27218930E-01)
    GET_NGFLD   - river runoff salinity,                     t =     0 **:**:**
    GET_2DFLD   - surface u-wind component,                  t =     0 00:00:00
                   (Rec=0000002, Index=1, File: frc_wind_field_OSOM_2006_new.nc)
                   (Tmin=         -0.0417 Tmax=        365.0000)
                   (Min = -4.81854172E+00 Max = -1.58071958E+00)
    GET_2DFLD   - surface v-wind component,                  t =     0 00:00:00
                   (Min = -2.42937271E+00 Max =  1.13576238E+00)
    GET_2DFLD   - surface air pressure,                      t =     0 00:00:00
                   (Rec=0000001, Index=1, File: frc_bulk8_point_osom_2006.nc)
                   (Tmin=          0.0000 Tmax=        365.0000)
                   (Min =  1.00983752E+03 Max =  1.00983752E+03)
    GET_2DFLD   - solar shortwave radiation flux,            t =     0 00:00:00
                   (Min =  8.57305843E-13 Max =  8.57305843E-13)
    GET_2DFLD   - downwelling longwave radiation flux,       t =     0 00:00:00
                   (Min =  7.64574591E-05 Max =  7.64574591E-05)
    GET_2DFLD   - surface air temperature,                   t =     0 00:00:00
                   (Min =  3.75000000E-01 Max =  3.75000000E-01)
    GET_2DFLD   - surface air relative humidity,             t =     0 00:00:00
                   (Min =  9.24499969E-01 Max =  9.24499969E-01)
    GET_2DFLD   - rain fall rate,                            t =     0 00:00:00
                   (Min =  1.17592590E-05 Max =  1.17592590E-05)
    GET_NGFLD   - free-surface western boundary condition,   t =     0 00:00:00
                   (Rec=0000001, Index=2, File: bry_osom_grid4_mindep_smlp_mod6_2006.nc)
    GET_NGFLD   - free-surface eastern boundary condition,   t =     0 00:00:00
    GET_NGFLD   - free-surface southern boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 2D u-momentum western boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 2D v-momentum western boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 2D u-momentum southern boundary condition, t =     0 00:00:00
    GET_NGFLD   - 2D v-momentum southern boundary condition, t =     0 00:00:00
    GET_NGFLD   - 3D u-momentum western boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 3D v-momentum western boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t =     0 00:00:00
    GET_NGFLD   - 3D u-momentum southern boundary condition, t =     0 00:00:00
    GET_NGFLD   - 3D v-momentum southern boundary condition, t =     0 00:00:00
    GET_NGFLD   - temperature western boundary condition,    t =     0 00:00:00
                   (Min =  0.00000000E+00 Max =  6.42663527E+00)
    GET_NGFLD   - salinity western boundary condition,       t =     0 00:00:00
                   (Min =  0.00000000E+00 Max =  2.96997375E+01)
    GET_NGFLD   - temperature eastern boundary condition,    t =     0 00:00:00
                   (Min =  0.00000000E+00 Max =  5.38652849E+00)
    GET_NGFLD   - salinity eastern boundary condition,       t =     0 00:00:00
                   (Min =  0.00000000E+00 Max =  3.13541832E+01)
    GET_NGFLD   - temperature southern boundary condition,   t =     0 00:00:00
                   (Min =  0.00000000E+00 Max =  1.24026794E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =     0 00:00:00
                   (Min =  0.00000000E+00 Max =  3.36533089E+01)
 Maximum grid stiffness ratios:  rx0 =   2.000008E-01 (Beckmann and Haidvogel)
                                 rx1 =   5.076469E+00 (Haney)
 Initial basin volumes: TotVolume =  6.2370337146E+11 m3
                        MinVolume =  3.0294087096E+02 m3
                        MaxVolume =  6.8561716618E+05 m3
                          Max/Min =  2.2632045785E+03
 NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00129600)
    GET_NGFLD   - river runoff mass transport,               t =     0 17:00:00
                   (Rec=0000002, Index=1, File: frc_rivers_osom_2006-2010.nc)
                   (Min = -2.80837539E+00 Max = -2.80837539E+00)
    GET_NGFLD   - river runoff potential temperature,        t =     0 17:00:00
                   (Min =  3.59214325E-01 Max =  3.59214325E-01)
    GET_NGFLD   - river runoff salinity,                     t =     0 17:00:00
    GET_2DFLD   - surface u-wind component,                  t =     0 00:59:59
                   (Rec=0000003, Index=2, File: frc_wind_field_OSOM_2006_new.nc)
                   (Min = -7.11108624E+00 Max = -3.16260144E+00)
    GET_2DFLD   - surface v-wind component,                  t =     0 00:59:59
                   (Min = -1.93170730E+00 Max =  2.58984371E+00)
    GET_2DFLD   - surface air pressure,                      t =     0 03:00:00
                   (Rec=0000002, Index=2, File: frc_bulk8_point_osom_2006.nc)
                   (Min =  1.00822778E+03 Max =  1.00822778E+03)
    GET_2DFLD   - solar shortwave radiation flux,            t =     0 03:00:00
    GET_2DFLD   - downwelling longwave radiation flux,       t =     0 03:00:00
                   (Min =  7.66043529E-05 Max =  7.66043529E-05)
    GET_2DFLD   - surface air temperature,                   t =     0 03:00:00
                   (Min =  8.00000012E-01 Max =  8.00000012E-01)
    GET_2DFLD   - surface air relative humidity,             t =     0 03:00:00
                   (Min =  9.20000000E-01 Max =  9.20000000E-01)
    GET_2DFLD   - rain fall rate,                            t =     0 03:00:00
    GET_NGFLD   - free-surface western boundary condition,   t =     0 06:00:00
                   (Rec=0000002, Index=1, File: bry_osom_grid4_mindep_smlp_mod6_2006.nc)
                   (Min = -4.23068777E-02 Max =  0.00000000E+00)
    GET_NGFLD   - free-surface eastern boundary condition,   t =     0 06:00:00
                   (Min = -2.07332429E-02 Max =  0.00000000E+00)
    GET_NGFLD   - free-surface southern boundary condition,  t =     0 06:00:00
                   (Min = -1.39146959E-02 Max =  3.52518074E-02)
    GET_NGFLD   - 2D u-momentum western boundary condition,  t =     0 06:00:00
                   (Min = -4.16707098E-02 Max =  0.00000000E+00)
    GET_NGFLD   - 2D v-momentum western boundary condition,  t =     0 06:00:00
                   (Min = -3.41589265E-02 Max =  4.35377558E-04)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =     0 06:00:00
                   (Min = -9.58518870E-03 Max =  4.02900055E-02)
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =     0 06:00:00
                   (Min = -3.39524075E-02 Max =  5.07995533E-03)
    GET_NGFLD   - 2D u-momentum southern boundary condition, t =     0 06:00:00
                   (Min = -8.91573448E-03 Max =  5.82007766E-02)
    GET_NGFLD   - 2D v-momentum southern boundary condition, t =     0 06:00:00
                   (Min = -6.17771409E-02 Max =  2.03768909E-02)
    GET_NGFLD   - 3D u-momentum western boundary condition,  t =     0 06:00:00
                   (Min = -6.19846620E-02 Max =  0.00000000E+00)
    GET_NGFLD   - 3D v-momentum western boundary condition,  t =     0 06:00:00
                   (Min = -5.00817895E-02 Max =  1.04351330E-03)
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t =     0 06:00:00
                   (Min = -1.17071811E-02 Max =  5.05722351E-02)
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t =     0 06:00:00
                   (Min = -4.30298895E-02 Max =  5.63606620E-03)
    GET_NGFLD   - 3D u-momentum southern boundary condition, t =     0 06:00:00
                   (Min = -2.29379460E-02 Max =  6.88057020E-02)
    GET_NGFLD   - 3D v-momentum southern boundary condition, t =     0 06:00:00
                   (Min = -7.85559937E-02 Max =  3.22754867E-02)
    GET_NGFLD   - temperature western boundary condition,    t =     0 06:00:00
                   (Min =  0.00000000E+00 Max =  6.45185947E+00)
    GET_NGFLD   - salinity western boundary condition,       t =     0 06:00:00
                   (Min =  0.00000000E+00 Max =  2.98226089E+01)
    GET_NGFLD   - temperature eastern boundary condition,    t =     0 06:00:00
                   (Min =  0.00000000E+00 Max =  4.65854502E+00)
    GET_NGFLD   - salinity eastern boundary condition,       t =     0 06:00:00
                   (Min =  0.00000000E+00 Max =  3.14130192E+01)
    GET_NGFLD   - temperature southern boundary condition,   t =     0 06:00:00
                   (Min =  0.00000000E+00 Max =  1.23872366E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =     0 06:00:00
                   (Min =  0.00000000E+00 Max =  3.36308708E+01)
      0     0 00:00:00  0.000000E+00  2.254689E+02  2.254689E+02  6.480012E+11
         (000,0000,00)  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00
      DEF_HIS   - creating history file, Grid 01: /users/dullman1/data/dullman1/OSOM/test/ocean_his_0001.nc
 WRT_HIS - error while writing variable: vbar
           into history NetCDF file for time record:    1
 Node   #  0 CPU:       9.521
 Node   #  1 CPU:      17.072
 Node   #  8 CPU:      17.200
 Node   #  7 CPU:      17.182
 Node   #  2 CPU:      17.159
 Node   # 10 CPU:      17.060
 Node   # 68 CPU:      17.537
 Node   # 66 CPU:      17.551
 Node   # 88 CPU:      17.492
 Node   # 73 CPU:      17.544
 Node   # 99 CPU:      17.481
 Node   # 18 CPU:      17.143
 Node   # 76 CPU:      17.535
 Node   # 21 CPU:      17.088
 Node   # 85 CPU:      17.473
 Node   # 72 CPU:      17.546
 Node   # 90 CPU:      17.477
 Node   # 61 CPU:      17.529
 Node   # 36 CPU:      17.084
 Node   # 86 CPU:      17.482
 Node   # 69 CPU:      17.535
 Node   # 98 CPU:      17.480
 Node   # 40 CPU:      17.543
 Node   # 78 CPU:      17.544
 Node   # 81 CPU:      17.481
 Node   # 47 CPU:      17.563
 Node   # 67 CPU:      17.546
 Node   # 24 CPU:      17.107
 Node   # 71 CPU:      17.524
 Node   # 87 CPU:      17.483
 Node   # 57 CPU:      17.522
 Node   # 14 CPU:      17.253
 Node   # 93 CPU:      17.484
 Node   # 42 CPU:      17.545
 Node   # 27 CPU:      17.082
 Node   # 19 CPU:      17.214
 Node   # 49 CPU:      17.556
 Node   # 91 CPU:      17.494
 Node   # 29 CPU:      17.093
 Node   # 52 CPU:      17.535
 Node   # 80 CPU:      17.465
 Node   # 20 CPU:      17.084
 Node   # 79 CPU:      17.545
 Node   #  4 CPU:      17.177
 Node   # 12 CPU:      17.161
 Node   # 26 CPU:      17.092
 Node   # 65 CPU:      17.540
 Node   # 38 CPU:      17.109
 Node   # 44 CPU:      17.548
 Node   # 17 CPU:      17.198
 Node   # 31 CPU:      17.092
 Node   # 16 CPU:      17.168
 Node   # 83 CPU:      17.478
 Node   # 45 CPU:      17.547
 Node   # 35 CPU:      17.100
 Node   #  3 CPU:      17.087
 Node   # 39 CPU:      17.097
 Node   # 92 CPU:      17.462
 Node   # 11 CPU:      17.090
 Node   # 96 CPU:      17.482
 Node   # 63 CPU:      17.546
 Node   # 51 CPU:      17.547
 Node   #  5 CPU:      17.166
 Node   # 13 CPU:      17.169
 Node   #  9 CPU:      17.181
 Node   # 15 CPU:      17.194
 Node   # 75 CPU:      17.545
 Node   #  6 CPU:      17.122
 Node   # 54 CPU:      17.546
 Node   # 95 CPU:      17.480
 Node   # 37 CPU:      17.093
 Node   # 64 CPU:      17.545
 Node   # 50 CPU:      17.543
 Node   # 41 CPU:      17.554
 Node   # 55 CPU:      17.545
 Node   # 25 CPU:      17.110
 Node   # 77 CPU:      17.545
 Node   # 53 CPU:      17.547
 Node   # 62 CPU:      17.541
 Node   # 82 CPU:      17.474
 Node   # 59 CPU:      17.545
 Node   # 89 CPU:      17.477
 Node   # 28 CPU:      17.115
 Node   # 74 CPU:      17.540
 Node   # 70 CPU:      17.532
 Node   # 48 CPU:      17.547
 Node   # 94 CPU:      17.480
 Node   # 56 CPU:      17.535
 Node   # 60 CPU:      17.535
 Node   # 97 CPU:      17.489
 Node   # 46 CPU:      17.544
 Node   # 58 CPU:      17.546
 Node   # 43 CPU:      17.546
 Node   # 23 CPU:      17.092
 Node   # 84 CPU:      17.490
 Node   # 22 CPU:      17.104
 Node   # 32 CPU:      17.098
 Node   # 30 CPU:      17.088
 Node   # 33 CPU:      17.086
 Node   # 34 CPU:      17.087
 Total:              1728.766
  Allocation and array initialization ..............        26.320  ( 1.5225 %)
  Ocean state initialization .......................         9.014  ( 0.5214 %)
  Reading of input data ............................      1156.506  (66.8978 %)
  Processing of input data .........................         1.576  ( 0.0911 %)
  Computation of vertical boundary conditions ......         1.050  ( 0.0607 %)
  Computation of global information integrals ......         2.225  ( 0.1287 %)
  Tidal forcing ....................................         5.464  ( 0.3161 %)
  2D/3D coupling, vertical metrics .................         5.089  ( 0.2944 %)
  Omega vertical velocity ..........................         1.305  ( 0.0755 %)
  Equation of state for seawater ...................         7.016  ( 0.4058 %)
  Atmosphere-Ocean bulk flux parameterization ......         6.634  ( 0.3837 %)
                                              Total:      1222.198   70.6977
  Message Passage: 2D halo exchanges ...............        13.104  ( 0.7580 %)
  Message Passage: 3D halo exchanges ...............        11.133  ( 0.6440 %)
  Message Passage: 4D halo exchanges ...............         1.783  ( 0.1031 %)
  Message Passage: data broadcast ..................      1339.021  (77.4553 %)
  Message Passage: data reduction ..................         5.131  ( 0.2968 %)
  Message Passage: data gathering ..................         4.691  ( 0.2714 %)
  Message Passage: data scattering..................       270.364  (15.6391 %)
  Message Passage: boundary data gathering .........         3.732  ( 0.2159 %)
  Message Passage: point data gathering ............         0.681  ( 0.0394 %)
                                              Total:      1649.641   95.4230
 All percentages are with respect to total time =         1728.766
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
 ROMS/TOMS - Output error ............ exit_flag:   3
dullman
Re: History file output fails using WRITE_WATER and river in
#2 Unread post by dullman »
I delved a bit further into this problem and I think that I have found the source of the problem. I also have what I think is the solution.
The problem:
The run would fail when writing ubar because the program was attempting to write more ubar values than the history netcdf file was dimensioned for. the dimension of ubar is set in def_his.F and makes use of the variable IOBOUNDS(ng)%xy_u which contains the number of water points (at u-points). this value is determined in routine wpoints.F based on the umask array. but when ubar is written from wrt_his.F by a call to subroutine nf_fwrite2d, the mask that is passed to that subroutine is umask_full. when rivers are implemented (using LuvSrc=T), this mask (created in set_masks.F) is identical to umask except that river inflow points are set to 1. so the umask_full array has more points flagged as water than does umask, which is the source of the error i encountered.
The solution:
I modified wpoints.F so that when subroutine wpoints_tile is called, the program passes umask_full and vmask_full to it (as opposed to umask and vmask as in the original code). in this way, the netcdf history file has the correct dimensions (for example, dimension xy_u now is equal to the number of wet u-points including those associated with river inflows.
As far as I can tell, the above solution results in netcdf history files with exactly the same values when reshaped onto the grid as do the history files from a run with WRITE_WATER disabled.
#3 Unread post by arango »
Good catch, thank you :!: I updated the repository. Check the following :arrow: trac ticket for more information.
