Lee2015
#1 Unread post by Lee2015 »
I got a BLOWUP error, as follows. Do you guys have any ideas about it? Thanks alot!
Wednesday - June 8, 2016 - 6:37:03 PM
Mexico
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 783M
Local Root : /home/lee/ROMS/src
Header Dir : /home/lee/ROMS/Projects/mexico
Header file : mexico.h
Analytical Dir: /home/lee/ROMS/Projects/mexico
Resolution, Grid 01: 0179x0134x015, Parallel Nodes: 8, Tiling: 002x004
8784 ntimes Number of timesteps for 3-D equations.
600.000 dt Timestep size (s) for 3-D equations.
F LcycleRST Switch to recycle time-records in restart file.
144000 nRST Number of timesteps between the writing of data
into restart fields.
6 ninfo Number of timesteps between print of information
to standard output.
144000 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
144000 nAVG Number of timesteps between the writing of
5.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E+02 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
2.6500E-04 rdrg Linear bottom drag coefficient (m/s).
1 lmd_Jwt Jerlov water type.
2 Vstretching S-coordinate stretching function.
7.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E-01 theta_b S-coordinate bottom control parameter.
100.000 Tcline S-coordinate surface/bottom layer width (m) used
20130801.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idHsbl) Write out depth of surface boundary layer.
Output Restart File: Out/mexico_rst.nc
Output Averages File: Out/mexico_avg.nc
Input Grid File: In/t03031_smth9_grid.nc
Input Nonlinear Initial File: In/damee4_levfeb_b.nc
Input Forcing File 01: In/gom_shflux_era.nc
Input Forcing File 02: In/gom_sms_era.nc
Input Forcing File 03: In/gom_swflux_era.nc
Input Forcing File 04: In/gom_swrad_era.nc
Input Forcing File 05: In/gom_wind_era.nc
Input Climatology File: In/damee4_Lclm_b.nc
Input Boundary File: In/t0604_bry.nc
Tile partition information for Grid 01: 0179x0134x0015 tiling: 002x004
tile Istr Iend Jstr Jend Npts
0 1 90 1 33 44550
1 91 179 1 33 44055
2 1 90 34 67 45900
3 91 179 34 67 45390
4 1 90 68 101 45900
5 91 179 68 101 45390
6 1 90 102 134 44550
7 91 179 102 134 44055
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 90.50 0.50 33.50 RHO-points
1 90.50 179.50 0.50 33.50 RHO-points
2 0.50 90.50 33.50 67.50 RHO-points
3 90.50 179.50 33.50 67.50 RHO-points
4 0.50 90.50 67.50 101.50 RHO-points
5 90.50 179.50 67.50 101.50 RHO-points
6 0.50 90.50 101.50 134.50 RHO-points
7 90.50 179.50 101.50 134.50 RHO-points
0 1.00 90.50 0.50 33.50 U-points
1 90.50 179.00 0.50 33.50 U-points
2 1.00 90.50 33.50 67.50 U-points
3 90.50 179.00 33.50 67.50 U-points
4 1.00 90.50 67.50 101.50 U-points
5 90.50 179.00 67.50 101.50 U-points
6 1.00 90.50 101.50 134.50 U-points
7 90.50 179.00 101.50 134.50 U-points
0 0.50 90.50 1.00 33.50 V-points
1 90.50 179.50 1.00 33.50 V-points
2 0.50 90.50 33.50 67.50 V-points
3 90.50 179.50 33.50 67.50 V-points
4 0.50 90.50 67.50 101.50 V-points
5 90.50 179.50 67.50 101.50 V-points
6 0.50 90.50 101.50 134.00 V-points
7 90.50 179.50 101.50 134.00 V-points
HaloSizeI(1) = 306
HaloSizeJ(1) = 144
TileSide(1) = 96
TileSize(1) = 4032
zeta 1 Closed Gradient Gradient Closed
ubar 1 Closed Clamped Clamped Closed
vbar 1 Closed Clamped Clamped Closed
u 1 Closed Clamped Clamped Closed
v 1 Closed Clamped Clamped Closed
temp 1 Closed Clamped Clamped Closed
salt 1 Closed Clamped Clamped Closed
MEXICO Mexico
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
PERFECT_RESTART Processing perfect restart variables.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
Process Information:
Node # 0 (pid= 12099) is active.
Node # 4 (pid= 12103) is active.
Node # 6 (pid= 12105) is active.
Node # 2 (pid= 12101) is active.
Node # 3 (pid= 12102) is active.
Node # 1 (pid= 12100) is active.
Node # 5 (pid= 12104) is active.
Node # 7 (pid= 12106) is active.
15 0.0000000 0.0000000 -0.000 0.000 0.000 0.000
14 -0.0666667 -0.0004989 2.218 -3.358 -7.757 -9.257
13 -0.1333333 -0.0032168 4.418 -6.828 -21.407 -30.564
12 -0.2000000 -0.0100379 6.583 -10.502 -45.951 -74.151
11 -0.2666667 -0.0229247 8.698 -14.480 -86.600 -150.675
10 -0.3333333 -0.0439342 10.745 -18.863 -148.816 -271.306
9 -0.4000000 -0.0752335 12.706 -23.762 -238.353 -447.812
8 -0.4666667 -0.1191055 14.563 -29.289 -361.273 -692.587
7 -0.5333333 -0.1779212 16.295 -35.563 -523.870 -1018.508
6 -0.6000000 -0.2540303 17.883 -42.702 -732.384 -1438.333
5 -0.6666667 -0.3494770 19.310 -50.807 -992.242 -1963.162
4 -0.7333333 -0.4653579 20.566 -59.935 -1306.355 -2598.950
3 -0.8000000 -0.6004851 21.663 -70.024 -1671.571 -3339.247
2 -0.8666667 -0.7487245 22.650 -80.770 -2071.601 -4150.744
1 -0.9333333 -0.8938704 23.662 -91.360 -2463.418 -4945.443
0 -1.0000000 -1.0000000 25.000 -100.000 -2751.640 -5528.281
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865133 0.0497264335364439 0.0139401130576348 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767398 0.4496985103876601
10 0.0161716623600090 0.0486998273761630 0.0421751148367488 0.4983983377638231
11 0.0207585511322367 0.0478912442581626 0.0629336659689855 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430846 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924699 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366961 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873358 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240974 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194839 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038023 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834592 0.9445203630883545
23 0.0746596950216179 0.0177785909158270 0.7190878767050771 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669231 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836255 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321975 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447905
28 0.0292219798521905 0.0017718319739095 0.9937853403740003 0.9996892670187000
29 0.0062146596259993 0.0003107329813000 0.9999999999999997 1.0000000000000000
Minimum X-grid spacing, DXmin = 9.53173644E+00 km
Maximum X-grid spacing, DXmax = 1.06053729E+01 km
Minimum Y-grid spacing, DYmin = 1.11200424E+01 km
Maximum Y-grid spacing, DYmax = 1.11200424E+01 km
Minimum Z-grid spacing, DZmin = -2.21806494E+00 m
Maximum Z-grid spacing, DZmax = 8.11496867E+02 m
Minimum barotropic Courant Number = 5.49001381E-02
Maximum barotropic Courant Number = 9.10581682E-01
Maximum Coriolis Courant Number = 4.45309430E-02
Horizontal mixing scaled by grid size, GRDMAX = 1.08596592E+01 km
NLM: GET_STATE - Read state initial conditions, t = 1 00:00:00
(Grid 01, File: damee4_levfeb_b.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 0.00000000E+00 Max = 3.00944372E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.68434650E+01)
GET_2DFLD - surface u-momentum stress, t = 0 22:30:00
(Rec=0000008, Index=1, File: gom_sms_era.nc)
(Tmin= 0.0625 Tmax= 91.9375)
(Min = -5.84637914E-04 Max = 1.22592792E-04)
GET_2DFLD - surface v-momentum stress, t = 0 22:30:00
(Min = -2.31960137E-04 Max = 2.06426426E-04)
GET_2DFLD - solar shortwave radiation flux, t = 0 22:30:00
(Rec=0000008, Index=1, File: gom_swrad_era.nc)
(Min = 1.51806455E-05 Max = 1.16572371E-04)
GET_2DFLD - surface net heat flux, t = 0 22:30:00
(Rec=0000008, Index=1, File: gom_shflux_era.nc)
(Min = -9.66121467E-06 Max = 8.56924329E-05)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 0 00:00:00
(Rec=0000001, Index=2, File: t0604_bry.nc)
(Tmin= 0.0000 Tmax= 61.0000)
(Min = -7.70141743E-03 Max = 2.82108545E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -2.10545473E-02 Max = 5.74858561E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -1.16785280E-01 Max = 2.00956576E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -2.10545473E-02 Max = 7.94643536E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -1.47733809E-02 Max = 3.51793170E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -1.24065101E-01 Max = 8.88886154E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -3.89331788E-01 Max = 5.45626506E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -1.17090203E-01 Max = 2.46778369E-01)
GET_NGFLD - temperature eastern boundary condition, t = 0 00:00:00
(Min = -3.09180876E-13 Max = 3.00770473E+01)
GET_NGFLD - salinity eastern boundary condition, t = 0 00:00:00
(Min = -4.34068986E-13 Max = 3.65945892E+01)
GET_NGFLD - temperature southern boundary condition, t = 0 00:00:00
(Min = -1.54044008E-12 Max = 2.94915771E+01)
GET_NGFLD - salinity southern boundary condition, t = 0 00:00:00
(Min = -1.91542485E-12 Max = 3.66457024E+01)
GET_3DFLD - potential temperature climatology, t = 0 00:00:00
(Rec=0000001, Index=1, File: damee4_Lclm_b.nc)
(Tmin= 0.0000 Tmax= 334.0000)
(Min = 0.00000000E+00 Max = 2.74143713E+01)
GET_3DFLD - salinity climatology, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.67458003E+01)
Maximum grid stiffness ratios: rx0 = 4.785948E-01 (Beckmann and Haidvogel)
rx1 = 1.144999E+01 (Haney)
Initial basin volumes: TotVolume = 3.4615820664E+15 m3
MinVolume = 1.1843849025E+08 m3
MaxVolume = 9.5648797369E+10 m3
Max/Min = 8.0758203831E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000145 - 00008784)
GET_2DFLD - surface u-momentum stress, t = 1 01:30:00
(Rec=0000009, Index=2, File: gom_sms_era.nc)
(Min = -3.85218911E-04 Max = 1.04836739E-04)
GET_2DFLD - surface v-momentum stress, t = 1 01:30:00
(Min = -1.19083844E-04 Max = 2.21327180E-04)
GET_2DFLD - solar shortwave radiation flux, t = 1 01:30:00
(Rec=0000009, Index=2, File: gom_swrad_era.nc)
(Min = -4.22234950E-20 Max = 6.54829338E-06)
GET_2DFLD - surface net heat flux, t = 1 01:30:00
(Rec=0000009, Index=2, File: gom_shflux_era.nc)
(Min = -6.49440989E-05 Max = -4.62032956E-06)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 31 00:00:00
(Rec=0000002, Index=1, File: t0604_bry.nc)
(Min = -4.88156872E-03 Max = 2.52899200E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 31 00:00:00
(Min = -2.15718057E-02 Max = 6.22464232E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 31 00:00:00
(Min = -1.28449917E-01 Max = 1.85216349E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 31 00:00:00
(Min = -2.15718057E-02 Max = 9.02452767E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 31 00:00:00
(Min = -1.58911180E-02 Max = 3.12854528E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 31 00:00:00
(Min = -1.16634078E-01 Max = 7.79765025E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 31 00:00:00
(Min = -3.83034706E-01 Max = 3.61946411E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 31 00:00:00
(Min = -1.13600455E-01 Max = 2.92638898E-01)
GET_NGFLD - temperature eastern boundary condition, t = 31 00:00:00
(Min = -3.08041814E-13 Max = 2.99027557E+01)
GET_NGFLD - salinity eastern boundary condition, t = 31 00:00:00
(Min = -4.34010629E-13 Max = 3.65638466E+01)
GET_NGFLD - temperature southern boundary condition, t = 31 00:00:00
(Min = -1.51450098E-12 Max = 2.96635704E+01)
GET_NGFLD - salinity southern boundary condition, t = 31 00:00:00
(Min = -1.91184872E-12 Max = 3.66002235E+01)
GET_3DFLD - potential temperature climatology, t = 31 00:00:00
(Rec=0000002, Index=2, File: damee4_Lclm_b.nc)
(Min = 0.00000000E+00 Max = 2.72762837E+01)
GET_3DFLD - salinity climatology, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 3.67549533E+01)
144 1 00:00:00 1.101055E-05 1.555875E+04 1.555875E+04 3.440743E+15
(179,065,13) 1.035187E-02 0.000000E+00 0.000000E+00 2.478671E-01
150 1 01:00:00 2.369821E-02 1.555558E+04 1.555560E+04 3.440761E+15
(108,010,15) 2.492003E-02 4.008041E-02 2.527212E+00 3.866112E+00
GET_2DFLD - surface u-momentum stress, t = 1 04:30:00
(Rec=0000010, Index=1, File: gom_sms_era.nc)
(Min = -1.63608568E-04 Max = 3.22725184E-05)
GET_2DFLD - surface v-momentum stress, t = 1 04:30:00
(Min = -7.96744387E-05 Max = 2.31890816E-04)
GET_2DFLD - solar shortwave radiation flux, t = 1 04:30:00
(Rec=0000010, Index=1, File: gom_swrad_era.nc)
(Min = -9.37076875E-09 Max = 9.37076875E-09)
GET_2DFLD - surface net heat flux, t = 1 04:30:00
(Rec=0000010, Index=1, File: gom_shflux_era.nc)
(Min = -6.52646996E-05 Max = -4.33468254E-06)
156 1 02:00:00 8.555982E-02 1.555581E+04 1.555589E+04 3.440779E+15
(045,007,15) 1.897565E-03 1.768342E-02 1.276331E+00 5.946715E+00
162 1 03:00:00 2.754587E-01 1.555611E+04 1.555638E+04 3.440796E+15
(045,040,08) 1.405551E-02 1.228169E-02 2.865928E+00 1.217377E+01
168 1 04:00:00 NaN NaN NaN NaN
(090,000,01) NaN NaN NaN 0.000000E+00
Node # 0 CPU: 48.228
Node # 4 CPU: 49.788
Node # 1 CPU: 49.612
Node # 2 CPU: 49.964
Node # 5 CPU: 49.464
Node # 6 CPU: 49.516
Node # 3 CPU: 49.580
Node # 7 CPU: 49.664
Total: 395.816
Allocation and array initialization .............. 0.088 ( 0.0222 %)
Ocean state initialization ....................... 0.732 ( 0.1849 %)
Reading of input data ............................ 21.804 ( 5.5086 %)
Processing of input data ......................... 13.304 ( 3.3612 %)
Processing of output time averaged data .......... 0.420 ( 0.1061 %)
Computation of vertical boundary conditions ...... 1.424 ( 0.3598 %)
Computation of global information integrals ...... 1.048 ( 0.2648 %)
Model 2D kernel .................................. 295.088 (74.5518 %)
2D/3D coupling, vertical metrics ................. 9.388 ( 2.3718 %)
Omega vertical velocity .......................... 3.288 ( 0.8307 %)
Equation of state for seawater ................... 7.680 ( 1.9403 %)
KPP vertical mixing parameterization ............. 6.564 ( 1.6583 %)
3D equations right-side terms .................... 0.376 ( 0.0950 %)
3D equations predictor step ...................... 3.280 ( 0.8287 %)
Pressure gradient ................................ 0.312 ( 0.0788 %)
Harmonic mixing of tracers, geopotentials ........ 0.384 ( 0.0970 %)
Harmonic stress tensor, S-surfaces ............... 0.168 ( 0.0424 %)
Corrector time-step for 3D momentum .............. 4.528 ( 1.1440 %)
Corrector time-step for tracers .................. 10.372 ( 2.6204 %)
Total: 380.248 96.0669
Message Passage: 2D halo exchanges ............... 311.556 (78.7123 %)
Message Passage: 3D halo exchanges ............... 21.480 ( 5.4268 %)
Message Passage: 4D halo exchanges ............... 9.604 ( 2.4264 %)
Message Passage: data broadcast .................. 18.972 ( 4.7931 %)
Message Passage: data reduction .................. 3.028 ( 0.7650 %)
Message Passage: data scattering.................. 11.032 ( 2.7872 %)
Total: 375.672 94.9108
All percentages are with respect to total time = 395.816
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_srflux.h
ROMS/Functionals/ana_stflux.h
Re: MAIN: Abnormal termination: BLOWUP.
#2 Unread post by wilkin »
Check your grid. It looks like there is a point somewhere where the water depth is 25 m above 0:
This might explain why you have a minimum dz that is actually negative.
Lee2015
#3 Unread post by Lee2015 »
Sorry for late reply. Thanks! I will check and fix it.
Lee2015
#4 Unread post by Lee2015 »
wilkin wrote:Check your grid. It looks like there is a point somewhere where the water depth is 25 m above 0:
Hi wilkin,
I have modify 25 to 0, but the same blowup error still exist.
Saturday - June 11, 2016 - 6:16:21 PM
Mexico
Input Script :
SVN Revision : 783M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
Input Nonlinear Initial File: In/gom_ini.nc
Input Climatology File: In/gom_clm.nc
Input Boundary File: In/gom_bry.nc
0 1 90 1 33 44550
1 91 179 1 33 44055
2 1 90 34 67 45900
4 1 90 68 101 45900
HaloSizeI(1) = 306
HaloSizeJ(1) = 144
TileSide(1) = 96
TileSize(1) = 4032
MEXICO Mexico
Node # 0 (pid= 2254) is active.
Node # 4 (pid= 2258) is active.
Node # 5 (pid= 2259) is active.
Node # 2 (pid= 2256) is active.
Node # 1 (pid= 2255) is active.
Node # 3 (pid= 2257) is active.
Node # 6 (pid= 2260) is active.
Node # 7 (pid= 2261) is active.
15 0.0000000 0.0000000 0.000 0.000 0.000 0.000
14 -0.0666667 -0.0004989 -0.000 -3.358 -7.765 -9.257
13 -0.1333333 -0.0032168 -0.000 -6.828 -21.449 -30.564
12 -0.2000000 -0.0100379 -0.000 -10.502 -46.079 -74.151
11 -0.2666667 -0.0229247 -0.000 -14.480 -86.890 -150.675
10 -0.3333333 -0.0439342 -0.000 -18.863 -149.370 -271.306
9 -0.4000000 -0.0752335 -0.000 -23.762 -239.299 -447.812
8 -0.4666667 -0.1191055 -0.000 -29.289 -362.767 -692.587
7 -0.5333333 -0.1779212 -0.000 -35.563 -526.099 -1018.508
6 -0.6000000 -0.2540303 -0.000 -42.702 -735.565 -1438.333
5 -0.6666667 -0.3494770 -0.000 -50.807 -996.615 -1963.162
4 -0.7333333 -0.4653579 -0.000 -59.935 -1312.176 -2598.950
3 -0.8000000 -0.6004851 -0.000 -70.024 -1679.080 -3339.247
2 -0.8666667 -0.7487245 -0.000 -80.770 -2080.962 -4150.744
1 -0.9333333 -0.8938704 -0.000 -91.360 -2474.592 -4945.443
0 -1.0000000 -1.0000000 -0.000 -100.000 -2764.140 -5528.281
Minimum Z-grid spacing, DZmin = 0.00000000E+00 m
NLM: GET_STATE - Read state initial conditions, t = 10 00:00:00
(Grid 01, File: gom_ini.nc, Rec=0001, Index=1)
- free-surface
- salinity
GET_2DFLD - surface u-momentum stress, t = 9 22:30:00
(Rec=0000080, Index=1, File: gom_sms_era.nc)
(Min = -4.46521160E-04 Max = 7.88658003E-05)
GET_2DFLD - surface v-momentum stress, t = 9 22:30:00
(Min = -2.43290482E-04 Max = 2.63755963E-04)
GET_2DFLD - solar shortwave radiation flux, t = 9 22:30:00
(Rec=0000080, Index=1, File: gom_swrad_era.nc)
(Min = 2.46170107E-05 Max = 9.84193118E-05)
GET_2DFLD - surface net heat flux, t = 9 22:30:00
(Rec=0000080, Index=1, File: gom_shflux_era.nc)
(Min = -3.01548208E-05 Max = 4.19633997E-05)
(Rec=0000001, Index=2, File: gom_bry.nc)
(Rec=0000001, Index=1, File: gom_clm.nc)
(Tmin= 0.0000 Tmax= 59.0000)
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00001441 - 00008784)
GET_2DFLD - surface u-momentum stress, t = 10 01:30:00
(Rec=0000081, Index=2, File: gom_sms_era.nc)
(Min = -2.81609960E-04 Max = 1.96982535E-05)
GET_2DFLD - surface v-momentum stress, t = 10 01:30:00
(Min = -8.42378340E-05 Max = 2.03187849E-04)
GET_2DFLD - solar shortwave radiation flux, t = 10 01:30:00
(Rec=0000081, Index=2, File: gom_swrad_era.nc)
(Min = -4.22234950E-20 Max = 4.63853085E-06)
GET_2DFLD - surface net heat flux, t = 10 01:30:00
(Rec=0000081, Index=2, File: gom_shflux_era.nc)
(Min = -7.62745490E-05 Max = -4.25195064E-06)
(Rec=0000002, Index=1, File: gom_bry.nc)
(Rec=0000002, Index=2, File: gom_clm.nc)
1440 10 00:00:00 1.048932E-05 1.546437E+04 1.546437E+04 3.461582E+15
(090,000,01) 0.000000E+00 0.000000E+00 NaN 2.398735E-01
1446 10 01:00:00 NaN NaN NaN NaN
Node # 0 CPU: 15.040
Node # 4 CPU: 15.072
Node # 5 CPU: 14.960
Node # 2 CPU: 15.084
Node # 1 CPU: 14.944
Node # 3 CPU: 15.076
Node # 6 CPU: 15.076
Node # 7 CPU: 15.000
Total: 120.252
Allocation and array initialization .............. 0.072 ( 0.0599 %)
Ocean state initialization ....................... 0.744 ( 0.6187 %)
Reading of input data ............................ 11.528 ( 9.5865 %)
Processing of input data ......................... 4.212 ( 3.5026 %)
Processing of output time averaged data .......... 0.080 ( 0.0665 %)
Computation of vertical boundary conditions ...... 0.392 ( 0.3260 %)
Computation of global information integrals ...... 0.296 ( 0.2461 %)
Model 2D kernel .................................. 75.340 (62.6518 %)
2D/3D coupling, vertical metrics ................. 3.624 ( 3.0137 %)
Omega vertical velocity .......................... 1.108 ( 0.9214 %)
Equation of state for seawater ................... 2.960 ( 2.4615 %)
KPP vertical mixing parameterization ............. 1.992 ( 1.6565 %)
3D equations right-side terms .................... 0.088 ( 0.0732 %)
3D equations predictor step ...................... 0.860 ( 0.7152 %)
Pressure gradient ................................ 0.044 ( 0.0366 %)
Harmonic mixing of tracers, geopotentials ........ 0.080 ( 0.0665 %)
Harmonic stress tensor, S-surfaces ............... 0.052 ( 0.0432 %)
Corrector time-step for 3D momentum .............. 1.376 ( 1.1443 %)
Corrector time-step for tracers .................. 2.732 ( 2.2719 %)
Total: 107.580 89.4621
Message Passage: 2D halo exchanges ............... 82.312 (68.4496 %)
Message Passage: 3D halo exchanges ............... 7.972 ( 6.6294 %)
Message Passage: 4D halo exchanges ............... 3.124 ( 2.5979 %)
Message Passage: data broadcast .................. 7.316 ( 6.0839 %)
Message Passage: data reduction .................. 1.028 ( 0.8549 %)
Message Passage: data scattering.................. 13.524 (11.2464 %)
Total: 115.276 95.8620
All percentages are with respect to total time = 120.252
#5 Unread post by wilkin »
Why we cannot have zero bathymetry:
https://www.myroms.org/wiki/Frequently_ ... .3D0.29.3F
lalvarez
#6 Unread post by lalvarez »
Hello
I guess you may check your rx0 too, it is a bit greater than 0.4 and as suggested rx0<0.4
Have a nice day
Lee2015
#7 Unread post by Lee2015 »
wilkin and lalvarez,
Thanks for your reply!
Lee2015
#8 Unread post by Lee2015 »
I have modify the zero value and rx0 value, but I still got the blowup error.
Saturday - June 11, 2016 - 11:10:47 PM
Mexico
Input Script :
SVN Revision : 783M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 90 1 33 44550
1 91 179 1 33 44055
2 1 90 34 67 45900
4 1 90 68 101 45900
HaloSizeI(1) = 306
HaloSizeJ(1) = 144
TileSide(1) = 96
TileSize(1) = 4032
MEXICO Mexico
Node # 0 (pid= 11224) is active.
Node # 4 (pid= 11228) is active.
Node # 1 (pid= 11225) is active.
Node # 5 (pid= 11229) is active.
Node # 6 (pid= 11230) is active.
Node # 7 (pid= 11231) is active.
Node # 2 (pid= 11226) is active.
Node # 3 (pid= 11227) is active.
14 -0.0666667 -0.0004989 -0.595 -3.358 -7.748 -9.222
13 -0.1333333 -0.0032168 -1.192 -6.828 -21.351 -30.343
12 -0.2000000 -0.0100379 -1.792 -10.502 -45.780 -73.465
11 -0.2666667 -0.0229247 -2.398 -14.480 -86.215 -149.112
10 -0.3333333 -0.0439342 -3.011 -18.863 -148.082 -268.314
9 -0.4000000 -0.0752335 -3.632 -23.762 -237.099 -442.692
8 -0.4666667 -0.1191055 -4.265 -29.289 -359.291 -684.486
7 -0.5333333 -0.1779212 -4.911 -35.563 -520.912 -1006.409
6 -0.6000000 -0.2540303 -5.572 -42.702 -728.164 -1421.063
5 -0.6666667 -0.3494770 -6.250 -50.807 -986.440 -1939.406
4 -0.7333333 -0.4653579 -6.945 -59.935 -1298.633 -2567.321
3 -0.8000000 -0.6004851 -7.658 -70.024 -1661.609 -3298.436
2 -0.8666667 -0.7487245 -8.382 -80.770 -2059.183 -4099.861
1 -0.9333333 -0.8938704 -9.103 -91.360 -2448.594 -4884.698
0 -1.0000000 -1.0000000 -9.790 -100.000 -2735.057 -5460.325
Minimum Z-grid spacing, DZmin = 5.94894030E-01 m
Maximum Z-grid spacing, DZmax = 8.01424881E+02 m
Minimum barotropic Courant Number = 4.34046573E-02
Maximum barotropic Courant Number = 9.04967747E-01
- free-surface
- salinity
(Min = -8.75419937E-03 Max = 2.78583258E-01)
(Min = -1.94059033E-02 Max = 5.33198379E-02)
(Min = -1.12739071E-01 Max = 1.90938376E-02)
(Min = -1.94059033E-02 Max = 7.94746801E-02)
(Min = -1.47942649E-02 Max = 3.51850867E-01)
(Min = -1.24114767E-01 Max = 8.88591483E-02)
(Min = -3.89335334E-01 Max = 5.40571101E-02)
(Min = -1.17034659E-01 Max = 2.46785000E-01)
(Min = -3.17184945E-13 Max = 3.00770473E+01)
(Min = -4.33525747E-13 Max = 3.66118050E+01)
(Min = -1.54043206E-12 Max = 2.94916019E+01)
(Min = -1.91539840E-12 Max = 3.66452904E+01)
Maximum grid stiffness ratios: rx0 = 3.448646E-01 (Beckmann and Haidvogel)
rx1 = 8.584919E+00 (Haney)
Initial basin volumes: TotVolume = 3.4520265032E+15 m3
MinVolume = 7.9353319836E+07 m3
MaxVolume = 9.4461641422E+10 m3
Max/Min = 1.1903930625E+03
(Min = -4.82287770E-03 Max = 2.48840362E-01)
(Min = -2.02356186E-02 Max = 5.92395216E-02)
(Min = -1.24096043E-01 Max = 1.82952601E-02)
(Min = -2.02356186E-02 Max = 9.02760997E-02)
(Min = -1.59372259E-02 Max = 3.12866628E-01)
(Min = -1.16848841E-01 Max = 7.79633820E-02)
(Min = -3.83063942E-01 Max = 3.64063419E-02)
(Min = -1.13282099E-01 Max = 2.92650521E-01)
(Min = -3.19303584E-13 Max = 2.99027519E+01)
(Min = -4.33347667E-13 Max = 3.65748367E+01)
(Min = -1.51449003E-12 Max = 2.96636028E+01)
(Min = -1.91220173E-12 Max = 3.66001740E+01)
(Min = 0.00000000E+00 Max = 2.99086880E+01)
(Min = 0.00000000E+00 Max = 3.66465970E+01)
1440 10 00:00:00 1.046594E-05 1.529191E+04 1.529191E+04 3.470239E+15
(179,065,13) 1.001929E-02 0.000000E+00 0.000000E+00 2.399039E-01
1446 10 01:00:00 2.144616E-02 1.528879E+04 1.528881E+04 3.470259E+15
(108,010,15) 2.315671E-02 4.110335E-02 3.154906E+00 3.922275E+00
GET_2DFLD - surface u-momentum stress, t = 10 04:30:00
(Rec=0000082, Index=1, File: gom_sms_era.nc)
(Min = -2.76960764E-04 Max = 1.72726149E-05)
GET_2DFLD - surface v-momentum stress, t = 10 04:30:00
(Min = -7.20951979E-05 Max = 1.92146024E-04)
GET_2DFLD - solar shortwave radiation flux, t = 10 04:30:00
(Rec=0000082, Index=1, File: gom_swrad_era.nc)
GET_2DFLD - surface net heat flux, t = 10 04:30:00
(Rec=0000082, Index=1, File: gom_shflux_era.nc)
(Min = -8.50984428E-05 Max = -2.81554360E-06)
1452 10 02:00:00 7.562188E-02 1.528910E+04 1.528917E+04 3.470278E+15
(045,007,15) 4.073904E-03 1.695849E-02 1.691881E+00 6.039989E+00
1458 10 03:00:00 2.296695E-01 1.528951E+04 1.528974E+04 3.470297E+15
(045,047,08) 1.624805E-02 7.647977E-03 2.633696E+00 1.074933E+01
1464 10 04:00:00 NaN NaN NaN NaN
Node # 0 CPU: 45.568
Node # 1 CPU: 45.792
Node # 2 CPU: 45.720
Node # 4 CPU: 45.772
Node # 5 CPU: 45.880
Node # 3 CPU: 45.724
Node # 6 CPU: 45.952
Node # 7 CPU: 45.716
Total: 366.124
Allocation and array initialization .............. 0.096 ( 0.0262 %)
Ocean state initialization ....................... 0.928 ( 0.2535 %)
Reading of input data ............................ 18.336 ( 5.0081 %)
Processing of input data ......................... 12.888 ( 3.5201 %)
Processing of output time averaged data .......... 0.360 ( 0.0983 %)
Computation of vertical boundary conditions ...... 1.236 ( 0.3376 %)
Computation of global information integrals ...... 0.972 ( 0.2655 %)
Model 2D kernel .................................. 263.960 (72.0958 %)
2D/3D coupling, vertical metrics ................. 9.832 ( 2.6854 %)
Omega vertical velocity .......................... 3.504 ( 0.9571 %)
Equation of state for seawater ................... 8.100 ( 2.2124 %)
KPP vertical mixing parameterization ............. 6.488 ( 1.7721 %)
3D equations right-side terms .................... 0.356 ( 0.0972 %)
3D equations predictor step ...................... 3.292 ( 0.8991 %)
Pressure gradient ................................ 0.280 ( 0.0765 %)
Harmonic mixing of tracers, geopotentials ........ 0.336 ( 0.0918 %)
Harmonic stress tensor, S-surfaces ............... 0.160 ( 0.0437 %)
Corrector time-step for 3D momentum .............. 5.592 ( 1.5274 %)
Corrector time-step for tracers .................. 10.840 ( 2.9607 %)
Total: 347.556 94.9285
Message Passage: 2D halo exchanges ............... 282.632 (77.1957 %)
Message Passage: 3D halo exchanges ............... 22.860 ( 6.2438 %)
Message Passage: 4D halo exchanges ............... 10.352 ( 2.8275 %)
Message Passage: data broadcast .................. 13.520 ( 3.6927 %)
Message Passage: data reduction .................. 2.464 ( 0.6730 %)
Message Passage: data scattering.................. 15.644 ( 4.2729 %)
Total: 347.472 94.9056
All percentages are with respect to total time = 366.124
susonic
#9 Unread post by susonic »
You are not allowed to have zero value in your depth.
Check out more information on the below website.
https://myroms.org/forum/viewtopic.php? ... w=previous
viewtopic.php?f=23&t=2546
Joonho Lee
#10 Unread post by kate »
He's gotten beyond the zero depth.
I would set NINFO to 1 so that you can watch it blow up, perhaps get a restart record before you have NaNs everywhere. Then from the wiki FAQ:
ROMS will check for extreme values of velocity and density at run time, including looking for NaN and Inf. If found, it will save a record to the restart file and die. If this happens early in the run, you might just try a shorter timestep. If it happens after many days/years of model time, you need to dig more deeply. Find out which field went bad and where in the domain it happened. The restart record can be viewed to look for this trouble. I've had runs go bad at the bottom with a bottom stress instability, at the top with a surface forcing problem, at the boundary with boundary condition issues. I've also had it go bad in the middle of the water column in no place special due to some other instability - it goes from fine to terrible in just a few timesteps. This last can often be run past with a shorter timestep, while the other problems call for more thoughtful responses.
susonic
#11 Unread post by susonic »
Oh! I saw wrong log file(I should have read third one). Sorry for the wrong post.
Yes, like Kate mentioned, I also recommend you to try shorter time step.
I also have a question about your boundary condition.
As far as I know, the conventional boundary condition for the sea surface and barotropic velocity are
Chapman and Flather, respectively. Would you try that one also?
-JH
Joonho Lee
#12 Unread post by wilkin »
You need to figure out where ROMS is blowing up in order to begin taking rational remedial steps. But you are not saving any output that would help you do that.
144000 nRST Number of timesteps between the writing of data into restart fields.
6 ninfo Number of timesteps between print of information to standard output.
144000 nHIS Number of timesteps between the writing fields into history file.
Kate has already suggested that you decrease NINFO to 1 instead of 6 so that you can monitor the progression to blow-up. You should do that. The information that is sent to stdout every NINFO steps includes the i,j,k coordinate of the max speed so at the moment of blow-up this gives a clue where to look at your output to see what conditions preceded the blow-up.
But to look at what ROMS had computed so far you need to save some output. You have st nRST, nHIS and nAVG all to 144000, so you won't get any output for that many time steps, which is 1000 days. (It will be hard to do any science with so little output, too).
Until you get these issues sorted out, I suggest you save restart output very frequently, say every nRST = 6 time steps so you can see some evolution of the solution. If you set LcycleRST to TRUE then ROMS will only keep the last 2 records so the file is not going to grow absurdly large in size. At blow-up ROMS will also write the model state to a 3rd record in the restart file. It is not doing this at present because the file has not been created yet. It needs to exist for the blow-up save action to complete.
I suggest you think about your boundary condition choices, and consult with ROMS users in your immediate group. You have everything clamped (except zeta) which is going to generate all manner of wave reflections at the boundaries.
#13 Unread post by kate »
John - this is good stuff. Feel free to pad out the FAQ section of the wiki with these gems.
Is it true that the restart dump won't happen before any records are written? I know you get it for restart runs before new records are written (and it goes into record 1 instead of 3).
Lee2015
#14 Unread post by Lee2015 »
Thank you all!I will check them...
Lee2015
#15 Unread post by Lee2015 »
Based on your suggestions above, I got the new output, include the re-start file (I just post the download link http://www.filedropper.com/mexicorst, since I cannot post attachments here). I want to know what information the re-start file told us? the log file is as follows.
many Thanks!
Monday - June 13, 2016 - 9:26:08 PM
Mexico
Input Script :
SVN Revision : 783M
Resolution, Grid 01: 0179x0134x015, Parallel Nodes: 8, Tiling: 004x002
21960 ntimes Number of timesteps for 3-D equations.
240.000 dt Timestep size (s) for 3-D equations.
1440 nRST Number of timesteps between the writing of data
to standard output.
1440 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
1440 nAVG Number of timesteps between the writing of
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
Output History File: Out/mexico_his.nc
Input Grid File: In/gom_grd.nc
Tile partition information for Grid 01: 0179x0134x0015 tiling: 004x002
0 1 45 1 67 45225
1 46 90 1 67 45225
2 91 135 1 67 45225
3 136 179 1 67 44220
4 1 45 68 134 45225
5 46 90 68 134 45225
6 91 135 68 134 45225
7 136 179 68 134 44220
0 0.50 45.50 0.50 67.50 RHO-points
1 45.50 90.50 0.50 67.50 RHO-points
2 90.50 135.50 0.50 67.50 RHO-points
3 135.50 179.50 0.50 67.50 RHO-points
4 0.50 45.50 67.50 134.50 RHO-points
5 45.50 90.50 67.50 134.50 RHO-points
6 90.50 135.50 67.50 134.50 RHO-points
7 135.50 179.50 67.50 134.50 RHO-points
0 1.00 45.50 0.50 67.50 U-points
1 45.50 90.50 0.50 67.50 U-points
2 90.50 135.50 0.50 67.50 U-points
3 135.50 179.00 0.50 67.50 U-points
4 1.00 45.50 67.50 134.50 U-points
5 45.50 90.50 67.50 134.50 U-points
6 90.50 135.50 67.50 134.50 U-points
7 135.50 179.00 67.50 134.50 U-points
0 0.50 45.50 1.00 67.50 V-points
1 45.50 90.50 1.00 67.50 V-points
2 90.50 135.50 1.00 67.50 V-points
3 135.50 179.50 1.00 67.50 V-points
4 0.50 45.50 67.50 134.00 V-points
5 45.50 90.50 67.50 134.00 V-points
6 90.50 135.50 67.50 134.00 V-points
7 135.50 179.50 67.50 134.00 V-points
HaloSizeI(1) = 177
HaloSizeJ(1) = 240
TileSide(1) = 74
TileSize(1) = 3922
MEXICO Mexico
Node # 0 (pid= 13856) is active.
Node # 2 (pid= 13858) is active.
Node # 3 (pid= 13859) is active.
Node # 1 (pid= 13857) is active.
Node # 4 (pid= 13860) is active.
Node # 6 (pid= 13862) is active.
Node # 7 (pid= 13863) is active.
Node # 5 (pid= 13861) is active.
Minimum barotropic Courant Number = 1.73618629E-02
Maximum barotropic Courant Number = 3.61987099E-01
Maximum Coriolis Courant Number = 1.78123772E-02
- free-surface
- salinity
(Min = -4.44913672E-04 Max = 7.82397046E-05)
(Min = -2.40179656E-04 Max = 2.63159577E-04)
(Min = 2.48795581E-05 Max = 9.84199738E-05)
(Min = -3.01287096E-05 Max = 4.17307627E-05)
(Min = -8.51026922E-03 Max = 2.78584391E-01)
(Min = -1.92203652E-02 Max = 5.33318147E-02)
(Min = -1.12915687E-01 Max = 1.86779350E-02)
(Min = -1.92203652E-02 Max = 7.93284103E-02)
(Min = -1.46363117E-02 Max = 3.48533183E-01)
(Min = -1.23634353E-01 Max = 8.88170972E-02)
(Min = -3.88949215E-01 Max = 5.43890595E-02)
(Min = -1.17089726E-01 Max = 2.46610597E-01)
(Min = -2.14433153E-13 Max = 3.00768490E+01)
(Min = -4.35830842E-13 Max = 3.66052551E+01)
(Min = -1.54100701E-12 Max = 2.94919109E+01)
(Min = -1.90932795E-12 Max = 3.66514893E+01)
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00003601 - 00021960)
(Min = -2.77185324E-04 Max = 1.97672739E-05)
(Min = -8.34200513E-05 Max = 2.03272235E-04)
(Min = -4.22234950E-20 Max = 4.63856167E-06)
(Min = -7.59643827E-05 Max = -4.42213781E-06)
(Min = -4.69327252E-03 Max = 2.47487098E-01)
(Min = -1.97281577E-02 Max = 5.92264719E-02)
(Min = -1.23686261E-01 Max = 1.74726173E-02)
(Min = -1.97281577E-02 Max = 9.00412723E-02)
(Min = -1.61137376E-02 Max = 3.11915249E-01)
(Min = -1.14210762E-01 Max = 7.79447556E-02)
(Min = -3.80391806E-01 Max = 3.62655930E-02)
(Min = -1.13598138E-01 Max = 2.92345315E-01)
(Min = -2.13158240E-13 Max = 2.99025478E+01)
(Min = -4.35715293E-13 Max = 3.65579834E+01)
(Min = -1.51527662E-12 Max = 2.96640129E+01)
(Min = -1.89893479E-12 Max = 3.66007004E+01)
3600 10 00:00:00 3.984212E-06 1.529191E+04 1.529191E+04 3.470239E+15
(179,065,14) 3.968520E-03 0.000000E+00 0.000000E+00 2.375576E-01
DEF_HIS - creating history file, Grid 01: Out/mexico_his.nc
DEF_AVG - creating average file, Grid 01: Out/mexico_avg.nc
3601 10 00:04:00 2.331361E-04 1.529169E+04 1.529169E+04 3.470241E+15
(179,065,10) 4.384972E-03 1.131634E-04 1.365077E-02 4.166317E-01
3602 10 00:08:00 7.249875E-04 1.529124E+04 1.529124E+04 3.470242E+15
(122,029,15) 2.481900E-03 3.597630E-03 3.793006E-01 7.185987E-01
3603 10 00:12:00 1.362833E-03 1.529075E+04 1.529075E+04 3.470244E+15
(110,003,15) 5.058651E-03 3.855910E-04 4.159279E-01 9.214140E-01
3604 10 00:16:00 2.136378E-03 1.529031E+04 1.529031E+04 3.470245E+15
(109,004,15) 2.499647E-03 2.152558E-04 6.768207E-01 1.130340E+00
3605 10 00:20:00 3.076398E-03 1.528993E+04 1.528993E+04 3.470246E+15
(108,001,15) 9.948771E-03 0.000000E+00 7.567061E-01 1.309797E+00
3606 10 00:24:00 4.194239E-03 1.528961E+04 1.528961E+04 3.470248E+15
(108,001,15) 6.484163E-03 0.000000E+00 9.769017E-01 1.597078E+00
3607 10 00:28:00 5.478975E-03 1.528934E+04 1.528935E+04 3.470249E+15
(019,032,15) 5.986766E-03 5.037206E-03 8.355048E-01 1.941845E+00
3608 10 00:32:00 6.931891E-03 1.528912E+04 1.528913E+04 3.470251E+15
(109,009,15) 5.106881E-02 1.700630E-02 7.999557E-01 2.559568E+00
3609 10 00:36:00 8.561587E-03 1.528893E+04 1.528894E+04 3.470252E+15
(108,009,15) 2.974816E-02 8.403897E-03 8.575925E-01 3.117455E+00
3610 10 00:40:00 1.035894E-02 1.528878E+04 1.528879E+04 3.470254E+15
(108,009,15) 3.498620E-02 1.543519E-02 1.105194E+00 3.367350E+00
3611 10 00:44:00 1.229890E-02 1.528868E+04 1.528870E+04 3.470255E+15
(108,009,15) 3.297677E-02 2.318000E-02 1.067438E+00 3.188883E+00
3612 10 00:48:00 1.436901E-02 1.528864E+04 1.528866E+04 3.470256E+15
(108,010,15) 1.774792E-02 2.876980E-02 1.306272E+00 3.313093E+00
3613 10 00:52:00 1.657581E-02 1.528866E+04 1.528868E+04 3.470258E+15
(108,010,15) 1.313418E-02 2.987557E-02 1.458393E+00 3.537982E+00
3614 10 00:56:00 1.892239E-02 1.528872E+04 1.528874E+04 3.470259E+15
(108,010,15) 3.300062E-03 2.594292E-02 1.309494E+00 3.749671E+00
3615 10 01:00:00 2.140175E-02 1.528881E+04 1.528883E+04 3.470261E+15
(108,010,15) 8.966180E-03 1.824740E-02 8.407136E-01 3.936472E+00
3616 10 01:04:00 2.400817E-02 1.528891E+04 1.528893E+04 3.470262E+15
(109,012,15) 0.000000E+00 2.740508E-02 7.131155E-01 4.097715E+00
3617 10 01:08:00 2.675458E-02 1.528898E+04 1.528901E+04 3.470263E+15
(109,012,15) 0.000000E+00 2.966750E-02 8.109075E-01 4.254162E+00
3618 10 01:12:00 2.963748E-02 1.528901E+04 1.528904E+04 3.470265E+15
(108,010,15) 2.505680E-02 2.420295E-03 1.065913E+00 4.427669E+00
3619 10 01:16:00 3.265485E-02 1.528900E+04 1.528903E+04 3.470266E+15
(108,010,15) 1.955225E-02 2.275597E-03 1.132337E+00 4.622279E+00
3620 10 01:20:00 3.579026E-02 1.528895E+04 1.528899E+04 3.470268E+15
(108,010,15) 1.218631E-02 1.108611E-03 8.360314E-01 4.822438E+00
3621 10 01:24:00 3.905354E-02 1.528890E+04 1.528894E+04 3.470269E+15
(109,012,15) 0.000000E+00 2.618865E-02 7.640983E-01 5.014980E+00
3622 10 01:28:00 4.245375E-02 1.528886E+04 1.528890E+04 3.470270E+15
(109,010,15) 3.573767E-03 2.770917E-02 9.416745E-01 5.194289E+00
(Min = -2.73595886E-04 Max = 1.66984640E-05)
(Min = -7.22489153E-05 Max = 1.92062339E-04)
(Min = -9.37083168E-09 Max = 9.37083168E-09)
(Min = -8.47400282E-05 Max = -3.07336624E-06)
3623 10 01:32:00 4.599358E-02 1.528884E+04 1.528889E+04 3.470272E+15
(109,010,15) 4.617939E-03 2.224240E-02 8.550595E-01 5.355370E+00
3624 10 01:36:00 4.968190E-02 1.528884E+04 1.528889E+04 3.470273E+15
(121,040,15) 9.589057E-03 5.186521E-03 8.287023E-01 5.501056E+00
3625 10 01:40:00 5.352390E-02 1.528885E+04 1.528890E+04 3.470275E+15
(044,008,15) 3.196751E-03 1.062091E-02 7.694056E-01 5.619483E+00
3626 10 01:44:00 5.753623E-02 1.528887E+04 1.528893E+04 3.470276E+15
(044,008,15) 2.394450E-03 1.030454E-02 7.647498E-01 5.714415E+00
3627 10 01:48:00 6.172572E-02 1.528891E+04 1.528897E+04 3.470277E+15
(109,010,15) 8.085987E-03 5.163271E-03 8.453291E-01 5.801720E+00
3628 10 01:52:00 6.609474E-02 1.528897E+04 1.528904E+04 3.470279E+15
(049,008,15) 2.704955E-03 1.112156E-02 7.692953E-01 5.885102E+00
3629 10 01:56:00 7.066218E-02 1.528905E+04 1.528912E+04 3.470280E+15
(121,040,15) 1.101593E-02 3.912608E-03 7.780297E-01 5.964541E+00
3630 10 02:00:00 7.547039E-02 1.528913E+04 1.528921E+04 3.470282E+15
(121,040,15) 8.869402E-03 9.083749E-04 7.301998E-01 6.149596E+00
3631 10 02:04:00 8.055739E-02 1.528922E+04 1.528930E+04 3.470283E+15
(138,121,15) 7.048984E-03 8.731135E-03 6.906800E-01 6.327256E+00
3632 10 02:08:00 8.595955E-02 1.528929E+04 1.528937E+04 3.470284E+15
(136,123,15) 1.027427E-02 1.786717E-02 9.204820E-01 6.488789E+00
3633 10 02:12:00 9.172380E-02 1.528933E+04 1.528942E+04 3.470286E+15
(136,123,15) 6.703218E-03 1.772417E-02 9.423716E-01 6.634722E+00
3634 10 02:16:00 9.791744E-02 1.528935E+04 1.528945E+04 3.470287E+15
(140,121,15) 2.649422E-02 9.133879E-03 7.681593E-01 6.766490E+00
3635 10 02:20:00 1.046267E-01 1.528934E+04 1.528944E+04 3.470289E+15
(140,121,15) 2.162363E-02 7.775663E-03 8.224076E-01 6.886544E+00
3636 10 02:24:00 1.119589E-01 1.528931E+04 1.528943E+04 3.470290E+15
(109,011,15) 0.000000E+00 2.848855E-02 8.718303E-01 6.999169E+00
3637 10 02:28:00 1.200489E-01 1.528929E+04 1.528941E+04 3.470291E+15
(121,040,15) 1.426204E-02 2.905948E-03 9.133727E-01 7.110603E+00
3638 10 02:32:00 1.290457E-01 1.528927E+04 1.528940E+04 3.470293E+15
(121,040,15) 1.114994E-02 1.637831E-04 8.640343E-01 7.202179E+00
3639 10 02:36:00 1.391186E-01 1.528928E+04 1.528942E+04 3.470294E+15
(047,007,15) 6.832116E-03 1.572893E-02 7.884898E-01 7.265214E+00
3640 10 02:40:00 1.504336E-01 1.528931E+04 1.528946E+04 3.470296E+15
(047,007,15) 7.002819E-03 1.662025E-02 9.429529E-01 7.295220E+00
3641 10 02:44:00 1.631245E-01 1.528936E+04 1.528952E+04 3.470297E+15
(047,007,15) 6.181791E-03 1.535012E-02 9.674423E-01 7.445450E+00
3642 10 02:48:00 1.773106E-01 1.528942E+04 1.528959E+04 3.470298E+15
(121,040,15) 2.560130E-02 3.437448E-03 1.139805E+00 8.617138E+00
3643 10 02:52:00 1.931022E-01 1.528947E+04 1.528966E+04 3.470300E+15
(121,040,15) 2.663875E-02 1.444769E-03 1.395839E+00 9.867375E+00
3644 10 02:56:00 2.107122E-01 1.528952E+04 1.528973E+04 3.470301E+15
(121,040,15) 2.148073E-02 1.770466E-03 1.332578E+00 1.119750E+01
3645 10 03:00:00 2.303688E-01 1.528956E+04 1.528979E+04 3.470303E+15
(045,040,09) 6.122850E-03 2.276929E-03 1.237030E+00 1.257177E+01
3646 10 03:04:00 2.523248E-01 1.528959E+04 1.528984E+04 3.470304E+15
(045,040,10) 4.889920E-03 3.377145E-03 1.284976E+00 1.394920E+01
3647 10 03:08:00 2.769665E-01 1.528962E+04 1.528990E+04 3.470305E+15
(045,040,10) 5.193763E-03 4.910245E-03 1.310795E+00 1.521999E+01
3648 10 03:12:00 3.048203E-01 1.528964E+04 1.528994E+04 3.470307E+15
(045,040,11) 3.668202E-03 6.175925E-03 1.300097E+00 1.622125E+01
3649 10 03:16:00 3.364472E-01 1.528965E+04 1.528998E+04 3.470308E+15
(121,040,15) 1.733358E-02 1.677701E-02 1.431345E+00 1.671645E+01
3650 10 03:20:00 3.724959E-01 1.528964E+04 1.529001E+04 3.470310E+15
(121,040,15) 1.845981E-02 1.336600E-02 1.611351E+00 1.643193E+01
3651 10 03:24:00 4.135850E-01 1.528961E+04 1.529002E+04 3.470311E+15
(121,040,15) 1.678576E-02 7.655297E-03 1.511983E+00 1.549626E+01
3652 10 03:28:00 4.603240E-01 1.528956E+04 1.529002E+04 3.470313E+15
(014,074,15) 1.539766E-02 2.014759E-02 1.333331E+00 1.462018E+01
3653 10 03:32:00 5.132328E-01 1.528949E+04 1.529001E+04 3.470314E+15
(014,074,15) 1.244568E-02 1.654827E-02 1.264256E+00 1.411822E+01
3654 10 03:36:00 5.724773E-01 1.528941E+04 1.528999E+04 3.470315E+15
(047,042,10) 5.101470E-03 7.731331E-03 1.211294E+00 1.338915E+01
3655 10 03:40:00 6.379735E-01 1.528933E+04 1.528997E+04 3.470317E+15
(047,042,10) 5.593948E-03 7.345588E-03 1.172573E+00 1.406011E+01
3656 10 03:44:00 7.092232E-01 1.528926E+04 1.528997E+04 3.470318E+15
(121,040,15) 2.070829E-02 8.687044E-03 1.232906E+00 1.444265E+01
3657 10 03:48:00 7.853810E-01 1.528920E+04 1.528999E+04 3.470320E+15
(121,040,15) 2.144827E-02 4.054632E-03 1.379919E+00 1.445850E+01
3658 10 03:52:00 8.654652E-01 1.528917E+04 1.529003E+04 3.470321E+15
(121,040,15) 1.732117E-02 1.218217E-03 1.213976E+00 1.405132E+01
3659 10 03:56:00 9.485126E-01 1.528913E+04 1.529008E+04 3.470322E+15
(125,101,08) 2.542501E-03 6.378816E-03 1.125459E+00 1.306192E+01
3660 10 04:00:00 1.033557E+00 1.528909E+04 1.529013E+04 3.470324E+15
(125,101,09) 2.423781E-03 9.923938E-03 1.165756E+00 1.368127E+01
3661 10 04:04:00 1.119441E+00 1.528904E+04 1.529016E+04 3.470325E+15
(125,102,08) 3.118956E-03 4.393947E-02 1.169328E+00 1.411867E+01
3662 10 04:08:00 1.205361E+00 1.528897E+04 1.529018E+04 3.470327E+15
(125,102,09) 2.737442E-03 7.634651E-02 1.229841E+00 1.429991E+01
3663 10 04:12:00 1.290547E+00 1.528889E+04 1.529018E+04 3.470328E+15
(125,102,10) 1.397418E-03 1.338453E-01 1.256176E+00 1.427759E+01
3664 10 04:16:00 1.375694E+00 1.528880E+04 1.529018E+04 3.470329E+15
(125,102,11) 1.189798E-03 2.338407E-01 1.248262E+00 1.479935E+01
3665 10 04:20:00 1.467634E+00 1.528871E+04 1.529018E+04 3.470331E+15
(125,101,10) 2.241018E-03 4.462208E-01 1.394132E+00 3.398482E+01
WRT_RST - wrote re-start fields (Index=2,2) into time record = 0000001
Node # 0 CPU: 112.768
Node # 4 CPU: 113.556
Node # 6 CPU: 113.372
Node # 7 CPU: 113.460
Node # 1 CPU: 112.928
Node # 2 CPU: 112.872
Node # 3 CPU: 111.844
Node # 5 CPU: 111.656
Total: 902.456
Allocation and array initialization .............. 0.080 ( 0.0089 %)
Ocean state initialization ....................... 1.076 ( 0.1192 %)
Reading of input data ............................ 12.140 ( 1.3452 %)
Processing of input data ......................... 31.064 ( 3.4422 %)
Processing of output time averaged data .......... 1.112 ( 0.1232 %)
Computation of vertical boundary conditions ...... 3.408 ( 0.3776 %)
Computation of global information integrals ...... 11.672 ( 1.2934 %)
Writing of output data ........................... 5.756 ( 0.6378 %)
Model 2D kernel .................................. 709.952 (78.6689 %)
2D/3D coupling, vertical metrics ................. 17.968 ( 1.9910 %)
Omega vertical velocity .......................... 7.712 ( 0.8546 %)
Equation of state for seawater ................... 13.956 ( 1.5464 %)
KPP vertical mixing parameterization ............. 14.924 ( 1.6537 %)
3D equations right-side terms .................... 1.308 ( 0.1449 %)
3D equations predictor step ...................... 6.840 ( 0.7579 %)
Pressure gradient ................................ 0.984 ( 0.1090 %)
Harmonic mixing of tracers, geopotentials ........ 1.040 ( 0.1152 %)
Harmonic stress tensor, S-surfaces ............... 0.476 ( 0.0527 %)
Corrector time-step for 3D momentum .............. 14.020 ( 1.5535 %)
Corrector time-step for tracers .................. 22.048 ( 2.4431 %)
Total: 877.536 97.2386
Message Passage: 2D halo exchanges ............... 739.876 (81.9847 %)
Message Passage: 3D halo exchanges ............... 45.656 ( 5.0591 %)
Message Passage: 4D halo exchanges ............... 13.224 ( 1.4653 %)
Message Passage: data broadcast .................. 15.076 ( 1.6706 %)
Message Passage: data reduction .................. 12.036 ( 1.3337 %)
Message Passage: data gathering .................. 3.468 ( 0.3843 %)
Message Passage: data scattering.................. 13.456 ( 1.4910 %)
Total: 842.792 93.3887
All percentages are with respect to total time = 902.456
ROMS/TOMS: DONE... Monday - June 13, 2016 - 9:29:56 PM
#16 Unread post by kate »
I can't speak for the rest, but I don't want to look at your restart file. You need to start developing tools for looking at ROMS output, including restart files. The simplest way to start is with ncview, which will show you the fields in any netcdf file (or group of files). That is often good enough for this sort of blow-up.
Beyond that, you need to pick a language, whether Matlab, Ferret, Python, Fortran, NCL, whatever. It has to have a means of reading netcdf files and of creating plots. There are ROMS tools for all of the above, some easier to find than others. Anyway, pick one and start using it to see what the model output looks like.
Lee2015
#17 Unread post by Lee2015 »
kate wrote:I can't speak for the rest, but I don't want to look at your restart file. You need to start developing tools for looking at ROMS output, including restart files. The simplest way to start is with ncview, which will show you the fields in any netcdf file (or group of files). That is often good enough for this sort of blow-up.
kate, thank you! I have the tools to read netcdf, I can open the restart file. But I am a ROMS newbie, I don't know how to check the reason of the blow-up. Can you give me some suggestions about it?
lindandan
#18 Unread post by lindandan »
Hello! I have a problem when run a spinup with climatology data.
I have run 855 days without error but blowup suddenly. I see the restart file,it has 11 variables 'zeta' 'u' 'v' 'ubar' 'vbar' 'temp' 'salt' 'rho' 'akv' 'akt' 'aks',and I found that there is a abnormal value at right boundary with coordinate(245,276). so I correct the value with its near value. But I just have corrected 9 variables without 'Akt''Akv''Aks',because I don't know how to correct them. And after I correct 9 variable of the restart file. I try to run with restart mode, but failed. What should I do ?
Next is the output
Sunday - June 12, 2016 - 12:33:04 PM
Region Ocena System, 1/12 degree resolution
Compiler system : ifort
Compiler command : /usr/local/mpi/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -I/usr/local/mpi/include -ip -O3 -free -free -free
Input Script :
SVN Revision : 783M
Local Root : /vol/home/student/lshw/roms/trunk
Header Dir : /vol/home/student/lshw/roms/MYPROJECT/SSC12
Header file : ssc12.h
Analytical Dir: /vol/home/student/lshw/roms/MYPROJECT/Functionals
Resolution, Grid 01: 0275x0275x032, Parallel Nodes: 16, Tiling: 004x004
424800 ntimes Number of timesteps for 3-D equations.
360.000 dt Timestep size (s) for 3-D equations.
72 ndtfast Number of timesteps for 2-D equations between
1 nrrec Number of restart records to read from disk.
to standard output.
F ldefout Switch to create a new output NetCDF file(s).
1200 nHIS Number of timesteps between the writing fields
into history file.
14400 ndefHIS Number of timesteps between creation of new
history files.
8640000 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
864000 nAVG Number of timesteps between the writing of
864000 ndefAVG Number of timesteps between creation of new
time-averaged file.
2.5000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
2.5000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
5.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
T LuvSponge Turning ON sponge on horizontal momentum.
T LtracerSponge(01) Turning ON sponge on tracer 01: temp
T LtracerSponge(02) Turning ON sponge on tracer 02: salt
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
1.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
2.5000E-03 rdrg2 Quadratic bottom drag coefficient.
6.0000E+00 theta_s S-coordinate surface control parameter.
5.0000E-01 theta_b S-coordinate bottom control parameter.
15.000 Tcline S-coordinate surface/bottom layer width (m) used
-1.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
3.6000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.6000E+02 Znudg Nudging/relaxation time scale (days)
3.6000E+02 M2nudg Nudging/relaxation time scale (days)
3.6000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
5.000 T0 Background potential temperature (C) constant.
T LnudgeTCLM(01) Turning ON nudging of climatology tracer 01: temp
T LnudgeTCLM(02) Turning ON nudging of climatology tracer 02: salt
T Hout(idTdif) Write out vertical diffusion: AKt(itemp).
T Hout(idSdif) Write out vertical diffusion: AKt(isalt).
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Output Restart File: ssc12_rst.nc
Prefix for History Files: ssc12_his
Node # 9 (pid= 10133) is active.
Prefix for Averages Files: ssc12_avg
Node # 12 (pid= 10136) is active.
Input Grid File: ../Data/ssc12_grd.nc
Node # 13 (pid= 10137) is active.
Input Nonlinear Initial File: ssc12_rst.nc
Node # 8 (pid= 10132) is active.
Input Forcing File 01: ../Data/ssc12_frc.nc
Node # 10 (pid= 10134) is active.
Input Climatology File: ../Data/ssc12_clm.nc
Node # 11 (pid= 10135) is active.
Input Boundary File: ../Data/ssc12_bry.nc
Node # 14 (pid= 10138) is active.
Input/Output USER File: MyFile.dat
Node # 15 (pid= 10139) is active.
Generic User Parameters:
2.0000E+01 user(01) User parameter 01.
Tile partition information for Grid 01: 0275x0275x0032 tiling: 004x004
0 1 69 1 69 152352
1 70 138 1 69 152352
2 139 207 1 69 152352
3 208 275 1 69 150144
4 1 69 70 138 152352
5 70 138 70 138 152352
6 139 207 70 138 152352
7 208 275 70 138 150144
8 1 69 139 207 152352
9 70 138 139 207 152352
10 139 207 139 207 152352
11 208 275 139 207 150144
12 1 69 208 275 150144
13 70 138 208 275 150144
14 139 207 208 275 150144
15 208 275 208 275 147968
0 0.50 69.50 0.50 69.50 RHO-points
1 69.50 138.50 0.50 69.50 RHO-points
2 138.50 207.50 0.50 69.50 RHO-points
3 207.50 275.50 0.50 69.50 RHO-points
4 0.50 69.50 69.50 138.50 RHO-points
5 69.50 138.50 69.50 138.50 RHO-points
6 138.50 207.50 69.50 138.50 RHO-points
7 207.50 275.50 69.50 138.50 RHO-points
8 0.50 69.50 138.50 207.50 RHO-points
9 69.50 138.50 138.50 207.50 RHO-points
10 138.50 207.50 138.50 207.50 RHO-points
11 207.50 275.50 138.50 207.50 RHO-points
12 0.50 69.50 207.50 275.50 RHO-points
13 69.50 138.50 207.50 275.50 RHO-points
14 138.50 207.50 207.50 275.50 RHO-points
15 207.50 275.50 207.50 275.50 RHO-points
0 1.00 69.50 0.50 69.50 U-points
1 69.50 138.50 0.50 69.50 U-points
2 138.50 207.50 0.50 69.50 U-points
3 207.50 275.00 0.50 69.50 U-points
4 1.00 69.50 69.50 138.50 U-points
5 69.50 138.50 69.50 138.50 U-points
6 138.50 207.50 69.50 138.50 U-points
7 207.50 275.00 69.50 138.50 U-points
8 1.00 69.50 138.50 207.50 U-points
9 69.50 138.50 138.50 207.50 U-points
10 138.50 207.50 138.50 207.50 U-points
11 207.50 275.00 138.50 207.50 U-points
12 1.00 69.50 207.50 275.50 U-points
13 69.50 138.50 207.50 275.50 U-points
14 138.50 207.50 207.50 275.50 U-points
15 207.50 275.00 207.50 275.50 U-points
0 0.50 69.50 1.00 69.50 V-points
1 69.50 138.50 1.00 69.50 V-points
2 138.50 207.50 1.00 69.50 V-points
3 207.50 275.50 1.00 69.50 V-points
4 0.50 69.50 69.50 138.50 V-points
5 69.50 138.50 69.50 138.50 V-points
6 138.50 207.50 69.50 138.50 V-points
7 207.50 275.50 69.50 138.50 V-points
8 0.50 69.50 138.50 207.50 V-points
9 69.50 138.50 138.50 207.50 V-points
10 138.50 207.50 138.50 207.50 V-points
11 207.50 275.50 138.50 207.50 V-points
12 0.50 69.50 207.50 275.00 V-points
13 69.50 138.50 207.50 275.00 V-points
14 138.50 207.50 207.50 275.00 V-points
15 207.50 275.50 207.50 275.00 V-points
HaloSizeI(1) = 162
HaloSizeJ(1) = 162
TileSide(1) = 75
TileSize(1) = 5625
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
u 1 Radiation Radiation Radiation Radiation
v 1 Radiation Radiation Radiation Radiation
temp 1 Clamped Clamped Clamped Clamped
salt 1 Clamped Clamped Clamped Clamped
tke 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
SSC12 South Sea of China Internal tidal System, 1/12 degree resolution
ANA_NUDGCOEF Analytical spatially varying nudging time-scales.
ANA_SPONGE Analytical enhanced viscosity/diffusion sponge.
MIX_GEO_UV Mixing of momentum along geopotential surfaces.
QCORRECTION Surface net heat flux correction.
TS_SVADVECTION Parabolic splines vertical advection of tracers.
Node # 0 (pid= 10246) is active.
Node # 1 (pid= 10247) is active.
Node # 5 (pid= 10251) is active.
Node # 3 (pid= 10249) is active.
Node # 7 (pid= 10253) is active.
Node # 2 (pid= 10248) is active.
Node # 4 (pid= 10250) is active.
Node # 6 (pid= 10252) is active.
32 0.0000000 0.0000000 0.000 0.000 0.000 0.000
31 -0.0312500 -0.0001116 -0.188 -0.235 -0.800 -1.136
30 -0.0625000 -0.0004504 -0.377 -0.472 -2.279 -3.630
29 -0.0937500 -0.0010281 -0.567 -0.711 -4.473 -7.555
28 -0.1250000 -0.0018650 -0.757 -0.951 -7.442 -13.031
27 -0.1562500 -0.0029903 -0.949 -1.194 -11.272 -20.233
26 -0.1875000 -0.0044433 -1.143 -1.440 -16.083 -29.396
25 -0.2187500 -0.0062746 -1.338 -1.688 -22.025 -40.823
24 -0.2500000 -0.0085478 -1.534 -1.939 -29.287 -54.895
23 -0.2812500 -0.0113419 -1.733 -2.194 -38.107 -72.083
22 -0.3125000 -0.0147533 -1.934 -2.454 -48.773 -92.966
21 -0.3437500 -0.0188997 -2.138 -2.720 -61.637 -118.248
20 -0.3750000 -0.0239231 -2.346 -2.992 -77.122 -148.778
19 -0.4062500 -0.0299948 -2.557 -3.272 -95.741 -185.581
18 -0.4375000 -0.0373204 -2.774 -3.561 -118.110 -229.889
17 -0.4687500 -0.0461459 -2.997 -3.862 -144.963 -283.172
16 -0.5000000 -0.0567646 -3.227 -4.176 -177.177 -347.187
15 -0.5312500 -0.0695249 -3.466 -4.506 -215.794 -424.018
14 -0.5625000 -0.0848395 -3.714 -4.855 -262.047 -516.135
13 -0.5937500 -0.1031943 -3.975 -5.227 -317.391 -626.446
12 -0.6250000 -0.1251587 -4.251 -5.626 -383.526 -758.359
11 -0.6562500 -0.1513952 -4.543 -6.057 -462.434 -915.837
10 -0.6875000 -0.1826680 -4.856 -6.526 -556.399 -1103.456
9 -0.7187500 -0.2198500 -5.192 -7.039 -668.032 -1326.437
8 -0.7500000 -0.2639239 -5.556 -7.604 -800.270 -1590.663
7 -0.7812500 -0.3159778 -5.951 -8.229 -956.366 -1902.645
6 -0.8125000 -0.3771881 -6.384 -8.923 -1139.838 -2269.423
5 -0.8437500 -0.4487876 -6.858 -9.694 -1354.372 -2698.375
4 -0.8750000 -0.5320097 -7.378 -10.553 -1603.654 -3196.882
3 -0.9062500 -0.6280041 -7.950 -11.507 -1891.123 -3771.824
2 -0.9375000 -0.7377147 -8.576 -12.564 -2219.601 -4428.850
1 -0.9687500 -0.8617150 -9.259 -13.728 -2590.801 -5171.391
0 -1.0000000 -1.0000000 -10.000 -15.000 -3004.710 -5999.420
Time Splitting Weights for Grid 01: ndtfast = 72 nfast = 98
1-0.0002697221589845 0.0138888888888889-0.0002697221589845 0.0138888888888889
2-0.0005179738466200 0.0138926350299859-0.0007876960056045 0.0277815239188748
3-0.0007447551074202 0.0138998291111890-0.0015324511130247 0.0416813530300638
4-0.0009500661144945 0.0139101729321254-0.0024825172275192 0.0555915259621891
5-0.0011339073179268 0.0139233682948267-0.0036164245454460 0.0695148942570158
6-0.0012962796525070 0.0139391170075756-0.0049127041979530 0.0834540112645914
7-0.0014371848048139 0.0139571208916382-0.0063498890027669 0.0974111321562297
8-0.0015566255396494 0.0139770817917051-0.0079065145424162 0.1113882139479348
9-0.0016546060858249 0.0139987015908669-0.0095611206282412 0.1253869155388017
10-0.0017311325812999 0.0140216822309478-0.0112922532095411 0.1394085977697495
11-0.0017862135776710 0.0140457257390214-0.0130784667872121 0.1534543235087709
12-0.0018198606040138 0.0140705342609335-0.0148983273912259 0.1675248577697044
13-0.0018320887900766 0.0140958101026559-0.0167304161813025 0.1816206678723603
14-0.0018229175488246 0.0141212557802959-0.0185533337301271 0.1957419236526562
15-0.0017923713183374 0.0141465740795851-0.0203457050484645 0.2098884977322413
16-0.0017404803630569 0.0141714681256731-0.0220861854115213 0.2240599658579144
17-0.0016672816343881 0.0141956414640489-0.0237534670459094 0.2382556073219634
18-0.0015728196906507 0.0142187981534154-0.0253262867365601 0.2524744054753787
19-0.0014571476763831 0.0142406428713411-0.0267834344129432 0.2667150483467199
20-0.0013203283609977 0.0142608810335131-0.0281037627739409 0.2809759293802330
21-0.0011624352367880 0.0142792189274159-0.0292661980107289 0.2952551483076488
22-0.0009835536762878 0.0142953638612601-0.0302497516870167 0.3095505121689089
23-0.0007837821489820 0.0143090243289864-0.0310335338359988 0.3238595364978953
24-0.0005632334973686 0.0143199101921667-0.0315967673333673 0.3381794466900619
25-0.0003220362723731 0.0143277328796301-0.0319188036057405 0.3525071795696921
26-0.0000603361281147 0.0143322056056353-0.0319791397338552 0.3668393851753274
27 0.0002217027239766 0.0143330436074147-0.0317574370098786 0.3811724287827420
28 0.0005238960016901 0.0143299644029150-0.0312335410081885 0.3955023931856571
29 0.0008460377792135 0.0143226880695582-0.0303875032289750 0.4098250812552152
30 0.0011878988549600 0.0143109375448469-0.0291996043740150 0.4241360188000621
31 0.0015492250600437 0.0142944389496391-0.0276503793139713 0.4384304577497012
32 0.0019297355074029 0.0142729219349163-0.0257206438065684 0.4527033796846174
33 0.0023291207815727 0.0142461200528690-0.0233915230249958 0.4669494997374865
34 0.0027470410691043 0.0142137711531249-0.0206444819558915 0.4811632708906114
35 0.0031831242296341 0.0141756178049429-0.0174613577262575 0.4953388886955543
36 0.0036369638075999 0.0141314077461980-0.0138243939186576 0.5094702964417523
37 0.0041081169846063 0.0140808943599814-0.0097162769340513 0.5235511908017337
38 0.0045961024724372 0.0140238371796396-0.0051201744616140 0.5375750279813734
39 0.0051003983467181 0.0139600024230780-0.0000197761148959 0.5515350304044513
40 0.0056204398212250 0.0138891635571513 0.0056006637063291 0.5654241939616026
41 0.0061556169628429 0.0138111018929677 0.0117562806691720 0.5792352958545702
42 0.0067052723471717 0.0137256072129282 0.0184615530163437 0.5929609030674984
43 0.0072686986547809 0.0136324784303286 0.0257302516711247 0.6065933814978269
44 0.0078451362081123 0.0135315242823455 0.0335753878792370 0.6201249057801724
45 0.0084337704490309 0.0134225640572328 0.0420091583282679 0.6335474698374053
46 0.0090337293570240 0.0133054283565518 0.0510428876852919 0.6468528981939571
47 0.0096440808080493 0.0131799598932598 0.0606869684933412 0.6600328580872169
48 0.0102638298740300 0.0130460143264814 0.0709507983673713 0.6730788724136982
49 0.0108919160629993 0.0129034611337865 0.0818427144303705 0.6859823335474847
50 0.0115272104998922 0.0127521845218004 0.0933699249302627 0.6987345180692851
51 0.0121685130479867 0.0125920843759686 0.1055384379782495 0.7113266024452537
52 0.0128145493709923 0.0124230772503021 0.1183529873492417 0.7237496796955558
53 0.0134639679357865 0.0122450973979272 0.1318169552850283 0.7359947770934830
54 0.0141153369558014 0.0120580978432635 0.1459322922408297 0.7480528749367465
55 0.0147671412750559 0.0118620514966551 0.1606994335158856 0.7599149264334017
56 0.0154177791928386 0.0116569523122794 0.1761172127087242 0.7715718787456811
57 0.0160655592290373 0.0114428164901566 0.1921827719377615 0.7830146952358378
58 0.0167086968301175 0.0112196837230866 0.2088914687678790 0.7942343789589245
59 0.0173453110157492 0.0109876184893350 0.2262367797836282 0.8052219974482595
60 0.0179734209660816 0.0107467113918941 0.2442102007497098 0.8159687088401536
61 0.0185909425496662 0.0104970805451429 0.2628011432993760 0.8264657893852965
62 0.0191956847920284 0.0102388730097309 0.2819968280914044 0.8367046623950274
63 0.0197853462848869 0.0099722662765083 0.3017821743762913 0.8466769286715357
64 0.0203575115360218 0.0096974698003293 0.3221396859123131 0.8563743984718649
65 0.0209096472597907 0.0094147265845512 0.3430493331721038 0.8657891250564161
66 0.0214390986082931 0.0091243148170541 0.3644884317803970 0.8749134398734703
67 0.0219430853431833 0.0088265495586056 0.3864315171235803 0.8837399894320759
68 0.0224186979481308 0.0085217844843947 0.4088502150717111 0.8922617739164705
69 0.0228628936819303 0.0082104136795596 0.4317131087536414 0.9004721875960301
70 0.0232724925722585 0.0078928734895328 0.4549856013258999 0.9083650610855628
71 0.0236441733500801 0.0075696444260292 0.4786297746759800 0.9159347055115920
72 0.0239744693247019 0.0072412531295003 0.5026042440006819 0.9231759586410923
73 0.0242597641994746 0.0069082743888794 0.5268640082001566 0.9300842330299717
74 0.0244962878281439 0.0065713332194423 0.5513602960283005 0.9366555662494139
75 0.0246801119118487 0.0062311069996069 0.5760404079401492 0.9428866732490209
76 0.0248071456367686 0.0058883276674979 0.6008475535769178 0.9487750009165188
77 0.0248731312524188 0.0055437839780984 0.6257206848293365 0.9543187848946172
78 0.0248736395905937 0.0051983238218148 0.6505943244199301 0.9595171087164319
79 0.0248040655249589 0.0048528566052787 0.6753983899448891 0.9643699653217107
80 0.0246596233712912 0.0045083556952099 0.7000580133161803 0.9688783210169206
81 0.0244353422283667 0.0041658609261642 0.7244933555445470 0.9730441819430847
82 0.0241260612594974 0.0038264811729924 0.7486194168040444 0.9768706631160772
83 0.0237264249147164 0.0034913969888327 0.7723458417187609 0.9803620601049099
84 0.0232308780936106 0.0031618633094617 0.7955767198123714 0.9835239234143716
85 0.0226336612488020 0.0028392122248282 0.8182103810611735 0.9863631356391998
86 0.0219288054300778 0.0025248558185948 0.8401391864912513 0.9888879914577946
87 0.0211101272691677 0.0022202890765104 0.8612493137604190 0.9911082805343050
88 0.0201712239051703 0.0019270928644386 0.8814205376655893 0.9930353733987436
89 0.0191054678506273 0.0016469369768668 0.9005260055162165 0.9946823103756104
90 0.0179060017982467 0.0013815832567192 0.9184320073144632 0.9960638936323296
91 0.0165657333682728 0.0011328887872991 0.9349977406827360 0.9971967824196287
92 0.0150773297965061 0.0009028091571842 0.9500750704792420 0.9980995915768129
93 0.0134332125629703 0.0006934017988994 0.9635082830422124 0.9987929933757124
94 0.0116255519612283 0.0005068294021915 0.9751338350034406 0.9992998227779039
95 0.0096462616083458 0.0003453634027300 0.9847800966117864 0.9996451861806338
96 0.0074869928955037 0.0002113875470585 0.9922670895072901 0.9998565737276923
97 0.0051391293792585 0.0001074015346210 0.9974062188865486 0.9999639752623133
98 0.0025937811134509 0.0000360247376868 0.9999999999999996 1.0000000000000000
ndtfast, nfast = 72 98 nfast/ndtfast = 1.36111
1.000000000000 1.025151749473 0.512575874736 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.24456
Minimum X-grid spacing, DXmin = 8.31956155E+00 km
Maximum X-grid spacing, DXmax = 9.23851059E+00 km
Minimum Y-grid spacing, DYmin = 8.32752431E+00 km
Maximum Y-grid spacing, DYmax = 9.23803707E+00 km
Minimum Z-grid spacing, DZmin = 1.87946450E-01 m
Maximum Z-grid spacing, DZmax = 8.28028490E+02 m
Minimum barotropic Courant Number = 7.65400315E-03
Maximum barotropic Courant Number = 2.03630778E-01
Maximum Coriolis Courant Number = 2.30020631E-02
NLM: GET_STATE - Read state initial conditions, t = 834 00:00:00
(Grid 01, File: ssc12_rst.nc, Rec=0001, Index=1)
- free-surface
(Min = -1.68187836E+00 Max = 7.37968147E-01)
(Min = -1.18573319E+00 Max = 1.04792744E+00)
(Min = -7.39885390E-01 Max = 1.14603496E+00)
(Min = -2.14761646E+00 Max = 2.94321512E+00)
(Min = -3.85626957E+00 Max = 1.83796010E+00)
(Min = -1.72992955E+00 Max = 3.28646731E+01)
- salinity
(Min = 3.24795329E+01 Max = 3.50028380E+01)
- vertical viscosity coefficient
(Min = 0.00000000E+00 Max = 3.20311947E+02)
- temperature vertical diffusion coefficient
(Min = 0.00000000E+00 Max = 4.33677575E+02)
- salinity vertical diffusion coefficient
GET_2DFLD - surface u-momentum stress, t = 105 00:00:00
(Rec=0000004, Index=1, File: ssc12_frc.nc)
(Min = -6.20676099E-05 Max = -1.88522345E-06)
GET_2DFLD - surface v-momentum stress, t = 105 00:00:00
(Min = -9.36735938E-05 Max = 2.28887546E-05)
GET_2DFLD - solar shortwave radiation flux, t = 105 00:00:00
(Min = 4.67014091E-05 Max = 7.53452299E-05)
GET_2DFLD - surface net heat flux, t = 105 00:00:00
(Min = -1.61152481E-05 Max = 3.52080195E-05)
GET_2DFLD - sea surface temperature climatology, t = 105 00:00:00
(Min = 1.78500004E+01 Max = 3.01499996E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 105 00:00:00
(Min = -1.08742870E-05 Max = -5.57647613E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 105 00:00:00
(Min = -5.87691981E-08 Max = 5.38352896E-08)
GET_NGFLD - free-surface western boundary condition, t = 105 00:00:00
(Rec=0000004, Index=2, File: ssc12_bry.nc)
GET_NGFLD - free-surface eastern boundary condition, t = 105 00:00:00
GET_NGFLD - free-surface southern boundary condition, t = 105 00:00:00
GET_NGFLD - free-surface northern boundary condition, t = 105 00:00:00
GET_NGFLD - 2D u-momentum western boundary condition, t = 105 00:00:00
GET_NGFLD - 2D v-momentum western boundary condition, t = 105 00:00:00
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 105 00:00:00
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 105 00:00:00
GET_NGFLD - 2D u-momentum southern boundary condition, t = 105 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 105 00:00:00
GET_NGFLD - 2D u-momentum northern boundary condition, t = 105 00:00:00
GET_NGFLD - 2D v-momentum northern boundary condition, t = 105 00:00:00
GET_NGFLD - temperature western boundary condition, t = 105 00:00:00
(Min = 2.58318077E+01 Max = 2.91239976E+01)
GET_NGFLD - salinity western boundary condition, t = 105 00:00:00
(Min = 3.31880350E+01 Max = 3.39559378E+01)
GET_NGFLD - temperature eastern boundary condition, t = 105 00:00:00
(Min = 1.14744140E+00 Max = 2.87537389E+01)
GET_NGFLD - salinity eastern boundary condition, t = 105 00:00:00
(Min = 3.39671503E+01 Max = 3.49988728E+01)
GET_NGFLD - temperature southern boundary condition, t = 105 00:00:00
(Min = 2.19736436E+00 Max = 2.94572413E+01)
GET_NGFLD - salinity southern boundary condition, t = 105 00:00:00
(Min = 3.23207594E+01 Max = 3.50003110E+01)
GET_NGFLD - temperature northern boundary condition, t = 105 00:00:00
(Min = 3.08338799E+00 Max = 2.33881566E+01)
GET_NGFLD - salinity northern boundary condition, t = 105 00:00:00
(Min = 3.27818864E+01 Max = 3.48521938E+01)
GET_3DFLD - potential temperature climatology, t = 105 00:00:00
(Rec=0000004, Index=1, File: ssc12_clm.nc)
(Min = 1.12952750E+00 Max = 2.93347012E+01)
GET_3DFLD - salinity climatology, t = 105 00:00:00
(Min = 3.23027001E+01 Max = 3.50098615E+01)
Maximum grid stiffness ratios: rx0 = 1.470108E-01 (Beckmann and Haidvogel)
rx1 = 2.393509E+00 (Haney)
Initial basin volumes: TotVolume = 8.9740602851E+15 m3
MinVolume = 1.3390901769E+07 m3
MaxVolume = 7.0378199510E+10 m3
Max/Min = 5.2556728981E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00200161 - 00424800)
GET_2DFLD - surface u-momentum stress, t = 135 00:00:00
(Rec=0000005, Index=2, File: ssc12_frc.nc)
(Min = -3.82850855E-05 Max = 1.04670723E-05)
GET_2DFLD - surface v-momentum stress, t = 135 00:00:00
(Min = -4.57473183E-05 Max = 2.86107910E-05)
GET_2DFLD - solar shortwave radiation flux, t = 135 00:00:00
(Min = 5.37974143E-05 Max = 7.05541445E-05)
GET_2DFLD - surface net heat flux, t = 135 00:00:00
(Min = 5.89348978E-06 Max = 3.80686309E-05)
GET_2DFLD - sea surface temperature climatology, t = 135 00:00:00
(Min = 2.20245279E+01 Max = 3.10499992E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 135 00:00:00
(Min = -1.03150482E-05 Max = -5.28865044E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 135 00:00:00
(Min = -8.59949345E-08 Max = 3.07742399E-08)
GET_NGFLD - free-surface western boundary condition, t = 135 00:00:00
(Rec=0000005, Index=1, File: ssc12_bry.nc)
GET_NGFLD - free-surface eastern boundary condition, t = 135 00:00:00
GET_NGFLD - free-surface southern boundary condition, t = 135 00:00:00
GET_NGFLD - free-surface northern boundary condition, t = 135 00:00:00
GET_NGFLD - 2D u-momentum western boundary condition, t = 135 00:00:00
GET_NGFLD - 2D v-momentum western boundary condition, t = 135 00:00:00
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 135 00:00:00
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 135 00:00:00
GET_NGFLD - 2D u-momentum southern boundary condition, t = 135 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 135 00:00:00
GET_NGFLD - 2D u-momentum northern boundary condition, t = 135 00:00:00
GET_NGFLD - 2D v-momentum northern boundary condition, t = 135 00:00:00
GET_NGFLD - temperature western boundary condition, t = 135 00:00:00
(Min = 2.42429398E+01 Max = 3.00986811E+01)
GET_NGFLD - salinity western boundary condition, t = 135 00:00:00
(Min = 3.28348526E+01 Max = 3.40548760E+01)
GET_NGFLD - temperature eastern boundary condition, t = 135 00:00:00
(Min = 1.14744140E+00 Max = 2.92940963E+01)
GET_NGFLD - salinity eastern boundary condition, t = 135 00:00:00
(Min = 3.36917025E+01 Max = 3.50467227E+01)
GET_NGFLD - temperature southern boundary condition, t = 135 00:00:00
(Min = 2.19736436E+00 Max = 3.01042090E+01)
GET_NGFLD - salinity southern boundary condition, t = 135 00:00:00
(Min = 3.28487554E+01 Max = 3.50486625E+01)
GET_NGFLD - temperature northern boundary condition, t = 135 00:00:00
(Min = 3.08338799E+00 Max = 2.51038226E+01)
GET_NGFLD - salinity northern boundary condition, t = 135 00:00:00
(Min = 3.37117703E+01 Max = 3.48547595E+01)
GET_3DFLD - potential temperature climatology, t = 135 00:00:00
(Rec=0000005, Index=2, File: ssc12_clm.nc)
(Min = 1.12952750E+00 Max = 3.01322845E+01)
GET_3DFLD - salinity climatology, t = 135 00:00:00
(Min = 3.27405017E+01 Max = 3.50487220E+01)
200160 834 00:00:00 2.709243E-02 1.908407E+04 1.908410E+04 9.009309E+15
(275,250,27) 1.116631E-01 1.106118E-01 0.000000E+00 3.738429E+00
DEF_HIS - inquiring history file, Grid 01: ssc12_his_0014.nc
DEF_AVG - inquiring average file, Grid 01: ssc12_avg_0000.nc
200161 834 00:06:00 2.709387E-02 1.908407E+04 1.908410E+04 9.009309E+15
(274,250,26) 8.662358E-02 9.662954E-02 2.610078E-01 3.738679E+00
(omit)*********(omit)*****
205303 855 10:18:00 3.526154E-02 1.908405E+04 1.908408E+04 9.009412E+15
(275,253,12) 2.359342E-02 4.247913E-02 5.696632E-01 2.826756E+00
205304 855 10:24:00 3.527035E-02 1.908405E+04 1.908408E+04 9.009412E+15
(275,253,12) 2.475272E-02 4.158159E-02 5.812245E-01 2.823614E+00
205305 855 10:30:00 3.527900E-02 1.908405E+04 1.908408E+04 9.009412E+15
(275,253,12) 2.591119E-02 4.067038E-02 5.919800E-01 2.820217E+00
205306 855 10:36:00 3.528818E-02 1.908405E+04 1.908408E+04 9.009412E+15
(275,253,12) 2.706134E-02 3.970224E-02 6.024620E-01 2.816664E+00
205307 855 10:42:00 3.529777E-02 1.908405E+04 1.908408E+04 9.009411E+15
(275,253,12) 2.819525E-02 3.865272E-02 6.125581E-01 2.817170E+00
205308 855 10:48:00 3.530754E-02 1.908405E+04 1.908408E+04 9.009411E+15
(275,253,12) 2.927960E-02 3.753774E-02 6.226051E-01 2.826378E+00
205309 855 10:54:00 3.531776E-02 1.908405E+04 1.908408E+04 9.009411E+15
(275,253,12) 2.995494E-02 3.636968E-02 6.325719E-01 2.835087E+00
205310 855 11:00:00 3.532825E-02 1.908405E+04 1.908408E+04 9.009411E+15
(275,253,12) 3.099315E-02 3.516521E-02 6.422409E-01 2.843332E+00
205311 855 11:06:00 3.533900E-02 1.908405E+04 1.908408E+04 9.009410E+15
(275,253,12) 3.203498E-02 3.392989E-02 6.524234E-01 2.851146E+00
205312 855 11:12:00 3.534990E-02 1.908405E+04 1.908409E+04 9.009410E+15
(275,253,12) 3.305723E-02 3.272617E-02 6.627129E-01 2.858856E+00
205313 855 11:18:00 3.536101E-02 1.908405E+04 1.908409E+04 9.009410E+15
(275,253,12) 3.405883E-02 3.158176E-02 6.730664E-01 2.866121E+00
205314 855 11:24:00 3.537232E-02 1.908405E+04 1.908409E+04 9.009410E+15
(275,253,12) 3.503133E-02 3.045003E-02 6.835305E-01 2.873413E+00
205315 855 11:30:00 3.538395E-02 1.908405E+04 1.908409E+04 9.009409E+15
(275,253,12) 3.595725E-02 2.926428E-02 6.942394E-01 2.880557E+00
205316 855 11:36:00 3.539564E-02 1.908405E+04 1.908409E+04 9.009409E+15
(275,253,12) 3.683159E-02 2.799544E-02 7.049749E-01 2.889096E+00
205317 855 11:42:00 3.540743E-02 1.908405E+04 1.908409E+04 9.009409E+15
(275,253,12) 3.763728E-02 2.665123E-02 7.154729E-01 2.915840E+00
205318 855 11:48:00 3.541921E-02 1.908405E+04 1.908409E+04 9.009409E+15
(275,253,12) 3.837849E-02 2.526051E-02 7.255248E-01 2.942315E+00
205319 855 11:54:00 3.543090E-02 1.908405E+04 1.908409E+04 9.009408E+15
(275,253,12) 3.903485E-02 2.383714E-02 7.352442E-01 2.968751E+00
205320 855 12:00:00 3.544240E-02 1.908405E+04 1.908409E+04 9.009408E+15
(275,253,12) 3.959201E-02 2.245813E-02 7.445034E-01 2.994961E+00
205321 855 12:06:00 3.545381E-02 1.908405E+04 1.908409E+04 9.009408E+15
(275,253,12) 4.006172E-02 2.117694E-02 7.530285E-01 3.020709E+00
205322 855 12:12:00 3.546518E-02 1.908405E+04 1.908409E+04 9.009408E+15
(275,253,12) 4.041660E-02 1.997603E-02 7.608261E-01 3.046144E+00
205323 855 12:18:00 3.547637E-02 1.908405E+04 1.908409E+04 9.009408E+15
(275,253,13) 4.348721E-02 1.939974E-02 7.636952E-01 3.071278E+00
205324 855 12:24:00 3.548745E-02 1.908405E+04 1.908409E+04 9.009407E+15
(275,253,13) 4.360021E-02 1.811768E-02 7.705619E-01 3.095744E+00
205325 855 12:30:00 3.549807E-02 1.908405E+04 1.908409E+04 9.009407E+15
(275,253,13) 4.368998E-02 1.697693E-02 7.760241E-01 3.119359E+00
205326 855 12:36:00 3.550857E-02 1.908405E+04 1.908409E+04 9.009407E+15
(275,253,13) 4.373112E-02 1.595639E-02 7.796340E-01 3.142272E+00
205327 855 12:42:00 3.551871E-02 1.908405E+04 1.908409E+04 9.009407E+15
(275,253,13) 4.376087E-02 1.508760E-02 7.820757E-01 3.164540E+00
205328 855 12:48:00 3.552841E-02 1.908405E+04 1.908409E+04 9.009406E+15
(275,253,13) 4.377394E-02 1.438975E-02 7.830106E-01 3.186193E+00
205329 855 12:54:00 3.553786E-02 1.908405E+04 1.908409E+04 9.009406E+15
(275,253,13) 4.373087E-02 1.380425E-02 7.824235E-01 3.207101E+00
205330 855 13:00:00 3.554692E-02 1.908405E+04 1.908409E+04 9.009406E+15
(275,253,13) 4.363620E-02 1.326950E-02 7.805699E-01 3.227246E+00
205331 855 13:06:00 3.555572E-02 1.908405E+04 1.908409E+04 9.009406E+15
(275,253,13) 4.347621E-02 1.279885E-02 7.771226E-01 3.246639E+00
205332 855 13:12:00 3.556413E-02 1.908405E+04 1.908409E+04 9.009405E+15
(275,251,11) 8.687961E-03 5.868544E-02 7.606430E-01 3.265299E+00
205333 855 13:18:00 3.557216E-02 1.908405E+04 1.908409E+04 9.009405E+15
(275,251,11) 7.655248E-03 5.796280E-02 7.986381E-01 3.283115E+00
205334 855 13:24:00 3.557991E-02 1.908405E+04 1.908409E+04 9.009405E+15
(275,251,12) 7.625260E-03 5.806786E-02 8.368371E-01 3.299912E+00
205335 855 13:30:00 3.558742E-02 1.908405E+04 1.908409E+04 9.009405E+15
(275,251,12) 6.596264E-03 5.734744E-02 8.772965E-01 3.315893E+00
205336 855 13:36:00 3.559463E-02 1.908405E+04 1.908409E+04 9.009405E+15
(275,251,12) 5.537195E-03 5.650501E-02 9.163505E-01 3.331017E+00
205337 855 13:42:00 3.560156E-02 1.908405E+04 1.908409E+04 9.009404E+15
(275,251,12) 4.468625E-03 5.553002E-02 9.529627E-01 3.345418E+00
205338 855 13:48:00 3.560823E-02 1.908405E+04 1.908409E+04 9.009404E+15
(275,251,13) 3.995803E-03 5.505565E-02 9.875739E-01 3.360165E+00
205339 855 13:54:00 3.561458E-02 1.908405E+04 1.908409E+04 9.009404E+15
(275,251,13) 3.121549E-03 5.403858E-02 1.024790E+00 3.375139E+00
205340 855 14:00:00 3.562080E-02 1.908405E+04 1.908409E+04 9.009404E+15
(275,251,13) 2.427986E-03 5.308032E-02 1.060749E+00 3.389437E+00
205341 855 14:06:00 3.562679E-02 1.908405E+04 1.908409E+04 9.009403E+15
(275,251,13) 1.558878E-03 5.220892E-02 1.093671E+00 3.403209E+00
205342 855 14:12:00 3.563262E-02 1.908405E+04 1.908409E+04 9.009403E+15
(275,251,14) 9.068599E-04 5.085986E-02 1.123449E+00 3.417124E+00
205343 855 14:18:00 3.563828E-02 1.908405E+04 1.908409E+04 9.009403E+15
(275,251,14) 6.136644E-04 4.993357E-02 1.155907E+00 3.431265E+00
205344 855 14:24:00 3.564350E-02 1.908405E+04 1.908409E+04 9.009403E+15
(275,251,14) 8.381187E-05 4.897187E-02 1.184329E+00 3.445476E+00
205345 855 14:30:00 3.564900E-02 1.908405E+04 1.908409E+04 9.009402E+15
(275,251,14) 1.176028E-03 4.829006E-02 1.205966E+00 3.460747E+00
205346 855 14:36:00 3.565424E-02 1.908405E+04 1.908409E+04 9.009402E+15
(275,251,15) 3.141366E-03 4.644630E-02 1.233495E+00 3.475221E+00
205347 855 14:42:00 3.565942E-02 1.908406E+04 1.908409E+04 9.009402E+15
(275,251,15) 2.754590E-03 4.529407E-02 1.254921E+00 3.490049E+00
205348 855 14:48:00 3.566471E-02 1.908406E+04 1.908409E+04 9.009402E+15
(275,251,15) 3.662880E-03 4.342926E-02 1.270466E+00 3.507288E+00
205349 855 14:54:00 3.567121E-02 1.908405E+04 1.908409E+04 9.009401E+15
(275,251,16) 5.686473E-03 4.105372E-02 1.295611E+00 3.530932E+00
205350 855 15:00:00 3.568281E-02 1.908405E+04 1.908409E+04 9.009401E+15
(275,251,16) 9.154510E-03 3.918325E-02 1.337819E+00 3.707565E+00
205351 855 15:06:00 3.572494E-02 1.908405E+04 1.908409E+04 9.009400E+15
(275,251,17) 2.925438E-02 3.822207E-02 1.486118E+00 4.974890E+00
205352 855 15:12:00 3.620864E-02 2.626193E+04 2.626196E+04 9.009397E+15
(275,251,17) 1.398685E-01 3.509188E-02 2.106421E+00 1.220272E+01
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000003
Node # 0 CPU: 1878.147
Node # 3 CPU: 1895.773
Node # 1 CPU: 1895.909
Node # 7 CPU: 1896.513
Node # 2 CPU: 1896.583
Node # 4 CPU: 1896.520
Node # 5 CPU: 1896.442
Node # 6 CPU: 1896.219
Node # 9 CPU: 1896.308
Node # 10 CPU: 1896.471
Node # 12 CPU: 1896.603
Node # 13 CPU: 1896.665
Node # 14 CPU: 1896.622
Total: 30322.101
Node # 15 CPU: 1896.529
Allocation and array initialization .............. 1.099 ( 0.0036 %)
Node # 8 CPU: 1894.255
Ocean state initialization ....................... 0.299 ( 0.0010 %)
Reading of input data ............................ 18.717 ( 0.0617 %)
Processing of input data ......................... 531.208 ( 1.7519 %)
Processing of output time averaged data .......... 0.400 ( 0.0013 %)
Computation of vertical boundary conditions ...... 19.930 ( 0.0657 %)
Computation of global information integrals ...... 371.286 ( 1.2245 %)
Writing of output data ........................... 336.025 ( 1.1082 %)
Model 2D kernel .................................. 14348.311 (47.3196 %)
2D/3D coupling, vertical metrics ................. 788.128 ( 2.5992 %)
Omega vertical velocity .......................... 493.266 ( 1.6268 %)
Equation of state for seawater ................... 660.155 ( 2.1771 %)
My2.5 vertical mixing parameterization ........... 3560.626 (11.7427 %)
Node # 11 CPU: 1896.546
3D equations right-side terms .................... 760.302 ( 2.5074 %)
3D equations predictor step ...................... 1985.028 ( 6.5465 %)
Pressure gradient ................................ 890.511 ( 2.9368 %)
Harmonic mixing of tracers, geopotentials ........ 856.133 ( 2.8235 %)
Harmonic stress tensor, geopotentials ............ 1612.028 ( 5.3163 %)
Corrector time-step for 3D momentum .............. 1045.567 ( 3.4482 %)
Corrector time-step for tracers .................. 1509.167 ( 4.9771 %)
Total: 29788.185 98.2392
Message Passage: 2D halo exchanges ............... 1790.132 ( 5.9037 %)
Message Passage: 3D halo exchanges ............... 817.576 ( 2.6963 %)
Message Passage: 4D halo exchanges ............... 200.821 ( 0.6623 %)
Message Passage: data broadcast .................. 329.280 ( 1.0859 %)
Message Passage: data reduction .................. 21.304 ( 0.0703 %)
Message Passage: data gathering .................. 34.376 ( 0.1134 %)
Message Passage: data scattering.................. 11.133 ( 0.0367 %)
Total: 3204.622 10.5686
All percentages are with respect to total time = 30322.101
number of time records written in HISTORY file = 00000003
number of time records written in RESTART file = 00000008
Analytical header files used:
/vol/home/student/lshw/roms/MYPROJECT/Functionals/ana_btflux.h
/vol/home/student/lshw/roms/MYPROJECT/Functionals/ana_sponge.h
ROMS/TOMS: DONE... Sunday - June 12, 2016 - 1:04:46 PM
Re: MAIN: Abnormal termination: BLOWUP.
#19 Unread post by kate »
No need to double post.
