blowing up with ubar and vbar with min and max as NaNs
fagundesmo
#1 Unread post by fagundesmo »
my model is blowing up and, therefore, I was wondering if it has anything to do with ubar and vbar having min and max as NAN values. If so, how could I fix this problem since I've checked my ubar e vbar and both have values except in the borders which are masked with NAN values.
Monday - May 30, 2016 - 3:10:23 PM
Atlantic Equatorial
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/local/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script :
SVN Revision :
Local Root : /models/roms
Header Dir : /home/roms/projects_roms/matheus/atleq/benchmark/proc2
Header file : atleq.h
Analytical Dir: /home/roms/projects_roms/matheus/atleq/benchmark/proc2/ROMS/Functionals
Resolution, Grid 01: 0903x0321x050, Parallel Nodes: 2, Tiling: 002x001
10800 ntimes Number of timesteps for 3-D equations.
1800.000 dt Timestep size (s) for 3-D equations.
360 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
5400 nHIS Number of timesteps between the writing fields
into history file.
360 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
360 nAVG Number of timesteps between the writing of
5400 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
1.0500E-06 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
4.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E+00 theta_b S-coordinate bottom control parameter.
300.000 Tcline S-coordinate surface/bottom layer width (m) used
29222.500 dstart Time-stamp assigned to model initialization (days).
19000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
6.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
6.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)
3.0000E+01 M2nudg Nudging/relaxation time scale (days)
3.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
5.000 T0 Background potential temperature (C) constant.
Output Restart File: river_rst.nc
Output History File: atleq_his.nc
Prefix for Averages Files: atleq_avg
Input Grid File: /home/roms/DATA/grade/Atleq112.nc
Input Nonlinear Initial File: /home/roms/DATA/oceano/roms_ini_SODA_Y1980M1D3.nc
Input Forcing File 01: /home/roms/DATA/atmosfera/CFSR-blk-TSA-roms-prate.nc
Input Forcing File 02: /home/roms/DATA/atmosfera/CFSR-blk-TSA-roms-pressfc.nc
Input Forcing File 03: /home/roms/DATA/atmosfera/CFSR-blk-TSA-roms-q2m.nc
Input Forcing File 04: /home/roms/DATA/atmosfera/CFSR-blk-TSA-roms-tmp2m.nc
Input Forcing File 05: /home/roms/DATA/atmosfera/CFSR-blk-TSA-roms-uwnd10m.nc
Input Forcing File 06: /home/roms/DATA/atmosfera/CFSR-blk-TSA-roms-vwnd10m.nc
Input Boundary File: /home/roms/DATA/oceano/Atleq_bry.nc
Tile partition information for Grid 01: 0903x0321x0050 tiling: 002x001
tile Istr Iend Jstr Jend Npts
0 1 452 1 321 7254600
1 453 903 1 321 7238550
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 452.50 0.50 321.50 RHO-points
1 452.50 903.50 0.50 321.50 RHO-points
0 1.00 452.50 0.50 321.50 U-points
1 452.50 903.00 0.50 321.50 U-points
0 0.50 452.50 1.00 321.00 V-points
1 452.50 903.50 1.00 321.00 V-points
HaloSizeI(1) = 926
HaloSizeJ(1) = 662
TileSide(1) = 457
TileSize(1) = 148525
zeta 1 Chapman Imp Chapman Imp Closed Chapman Imp
ubar 1 Flather Flather Closed Flather
vbar 1 Flather Flather Closed Flather
u 1 Rad + Nud Rad + Nud Closed Rad + Nud
v 1 Rad + Nud Rad + Nud Closed Rad + Nud
temp 1 Rad + Nud Rad + Nud Closed Rad + Nud
salt 1 Rad + Nud Rad + Nud Closed Rad + Nud
tke 1 Radiation Radiation Closed Radiation
ATLEQ Atlantic Equatorial
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_LBC_ATT Not checking NetCDF global attribute NLM_LBC during restart.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
VISC_3DCOEF Horizontal, time-dependent 3D viscosity coefficient.
Process Information:
Node # 0 (pid= 45510) is active.
Node # 1 (pid= 45511) is active.
50 0.0000000 0.0000000 0.000 0.000 0.000 0.000
49 -0.0200000 -0.0004958 -0.098 -3.074 -6.466 -7.999
48 -0.0400000 -0.0019848 -0.197 -6.298 -15.151 -20.683
47 -0.0600000 -0.0044722 -0.295 -9.671 -26.067 -38.076
46 -0.0800000 -0.0079665 -0.394 -13.195 -39.233 -60.219
45 -0.1000000 -0.0124794 -0.493 -16.872 -54.675 -87.167
44 -0.1200000 -0.0180260 -0.592 -20.704 -72.428 -118.991
43 -0.1400000 -0.0246241 -0.691 -24.694 -92.529 -155.774
42 -0.1600000 -0.0322941 -0.790 -28.844 -115.027 -197.614
41 -0.1800000 -0.0410591 -0.889 -33.159 -139.971 -244.618
40 -0.2000000 -0.0509440 -0.988 -37.642 -167.417 -296.906
39 -0.2200000 -0.0619756 -1.087 -42.296 -197.426 -354.602
38 -0.2400000 -0.0741814 -1.186 -47.127 -230.059 -417.837
37 -0.2600000 -0.0875898 -1.286 -52.138 -265.380 -486.744
36 -0.2800000 -0.1022287 -1.385 -57.334 -303.450 -561.456
35 -0.3000000 -0.1181254 -1.485 -62.719 -344.330 -642.101
34 -0.3200000 -0.1353048 -1.585 -68.296 -388.078 -728.796
33 -0.3400000 -0.1537894 -1.685 -74.068 -434.741 -821.648
32 -0.3600000 -0.1735973 -1.785 -80.040 -484.362 -920.742
31 -0.3800000 -0.1947414 -1.885 -86.211 -536.968 -1026.138
30 -0.4000000 -0.2172277 -1.985 -92.584 -592.574 -1137.866
29 -0.4200000 -0.2410540 -2.085 -99.158 -651.175 -1255.915
28 -0.4400000 -0.2662085 -2.186 -105.931 -712.743 -1380.229
27 -0.4600000 -0.2926672 -2.286 -112.900 -777.226 -1510.694
26 -0.4800000 -0.3203933 -2.387 -120.059 -844.541 -1647.138
25 -0.5000000 -0.3493346 -2.488 -127.400 -914.571 -1789.314
24 -0.5200000 -0.3794221 -2.588 -134.913 -987.163 -1936.897
23 -0.5400000 -0.4105683 -2.689 -142.585 -1062.120 -2089.473
22 -0.5600000 -0.4426658 -2.790 -150.400 -1139.203 -2246.537
21 -0.5800000 -0.4755864 -2.891 -158.338 -1218.126 -2407.483
20 -0.6000000 -0.5091798 -2.993 -166.377 -1298.552 -2571.603
19 -0.6200000 -0.5432741 -3.094 -174.491 -1380.097 -2738.085
18 -0.6400000 -0.5776758 -3.195 -182.651 -1462.329 -2906.018
17 -0.6600000 -0.6121712 -3.296 -190.826 -1544.771 -3074.392
16 -0.6800000 -0.6465284 -3.397 -198.979 -1626.904 -3242.115
15 -0.7000000 -0.6805007 -3.498 -207.075 -1708.177 -3408.022
14 -0.7200000 -0.7138307 -3.599 -215.075 -1788.014 -3570.900
13 -0.7400000 -0.7462556 -3.701 -222.938 -1865.829 -3729.508
12 -0.7600000 -0.7775137 -3.801 -230.627 -1941.036 -3882.612
11 -0.7800000 -0.8073512 -3.902 -238.103 -2013.069 -4029.015
10 -0.8000000 -0.8355308 -4.003 -245.330 -2081.398 -4167.598
9 -0.8200000 -0.8618395 -4.103 -252.276 -2145.545 -4297.356
8 -0.8400000 -0.8860972 -4.204 -258.915 -2205.109 -4417.440
7 -0.8600000 -0.9081638 -4.304 -265.225 -2259.778 -4527.188
6 -0.8800000 -0.9279462 -4.404 -271.192 -2309.341 -4626.161
5 -0.9000000 -0.9454027 -4.504 -276.810 -2353.707 -4714.163
4 -0.9200000 -0.9605452 -4.603 -282.082 -2392.903 -4791.251
3 -0.9400000 -0.9734393 -4.703 -287.016 -2427.074 -4857.733
2 -0.9600000 -0.9842008 -4.802 -291.630 -2456.480 -4914.155
1 -0.9800000 -0.9929894 -4.901 -295.948 -2481.476 -4961.271
0 -1.0000000 -1.0000000 -5.000 -300.000 -2502.500 -5000.000
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 8.96492125E+00 km
Maximum X-grid spacing, DXmax = 9.27662045E+00 km
Minimum Y-grid spacing, DYmin = 8.99525215E+00 km
Maximum Y-grid spacing, DYmax = 9.30386323E+00 km
Minimum Z-grid spacing, DZmin = 9.84012919E-02 m
Maximum Z-grid spacing, DZmax = 1.68374265E+02 m
Minimum barotropic Courant Number = 6.39676115E-02
Maximum barotropic Courant Number = 2.09270051E+00
Maximum Coriolis Courant Number = 6.76708721E-02
Horizontal mixing scaled by grid size, GRDMAX = 9.29023185E+00 km
Minimum horizontal viscosity coefficient = 7.48339491E+01 m2/s
Maximum horizontal viscosity coefficient = 7.74185988E+01 m2/s
NLM: GET_STATE - Read state initial conditions, t = 29222 12:00:00
(Grid 01, File: roms_ini_SODA_Y1980M1D3.nc, Rec=0001, Index=1)
- free-surface
(Min = -3.70100817E-01 Max = 2.66125192E-01)
(Min = NaN Max = NaN)
- u-momentum component
(Min = -1.19349110E+00 Max = 1.48280624E+00)
- v-momentum component
(Min = -9.64514274E-01 Max = 1.18053425E+00)
- potential temperature
(Min = 4.36085150E-01 Max = 2.88065167E+01)
- salinity
(Min = 3.01144427E+01 Max = 3.71944949E+01)
GET_NGFLD - free-surface western boundary condition, t = 29222 12:00:00
(Rec=0000002, Index=2, File: Atleq_bry.nc)
(Tmin= 29217.5000 Tmax= 30212.5000)
(Min = -7.63329480E-02 Max = 0.00000000E+00)
GET_NGFLD - free-surface southern boundary condition, t = 29222 12:00:00
(Min = -2.06996103E-01 Max = 2.28605348E-01)
GET_NGFLD - free-surface northern boundary condition, t = 29222 12:00:00
(Min = -1.79728888E-01 Max = 5.65656418E-03)
GET_NGFLD - 2D u-momentum western boundary condition, t = 29222 12:00:00
(Min = -1.24101975E-01 Max = -5.94207262E-03)
GET_NGFLD - 2D v-momentum western boundary condition, t = 29222 12:00:00
(Min = 2.49592586E-04 Max = 6.28793664E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 29222 12:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 29222 12:00:00
GET_NGFLD - 2D u-momentum northern boundary condition, t = 29222 12:00:00
GET_NGFLD - 2D v-momentum northern boundary condition, t = 29222 12:00:00
GET_NGFLD - 3D u-momentum western boundary condition, t = 29222 12:00:00
(Min = -2.99767774E-01 Max = 6.75020457E-02)
GET_NGFLD - 3D v-momentum western boundary condition, t = 29222 12:00:00
(Min = -2.89718544E-02 Max = 2.41981859E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 29222 12:00:00
(Min = -2.42197277E-01 Max = 1.57265507E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 29222 12:00:00
(Min = -2.45226682E-01 Max = 2.45044268E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 29222 12:00:00
(Min = -2.69608758E-01 Max = 2.43040919E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 29222 12:00:00
(Min = -2.41488585E-01 Max = 2.80939748E-01)
GET_NGFLD - temperature western boundary condition, t = 29222 12:00:00
(Min = 0.00000000E+00 Max = 2.72299778E+01)
GET_NGFLD - salinity western boundary condition, t = 29222 12:00:00
(Min = 0.00000000E+00 Max = 3.67487356E+01)
GET_NGFLD - temperature southern boundary condition, t = 29222 12:00:00
(Min = 0.00000000E+00 Max = 2.75865267E+01)
GET_NGFLD - salinity southern boundary condition, t = 29222 12:00:00
(Min = 0.00000000E+00 Max = 3.70214136E+01)
GET_NGFLD - temperature northern boundary condition, t = 29222 12:00:00
(Min = 0.00000000E+00 Max = 2.79680253E+01)
GET_NGFLD - salinity northern boundary condition, t = 29222 12:00:00
(Min = 0.00000000E+00 Max = 3.69891889E+01)
Maximum grid stiffness ratios: rx0 = 2.100000E-01 (Beckmann and Haidvogel)
rx1 = 5.306240E+01 (Haney)
Initial basin volumes: TotVolume = 6.6573679764E+16 m3
MinVolume = 8.1416838766E+06 m3
MaxVolume = 1.4532114761E+10 m3
Max/Min = 1.7849028507E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00010800)
GET_NGFLD - free-surface western boundary condition, t = 29227 12:00:00
(Rec=0000003, Index=1, File: Atleq_bry.nc)
(Min = -1.15312136E-01 Max = 0.00000000E+00)
GET_NGFLD - free-surface southern boundary condition, t = 29227 12:00:00
(Min = -2.03842956E-01 Max = 2.32551762E-01)
GET_NGFLD - free-surface northern boundary condition, t = 29227 12:00:00
(Min = -1.87306332E-01 Max = 1.55312279E-02)
GET_NGFLD - 2D u-momentum western boundary condition, t = 29227 12:00:00
(Min = -1.95107994E-01 Max = -1.06365148E-02)
GET_NGFLD - 2D v-momentum western boundary condition, t = 29227 12:00:00
(Min = 3.16437822E-04 Max = 1.10563738E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 29227 12:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 29227 12:00:00
GET_NGFLD - 2D u-momentum northern boundary condition, t = 29227 12:00:00
GET_NGFLD - 2D v-momentum northern boundary condition, t = 29227 12:00:00
GET_NGFLD - 3D u-momentum western boundary condition, t = 29227 12:00:00
(Min = -4.21467055E-01 Max = 1.67933650E-02)
GET_NGFLD - 3D v-momentum western boundary condition, t = 29227 12:00:00
(Min = -1.64072255E-02 Max = 2.86393429E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 29227 12:00:00
(Min = -2.25998970E-01 Max = 1.48051707E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 29227 12:00:00
(Min = -2.29652536E-01 Max = 2.65987746E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 29227 12:00:00
(Min = -2.85973209E-01 Max = 3.60502392E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 29227 12:00:00
(Min = -1.88582333E-01 Max = 2.68122847E-01)
GET_NGFLD - temperature western boundary condition, t = 29227 12:00:00
(Min = 0.00000000E+00 Max = 2.72902457E+01)
GET_NGFLD - salinity western boundary condition, t = 29227 12:00:00
(Min = 0.00000000E+00 Max = 3.67482209E+01)
GET_NGFLD - temperature southern boundary condition, t = 29227 12:00:00
(Min = 0.00000000E+00 Max = 2.77164009E+01)
GET_NGFLD - salinity southern boundary condition, t = 29227 12:00:00
(Min = 0.00000000E+00 Max = 3.70264769E+01)
GET_NGFLD - temperature northern boundary condition, t = 29227 12:00:00
(Min = 0.00000000E+00 Max = 2.79277273E+01)
GET_NGFLD - salinity northern boundary condition, t = 29227 12:00:00
(Min = 0.00000000E+00 Max = 3.69862032E+01)
0 29222 12:00:00 2.718432E-03 2.158603E+04 2.158604E+04 6.661190E+16
(171,260,46) 2.679433E-01 1.431780E-01 0.000000E+00 1.571628E+00
DEF_HIS - creating history file, Grid 01: atleq_his.nc
DEF_AVG - creating average file, Grid 01: atleq_avg_0001.nc
1 29222 12:30:00 NaN NaN NaN NaN
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 NaN
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Node # 0 CPU: 16.849
Node # 1 CPU: 16.857
Total: 33.706
Allocation and array initialization .............. 2.436 ( 7.2276 %)
Ocean state initialization ....................... 0.512 ( 1.5191 %)
Reading of input data ............................ 0.052 ( 0.1543 %)
Processing of input data ......................... 0.008 ( 0.0237 %)
Computation of vertical boundary conditions ...... 0.008 ( 0.0237 %)
Computation of global information integrals ...... 0.548 ( 1.6259 %)
Writing of output data ........................... 2.920 ( 8.6637 %)
Model 2D kernel .................................. 4.920 (14.5977 %)
2D/3D coupling, vertical metrics ................. 0.636 ( 1.8870 %)
Omega vertical velocity .......................... 0.396 ( 1.1749 %)
Equation of state for seawater ................... 2.512 ( 7.4531 %)
My2.5 vertical mixing parameterization ........... 3.184 ( 9.4470 %)
3D equations right-side terms .................... 1.176 ( 3.4892 %)
3D equations predictor step ...................... 1.120 ( 3.3230 %)
Pressure gradient ................................ 0.924 ( 2.7415 %)
Harmonic mixing of tracers, geopotentials ........ 1.708 ( 5.0676 %)
Harmonic stress tensor, S-surfaces ............... 0.852 ( 2.5279 %)
Corrector time-step for 3D momentum .............. 1.224 ( 3.6316 %)
Corrector time-step for tracers .................. 0.952 ( 2.8246 %)
Total: 26.090 77.4033
Message Passage: 2D halo exchanges ............... 0.376 ( 1.1156 %)
Message Passage: 3D halo exchanges ............... 0.092 ( 0.2730 %)
Message Passage: 4D halo exchanges ............... 0.040 ( 0.1187 %)
Message Passage: data broadcast .................. 2.516 ( 7.4650 %)
Message Passage: data reduction .................. 0.052 ( 0.1543 %)
Message Passage: data gathering .................. 2.548 ( 7.5599 %)
Message Passage: data scattering.................. 1.072 ( 3.1806 %)
Total: 6.696 19.8671
All percentages are with respect to total time = 33.706
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Monday - May 30, 2016 - 3:10:40 PM
Re: blowing up with ubar and vbar with min and max as NaNs
If all the NaNs are in the land mask, you shouldn't see it in the GET_XXX reports like that. You need to clean the Nans out of your input files.
fagundesmo
#3 Unread post by fagundesmo »
Hi Kate,
ok, I'll try it here. Thank you.
#4 Unread post by wilkin »
You say:
You can't have NaNs anywhere, not even on the perimeter, because ROMS computes with all values then applies land mask and boundary conditions. So NaNs anywhere propagate to NaNs everywhere.
Even with the Flather open boundary condition for ubar/vbar, you need initial values on the perimeter because these enter into the calculation for the next time step. Flather does not fix the perimeter as the boundary condition file, but merges this in with the gravity wave calculation.
Since you have valid u,v everywhere, including on the boundary (or so it seems from the standard output), just compute corresponding ubar/vbar as you have elsewhere.
Helios
#5 Unread post by Helios »
After fixing the NaN issue, I think you should change your time step, in order to reduce your Maximum barotropic Courant Number.
fagundesmo
#6 Unread post by fagundesmo »
Hi wilkin and Helios,
I have fixed the NAN problem and now I'm playing with the courant number. Although, I have a max courant number 0.83 it keeps blowing up, I am trying to play with my DT in order to keep my courant number equals to 0.83 and my barotropic time step equals 24 sec. Since, it keeps blowing up I wonder what the problem is now. The following is my output:
Resolution, Grid 01: 0903x0321x050, Parallel Nodes: 6, Tiling: 003x002
360 ntimes Number of timesteps for 3-D equations.
360.000 dt Timestep size (s) for 3-D equations.
15 ndtfast Number of timesteps for 2-D equations between
to standard output.
into history file.
time-averaged data.
360 ndefAVG Number of timesteps between creation of new
time-averaged file.
5.0000E-06 nl_visc2 NLM Horizontal, harmonic mixing coefficient
for tracer 02: salt
29217.500 dstart Time-stamp assigned to model initialization (days).
for tracer 02: salt
for 3D momentum.
Input Nonlinear Initial File: /home/roms/DATA/oceano/roms_ini_SODA_Y1979M12D29.nc
Tile partition information for Grid 01: 0903x0321x0050 tiling: 003x002
0 1 301 1 161 2423050
1 302 602 1 161 2423050
2 603 903 1 161 2423050
3 1 301 162 321 2408000
4 302 602 162 321 2408000
5 603 903 162 321 2408000
0 0.50 301.50 0.50 161.50 RHO-points
1 301.50 602.50 0.50 161.50 RHO-points
2 602.50 903.50 0.50 161.50 RHO-points
3 0.50 301.50 161.50 321.50 RHO-points
4 301.50 602.50 161.50 321.50 RHO-points
5 602.50 903.50 161.50 321.50 RHO-points
0 1.00 301.50 0.50 161.50 U-points
1 301.50 602.50 0.50 161.50 U-points
2 602.50 903.00 0.50 161.50 U-points
3 1.00 301.50 161.50 321.50 U-points
4 301.50 602.50 161.50 321.50 U-points
5 602.50 903.00 161.50 321.50 U-points
0 0.50 301.50 1.00 161.50 V-points
1 301.50 602.50 1.00 161.50 V-points
2 602.50 903.50 1.00 161.50 V-points
3 0.50 301.50 161.50 321.00 V-points
4 301.50 602.50 161.50 321.00 V-points
5 602.50 903.50 161.50 321.00 V-points
HaloSizeI(1) = 626
HaloSizeJ(1) = 344
TileSide(1) = 307
TileSize(1) = 50962
tke 1 Rad + Nud Rad + Nud Closed Rad + Nud
Minimum barotropic Courant Number = 2.55870446E-02
Maximum barotropic Courant Number = 8.37080204E-01
Maximum Coriolis Courant Number = 1.35341744E-02
NLM: GET_STATE - Read state initial conditions, t = 29217 12:00:00
(Grid 01, File: roms_ini_SODA_Y1979M12D29.nc, Rec=0001, Index=1)
- free-surface
(Min = -3.56767006E-01 Max = 2.55167816E-01)
(Min = -5.00194538E-01 Max = 1.08272027E-01)
(Min = -9.59396706E-02 Max = 3.79799400E-01)
(Min = -1.28447083E+00 Max = 1.53294544E+00)
(Min = -9.05112139E-01 Max = 1.27386835E+00)
(Min = 4.37372040E-01 Max = 2.89420652E+01)
- salinity
(Min = 3.03602513E+01 Max = 3.72483137E+01)
GET_NGFLD - free-surface western boundary condition, t = 29217 12:00:00
(Rec=0000001, Index=2, File: Atleq_bry.nc)
(Tmin= 29217.5000 Tmax= 29627.5000)
(Min = -4.18840224E-02 Max = 0.00000000E+00)
GET_NGFLD - free-surface southern boundary condition, t = 29217 12:00:00
(Min = -2.11230831E-01 Max = 2.36514993E-01)
GET_NGFLD - free-surface northern boundary condition, t = 29217 12:00:00
(Min = -1.80912646E-01 Max = 2.36783240E-02)
GET_NGFLD - 2D u-momentum western boundary condition, t = 29217 12:00:00
(Min = -5.03907755E-02 Max = 7.54603368E-03)
GET_NGFLD - 2D v-momentum western boundary condition, t = 29217 12:00:00
(Min = 0.00000000E+00 Max = 1.87037196E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 29217 12:00:00
(Min = -2.75992599E-02 Max = 1.11919609E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 29217 12:00:00
(Min = -3.44734838E-02 Max = 3.66260725E-02)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 29217 12:00:00
(Min = -4.10003673E-02 Max = 1.49573967E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 29217 12:00:00
(Min = -5.03430284E-02 Max = 3.63252747E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 29217 12:00:00
(Min = -1.62394764E-01 Max = 8.25405164E-02)
GET_NGFLD - 3D v-momentum western boundary condition, t = 29217 12:00:00
(Min = -3.42322665E-02 Max = 1.34523490E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 29217 12:00:00
(Min = -2.10556234E-01 Max = 1.66392674E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 29217 12:00:00
(Min = -2.27173665E-01 Max = 2.50497737E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 29217 12:00:00
(Min = -3.02971686E-01 Max = 2.89232909E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 29217 12:00:00
(Min = -2.86692981E-01 Max = 3.27474357E-01)
GET_NGFLD - temperature western boundary condition, t = 29217 12:00:00
(Min = 0.00000000E+00 Max = 2.72470425E+01)
GET_NGFLD - salinity western boundary condition, t = 29217 12:00:00
(Min = 0.00000000E+00 Max = 3.67573813E+01)
GET_NGFLD - temperature southern boundary condition, t = 29217 12:00:00
(Min = 0.00000000E+00 Max = 2.75734003E+01)
GET_NGFLD - salinity southern boundary condition, t = 29217 12:00:00
(Min = 0.00000000E+00 Max = 3.70147834E+01)
GET_NGFLD - temperature northern boundary condition, t = 29217 12:00:00
(Min = 0.00000000E+00 Max = 2.79495202E+01)
GET_NGFLD - salinity northern boundary condition, t = 29217 12:00:00
(Min = 0.00000000E+00 Max = 3.69997306E+01)
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00000360)
(Rec=0000002, Index=1, File: Atleq_bry.nc)
(Min = -1.24302509E-01 Max = 0.00000000E+00)
(Min = 0.00000000E+00 Max = 6.68999065E-02)
(Min = -2.29775982E-02 Max = 1.39900757E-02)
(Min = -3.55426819E-02 Max = 3.15084993E-02)
(Min = -3.94047850E-02 Max = 2.82735992E-02)
(Min = -3.81182828E-02 Max = 2.30277945E-02)
(Min = -2.99767774E-01 Max = 6.74589893E-02)
(Min = -1.84976252E-02 Max = 2.39752689E-01)
(Min = -2.42197277E-01 Max = 1.55991417E-01)
(Min = -2.45226543E-01 Max = 2.45045739E-01)
(Min = -2.69608758E-01 Max = 2.40859870E-01)
(Min = -2.41489694E-01 Max = 2.80939464E-01)
0 29217 12:00:00 2.705264E-03 2.158604E+04 2.158604E+04 6.661195E+16
(159,218,50) 3.274578E-02 4.877767E-02 0.000000E+00 1.616027E+00
1 29217 12:06:00 2.705822E-03 2.158605E+04 2.158605E+04 6.661195E+16
(262,141,01) 5.879897E-03 2.746851E-05 1.978124E-01 1.615546E+00
2 29217 12:12:00 2.709873E-03 2.158606E+04 2.158607E+04 6.661195E+16
(197,308,01) 8.911839E-04 1.942702E-02 6.250043E-01 1.615115E+00
3 29217 12:18:00 2.715865E-03 2.158608E+04 2.158609E+04 6.661195E+16
(197,308,01) 1.063690E-03 2.947815E-02 1.248464E+00 1.614952E+00
4 29217 12:24:00 2.723602E-03 2.158610E+04 2.158610E+04 6.661195E+16
(197,308,01) 1.333597E-03 3.953959E-02 1.858658E+00 1.614558E+00
5 29217 12:30:00 2.732771E-03 2.158611E+04 2.158612E+04 6.661194E+16
(197,308,01) 1.711901E-03 4.935311E-02 2.439046E+00 1.672696E+00
6 29217 12:36:00 2.742932E-03 2.158612E+04 2.158613E+04 6.661194E+16
(197,308,01) 2.165261E-03 5.868695E-02 2.969803E+00 1.944916E+00
7 29217 12:42:00 2.753643E-03 2.158613E+04 2.158613E+04 6.661193E+16
(198,308,01) 2.516981E-03 6.848169E-02 3.430140E+00 2.168316E+00
8 29217 12:48:00 2.764259E-03 2.158614E+04 2.158614E+04 6.661193E+16
(200,308,01) 7.072145E-03 7.507266E-02 3.912601E+00 2.320211E+00
9 29217 12:54:00 2.774303E-03 2.158614E+04 2.158614E+04 6.661193E+16
(200,308,01) 9.035620E-03 8.074783E-02 4.301604E+00 8.676547E+00
10 29217 13:00:00 2.790531E-03 2.158615E+04 2.158615E+04 6.661192E+16
(195,162,27) 2.035074E-01 3.795590E-03 7.230745E+00 9.995135E+01
WRT_RST - wrote re-start fields (Index=1,1) into time record =
I am doing a benchmark with DT=240 and NDFAST=40 and it gives me a barotropic time step of 6sec which I think it's too much, but when I try to increase it and also my baroclinic value it blows up even with courant number less than 1. Is there anything else I could do to fix it?
Thank you,
fagundesmo
#7 Unread post by fagundesmo »
kate wrote:If all the NaNs are in the land mask, you shouldn't see it in the GET_XXX reports like that. You need to clean the Nans out of your input files.
Hi Kate,
I have fixed that in python since I'm still doing the benchmark I'm still waiting for the output.
Thank you,
#8 Unread post by kate »
I would still play with the timestep. Just because your Courant number based on the initial conditions is less than one, you're not out of the woods. In fact, I don't think 0.83 is out of the woods. Plus, as soon as things start evolving, your forcing, etc. could lead to larger currents than are in your initial conditions.
fagundesmo
#9 Unread post by fagundesmo »
kate wrote:I would still play with the timestep. Just because your Courant number based on the initial conditions is less than one, you're not out of the woods. In fact, I don't think 0.83 is out of the woods. Plus, as soon as things start evolving, your forcing, etc. could lead to larger currents than are in your initial conditions.
Hi Kate,
I'll certify about that. Thank you again.
Regards
mathieu
#10 Unread post by mathieu »
If you compile with ifort, you can detect the precise line where the NaN first occur with the compile option -fpe0. With gfortran the option is -ffpe-trap=invalid.
