upwelling case
YC13
upwelling case
#1 Unread post by YC13 »
when I attempt to compile the Upwelling case:
[model@model UPWELLING]$ ./build.bash
rm -f -r core *.ipo /home/model/ROMS/UPWELLING/Build /home/model/make_macros.mk
: No such file or directory
makefile:238: INCLUDING FILE /home/model/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
cp -f /home/model/local/include/netcdf.mod /home/model/ROMS/UPWELLING/Build
cp -f /home/model/local/include/typesizes.mod /home/model/ROMS/UPWELLING/Build
./ROMS/Bin/sfmakedepend --cpp --fext=f90 --file=- --objdir=/home/model/ROMS/UPWELLING/Build -DROMS_HEADER="upwelling.h" -I ROMS/Include -I /home/model/ROMS/UPWELLING -I ROMS/Nonlinear -I ROMS/Nonlinear/Biology
-I ROMS/Nonlinear/Sediment -I ROMS/Utility -I ROMS/Drivers -I ROMS/Functionals -I /home/model/ROMS/UPWELLING -I Master -I Compilers --silent --moddir /home/model/ROMS/UPWELLING/Build ROMS/Nonlinear/bbl.F
ROMS/Nonlinear/bc_2d.F ROMS/Nonlinear/bc_3d.F ROMS/Nonlinear/bc_bry2d.F ROMS/Nonlinear/bc_bry3d.F ROMS/Nonlinear/bulk_flux.F ROMS/Nonlinear/bvf_mix.F ROMS/Nonlinear/conv_2d.F ROMS/Nonlinear/conv_3d.F
ROMS/Nonlinear/conv_bry2d.F ROMS/Nonlinear/conv_bry3d.F ROMS/Nonlinear/diag.F ROMS/Nonlinear/exchange_2d.F ROMS/Nonlinear/exchange_3d.F ROMS/Nonlinear/forcing.F ROMS/Nonlinear/frc_adjust.F
ROMS/Nonlinear/get_data.F ROMS/Nonlinear/get_idata.F ROMS/Nonlinear/gls_corstep.F ROMS/Nonlinear/gls_prestep.F ROMS/Nonlinear/hmixing.F ROMS/Nonlinear/ini_fields.F ROMS/Nonlinear/initial.F
ROMS/Nonlinear/interp_floats.F ROMS/Nonlinear/lmd_bkpp.F ROMS/Nonlinear/lmd_skpp.F ROMS/Nonlinear/lmd_swfrac.F ROMS/Nonlinear/lmd_vmix.F ROMS/Nonlinear/main2d.F ROMS/Nonlinear/main3d.F
ROMS/Nonlinear/mpdata_adiff.F ROMS/Nonlinear/my25_corstep.F ROMS/Nonlinear/my25_prestep.F ROMS/Nonlinear/nesting.F ROMS/Nonlinear/obc_adjust.F ROMS/Nonlinear/obc_volcons.F ROMS/Nonlinear/omega.F
ROMS/Nonlinear/output.F ROMS/Nonlinear/pre_step3d.F ROMS/Nonlinear/prsgrd.F ROMS/Nonlinear/radiation_stress.F ROMS/Nonlinear/rho_eos.F ROMS/Nonlinear/rhs3d.F ROMS/Nonlinear/set_avg.F ROMS/Nonlinear/set_data.F
ROMS/Nonlinear/set_depth.F ROMS/Nonlinear/set_massflux.F ROMS/Nonlinear/set_tides.F ROMS/Nonlinear/set_vbc.F ROMS/Nonlinear/set_zeta.F ROMS/Nonlinear/step2d.F ROMS/Nonlinear/step3d_t.F ROMS/Nonlinear/step3d_uv.F
ROMS/Nonlinear/step_floats.F ROMS/Nonlinear/t3dbc_im.F ROMS/Nonlinear/t3dmix.F ROMS/Nonlinear/tkebc_im.F ROMS/Nonlinear/u2dbc_im.F ROMS/Nonlinear/u3dbc_im.F ROMS/Nonlinear/uv3dmix.F ROMS/Nonlinear/v2dbc_im.F
ROMS/Nonlinear/v3dbc_im.F ROMS/Nonlinear/vwalk_floats.F ROMS/Nonlinear/wetdry.F ROMS/Nonlinear/wvelocity.F ROMS/Nonlinear/zetabc.F ROMS/Nonlinear/Biology/biology.F ROMS/Nonlinear/Biology/biology_floats.F
ROMS/Nonlinear/Sediment/sed_bed.F ROMS/Nonlinear/Sediment/sed_bedload.F ROMS/Nonlinear/Sediment/sed_fluxes.F ROMS/Nonlinear/Sediment/sediment.F ROMS/Nonlinear/Sediment/sed_settling.F
ROMS/Nonlinear/Sediment/sed_surface.F ROMS/Functionals/analytical.F ROMS/Utility/abort.F ROMS/Utility/array_modes.F ROMS/Utility/back_cost.F ROMS/Utility/cgradient.F ROMS/Utility/checkadj.F
ROMS/Utility/checkdefs.F ROMS/Utility/checkerror.F ROMS/Utility/check_multifile.F ROMS/Utility/checkvars.F ROMS/Utility/close_io.F ROMS/Utility/congrad.F ROMS/Utility/convolve.F ROMS/Utility/cost_grad.F
ROMS/Utility/def_avg.F ROMS/Utility/def_diags.F ROMS/Utility/def_dim.F ROMS/Utility/def_error.F ROMS/Utility/def_floats.F ROMS/Utility/def_gst.F ROMS/Utility/def_hessian.F ROMS/Utility/def_his.F
ROMS/Utility/def_impulse.F ROMS/Utility/def_info.F ROMS/Utility/def_ini.F ROMS/Utility/def_lanczos.F ROMS/Utility/def_mod.F ROMS/Utility/def_norm.F ROMS/Utility/def_rst.F ROMS/Utility/def_station.F
ROMS/Utility/def_tides.F ROMS/Utility/def_var.F ROMS/Utility/distribute.F ROMS/Utility/dotproduct.F ROMS/Utility/erf.F ROMS/Utility/extract_obs.F ROMS/Utility/extract_sta.F ROMS/Utility/frc_weak.F
ROMS/Utility/gasdev.F ROMS/Utility/get_2dfld.F ROMS/Utility/get_2dfldr.F ROMS/Utility/get_3dfld.F ROMS/Utility/get_3dfldr.F ROMS/Utility/get_bounds.F ROMS/Utility/get_cycle.F ROMS/Utility/get_date.F
ROMS/Utility/get_grid.F ROMS/Utility/get_gst.F ROMS/Utility/get_ngfld.F ROMS/Utility/get_ngfldr.F ROMS/Utility/get_nudgcoef.F ROMS/Utility/get_state.F ROMS/Utility/get_varcoords.F ROMS/Utility/get_wetdry.F
ROMS/Utility/grid_coords.F ROMS/Utility/ini_adjust.F ROMS/Utility/ini_hmixcoef.F ROMS/Utility/ini_lanczos.F ROMS/Utility/inner2state.F ROMS/Utility/inp_par.F ROMS/Utility/inquire.F ROMS/Utility/interpolate.F
ROMS/Utility/lbc.F ROMS/Utility/lubksb.F ROMS/Utility/ludcmp.F ROMS/Utility/metrics.F ROMS/Utility/mp_exchange.F ROMS/Utility/mp_routines.F ROMS/Utility/nf_fread2d_bry.F ROMS/Utility/nf_fread2d.F
ROMS/Utility/nf_fread3d_bry.F ROMS/Utility/nf_fread3d.F ROMS/Utility/nf_fread4d.F ROMS/Utility/nf_fwrite2d_bry.F ROMS/Utility/nf_fwrite2d.F ROMS/Utility/nf_fwrite3d_bry.F ROMS/Utility/nf_fwrite3d.F
ROMS/Utility/nf_fwrite4d.F ROMS/Utility/normalization.F ROMS/Utility/nrutil.F ROMS/Utility/ntimestep.F ROMS/Utility/obs_cost.F ROMS/Utility/obs_depth.F ROMS/Utility/obs_initial.F ROMS/Utility/obs_read.F
ROMS/Utility/obs_write.F ROMS/Utility/packing.F ROMS/Utility/posterior.F ROMS/Utility/posterior_var.F ROMS/Utility/ran1.F ROMS/Utility/random_ic.F ROMS/Utility/ran_state.F ROMS/Utility/read_asspar.F
ROMS/Utility/read_biopar.F ROMS/Utility/read_couplepar.F ROMS/Utility/read_fltbiopar.F ROMS/Utility/read_fltpar.F ROMS/Utility/read_phypar.F ROMS/Utility/read_sedpar.F ROMS/Utility/read_stapar.F
ROMS/Utility/regrid.F ROMS/Utility/rep_matrix.F ROMS/Utility/set_2dfld.F ROMS/Utility/set_2dfldr.F ROMS/Utility/set_3dfld.F ROMS/Utility/set_3dfldr.F ROMS/Utility/set_contact.F ROMS/Utility/set_diags.F
ROMS/Utility/set_masks.F ROMS/Utility/set_ngfld.F ROMS/Utility/set_ngfldr.F ROMS/Utility/set_scoord.F ROMS/Utility/set_weights.F ROMS/Utility/shapiro.F ROMS/Utility/sqlq.F ROMS/Utility/state_addition.F
ROMS/Utility/state_copy.F ROMS/Utility/state_dotprod.F ROMS/Utility/state_initialize.F ROMS/Utility/state_product.F ROMS/Utility/state_scale.F ROMS/Utility/stats_modobs.F ROMS/Utility/stiffness.F
ROMS/Utility/strings.F ROMS/Utility/sum_grad.F ROMS/Utility/timers.F ROMS/Utility/uv_rotate.F ROMS/Utility/vorticity.F ROMS/Utility/white_noise.F ROMS/Utility/wpoints.F ROMS/Utility/wrt_avg.F
ROMS/Utility/wrt_diags.F ROMS/Utility/wrt_error.F ROMS/Utility/wrt_floats.F ROMS/Utility/wrt_gst.F ROMS/Utility/wrt_hessian.F ROMS/Utility/wrt_his.F ROMS/Utility/wrt_impulse.F ROMS/Utility/wrt_info.F
ROMS/Utility/wrt_ini.F ROMS/Utility/wrt_rst.F ROMS/Utility/wrt_station.F ROMS/Utility/wrt_tides.F ROMS/Utility/zeta_balance.F ROMS/Modules/mod_arrays.F ROMS/Modules/mod_average.F ROMS/Modules/mod_bbl.F
ROMS/Modules/mod_behavior.F ROMS/Modules/mod_biology.F ROMS/Modules/mod_boundary.F ROMS/Modules/mod_clima.F ROMS/Modules/mod_coupler.F ROMS/Modules/mod_coupling.F ROMS/Modules/mod_diags.F
ROMS/Modules/mod_eclight.F ROMS/Modules/mod_eoscoef.F ROMS/Modules/mod_floats.F ROMS/Modules/mod_forces.F ROMS/Modules/mod_fourdvar.F ROMS/Modules/mod_grid.F ROMS/Modules/mod_iounits.F ROMS/Modules/mod_kinds.F
ROMS/Modules/mod_mixing.F ROMS/Modules/mod_ncparam.F ROMS/Modules/mod_nesting.F ROMS/Modules/mod_netcdf.F ROMS/Modules/mod_ocean.F ROMS/Modules/mod_parallel.F ROMS/Modules/mod_param.F ROMS/Modules/mod_scalars.F
ROMS/Modules/mod_sedbed.F ROMS/Modules/mod_sediment.F ROMS/Modules/mod_sources.F ROMS/Modules/mod_stepping.F ROMS/Modules/mod_storage.F ROMS/Modules/mod_strings.F ROMS/Modules/mod_tides.F Master/esmf_roms.F
Master/master.F Master/ocean_control.F Master/ocean_coupler.F Master/propagator.F Master/roms_export.F Master/roms_import.F > /home/model/ROMS/UPWELLING/Build/MakeDepend
make: *** No rule to make target `/home/model/ROMS/UPWELLING/Build/MakeDepend', needed by `all'. Stop.
I have no idea about it
Thank you for all your time.
Re: upwelling case
I can think of two sorts of problems that can cause this. First does this directory exist and do you have permission to write to it (create files there)?
Second, it is attempting to execute ./ROMS/Bin/sfmakedepend, which is a Perl script. Do you have a working perl executable and what version is it?
perl --version
This is perl 5, version 18, subversion 2 (v5.18.2) built for x86_64-linux-gnu-thread-multi
(with 44 registered patches, see perl -V for more detail)
Copyright 1987-2013, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl".  If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
If you have Perl, it's probably new enough.
YC13
Re: upwelling case
#3 Unread post by YC13 »
hello Kate .Thanks for your prompt reply
I updated the version of perl . I got the same error message .
[root@centOS share]# perl --version
This is perl 5, version 22, subversion 1 (v5.22.1) built for x86_64-linux
Copyright 1987-2015, Larry Wall
The file of build.bash and make is posted. The direction of ${HOME} is /home/model
build&make.7z
(8.34 KiB) Downloaded 438 times
Re: upwelling case
YC13
Re: upwelling case
#5 Unread post by YC13 »
Thanks kate .I solved the problem.
