Another Problem with SWAN
zsurenj
#1 Unread post by zsurenj »
I'm using COAWST. I'm experiencing a problem while coupling ROMS and SWAN or only using SWA, I can't build and I get the following:
cd /HOME/sysu_hyxy_rj/WORKSPACE/COAWST/Projects/YeES/Build; /usr/local/mpi3-dynamic/bin/mpif90 -c -heap-arrays -fp-model precise -ip -O3 -assume byterecl -free -free nctablemd.f90
ifort: command line warning #10212: -fp-model precise evaluates in source precision with Fortran.
nctablemd.f90(62): error #5144: Invalid character_kind_parameter. No underscore
"air sea temperature difference (k)", &
nctablemd.f90(64): error #5144: Invalid character_kind_parameter. No underscore
nctable(7) / nctable_record("ustar", &
nctablemd.f90(65): error #5144: Invalid character_kind_parameter. No underscore
"none", &
nctablemd.f90(66): error #5144: Invalid character_kind_parameter. No underscore
"friction velocity", &
nctablemd.f90(67): error #5144: Invalid character_kind_parameter. No underscore
"m s-1", NF90_SHORT, 0, 20, variddum) /, &
nctablemd.f90(69): error #5144: Invalid character_kind_parameter. No underscore
"sea_surface_wave_significant_height", &
nctablemd.f90(70): error #5144: Invalid character_kind_parameter. No underscore
"hs", &
nctablemd.f90(71): error #5144: Invalid character_kind_parameter. No underscore
"m", NF90_SHORT, 0., 50., variddum) /, &
nctablemd.f90(72): error #5144: Invalid character_kind_parameter. No underscore
nctable(9) / nctable_record("L", &
nctablemd.f90(73): error #5144: Invalid character_kind_parameter. No underscore
"none", &
nctablemd.f90(74): error #5144: Invalid character_kind_parameter. No underscore
"L", &
nctablemd.f90(75): error #5144: Invalid character_kind_parameter. No underscore
"m", NF90_SHORT, 0, 0, variddum) /, &
nctablemd.f90(76): error #5144: Invalid character_kind_parameter. No underscore
nctable(10) / nctable_record("theta0", &
nctablemd.f90(77): error #5144: Invalid character_kind_parameter. No underscore
"sea_surface_wave_from_direction", &
nctablemd.f90(78): error #5144: Invalid character_kind_parameter. No underscore
"theta0", &
nctablemd.f90(79): error #5144: Invalid character_kind_parameter. No underscore
"degrees", NF90_SHORT, 0., 360., variddum) /&
nctablemd.f90(80): error #5144: Invalid character_kind_parameter. No underscore
nctable(11) / nctable_record("tmm10", &
nctablemd.f90(81): error #5144: Invalid character_kind_parameter. No underscore
"sea_surface_wave_mean_period_from_variance_&
nctablemd.f90(101): error #5144: Invalid character_kind_parameter. No underscore
"none", &
nctablemd.f90(102): error #5144: Invalid character_kind_parameter. No underscore
"direction of peak frequency of wind sea par&
nctablemd.f90(103): error #5144: Invalid character_kind_parameter. No underscore
"degrees", NF90_BYTE, 0., 360., variddum) /,&
nctablemd.f90(108): error #5144: Invalid character_kind_parameter. No underscore
nctable(18) / nctable_record("tp_partitions", &
nctablemd.f90(109): error #5144: Invalid character_kind_parameter. No underscore
"none", &
nctablemd.f90(110): error #5144: Invalid character_kind_parameter. No underscore
"relative peak periods of partitions of the &
nctablemd.f90(111): error #5144: Invalid character_kind_parameter. No underscore
"s", NF90_BYTE, 0., 24., variddum) /, &
nctablemd.f90(116): error #5144: Invalid character_kind_parameter. No underscore
nctable(20) / nctable_record("theta0_partitions", &
nctablemd.f90(117): error #5144: Invalid character_kind_parameter. No underscore
"none", &
nctablemd.f90(118): error #5144: Invalid character_kind_parameter. No underscore
"mean wave direction of partitions of spectr&
nctablemd.f90(119): error #5144: Invalid character_kind_parameter. No underscore
nctablemd.f90(124): error #5144: Invalid character_kind_parameter. No underscore
nctable(22) / nctable_record("wind_sea_fraction_partitions"&
nctablemd.f90(125): catastrophic error: Too many errors, exiting
compilation aborted for nctablemd.f90 (code 1)
make: *** [/HOME/sysu_hyxy_rj/WORKSPACE/COAWST/Projects/YeES/Build/nctablemd.o] Error 1
Does anyone have idea of what went wrong?
Thanks a lot for your help
Renjie
Re: Another Problem with SWAN
I answered you on the coawst forum. no need to also ask here.
-john
