Headland Test Case
tmortlock
Headland Test Case
#1 Unread post by tmortlock »
I am a newbie at ROMS but have managed to compile and install ROMS using Cygwin, and run the Upwelling test case successfully. However, my interest is coupled SWAN/ROMS results for sediment transport, therefore I am trying to run the Headland test case but running into problems (this may also be a relevant question for COAWST forum I guess).
I’ve downloaded and compiled the MCT ok using the openmpi library in Cygwin. I’ve also managed to compile the test head build.bash OK – here’s what I needed to modify to compile successfully (may be useful for others):
• Modified environmental variables (ROMS_APPLICATION, MY_ROOT_DIR and MY_PROJECT_DIR).
• I found that I also needed to change MCT_INCDIR to /usr/local/include and MCT_LIBDIR to /usr/local/lib, and
• I made sure “USE_NETCDF4=on” and “USE_MY_LIBS=on” were both set
Once compiled, I get the executable OceanM.exe. After some trial and error, I found I needed to change:
• VARNAME in ocean_test_head.in to /home/Tom/roms/trunk/ROMS/External/varinfo.dat
• CPLname in coupling_test_head.in to /home/Tom/roms/trunk/ROMS/External/coupling.dat
I then execute the command: mpiexec -np 2 ./oceanM coupling_test_head.in (as shown in the COAWT User Manual) to run the Test Head case using mpi.
Here’s where I’m stumped: the model runs up until this point:
Coupled Input File name = coupling_test_head.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 000
Waves Model MPI nodes: 001 - 001
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
Tuesday - February 2, 2016 - 9:47:51 PM
SWAN is preparing computation ...
Sediment Test Headland Case
Operating system : CYGWIN
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -I/usr/local/include -fno-bounds-check -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 783
Local Root : /home/Administrator/roms/trunk
Header Dir : /home/Administrator/roms/Projects/Test_Head
Header file : test_head.h
Analytical Dir: /home/Administrator/roms/Projects/Test_Head
Resolution, Grid 01: 0056x0026x010, Parallel Nodes: 1, Tiling: 001x001
30.000 dt Timestep size (s) for 3-D equations.
120 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
120 nHIS Number of timesteps between the writing fields
into history file.
for turbulent energy.
-1.000 gls_p GLS stability exponent.
0.500 gls_m GLS turbulent kinetic energy exponent.
5.5500E-01 gls_c1 GLS shear production coefficient.
8.3300E-01 gls_c2 GLS dissipation coefficient.
-6.0000E-01 gls_c3m GLS stable buoyancy production coefficient.
2.0000E+00 gls_sigk GLS constant Schmidt number for TKE.
2.0000E+00 gls_sigp GLS constant Schmidt number for PSI.
3.0000E-03 Zob Bottom roughness (m).
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
1.0000E-01 theta_s S-coordinate surface control parameter.
8.0000E-01 theta_b S-coordinate bottom control parameter.
0.100 Tcline S-coordinate surface/bottom layer width (m) used
1024.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
for 3D momentum.
1024.000 R0 Background density (kg/m3) used in linear Equation
of State.
T Hout(idBath) Write out time-dependent bathymetry.
T Hout(idVbms) Write out bottom V-momentum stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idU2rs) Write out total 2D u-radiation stress.
T Hout(idV2rs) Write out total 2D v-radiation stress.
T Hout(idU2Sd) Write out 2D u-momentum stokes velocity.
T Hout(idV2Sd) Write out 2D v-momentum stokes velocity.
T Hout(idW3xx) Write out 3D radiation stress, Sxx.
T Hout(idW3xy) Write out 3D radiation stress, Sxy.
T Hout(idW3yy) Write out 3D radiation stress, Syy.
T Hout(idW3zx) Write out 3D radiation stress, Szx.
T Hout(idW3zy) Write out 3D radiation stress, Szy.
T Hout(idU3rs) Write out total 3D u-radiation stress.
T Hout(idV3rs) Write out total 3D v-radiation stress.
T Hout(idU3Sd) Write out 3D u-momentum stokes velocity.
T Hout(idV3Sd) Write out 3D v-momentum stokes velocity.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
T Hout(idWptp) Write out wave surface period.
T Hout(idWpbt) Write out wave bottom period.
T Hout(idWdis) Write out wave dissipation.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 09: Zo_app
T Hout(idBott) Write out bottom property 10: Zo_Nik
T Hout(idBott) Write out bottom property 11: Zo_bio
T Hout(idBott) Write out bottom property 15: active_layer_thickness
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTdif) Write out vertical diffusion: AKt(itemp).
Physical parameters File:
Input Grid File: Data/test_head_curv_grd.nc
Input Nonlinear Initial File: Data/test_head_ini.nc
Input Forcing File 01: Data/test_head_frc.nc
Tile partition information for Grid 01: 0056x0026x0010 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 56 1 26 14560
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 56.50 0.50 26.50 RHO-points
0 1.00 56.00 0.50 26.50 U-points
0 0.50 56.50 1.00 26.00 V-points
HaloSizeI(1) = 201
HaloSizeJ(1) = 111
TileSide(1) = 61
TileSize(1) = 1891
Sediment Parameters, Grid: 01
1 2.5000E-01 0.0000E+00 2.6500E+03 3.0000E+01 5.0000E-04 9.0000E-01
1 1.9000E-01 6.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.1000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.0000E+00 (m).
Rate coefficient for bed load transport = 0.5000E-01
F LtracerSponge(02Turning OFF sponge on tracer 02: sand_01
F LtracerSrc(02) Turning OFF point sources/Sink on tracer 02: sand_01
F LtracerCLM(02) Turning OFF processing of climatology tracer 02: sand_01
F LnudgeTCLM(02) Turning OFF nudging of climatology tracer 02: sand_01
T Hout(idTvar) Write out sediment01: sand_01
T Hout(idfrac) Write out bed fraction, sediment 01: sandfrac_01
T Hout(idfrac) Write out mass, sediment 01: sandmass_01
T Hout(idUbld) Write out U-bedload, sediment 01: bedload_Usand_01
T Hout(idVbld) Write out V-bedload, sediment 01: bedload_Vsand_01
zeta 1 Clamped Closed Clamped Closed
ubar 1 Reduced Closed Reduced Closed
vbar 1 Reduced Closed Reduced Closed
u 1 Radiation Closed Radiation Closed
v 1 Radiation Closed Radiation Closed
temp 1 Gradient Closed Gradient Closed
sand_01 1 Gradient Closed Gradient Closed
tke 1 Gradient Closed Gradient Closed
TEST_HEAD Sediment Test Headland Case
BEDLOAD_MPM Activate bed load sediment transport Meyer-Peter-Mueller.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction.
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR05 Nearshore Radiation Stress Terms (Mellor 2005).
NONLINEAR Nonlinear Model.
SED_MORPH Allow bottom model elevation to evolve.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
Process Information:
Node # 0 (pid= 0) is active.
10 0.0000000 0.0000000 0.000 0.000 0.000 0.000
9 -0.1000000 -0.0998711 -0.184 -0.010 -1.091 -1.997
8 -0.2000000 -0.1998081 -0.368 -0.020 -2.182 -3.996
7 -0.3000000 -0.2997971 -0.552 -0.030 -3.274 -5.996
6 -0.4000000 -0.3998241 -0.736 -0.040 -4.366 -7.997
5 -0.5000000 -0.4998751 -0.920 -0.050 -5.459 -9.998
4 -0.6000000 -0.5999361 -1.104 -0.060 -6.551 -11.999
3 -0.7000000 -0.6999931 -1.288 -0.070 -7.644 -14.000
2 -0.8000000 -0.8000320 -1.472 -0.080 -8.736 -16.001
1 -0.9000000 -0.9000390 -1.656 -0.090 -9.828 -18.001
0 -1.0000000 -1.0000000 -1.840 -0.100 -10.920 -20.000
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136461 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876602
10 0.0161716623600090 0.0486998273761630 0.0421751148367487 0.4983983377638232
11 0.0207585511322367 0.0478912442581626 0.0629336659689854 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430844 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924698 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366960 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873357 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240973 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194840 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038024 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834594 0.9445203630883545
23 0.0746596950216180 0.0177785909158270 0.7190878767050775 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669234 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836260 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321980 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218105 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740009 0.9996892670186999
29 0.0062146596259991 0.0003107329813000 1.0000000000000000 0.9999999999999998
Minimum X-grid spacing, DXmin = 1.13252747E-01 km
Maximum X-grid spacing, DXmax = 2.08188350E+00 km
Minimum Y-grid spacing, DYmin = 1.00252718E-01 km
Maximum Y-grid spacing, DYmax = 1.64514065E+00 km
Minimum Z-grid spacing, DZmin = 1.83775741E-01 m
Maximum Z-grid spacing, DZmax = 2.00121356E+00 m
Minimum barotropic Courant Number = 1.29376506E-02
Maximum barotropic Courant Number = 1.03864092E-01
Maximum Coriolis Courant Number = 1.66318560E-05
(Grid 01, File: test_head_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 1.00000000E+01 Max = 1.00000000E+01)
- suspended noncohesive sediment, size class 01
- noncohesive sediment fraction, size class 01
(Min = 1.00000000E+00 Max = 1.00000000E+00)
- noncohesive sediment mass, size class 01
(Min = 7.95000000E+02 Max = 7.95000000E+02)
- sediment bed layer thickness
(Min = 3.00000000E+00 Max = 3.00000000E+00)
- sediment layer age
- sediment layer porosity
(Min = 9.00000000E-01 Max = 9.00000000E-01)
- biodiffusivity at bottom of each layer
- sediment median grain diameter size
(Min = 3.01900000E-05 Max = 3.01900000E-05)
- sediment median grain density
(Min = 2.65000000E+03 Max = 2.65000000E+03)
- sediment median grain settling velocity
(Min = 5.48500000E-04 Max = 5.48500000E-04)
- sediment median critical erosion stress
(Min = 5.87111845E-05 Max = 5.87111845E-05)
GET_NGFLD - tidal period
(Min = 4.32000000E+04 Max = 4.32000000E+04)
(Min = 2.50000000E-01 Max = 7.13896844E-01)
(Min = 4.83153953E-02 Max = 4.71238898E+00)
(Min = 0.00000000E+00 Max = 5.01397018E-01)
(Min = 4.24443233E-01 Max = 5.00000000E-01)
Maximum grid stiffness ratios: rx0 = 2.357374E-01 (Beckmann and Haidvogel)
rx1 = 4.480829E+00 (Haney)
Initial basin volumes: TotVolume = 1.9528627308E+10 m3
MinVolume = 2.5704990210E+03 m3
MaxVolume = 5.2472233629E+06 m3
Max/Min = 2.0413247856E+03
After which it seems to stall – not giving me anything else. I’ve left it practically all day, and I can tell the oceanM.exe is running in Windows, but never get any further than this. Swaninit is called, PRINT is blank, and four .mat files (force, fric, depth, dissip) appear but are empty.
Any ideas would be very much appreciated,
Cheers, Tom
Re: Headland Test Case
Tom-
if you are interested to use the roms+swan coupling, then I suggest you use the COAWST modeling system. we are using that system for advancements in the model coupling. please send an email to jcwarner@usgs.gov and ask for that code.
thanks,
john
tmortlock
#3 Unread post by tmortlock »
Hi John
Thanks, I have already done so and downloaded COAWST - I just thought I'd get familiar with ROMS before I started with COAWST. With regard to this particular problem, is this something you've come across before?
Many thanks, Tom
#4 Unread post by jcwarner »
if you want to use roms+swan coupling, then please use the formulations and coupling schemes that are in coawst. roms is distributed with an older version of swan, and it has a coupling infrastructure. but over the years we have updated swan, added wrf, updated the coupling scheme, added regridding for sparse matrix interpolations, etc. all of these additions are in coawst. At one point we had a lot of tests cases but we limited those now. so look at the COAWST/Projects/Inlet_test/Coupled as an example of roms+swan coupling with sediment. that can get you started.
-john
tmortlock
#5 Unread post by tmortlock »
Ok John, will do, thanks for advice.
Tom
