Nesting Run Problem
osua72
Nesting Run Problem
#1 Unread post by osua72 »
I am trying to create a nested ROMS model with two telescopic refined grids.
I have created the grids using the coarse2fine script with a Gfactor of 5 for both refined grids. I have also successfully created the contact.nc file using contact.m.
I created my frc.nc file for the outer (coarse) grid and set my boundaries as follows :
LBC(isFsur) == Cha Cha Cha Cha \ ! free-surface, Grid 1
Nes Nes Nes Nes \ ! free-surface, Grid 2
Nes Nes Nes Nes ! free-surface, Grid 3
LBC(isUbar) == Fla Fla Fla Fla \ ! 2D U-momentum, Grid 1
Nes Nes Nes Nes \ ! 2D U-momentum, Grid 2
Nes Nes Nes Nes ! 2D U-momentum, Grid 3
LBC(isVbar) == Fla Fla Fla Fla \ ! 2D V-momentum, Grid 1
Nes Nes Nes Nes \ ! 2D V-momentum, Grid 2
Nes Nes Nes Nes ! 2D V-momentum, Grid 3
LBC(isUvel) == Gra Gra Gra Gra \ ! 3D U-momentum, Grid 1
Nes Nes Nes Nes \ ! 3D U-momentum, Grid 2
Nes Nes Nes Nes ! 3D U-momentum, Grid 3
LBC(isVvel) == Gra Gra Gra Gra \ ! 3D V-momentum, Grid 1
Nes Nes Nes Nes \ ! 3D V-momentum, Grid 2
Nes Nes Nes Nes ! 3D V-momentum, Grid 3
LBC(isMtke) == Gra Gra Gra Gra \ ! mixing TKE, Grid 1
Nes Nes Nes Nes \ ! mixing TKE, Grid 2
Nes Nes Nes Nes ! mixing TKE, Grid 3
LBC(isTvar) == Gra Gra Gra Gra \ ! temperature, Grid 1
Gra Gra Gra Gra \ ! salinity, Grid 1
Nes Nes Nes Nes \ ! temperature, Grid 2
Nes Nes Nes Nes \ ! salinity, Grid 2
Nes Nes Nes Nes \ ! temperature, Grid 3
Nes Nes Nes Nes ! salinity, Grid 3
The model appears to compile fine but shortly after submitting the running script it breaks with the following error :
INP_PAR - illegal lateral boundary condition keyword: Cha
ROMS/TOMS - Output NetCDF summary for Grid 02:
ROMS/TOMS - Output NetCDF summary for Grid 03:
REASON: No error
Any clues to why this is happening would be much appreciated - see attached for header file if interested
nest_header.h
(612 Bytes) Downloaded 1047 times
Re: Nesting Run Problem
just for fun, lets try
Nes Nes Nes Nes \
Nes Nes Nes Nes
and see if that makes it happy.
osua72
#3 Unread post by osua72 »
Same error, just minus the comment!
Nes Nes Nes Nes \
osua72
#4 Unread post by osua72 »
Not sure quite what I did - possibly just reduced the spacing between the inputs - but this problem has now been solved. Thank you John for your input
TorresGarcia
#5 Unread post by TorresGarcia »
I am trying to do a 4 Nested grid and I am having same problem when trying to run. I created all my parent grid and subsequently the childs unsing coarse2fine. I also create my contact file using contact.m
I was sucessfully able to run using two nested grid. However when adding the 3 grid or 4 grid I get the same error:
Input file:
! Number of nested grids.
Ngrids = 4
! Number of grid nesting layers. This parameter is used to allow refinement
NestLayers = 4
GridsInLayer = 1 1 1 1
! these parameters correctly.
Lm == 72 200 206 230 ! Number of I-direction INTERIOR RHO-points
Mm == 71 160 265 365 ! Number of J-direction INTERIOR RHO-points
N == 10 10 10 10 ! Number of vertical levels
ND == 0 0 0 0 ! Number of wave directional bins
Nbed = 1 1 1 1 ! Number of sediment bed layers
NAT = 2 2 2 2 ! Number of active tracers (usually, 2)
NPT = 0 0 0 0 ! Number of inactive passive tracers
NCS = 1 1 1 1 ! Number of cohesive (mud) sediment tracers
NNS = 0 0 0 0 ! Number of non-cohesive (sand) sediment tracers
NtileI == 4 4 4 4 ! I-direction partition
NtileJ == 8 8 8 8 ! J-direction partition
! Cha Chapman_implicit (free-surface)
! Che Chapman_explicit (free-surface)
! Cla Clamped
! Clo Closed
! Fla Flather (2D momentum) _____N_____ j=Mm
! Gra Gradient | 4 |
! Nes Nested (refinement) | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics (2D momentum) 2 j=1
! Shc Shchepetkin (2D momentum) i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Cha Cha Cha Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
LBC(isUbar) == Fla Fla Fla Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
LBC(isVbar) == Fla Fla Fla Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
LBC(isUvel) == Rad Rad Rad Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
LBC(isVvel) == Rad Rad Rad Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
LBC(isMtke) == Rad Rad Rad Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
LBC(isTvar) == Gra Gra Gra Clo \
Gra Gra Gra Clo ! temprature
Nes Nes Nes Nes \
Nes Nes Nes Nes \
Nes Nes Nes Nes
Nes Nes Nes Nes \
Nes Nes Nes Nes
! Wec boundary conditions
LBC(isU2Sd) == Gra Gra Gra Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
Nes Nes Nes Nes ! 2D U-stokes
LBC(isV2Sd) == Gra Gra Gra Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
Nes Nes Nes Nes ! 2D V-stokes
LBC(isU3Sd) == Gra Gra Gra Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
Nes Nes Nes Nes ! 3D U-stokes
LBC(isV3Sd) == Gra Gra Gra Clo \
Nes Nes Nes Nes \
Nes Nes Nes Nes \
Nes Nes Nes Nes ! 3D V-stokes
ERROR:
LOAD_LBC - illegal lateral boundary condition keyword: Cha
Nes Nes Nes Nes \
If anyone could help me if I am missing something in the text
ocean_crocker_reef.in
Input File
(118.2 KiB) Downloaded 1018 times
#6 Unread post by jcwarner »
your input files has a lot of 'tabs' in it.
No tabs allowed.
please remove all tabs and try again. only use the space bar. not sure if there is a way to show all the tab characters in emacs or someother software.
TorresGarcia
#7 Unread post by TorresGarcia »
Thank you. I used Notepad ++ and I could see clear all the tabs I had. That problem is solved, now it reads all my BC, input and output files.
Legna
Vera
#8 Unread post by Vera »
hello~
I want to know that if I have two nested grids,can I set different N(number of vertical layers)for them?
Thanks in advance.
#9 Unread post by jcwarner »
no. you need N= the same number for each nested grid.
