model terminates if 'DIAGNOSTICS_UV' is activated
xwu
#1 Unread post by xwu »
Hi,all!
I run across this errors with a ROMS+SWAN coupled case. The case runs well if 'DIAGNOSTICS_UV' is unactivated. But once this cpp gets activated, the running terminates at the very beginning with the details shown as the following:
Coupled Input File name = Projects/Stormsrun/TS/Nest_TS/Factor7/bcf_coupling.in
Model Coupling:
Ocean Model MPI nodes: 000 - 001
Waves Model MPI nodes: 002 - 005
Friday - April 24, 2015 - 5:42:06 PM
SWAN grid 1 is preparing computation
BCF TEST
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/local/gfortran/openmpi/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -I/usr/local/gfortran/mct/include -ffree-form -ffree-line-length-none
Input Script :
SVN Root URL : https:://myroms.org/svn/src
SVN Revision : 889:931M
Local Root : /home/wxd/COAWST
Header Dir : /home/wxd/COAWST/Projects/Stormsrun/TS/Nest_TS/Factor7
Header file : bcf_test.h
Analytical Dir: /home/wxd/COAWST/Projects/Stormsrun/TS/Nest_TS/Factor7
Resolution, Grid 01: 0945x0210x004, Parallel Nodes: 2, Tiling: 002x001
33480 ntimes Number of timesteps for 3-D equations.
10.000 dt Timestep size (s) for 3-D equations.
10 ndtfast Number of timesteps for 2-D equations between
3480 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
180 nHIS Number of timesteps between the writing fields
into history file.
31 ntsDIA Starting timestep for the accumulation of output
180 nDIA Number of timesteps between the writing of
1.0000E-01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
0.000 wec_alpha WEC factor for roller/breaking energy distribution.
1.0000E-04 Zob Bottom roughness (m).
5.0000E-02 Zos Surface roughness (m).
1.0000E+00 Dcrit Minimum depth for wetting and drying (m).
50.000 Tcline S-coordinate surface/bottom layer width (m) used
53046.125 dstart Time-stamp assigned to model initialization (days).
18581124.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
1.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
of State.
T Hout(idVbms) Write out bottom V-momentum stress.
T Hout(idU2rs) Write out total 2D u-radiation stress.
T Hout(idV2rs) Write out total 2D v-radiation stress.
T Hout(idU2Sd) Write out 2D u-momentum stokes velocity.
T Hout(idV2Sd) Write out 2D v-momentum stokes velocity.
T Hout(idU3Sd) Write out 3D u-momentum stokes velocity.
T Hout(idV3Sd) Write out 3D v-momentum stokes velocity.
T Hout(idWztw) Write out WEC quasi-static sea level adjustment.
T Hout(idWqsp) Write out WEC quasi-static pressure.
T Hout(idWbeh) Write out WEC Bernoulli head.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
T Hout(idWptp) Write out wave surface period.
T Hout(idWpbt) Write out wave bottom period.
T Hout(idWorb) Write out wave bottom orbital velocity.
Output Restart File: land_ocean_rst.nc
Output History File: TSnest_ocean_his_Max2wMdLtd_f7.nc
Output Diagnostics File: TSnest_ocean_dia_Max2wMdLtd_f7.nc
Physical parameters File:
Input Grid File: Projects/Stormsrun/TS/Nest_TS/Factor7/zland_gridfine7.nc
Input Nonlinear Initial File: Projects/Stormsrun/TS/Nest_TS/Factor7/TSnest_Max2wMdLtd_inic7.nc
Input Forcing File 01: Projects/Stormsrun/TS/Nest_TS/Factor7/TSnest_wind_Max2wMdLtd.nc
Input Boundary File 01: Projects/Stormsrun/TS/Nest_TS/Factor7/TSnest_Max2wMdLtd_bdyc7.nc
Tile partition information for Grid 01: 0945x0210x0004 tiling: 002x001
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 473 1 210 397320
1 474 945 1 210 396480
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 473.50 0.50 210.50 RHO-points
1 473.50 945.50 0.50 210.50 RHO-points
0 1.00 473.50 0.50 210.50 U-points
1 473.50 945.00 0.50 210.50 U-points
0 0.50 473.50 1.00 210.00 V-points
1 473.50 945.50 1.00 210.00 V-points
HaloSizeI(1) = 968
HaloSizeJ(1) = 442
TileSide(1) = 478
TileSize(1) = 102770
zeta 1 Clamped Clamped Clamped Closed
ubar 1 Clamped Clamped Clamped Closed
vbar 1 Clamped Clamped Clamped Closed
u 1 Rad + Nud Rad + Nud Rad + Nud Closed
v 1 Rad + Nud Rad + Nud Rad + Nud Closed
temp 1 Gradient Gradient Gradient Closed
salt 1 Gradient Gradient Gradient Closed
tke 1 Gradient Gradient Gradient Closed
ubar_stokes 1 Gradient Gradient Gradient Closed
vbar_stokes 1 Gradient Gradient Gradient Closed
u_stokes 1 Gradient Gradient Gradient Closed
v_stokes 1 Gradient Gradient Gradient Closed
BCF_TEST BCF TEST
DIAGNOSTICS_UV Computing and writing momen Node # 1 (pid= 31238) is active.
tum diagnostic terms.
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
WEC_VF Vortex Force wave current interaction- UNDER DEVELOPMENT!!!!.
WDISS_WAVEMOD Wave energy dissipation acquired from coupled wave model.
NONLINEAR Nonlinear Model.
SWAN_COUPLING SWAN model coupling.
TS_C2HADVECTION Second-order centered horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_C2ADVECTION Second-order centered differences advection of momentum.
UV_KIRBY Compute uwave and vwave Kirby avg velocities.
WAVES_OCEAN Two-way wave-ocean models coupling.
Process Information:
Node # 0 (pid= 31237) is active.
mpirun noticed that process rank 0 with PID 31237 on node usc exited on signal 9 (Killed)
I donot know how to fix this problem. If anyone could help me out of this?
Thanks!
Xiaodong
Re: model terminates if 'DIAGNOSTICS_UV' is activated
i just a test with Inlet_test and added output for the diagnostics. It ran fine for me.
please do an update and try again.
thanks,
john
xwu
#3 Unread post by xwu »
Thanks, John!
I got the reason for my problem. The high resolution grid plus 'diagnostics' overburden the the desktop, thus it terminates in the very beginning. It runs well on cluster now.
Xiaodong
