pyroms_toolbox error
jlopez
#1 Unread post by jlopez »
I'm trying to install pyroms (downloaded from https://github.com/kshedstrom/pyroms) in my laptop. My OS is Ubuntu 14.04, and my fortran compiler gfortran.
I have follow the instructions on the README file, but changing the fortran compiler.
After installing some necessary modules, now if I try to run an example (examples/Yellow_Sea) I obtain the following:
scrip.so not found. Remapping function will not be available
Traceback (most recent call last):
  File "make_YELLOW_grd_v1.py", line 11, in <module>
    import pyroms_toolbox
  File "/usr/local/lib/python2.7/dist-packages/pyroms_toolbox/__init__.py", line 64, in <module>
    import Grid_HYCOM
  File "/usr/local/lib/python2.7/dist-packages/pyroms_toolbox/Grid_HYCOM/__init__.py", line 9, in <module>
    from flood_fast import flood_fast
  File "/usr/local/lib/python2.7/dist-packages/pyroms_toolbox/Grid_HYCOM/flood_fast.py", line 9, in <module>
    import creep
ImportError: No module named creep
I detect two errors:
1.- The "scrip.so" file is not found. Anyone has any hint to solve this problem?? I have check the forum, and I have found this viewtopic.php?f=14&t=3199#p12216 but it doesn't help me much.
2.- The "creep" python module is not found. Again, anyone can help me to solve this issue??
Thank you in advance,
Jaime
jlopez
Re: pyroms_toolbox error
#2 Unread post by jlopez »
I have found the error for "scrip.so".
I have try to compile the scrip source with its makefile, and I have a problem with netcdf libraries.
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./kinds_mod.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./constants.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./iounits.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./netcdf.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./grids.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./remap_vars.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./remap_distwgt.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./timers.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./remap_conserv.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./remap_bilinear.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./remap_bicubic.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./remap_write.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC -I/usr/local/include -c ./scrip.f
gfortran -g -fdefault-real-8 -ffixed-form -O2 -fPIC kinds_mod.o constants.o iounits.o netcdf.o grids.o remap_vars.o remap_distwgt.o remap_conserv.o remap_bilinear.o remap_bicubic.o timers.o remap_write.o scrip.o  -I/usr/local/include -o ./scrip
netcdf.o: En la función `__netcdf_mod_MOD_netcdf_error_handler':
/home/jaime/ROMSsvn/New_pyroms/pyroms-master/pyroms/external/scrip/source/./netcdf.f:67: referencia a `nf_strerror_' sin definir
grids.o: En la función `__grids_MOD_grid_init':
/home/jaime/ROMSsvn/New_pyroms/pyroms-master/pyroms/external/scrip/source/./grids.f:213: referencia a `nf_open_' sin definir
/home/jaime/ROMSsvn/New_pyroms/pyroms-master/pyroms/external/scrip/source/./grids.f:216: referencia a `nf_open_' sin definir
I will try to recompile them to solve this issue.
Any advice for the second problem (creep module)??
#3 Unread post by kate »
Sorry about that. Raphael gave me the attached files. I guess I included the python script without bothering to put creep into the install procedure.
ETA: Actually, the files are in pyroms_toolbox/pyroms_toolbox/Grid_HYCOM/. You need to go there and type "make", then put creep.so in your PYTHONPATH.
creep.tar
(20 KiB) Downloaded 439 times
jlopez
#4 Unread post by jlopez »
Thank you Kate, that works. Now I have another problems but I expect to solve them soon, otherwise I would ask you again.
Thanks again!!
Jaime
caioerick
#5 Unread post by caioerick »
I have the same problem.
>>> import pyroms
And I try import lpsolve55, but has a problem that I can't solve with conda install -c conda-forge (as suggested in viewtopic.php?f=14&t=4954&hilit=scrip.so.
>>> import lpsolve55
  File "<stdin>", line 1, in <module>
ImportError: dynamic module does not define module export function (PyInit_lpsolve55)
Does anyone have a similar problem?
