Problem
lithodes8
Problem
#1 Unread post by lithodes8 »
Hello community, I could help with this case, I do not understand it falls, I reviewed the mesh and interpolations speeds, I think everything is in order, but I run it and falls.
If someone sees something that I see, appreciate any guidance comment.
The case goes on the Catalan coast, a stretch that I took and what I try to simulate hydrodynamics is in a time of 6 days, attached the cpp file and ocean.in.
thank you very much.
my case:
#define UV_LDRAG
#undef MIX_GEO_UV
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#undef TS_MPDATA
#undef TS_DIF4
#undef MIX_GEO_TS
#define MIX_S_TS
#define SPLINES
#define DIAGNOSTICS_TS
#define DIAGNOSTICS_UV
my ocean.in
! Application title.
TITLE = Barcelona1
! C-preprocessing Flag.
MyAppCPP = BCN_1
VARNAME = ROMS/External/varinfo.dat
! Number of nested grids.
Ngrids = 1
! these parameters correctly.
Lm == 252 ! Number of I-direction INTERIOR RHO-points
Mm == 162 ! Number of J-direction INTERIOR RHO-points
N == 20 ! Number of vertical levels
Nbed = 0 ! Number of sediment bed layers
NAT = 2 ! Number of active tracers (usually, 2)
NPT = 0 ! Number of inactive passive tracers
NCS = 0 ! Number of cohesive (mud) sediment tracers
NNS = 0 ! Number of non-cohesive (sand) sediment tracers
NtileI == 1 ! I-direction partition
NtileJ == 1 ! J-direction partition
! Cha Chapman
! Cla Clamped
! Clo Closed
! Fla Flather _____N_____ j=Mm
! Gra Gradient | 4 |
! Nes Nested | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics 2 j=1
! i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Fla Fla Fla Clo ! free-surface
LBC(isUbar) == Fla Fla Fla Clo ! 2D U-momentum
LBC(isVbar) == Fla Fla Fla Clo ! 2D V-momentum
LBC(isUvel) == RadNud RadNud RadNud Clo ! 3D U-momentum
LBC(isVvel) == RadNud RadNud RadNud Clo ! 3D V-momentum
LBC(isMtke) == Fla Fla Fla Clo ! mixing TKE
LBC(isTvar) == Rad Rad Rad Clo \ ! temperature
Rad Rad Rad Clo ! salinity
! conservation, except if tidal forcing enabled. [1:Ngrids].
VolCons(west) == T ! western boundary
VolCons(east) == T ! eastern boundary
VolCons(south) == T ! southern boundary
VolCons(north) == T ! northern boundary
ad_VolCons(west) == F ! western boundary
ad_VolCons(east) == F ! eastern boundary
ad_VolCons(south) == F ! southern boundary
ad_VolCons(north) == F ! northern boundary
! Time-Stepping parameters.
NTIMES == 17280
DT == 30.0d0
NDTFAST == 40
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
! Input/Output parameters.
NRREC == 0
LcycleRST == T
NRST == 675
NSTA == 1
NFLT == 1
NINFO == 1 !mientras lo dejo en 1 .. pero cuando funcione lo cambio a 50 o más ...
LDEFOUT == T
NHIS == 720
NDEFHIS == 0
NTSAVG == 0
NAVG == 720
NDEFAVG == 0
NTSDIA == 0
NDIA == 0
NDEFDIA == 0
LcycleTLM == F
NTLM == 72
NDEFTLM == 0
LcycleADJ == F
NADJ == 120
NDEFADJ == 0
NSFF == 120
! Output check pointing GST restart parameters.
MaxIterGST = 1 ! maximun number of iterations
Ritz_tol = 1.0d-15
! Harmonic/biharmonic horizontal diffusion of tracer: [1:NAT+NPT,Ngrids].
TNU2 == 0.0d0 0.0d0 ! m2/s
TNU4 == 0.0d0 0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
! Harmononic/biharmonic, horizontal viscosity coefficient: [Ngrids].
VISC2 == 0.001d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
! Vertical mixing coefficients for active tracers: [1:NAT+NPT,Ngrids]
AKT_BAK == 5.0d-6 5.0d-6 5.0d-6 5.0d-6 ! m2/s
ad_AKT_fac== 1.0d0 1.0d0 !nondimensional
! Vertical mixing coefficient for momentum: [Ngrids].
ad_AKV_BAK == 1.0d0 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
GLS_P == 3.0d0 ! K-epsilon
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
CRGBAN_CW == 100.0d0 ! Craig and Banner wave breaking, [CAMBIO DE 0]
WEC_ALPHA == 0.0d0 !0: ALL WAVE DISSIP GOES TO BREAK AND NONE TO ROLLER
!1: all wave dissip goes to roller and none to breaking
RDRG == 3.0d-04 ! m/s
RDRG2 == 0.025d0 ! nondimensional
Zob == 0.015d0 ! m
Zos == 0.5d0 ! m
BLK_ZQ == 10.0d0 ! air humidity
BLK_ZT == 10.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
DCRIT == 3.0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
Vtransform == 1 ! transformation equation
Vstretching == 1 ! stretching function
! Vertical S-coordinates parameters, [1:Ngrids].
THETA_S == 7.0d0 ! 0 < THETA_S < 20
THETA_B == 0.4d0 ! 0 < THETA_B < 1
TCLINE == 5.00d0 ! m
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! NetCDF units attribute.
DSTART = 282.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 20101010.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 0.1d-1 ! days
ZNUDG == 0.1d0 ! days
M2NUDG == 0.0d0 ! days
M3NUDG == 0.0d0 ! days
OBCFAC == 10.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 10.0d0 ! Celsius
S0 == 30.0d0 ! PSU
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 7.6d-4 ! 1/PSU
GAMMA2 == 1.0d0
LuvSrc == F ! horizontal momentum transport
LwSrc == F ! volume vertical influx
! [1:NAT+NPT,Ngrids]. See glossary below for details.
LtracerSrc == F F ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to specify which variables to process for
! tracer climatology: [1:NAT+NPT,Ngrids]. See glossary below for details.
LsshCLM == T ! sea-surface height
Lm2CLM == T ! 2D momentum
Lm3CLM == T ! 3D momentum
LtracerCLM == T T ! temperature, salinity, inert
!If not analytical climatology fields, users need to turn ON the logical switches
!above to process the fields from the climatology NetCDF file that are needed for nudging.
LnudgeTCLM == F F ! temperature, salinity
LnudgeM2CLM == F ! 2D momentum
LnudgeM3CLM == F ! 3D momentum
DstrS == 00d0 ! starting day
DendS == 00d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
! Logical switches (TRUE/FALSE) to specify the adjoint state tracer
! variables whose sensitivity is required (NT values are expected).
Lstate(isTvar) == F F ! tracers
! Stochastic optimals time decorrelation scale (days) assumed for
! red noise processes.
SO_decay == 2.0d0 ! days
! Logical switches (TRUE/FALSE) to specify the state surface forcing
! variable whose stochastic optimals is required.
SOstate(isUstr) == T ! surface u-stress
SOstate(isVstr) == T ! surface v-stress
! Logical switches (TRUE/FALSE) to specify the surface tracer forcing
! variable whose stochastic optimals is required (NT values are expected).
SOstate(isTsur) == F F ! surface tracer flux
! Stochastic optimals surface forcing standard deviation for
! dimensionalization.
SO_sdev(isUstr) == 1.0d0 ! surface u-stress
SO_sdev(isVstr) == 1.0d0 ! surface v-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracer flux
! HISTORY output file.
Hout(idWvel) == T ! w 3D W-velocity
Hout(idOvel) == F ! omega omega vertical velocity
Hout(idUbar) == T ! ubar 2D U-velocity
Hout(idVbar) == T ! vbar 2D V-velocity
Hout(idBath) == F ! bath time-dependent bathymetry
Hout(idTvar) == T T ! temp, salt temperature and salinity
Hout(idUair) == F ! Uwind surface U-wind
Hout(idVair) == F ! Vwind surface V-wind
Hout(idUVwc) == F ! bottom max wave-current stress magnitude
Hout(idUbur) == F ! Ucur bottom U-velocity above bed
Hout(idVbvr) == F ! Vcur bottom V-velocity above bed
Hout(idW2xx) == F ! Sxx_bar 2D radiation stress, Sxx component
Hout(idW2xy) == F ! Sxy_bar 2D radiation stress, Sxy component
Hout(idW2yy) == F ! Syy_bar 2D radiation stress, Syy component
Hout(idW3xx) == F ! Sxx 3D radiation stress, Sxx component
Hout(idW3xy) == F ! Sxy 3D radiation stress, Sxy component
Hout(idW3yy) == F ! Syy 3D radiation stress, Syy component
Hout(idW3zx) == F ! Szx 3D radiation stress, Szx component
Hout(idW3zy) == F ! Szy 3D radiation stress, Szy component
Hout(idU2rs) == F ! ubar_WECstress 2D WEC U-stress
Hout(idV2rs) == F ! vbar_WECstress 2D WEC V-stress
Hout(idU3rs) == F ! u_WECstress 3D WEC U-stress
Hout(idV3rs) == F ! v_WECstress 3D WEC V-stress
Hout(idW3St) == F ! w_stokes 3D W-Stokes velocity
Hout(idW3Sd) == F ! omega_stokes 3D Omega-Stokes velocity
Hout(idWamp) == T ! Hwave wave height
Hout(idWlen) == T ! Lwave wave length, mean
Hout(idWlep) == T ! Lwavep wave length, peak
Hout(idWdir) == T ! Dwave wave direction
Hout(idWptp) == T ! Pwave_top wave surface period
Hout(idWpbt) == T ! Pwave_bot wave bottom period
Hout(idWorb) == T ! Uwave_rms wave bottom orbital velocity
Hout(idWbrk) == T ! Wave_break wave breaking (percent)
Hout(idUwav) == T ! uWave wave-depth avgeraged U-velocity
Hout(idVwav) == T ! vWave wave-depth avgeraged V-velocity
Hout(idWdif) == T ! Dissip_fric wave dissipation due to bottom friction
Hout(idWdib) == T ! Dissip_break wave dissipation due to breaking
Hout(idWdiw) == T ! Dissip_wcap wave dissipation due to white capping
Hout(idWdis) == F ! Dissip_roller wave roller dissipation
Hout(idWrol) == F ! rollA wave roller action density
Hout(idWztw) == F ! zetaw WEC quasi-static sea level adjustment
Hout(idWqsp) == F ! qsp WEC quasi-static pressure
Hout(idWbeh) == F ! bh WEC Bernoulli head
Hout(idTsur) == F ! shflux surface net heat and salt flux
Hout(idDano) == T ! rho density anomaly
Hout(idMtls) == F ! gls turbulent generic length scale
Hout(inert) == F ! inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of exposed sediment
! layer properties into HISTORY output file. Currently, MBOTP properties
! are expected for the bottom boundary layer and/or sediment models:
! Hout(idBott(isd50)), isd50 = 1 ! mean grain diameter
! Hout(idBott(idens)), idens = 2 ! mean grain density
! Hout(idBott(iwsed)), iwsed = 3 ! mean settling velocity
! Hout(idBott(itauc)), itauc = 4 ! critical erosion stress
! Hout(idBott(irlen)), irlen = 5 ! ripple length
! Hout(idBott(irhgt)), irhgt = 6 ! ripple height
! Hout(idBott(ibwav)), ibwav = 7 ! wave excursion amplitude
! Hout(idBott(izdef)), izdef = 8 ! default bottom roughness
! Hout(idBott(izapp)), izapp = 9 ! apparent bottom roughness
! Hout(idBott(izNik)), izNik = 10 ! Nikuradse bottom roughness
! Hout(idBott(izbio)), izbio = 11 ! biological bottom roughness
! Hout(idBott(izbfm)), izbfm = 12 ! bed form bottom roughness
! Hout(idBott(izbld)), izbld = 13 ! bed load bottom roughness
! Hout(idBott(izwbl)), izwbl = 14 ! wave bottom roughness
! Hout(idBott(iactv)), iactv = 15 ! active layer thickness
! Hout(idBott(ishgt)), ishgt = 16 ! saltation height
! 1 1 1 1 1 1 1 1 1
! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8
Hout(idBott) == T T T T T T T T T F F F F F F F F F
NUSER = 0
USER = 0.d0
! NetCDF-4/HDF5 compression parameters for output files.
! NC_SHUFFLE = 1 ! if non-zero, turn on shuffle filter
! NC_DEFLATE = 1 ! if non-zero, turn on deflate filter
! NC_DLEVEL = 1 ! deflate level [0-9]
GRDNAME == CASOS/bcn_4/roms_grd1.nc
ININAME == CASOS/bcn_4/ocean_ini.nc
CLMNAME == CASOS/bcn_4/clim.nc
! Input lateral boundary conditions and climatology file names. The
! USER has the option to split input data time records into several
! NetCDF files (see prologue instructions above). If so, use a single
! line per entry with a vertical bar (|) symbol after each entry,
! except the last one.
BRYNAME == CASOS/bcn_4/ocean_bry.nc
! Input forcing NetCDF file name(s). The USER has the option to enter
! have different files for wind products, heat fluxes, rivers, tides,
! etc. The model will scan the file list and will read the needed data
! from the first file in the list containing the forcing field. Therefore,
! and so on. Use a single line per entry with a continuation (\) symbol
! at the each entry, except the last one.
NFFILES == 5 ! number of forcing files
FRCNAME ==
CASOS/bcn_4/swrad6.nc\
CASOS/bcn_4/shflux6.nc\
CASOS/bcn_4/swflux6.nc\
CASOS/bcn_4/sustr6.nc\
CASOS/bcn_4/svstr6.nc
GSTNAME == ocean_gst.nc
RSTNAME == ocean_rst.nc
HISNAME == ocean_his.nc
TLMNAME == ocean_tlm.nc
TLFNAME == ocean_tlf.nc
ADJNAME == ocean_adj.nc
AVGNAME == ocean_avg.nc
DIANAME == ocean_dia.nc
STANAME == ocean_sta.nc
FLTNAME == ocean_flt.nc
APARNAM = ROMS/External/s4dvar.in
SPOSNAM = CASOS/BILBAO/BILBAO_i/stations.in
FPOSNAM = ROMS/External/floats.in
BPARNAM = ROMS/External/bioFasham.in
SPARNAM = ROMS/External/sediment.in
USRNAME = ROMS/External/MyFile.dat
270 282 02:15:00 7.621213E-04 1.543231E+02 1.543239E+02 5.960062E+08
(003,013,20) 5.423932E-01 2.915856E-01 1.852929E-01 6.176983E-01
271 282 02:15:30 7.661505E-04 1.543232E+02 1.543239E+02 5.960063E+08
(004,013,18) 2.074851E-02 1.220515E-01 1.408806E+00 9.215636E-01
272 282 02:16:00 7.726468E-04 1.543232E+02 1.543239E+02 5.960064E+08
(004,012,18) 4.784149E-02 1.918805E-01 2.327960E+00 1.772757E+00
273 282 02:16:30 8.067030E-04 1.543232E+02 1.543240E+02 5.960065E+08
(003,012,20) 2.777658E+00 1.073515E+00 2.407454E+00 5.586910E+00
274 282 02:17:00 2.977045E-03 1.543232E+02 1.543261E+02 5.960065E+08
(002,012,20) 2.739901E+01 9.369714E+00 8.074240E+00 4.528114E+01
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
Thread # 0 CPU: 727.404
Total: 727.404
Allocation and array initialization .............. 0.689 ( 0.0947 %)
Ocean state initialization ....................... 0.328 ( 0.0451 %)
Reading of input data ............................ 0.248 ( 0.0341 %)
Processing of input data ......................... 3.447 ( 0.4738 %)
Processing of output time averaged data .......... 0.436 ( 0.0600 %)
Computation of vertical boundary conditions ...... 0.079 ( 0.0108 %)
Computation of global information integrals ...... 5.018 ( 0.6899 %)
Writing of output data ........................... 0.181 ( 0.0249 %)
Model 2D kernel .................................. 539.348 (74.1470 %)
2D/3D coupling, vertical metrics ................. 3.945 ( 0.5423 %)
Omega vertical velocity .......................... 2.459 ( 0.3380 %)
Equation of state for seawater ................... 1.845 ( 0.2537 %)
3D equations right-side terms .................... 20.406 ( 2.8054 %)
3D equations predictor step ...................... 38.839 ( 5.3394 %)
Pressure gradient ................................ 14.971 ( 2.0581 %)
Harmonic mixing of tracers, S-surfaces ........... 6.955 ( 0.9562 %)
Harmonic stress tensor, S-surfaces ............... 13.153 ( 1.8081 %)
Corrector time-step for 3D momentum .............. 43.864 ( 6.0302 %)
Corrector time-step for tracers .................. 27.897 ( 3.8352 %)
Total: 724.108 99.5469
All percentages are with respect to total time = 727.404
Analytical header files used:
ROMS/Functionals/ana_btflux.h
number courant
Minimum barotropic Courant Number = 2.71042248E-01
Maximum barotropic Courant Number = 8.70451626E-01
Maximum Coriolis Courant Number = 2.89524458E-03
PLEASE IF ANYONE CAN SEE SOMETHING STRANGE NOTIFY ME, THANK YOU
Re: Problem
Have you looked at the output to see what's going wrong? It could be bad at (002,012,20).
I don't believe LBC(isFsur) of Fla is a valid option - try Cha or Che instead.
lithodes8
Re: Problem
#3 Unread post by lithodes8 »
Hello Kate, if I looked at the point (002,012,20) I still can not find the fault. And I tried LBC (isFsur) = cha on the surface as you suggested me ... it falls in the same time step.
2:16:30 273 282 8.414003E-04 1.543233E + 02 1.543241E + 02 5.960080E + 08
(004,012,20) 3.398158E 2.079186E + 00 + 00 + 00 2.970152E 8.160121E + 00
2:17:00 274 282 1.130490E-02 1.543233E + 02 1.543346E + 02 5.960081E + 08
(003,012,20) 5.093458E 2.226080E + 01 + 01 + 01 1.209906E 9.887029E + 01
I will continue checking may be happening at this point. If you see something that I have not seen you appreciate any comments.
Regards
Monica
Re: Problem
It isn't guaranteed to be bad at that point. You need to look at the restart file to see where it went bad and in which field. Probably velocity, but still - what does it look like?
lithodes8
Re: Problem
#5 Unread post by lithodes8 »
hello kate, I looked at the file and evidently ocean_rst.nc disturbance velocity is observed at the point where the model falls. I've been looking at the data input and not encounter errors. I've tried different configurations cpp and have modified some data ocean.in file and I can not make the model run. I personally believe that the input data are well. No it can be bad if you see something you do not see me comment, thanks.
Here I leave another model output.
My CPP:
#define ASSUMED_SHAPE
#undef AVERAGES
#define SPLINES
#define SPHERICAL
#define DOUBLE PRECISION
#define NONLINEAL
#define POWER_LAW
#define PROFILE
#define VAR_RHO_2D
#define K_GSCHEME
#define UV_U3HADVECTION
#define UV_C4VADVECTION
#define TS_MPDATA
#define SOLAR_SOURCE
#define MIX_GEO_TS
#define MIX_GEO_UV
#define MY25_MIXING
#define N2S2_HORAVG
#define KANTHA_CLAYSON
My ocean.in:
Application title.
TITLE = Barcelona1
MyAppCPP = BCN_1
Ngrids = 1
Lm == 252
Mm == 162
N == 20
Nbed = 0
NAT = 2
NPT = 0
NCS = 0
NNS = 0
! 1 2 3 4
LBC(isFsur) == Cha Cha Cha Clo ! free-surface
LBC(isMtke) == Rad Rad Rad Clo ! mixing TKE
NTIMES == 25920
DT == 20.0d0
NDTFAST == 40
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
NRREC == 0
LcycleRST == T
NRST == 540
NSTA == 1
NFLT == 1
LDEFOUT == T
NHIS == 1080
NDEFHIS == 0
NTSAVG == 0
NAVG == 1080
NDEFAVG == 0
NTSDIA == 0
NDIA == 0
NDEFDIA == 0
LcycleTLM == F
NTLM == 72
NDEFTLM == 0
LcycleADJ == F
NADJ == 120
NDEFADJ == 0
NSFF == 120
Ritz_tol = 1.0d-15
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
Zob == 0.015d0 ! m
Zos == 0.5d0 ! m
DCRIT == 3.0 ! m
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
TCLINE == 3.00d0 ! m
S0 == 30.0d0 ! PSU
GAMMA2 == 1.0d0
! 1 1 1 1 1 1 1 1 1
NUSER = 0
USER = 0.d0
FRCNAME ==
Output model:
Barcelona1
Operating system : Linux
25920 ntimes Number of timesteps for 3-D equations.
20.000 dt Timestep size (s) for 3-D equations.
40 ndtfast Number of timesteps for 2-D equations between
540 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1080 nHIS Number of timesteps between the writing fields
into history file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
0.0000E+00 Akv_bak Background vertical mixing coefficient (m2/s)
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
1 lmd_Jwt Jerlov water type.
7.0000E+00 theta_s S-coordinate surface control parameter.
3.000 Tcline S-coordinate surface/bottom layer width (m) used
282.000 dstart Time-stamp assigned to model initialization (days).
20101010.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.0000E-02 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E-02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.0000E-01 Znudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
T VolCons(1) NLM western edge boundary volume conservation.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T VolCons(4) NLM northern edge boundary volume conservation.
T LsshCLM Turning ON processing of SSH climatology.
T Lm2CLM Turning ON processing of 2D momentum climatology.
T Lm3CLM Turning ON processing of 3D momentum climatology.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
Input Grid File: CASOS/bcn_4/roms_grd1.nc
Input Nonlinear Initial File: CASOS/bcn_4/ocean_ini.nc
Input Forcing File 01: CASOS/bcn_4/swrad6.nc
Input Forcing File 02: CASOS/bcn_4/shflux6.nc
Input Forcing File 03: CASOS/bcn_4/swflux6.nc
Input Forcing File 04: CASOS/bcn_4/sustr6.nc
Input Forcing File 05: CASOS/bcn_4/svstr6.nc
Input Climatology File: CASOS/bcn_4/clim.nc
Input Boundary File: CASOS/bcn_4/ocean_bry.nc
Tile partition information for Grid 01: 0252x0162x0020 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 252 1 162 816480
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 253.50 0.50 163.50 RHO-points
0 0.00 253.00 0.50 163.50 U-points
0 0.50 253.50 0.00 163.00 V-points
zeta 1 Chapman Imp Chapman Imp Chapman Imp Closed
ubar 1 Flather Flather Flather Closed
vbar 1 Flather Flather Flather Closed
u 1 Rad + Nud Rad + Nud Rad + Nud Closed
v 1 Rad + Nud Rad + Nud Rad + Nud Closed
temp 1 Radiation Radiation Radiation Closed
salt 1 Radiation Radiation Radiation Closed
tke 1 Radiation Radiation Radiation Closed
Process Information:
Thread # 0 (pid= 29764) is active.
20 0.0000000 -0.0000000 0.000 0.000 -0.000 -0.000
19 -0.0500000 -0.0007603 -0.150 -0.150 -0.168 -0.187
18 -0.1000000 -0.0019414 -0.300 -0.300 -0.347 -0.394
17 -0.1500000 -0.0039690 -0.450 -0.450 -0.546 -0.642
16 -0.2000000 -0.0076391 -0.600 -0.600 -0.785 -0.969
15 -0.2500000 -0.0144346 -0.750 -0.750 -1.099 -1.448
14 -0.3000000 -0.0270074 -0.900 -0.900 -1.553 -2.206
13 -0.3500000 -0.0496464 -1.050 -1.050 -2.250 -3.450
12 -0.4000000 -0.0878699 -1.200 -1.200 -3.324 -5.448
11 -0.4500000 -0.1453465 -1.350 -1.350 -4.864 -8.377
10 -0.5000000 -0.2181019 -1.500 -1.500 -6.772 -12.045
9 -0.5500000 -0.2930976 -1.650 -1.650 -8.735 -15.820
8 -0.6000000 -0.3575721 -1.800 -1.800 -10.444 -19.088
7 -0.6500000 -0.4084171 -1.950 -1.950 -11.823 -21.696
6 -0.7000000 -0.4508634 -2.100 -2.100 -12.999 -23.898
5 -0.7500000 -0.4928804 -2.250 -2.250 -14.165 -26.079
4 -0.8000000 -0.5424010 -2.400 -2.400 -15.512 -28.624
3 -0.8500000 -0.6073645 -2.550 -2.550 -17.232 -31.914
2 -0.9000000 -0.6968391 -2.700 -2.700 -19.545 -36.390
1 -0.9500000 -0.8224431 -2.850 -2.850 -22.731 -42.613
0 -1.0000000 -1.0000000 -3.000 -3.000 -27.174 -51.347
Time Splitting Weights for Grid 01: ndtfast = 40 nfast = 56
1-0.0006038999279304 0.0250000000000000-0.0006038999279304 0.0250000000000000
2-0.0011053727845635 0.0250150974981983-0.0017092727124939 0.0500150974981983
3-0.0015044206959555 0.0250427318178123-0.0032136934084494 0.0750578293160106
4-0.0018010519301026 0.0250803423352112-0.0050147453385520 0.1001381716512218
5-0.0019952879837948 0.0251253686334638-0.0070100333223467 0.1252635402846856
6-0.0020871735042116 0.0251752508330587-0.0090972068265583 0.1504387911177443
7-0.0020767890452586 0.0252274301706640-0.0111739958718169 0.1756662212884082
8-0.0019642666586465 0.0252793498967954-0.0131382625304634 0.2009455711852036
9-0.0017498083197106 0.0253284565632616-0.0148880708501740 0.2262740277484652
10-0.0014337071879729 0.0253722017712543-0.0163217780381469 0.2516462295197196
11-0.0010163717024450 0.0254080444509537-0.0173381497405919 0.2770542739706733
12-0.0004983525116731 0.0254334537435148-0.0178365022522649 0.3024877277141881
13 0.0001196277614762 0.0254459125563066-0.0177168744907887 0.3279336402704947
14 0.0008366419202876 0.0254429218622697-0.0168802325705011 0.3533765621327644
15 0.0016515227599278 0.0254220058142625-0.0152287098105733 0.3787985679470269
16 0.0025628247984349 0.0253807177452643-0.0126658850121384 0.4041792856922913
17 0.0035687831729657 0.0253166471253035-0.0090971018391727 0.4294959328175947
18 0.0046672697013015 0.0252274275459793-0.0044298321378712 0.4547233603635741
19 0.0058557461086128 0.0251107458034468 0.0014259139707416 0.4798341061670209
20 0.0071312144194823 0.0249643521507315 0.0085571283902239 0.5047984583177524
21 0.0084901645151857 0.0247860717902444 0.0170472929054096 0.5295845301079968
22 0.0099285188562319 0.0245738176773648 0.0269758117616416 0.5541583477853615
23 0.0114415743701613 0.0243256047059590 0.0384173861318028 0.5784839524913206
24 0.0130239415046020 0.0240395653467049 0.0514413276364049 0.6025235178380255
25 0.0146694804455855 0.0237139668090899 0.0661108080819904 0.6262374846471154
26 0.0163712345011199 0.0233472297979502 0.0824820425831103 0.6495847144450656
27 0.0181213606500220 0.0229379489354222 0.1006034032331323 0.6725226633804878
28 0.0199110572560077 0.0224849149191717 0.1205144604891400 0.6950075782996595
29 0.0217304889470413 0.0219871384877715 0.1422449494361813 0.7169947167874310
30 0.0235687086599425 0.0214438762640955 0.1658136580961238 0.7384385930515265
31 0.0254135768502523 0.0208546585475969 0.1912272349463761 0.7592932515991234
32 0.0272516778673573 0.0202193191263406 0.2184789128137333 0.7795125707254640
33 0.0290682334948725 0.0195380271796567 0.2475471463086058 0.7990505979051207
34 0.0308470136562825 0.0188113213422849 0.2783941599648883 0.8178619192474056
35 0.0325702442858409 0.0180401460008778 0.3109644042507291 0.8359020652482834
36 0.0342185123647286 0.0172258898937318 0.3451829166154578 0.8531279551420151
37 0.0357706681224704 0.0163704270846136 0.3809535847379282 0.8694983822266287
38 0.0372037244036097 0.0154761603815518 0.4181573091415379 0.8849745426081804
39 0.0384927531996420 0.0145460672714616 0.4566500623411799 0.8995206098796420
40 0.0396107793462069 0.0135837484414705 0.4962608416873868 0.9131043583211125
41 0.0405286713855386 0.0125934789578153 0.5367895130729254 0.9256978372789278
42 0.0412150295941741 0.0115802621731769 0.5780045426670996 0.9372780994521047
43 0.0416360711759210 0.0105498864333225 0.6196406138430206 0.9478279858854273
44 0.0417555126200830 0.0095089846539245 0.6613961264631036 0.9573369705393517
45 0.0415344492249439 0.0084650968384224 0.7029305756880475 0.9658020673777742
46 0.0409312317865102 0.0074267356077988 0.7438618074745578 0.9732288029855730
47 0.0399013404525124 0.0064034548131361 0.7837631479270702 0.9796322577987091
48 0.0383972557416642 0.0054059213018233 0.8221604036687344 0.9850381791005324
49 0.0363683267281804 0.0044459899082817 0.8585287303969148 0.9894841690088140
50 0.0337606363915535 0.0035367817400771 0.8922893667884684 0.9930209507488911
51 0.0305168641315885 0.0026927658302883 0.9228062309200569 0.9957137165791794
52 0.0265761454486959 0.0019298442269986 0.9493823763687528 0.9976435608061780
53 0.0218739287894439 0.0012654405907812 0.9712563051581966 0.9989090013969592
54 0.0163418295573680 0.0007185923710451 0.9875981347155646 0.9996275937680043
55 0.0099074812890402 0.0003100466321109 0.9975056160046047 0.9999376404001151
56 0.0024943839953957 0.0000623595998849 1.0000000000000004 1.0000000000000000
ndtfast, nfast = 40 56 nfast/ndtfast = 1.40000
1.000000000000 1.039265571007 0.519632785503 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.21300
Minimum X-grid spacing, DXmin = 2.58599529E-02 km
Maximum X-grid spacing, DXmax = 2.59406915E-02 km
Minimum Y-grid spacing, DYmin = 2.90516375E-02 km
Maximum Y-grid spacing, DYmax = 2.91736244E-02 km
Minimum Z-grid spacing, DZmin = 1.50000000E-01 m
Maximum Z-grid spacing, DZmax = 8.73439803E+00 m
Minimum barotropic Courant Number = 1.80707181E-01
Maximum barotropic Courant Number = 5.80301084E-01
Maximum Coriolis Courant Number = 1.93015441E-03
NLM: GET_STATE - Read state initial conditions, t = 282 00:00:00
(Grid 01, File: ocean_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = -4.75686155E-02 Max = -4.68640514E-02)
(Min = -1.68286972E-02 Max = 8.52795783E-03)
(Min = -1.04508307E-02 Max = 3.14428136E-02)
- u-momentum component
(Min = -4.30831648E-02 Max = 3.23080756E-02)
- v-momentum component
(Min = -3.38471904E-02 Max = 5.60225472E-02)
- potential temperature
(Min = 1.98577404E+01 Max = 2.26086121E+01)
- salinity
(Min = 3.77595253E+01 Max = 3.81493454E+01)
GET_2DFLD - surface u-momentum stress, t = 282 00:00:00
(Rec=0000001, Index=1, File: sustr6.nc)
(Tmin= 282.0000 Tmax= 288.0000)
(Min = -4.21995541E-06 Max = -4.21995541E-06)
GET_2DFLD - surface v-momentum stress, t = 282 00:00:00
(Rec=0000001, Index=1, File: svstr6.nc)
(Min = -8.60704946E-06 Max = -8.60704946E-06)
GET_2DFLD - solar shortwave radiation flux, t = 282 00:00:00
(Rec=0000001, Index=1, File: swrad6.nc)
GET_2DFLD - surface net heat flux, t = 282 00:00:00
(Rec=0000001, Index=1, File: shflux6.nc)
(Min = 9.52333353E-06 Max = 9.52333353E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 282 00:00:00
(Rec=0000001, Index=1, File: swflux6.nc)
(Min = -6.70138671E-13 Max = -6.70138671E-13)
GET_NGFLD - free-surface western boundary condition, t = 282 00:00:00
(Rec=0000001, Index=2, File: ocean_bry.nc)
(Min = -4.69566435E-02 Max = -4.68640514E-02)
GET_NGFLD - free-surface eastern boundary condition, t = 282 00:00:00
(Min = -4.75686155E-02 Max = -4.73041758E-02)
GET_NGFLD - free-surface southern boundary condition, t = 282 00:00:00
(Min = -4.75598648E-02 Max = -4.69292477E-02)
GET_NGFLD - 2D u-momentum western boundary condition, t = 282 00:00:00
(Min = -1.81029644E-03 Max = 5.90772880E-03)
GET_NGFLD - 2D v-momentum western boundary condition, t = 282 00:00:00
(Min = 0.00000000E+00 Max = 1.85734350E-02)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 282 00:00:00
(Min = -1.68286972E-02 Max = 0.00000000E+00)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 282 00:00:00
(Min = -1.04508307E-02 Max = 9.80745535E-04)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 282 00:00:00
(Min = -1.68286972E-02 Max = 3.74676939E-03)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 282 00:00:00
(Min = -1.04508307E-02 Max = 1.31975661E-03)
GET_NGFLD - 3D u-momentum western boundary condition, t = 282 00:00:00
(Min = -1.47706280E-02 Max = 1.60237700E-02)
GET_NGFLD - 3D v-momentum western boundary condition, t = 282 00:00:00
(Min = -1.20345009E-02 Max = 3.74556296E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 282 00:00:00
(Min = -4.30457070E-02 Max = 3.14428769E-02)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 282 00:00:00
(Min = -3.26971523E-02 Max = 5.38541190E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 282 00:00:00
(Min = -4.30831648E-02 Max = 2.77706143E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 282 00:00:00
(Min = -2.94906776E-02 Max = 5.06360568E-02)
GET_2DFLD - sea surface height climatology, t = 282 00:00:00
(Rec=0000001, Index=1, File: clim.nc)
GET_2DFLD - vertically integrated u-momentum climatologt = 282 00:00:00
GET_2DFLD - vertically integrated v-momentum climatologt = 282 00:00:00
GET_3DFLD - u-momentum component climatology, t = 282 00:00:00
GET_3DFLD - v-momentum component climatology, t = 282 00:00:00
GET_3DFLD - potential temperature climatology, t = 282 00:00:00
GET_3DFLD - salinity climatology, t = 282 00:00:00
Maximum grid stiffness ratios: rx0 = 6.500888E-02 (Beckmann and Haidvogel)
rx1 = 1.353364E+00 (Haney)
Initial basin volumes: TotVolume = 5.2783853736E+08 m3
MinVolume = 1.1440514089E+02 m3
MaxVolume = 6.5637570868E+03 m3
Max/Min = 5.7372920796E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00025920)
GET_2DFLD - surface u-momentum stress, t = 282 06:00:00
(Rec=0000002, Index=2, File: sustr6.nc)
(Min = -4.98346302E-06 Max = -4.98346302E-06)
GET_2DFLD - surface v-momentum stress, t = 282 06:00:00
(Rec=0000002, Index=2, File: svstr6.nc)
(Min = -8.77611746E-06 Max = -8.77611746E-06)
GET_2DFLD - solar shortwave radiation flux, t = 282 06:00:00
(Rec=0000002, Index=2, File: swrad6.nc)
(Min = 9.79282064E-07 Max = 9.79282064E-07)
GET_2DFLD - surface net heat flux, t = 282 06:00:00
(Rec=0000002, Index=2, File: shflux6.nc)
GET_2DFLD - surface net freswater flux, (E-P), t = 282 06:00:00
(Rec=0000002, Index=2, File: swflux6.nc)
GET_NGFLD - free-surface western boundary condition, t = 282 06:00:00
(Rec=0000002, Index=1, File: ocean_bry.nc)
(Min = -4.16261256E-02 Max = -4.13955040E-02)
GET_NGFLD - free-surface eastern boundary condition, t = 282 06:00:00
(Min = -4.21330892E-02 Max = -4.13663946E-02)
GET_NGFLD - free-surface southern boundary condition, t = 282 06:00:00
(Min = -4.21330892E-02 Max = -4.16261256E-02)
GET_NGFLD - 2D u-momentum western boundary condition, t = 282 06:00:00
(Min = -7.05329655E-03 Max = 0.00000000E+00)
GET_NGFLD - 2D v-momentum western boundary condition, t = 282 06:00:00
(Min = -5.46532776E-03 Max = 7.50006596E-03)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 282 06:00:00
(Min = -3.32110785E-02 Max = 0.00000000E+00)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 282 06:00:00
(Min = -1.73836630E-02 Max = 0.00000000E+00)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 282 06:00:00
(Min = -3.32110785E-02 Max = -7.05329655E-03)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 282 06:00:00
(Min = -1.64540987E-02 Max = -5.46532776E-03)
GET_NGFLD - 3D u-momentum western boundary condition, t = 282 06:00:00
(Min = -2.62717977E-02 Max = 5.34539530E-03)
GET_NGFLD - 3D v-momentum western boundary condition, t = 282 06:00:00
(Min = -1.51458308E-02 Max = 1.90994795E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 282 06:00:00
(Min = -6.21158145E-02 Max = 1.08285658E-02)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 282 06:00:00
(Min = -3.37868407E-02 Max = 2.61279792E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 282 06:00:00
(Min = -6.22515157E-02 Max = 9.63686593E-03)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 282 06:00:00
(Min = -3.04044560E-02 Max = 2.51563080E-02)
GET_2DFLD - sea surface height climatology, t = 282 06:00:00
(Rec=0000002, Index=2, File: clim.nc)
(Min = -4.21330892E-02 Max = -4.13201377E-02)
GET_2DFLD - vertically integrated u-momentum climatologt = 282 06:00:00
(Min = -3.32110785E-02 Max = 1.93782919E-03)
GET_2DFLD - vertically integrated v-momentum climatologt = 282 06:00:00
(Min = -1.75860785E-02 Max = 1.59236267E-02)
GET_3DFLD - u-momentum component climatology, t = 282 06:00:00
(Min = -6.22515157E-02 Max = 1.27959438E-02)
GET_3DFLD - v-momentum component climatology, t = 282 06:00:00
(Min = -3.59462500E-02 Max = 3.38078290E-02)
GET_3DFLD - potential temperature climatology, t = 282 06:00:00
(Min = 1.99542446E+01 Max = 2.25935993E+01)
GET_3DFLD - salinity climatology, t = 282 06:00:00
(Min = 3.77610054E+01 Max = 3.81456871E+01)
0 282 00:00:00 2.500370E-04 1.535144E+02 1.535147E+02 5.966100E+08
(148,072,20) 2.615600E-02 3.788935E-02 0.000000E+00 6.472584E-02
DEF_HIS - creating history file, Grid 01: ocean_his.nc
1 282 00:00:20 2.472315E-04 1.535125E+02 1.535127E+02 5.966100E+08
(122,072,07) 2.696143E-03 5.031236E-04 1.895106E-01 6.611556E-02
2 282 00:00:40 2.466406E-04 1.535115E+02 1.535118E+02 5.966100E+08
(127,078,18) 3.726799E-03 1.363789E-02 6.103641E-01 6.885610E-02
________________________________________
1926 282 10:42:00 4.493968E-03 1.535481E+02 1.535526E+02 5.967331E+08
(225,005,07) 1.198266E-01 5.693774E-02 4.283715E+00 1.627468E+00
1927 282 10:42:20 4.819068E-03 1.535481E+02 1.535529E+02 5.967332E+08
(227,005,07) 2.009752E+00 1.227441E-01 4.368652E+00 4.397832E+00
1928 282 10:42:40 6.561588E-03 1.535481E+02 1.535546E+02 5.967333E+08
(226,005,06) 1.869035E+00 6.507227E-01 1.208935E+01 1.029872E+01
1929 282 10:43:00 2.936633E-02 1.536598E+02 1.536892E+02 5.967334E+08
(225,005,07) 5.002982E+00 4.321150E-01 2.153778E+01 3.258854E+01
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000003
Thread # 0 CPU: 4630.433
Total: 4630.433
Allocation and array initialization .............. 0.225 ( 0.0049 %)
Ocean state initialization ....................... 0.031 ( 0.0007 %)
Reading of input data ............................ 0.388 ( 0.0084 %)
Processing of input data ......................... 25.627 ( 0.5534 %)
Computation of vertical boundary conditions ...... 1.158 ( 0.0250 %)
Computation of global information integrals ...... 34.793 ( 0.7514 %)
Writing of output data ........................... 1.024 ( 0.0221 %)
Model 2D kernel .................................. 1582.227 (34.1702 %)
2D/3D coupling, vertical metrics ................. 29.175 ( 0.6301 %)
Omega vertical velocity .......................... 17.761 ( 0.3836 %)
Equation of state for seawater ................... 60.463 ( 1.3058 %)
My2.5 vertical mixing parameterization ........... 429.981 ( 9.2860 %)
3D equations right-side terms .................... 115.450 ( 2.4933 %)
3D equations predictor step ...................... 233.590 ( 5.0447 %)
Pressure gradient ................................ 95.124 ( 2.0543 %)
Harmonic mixing of tracers, geopotentials ........ 161.787 ( 3.4940 %)
Harmonic stress tensor, geopotentials ............ 261.755 ( 5.6529 %)
Corrector time-step for 3D momentum .............. 114.467 ( 2.4720 %)
Corrector time-step for tracers .................. 1440.522 (31.1099 %)
Total: 4605.548 99.4626
All percentages are with respect to total time = 4630.433
number of time records written in HISTORY file = 00000002
number of time records written in RESTART file = 00000004
ROMS/TOMS: DONE... Friday - March 13, 2015 - 3:29:04 PM
_________________________________________________________________________________
thank
Re: Problem
#6 Unread post by kate »
We like to see plots of the fields going bad - which is it? Where is the trouble?
Re: Problem
#7 Unread post by wilkin »
Your log file says:
... etc.
Is your grid really so fine that you have grid spacings of 25 m
Your log file says:
for tracer 02: salt
Those are very stiff nudging time scales. Especially for the free-surface that would be almost reflecting, except you are not doing any nudging on the boundary because you have Chapman Implicit.
Check your boundary conditions, because the logfile says you have a mix of Radiation and Radiation+Nudging. Did you mean to treat boundary 1 differently?
You have activated explicit horizontal viscosity (UV_VIS2) and diffusion (TS_DIF2) but set a very small coefficient for viscosity, and zero for tracers. The log file reports:
Even for a 25 m grid, that's a grid Reynolds number of Re = U.dx/nu = 2500 at a modest characteristic U scale of 10 cm/s. So that's effectively no friction at all.
