Segmentation fault at the start
Information about ongoing ROMS/TOMS applications
lalvarez
#1 Unread post by lalvarez »
Hello All
I'm having a problem by the time i try to run ROMS, this is what i got
ggv@SNI01 ~/roms/Projects/Leo $ ./oceanO <leo.in >out00.txt
Backtrace for this error:
#0 0x7FACD9F6A7D7
#1 0x7FACD9F6ADDE
#2 0x7FACD96ACD3F
#3 0x414C37 in read_fltpar_
#4 0x409155 in inp_par_
#5 0x403699 in __ocean_control_mod_MOD_roms_initialize
Segmentation fault
I attach my floats file
I really appreciate your help on this
Thanks in advance
Leofloats.in
(13.27 KiB) Downloaded 1649 times
m.hadfield
Re: Segmentation fault at the start
I suggest you get into read_fltpar with a debugger or (my choice) add some WRITE statements.
It would be helpful if your compiler told you the line number at which the error occurred. Most compilers can be persuaded to do this. For Gfortran (on most platforms) you just need to set the USE_DEBUG make variable.
lalvarez
#3 Unread post by lalvarez »
Hello Mike
Thanks for your comment, acrually we have solve that problem, what we are facing now iare the DT and dt, time steps. We are running on a large domain (figure atteched) and we can not fine aa adecuate pair of the to make Roms run, it blows up at the very start, here i attach the file too (out00.txt).
Thanks in advance Mike
Figure.docx
(1.11 MiB) Downloaded 1598 times
out00.txt
(38.68 KiB) Downloaded 1710 times
I suggest you set NINFO to 1 so that diag can check for extreme values every timestep. Then you can perhaps see what is going bad before the whole grid is full of NaN. When it saves a record to the restart file like that, look at it with your favorite viewer, ncview or whatever you like. Where is it blowing up? Perhaps you should also look at your boundary and forcing files. What are you doing with the ZCLIMATOLOGY?
machaielder
#5 Unread post by machaielder »
Hello Every one. I am having the the following error error message (see the log file in attachment) ; my compiler is gfortran;
Any help please
sofala.log
(11.41 KiB) Downloaded 1522 times
#6 Unread post by kate »
#4 0x4C9809 in check_multifile_
#5 0x433911 in initial_
Can you show us the part of your ocean.in that refers to the boundary, climatology and forcing files? Which version of ROMS is this, exactly?
machaielder
#7 Unread post by machaielder »
Dear Kate
thank you for replying.my ROMS version 3.7.
I send in attachment my ocean.in
Kindest Regards
ocean.in
(116.92 KiB) Downloaded 1845 times
#8 Unread post by kate »
     NFFILES ==                           ! number of unique forcing files
     FRCNAME ==                ! forcing file 1, grid 1
I suggest you put NFFILES == 1 even if you don't have any files. Also, provide some bogus filename for the forcing file. ROMS will allocate the FRC object to have NFFILES elements in it, so I don't know what it would do with a blank there. Nothing good, obviously. Also, you want a filename for FRCNAME just for error reporting. If ROMS thinks it needs a forcing file, it will try to open it, and the error is more meaningful with "unable to open file: some_bogus_forcing.nc" than with a blank filename.
