I'm trying to install ROMS on a windows XP laptop.
First, I have installed the netcdf librairy for matlab and second Cygwin, with the ar, flex, yacc, makeinfo, autoconf, tcsh packages and gcc, g++ and g77 compilers. All this allowed me to install netcdf for g77 in the /usr/local directory.
Then I tried to redo the Peruvian example, as it has been provided by Pierrick Penven.
There is no problem with the matlab routines start, make_grid, make_forcing andmake_clim, that generate netcdf files.
The next step consist in compiling ROMS, thanks to jobcomp. Since I use g77, I used this jobcomp:
#!/bin/tcsh
# COMPILATION JOB #
# set source, compilation and run directories
set SOURCE=../Roms_Agrif
set SCRDIR=../Compile
set RUNDIR=`pwd`
# Linux compiler options (only relevant to Linux OS)
set LINUX_FC=g77
# set 32 or 64 Bits executable
set BITS=THIRTYTWO
# set NETCDF directories
set NETCDFLIB=-L/usr/local/lib/
set NETCDFINC=-I/usr/local/include/
# END OF USER'S MODIFICATIONS
# Use GNU Make command
set MAKE = make
# clean scratch area
rm -rf $SCRDIR
mkdir $SCRDIR
# copy SOURCE code
cp -f ${SOURCE}/*.F $SCRDIR
cp -f ${SOURCE}/*.h $SCRDIR
cp -f ${SOURCE}/Make* $SCRDIR
cp -f ${SOURCE}/testkeys $SCRDIR
cp -f valwinrun ${SOURCE}
cp -f ${SOURCE}/jobcomp $SCRDIR
cp -f ${SOURCE}/amr.in $SCRDIR
cp -Rf ${SOURCE}/AGRIFZOOM $SCRDIR
# overwrite with local files
cp -f *.F $SCRDIR
cp -f Make* $SCRDIR
cp -f jobcomp $SCRDIR
cp -f amr.in $SCRDIR
# Change directory
cd $SCRDIR
pwd
# initialize LDFLAGS1
setenv LDFLAGS1 "$NETCDFLIB"
setenv CPPFLAGS1 "$NETCDFINC"
# determine operating system
set uname=Linux
echo $uname
echo "OPERATING SYSTEM IS:" $uname
# Set compilation options
set OS = Linux
##set CONV=conv.linux
setenv CPP1 "cpp -Wtraditional"
setenv CFT1 g77
setenv FFLAGS1 "-O3 -Wall"
setenv LDFLAGS1 "$LDFLAGS1"
# determine if the compilation of AGRIF is necessary
unset COMPILEAGRIF
if { eval `$CPP1 testkeys | grep -i -q agrif` } then
set COMPILEAGRIF = TRUE
setenv FFLAGS1 "$FFLAGS1 -IAGRIFZOOM"
setenv LDFLAGS1 "-LAGRIFZOOM -lagrif $LDFLAGS1"
endif
#echo $COMPILEAGRIF
# determine if the openmp compilation is necessary
unset COMPILEOMP
if { eval `$CPP1 testkeys | grep -i -q openmp` } then
set COMPILEOMP = TRUE
setenv FFLAGS1 "$FFLAGS1 -openmp"
endif
# determine if the mpi compilation is necessary
unset COMPILEMPI
if { eval `$CPP1 testkeys | grep -i -q mpiisdefined` } then
set COMPILEMPI = TRUE
setenv LDFLAGS1 "$LDFLAGS1 $MPILIB"
setenv FFLAGS1 "$FFLAGS1 $MPIINC"
endif
# write the Makedefs according to previous flags
echo 's?$(FFLAGS1)?'$FFLAGS1'?g' > flags.tmp
echo 's?$(LDFLAGS1)?'$LDFLAGS1'?g' >> flags.tmp
echo 's?$(CPP1)?'$CPP1'?g' >> flags.tmp
echo 's?$(CFT1)?'$CFT1'?g' >> flags.tmp
echo 's?$(CPPFLAGS1)?'$CPPFLAGS1'?g' >> flags.tmp
sed -f flags.tmp Makedefs.generic > Makedefs
rm -f flags.tmp
pwd
# clean scratch
pwd
$MAKE clobber
pwd
# compile the precompiling program
$MAKE mpc
And this last instruction does not work
Please, please, can somebody help me? Is there an other solution to run ROMS under windows? Thanks.
Regards,
Valere
