In mod_sources.F it is stated that the direction of rivers (SOURCES % Dsrc) should be zero for river flow along the xi-direction and larger than zero for flow along the eta-direction. And in pre_step3d.F, step2d.F and step3d_uv.F the IF-test roughly follows this convention:
IF (INT(Dsrc(is)).eq.0) THEN
ELSE
ELSE IF (INT(Dsrc(is)).eq.1) THEN
This seems to be the case for roms-2.1, 2.2 and 3.0.
Sorry if I overlooked some logic of the code.
Paal Erik
