problem creating 'contact' file for 3-layer grid nesting!
youngstor
#1 Unread post by youngstor »
Hi ROMS community,
I just started to play with the newest version of ROMS, and one important update is the way it handles grid nesting. The new ROMS now requires users to provide a 'contact' file to specify the overlapping regions between nesting grids. However I ran into some difficulties while trying to use the 'contact.m' script to generate 'contact' files. Following are the details:
I plan to do a 3-layer nesting, and I already have the parent grid. The parent grid is already created with reasonable bathymetry and masking, and the parent grid is named 'roms_grid_lyr1.nc' (size(h)=300x120).
I used the following code to create child and grand-child grids and create the contact file:
netcdf_load roms_grid_lyr1.nc
% child grid lyr 2 - ref5
% Select child indices
Istr=130; Iend=174; Jstr=40; Jend=104;    %
%now make some plots and call the coarse-> fine
ref_ratio=5;
F=coarse2fine('roms_grid_lyr1.nc','roms_grid_lyr2_ref5.nc', ...
              ref_ratio,Istr,Iend,Jstr,Jend);
% grand-child grid lyr 3 - ref3
netcdf_load roms_grid_lyr2_ref5.nc
Istr=75; Iend=171; Jstr=60; Jend=249;    %
ref_ratio=3;
F=coarse2fine('roms_grid_lyr2_ref5.nc','roms_grid_lyr3_ref3.nc', ...
Executing above code gave me all 3 grid files. When I ran the following code with only the parent and child grids, I was able to successfully create a contact file 'roms_contact.nc':
Gnames={'roms_grid_lyr1.nc', 'roms_grid_lyr2_ref5.nc'};
[S,G]=contact(Gnames,'roms_contact.nc');
However, I wanted to nest all 3 grids, and when I ran the following code with all 3 grids, I got an error:
Gnames={'roms_grid_lyr1.nc', 'roms_grid_lyr2_ref5.nc', 'roms_grid_lyr3_ref3.nc'};
Is =
   Empty matrix: 0-by-1
Error using  .*
Matrix dimensions must agree.
Error in grid_connections (line 224)
          Iwest  = ones(size(Jwest )).*Is;
Error in contact (line 316)
S = grid_connections(G, S);
I also experimented and ran only with child and grand-child grids like the following, and I still got the same error:
Gnames={'roms_grid_lyr2_ref5.nc', 'roms_grid_lyr3_ref3.nc'};
Error using  .*
I tried to look into the code and figure out how the code works, but still couldn't find a solution. Can the ROMS developers give me some clues?
I've attached my parent grid file, so you can easily repeat the above problem.
I thank you for your kind help!
Xiufeng
roms_grid_lyr1.nc
parent grid file
(7.66 MiB) Downloaded 375 times
Re: problem creating 'contact' file for 3-layer grid nesting
#2 Unread post by wilkin »
Yes, there are bugs in the 3-level nesting code for the contacts file.
We're working on it and will announce a solution when we have it corrected.
youngstor
#3 Unread post by youngstor »
Hi John,
I appreciate your response. I am looking forward to seeing a solution to this problem soon!
Xiufeng
wilkin wrote:Yes, there are bugs in the 3-level nesting code for the contacts file.
