Help with linking netcdf library
PJ_CAGE
#1 Unread post by PJ_CAGE »
Hi!
Moved to use Ubuntu and finally managed to install netcdf-fortran with parallel capacity, after many support-mails...
Now I'm trying to compile the upwelling case, but I have some linking problem. I don't know how to set the links.
Can I do this in the build.bash file, and if so, where do I do that?
Here is part of the error message;
close_io.f90:(.text+0x106e): undefined reference to `__netcdf_MOD_nf90_strerror'
The whole output is included in the attached errors.txt
I also attch the build.bash so you can see what I'm doing.
I find in the library;
per@UiT-HP-Z620:~/Projects/upwelling$ ls /usr/local/lib
libnetcdf.a libnetcdff.a libnetcdff.la libnetcdf.la libz.a libz.so libz.so.1 libz.so.1.2.8 pkgconfig python2.7 python3.4
Thankful for any help on this!
build.bash
(16.75 KiB) Downloaded 359 times
errors.txt
(185.58 KiB) Downloaded 370 times
Re: Help with linking netcdf library
You don't include the full output of the make so we can't see the final link command. The most common problem is not getting the -lnetcdff in the link and therefore not getting the library at all. If you have USE_NETCDF4, what is the output of "nc-config --flibs"?
PJ_CAGE
#3 Unread post by PJ_CAGE »
Hi!
Thanks for your reply and sorry I'm such a newb here.
I tried to redirect the output using "./build.bash &>errors.txt", but apparently not all output goes in that file..?
Is there a better way?
The output from nc-config --all
per@UiT-HP-Z620:~/Projects/upwelling$ nc-config --all
This netCDF 4.3.2 has been built with the following features:
--cc -> mpicc
--cflags -> -I/usr/local/include -I/usr/include
--libs -> -L/usr/local/lib -L/usr/lib -lnetcdf -lm -lhdf5 -lz -ldl
--has-c++ -> no
--cxx ->
--has-c++4 -> no
--cxx4 ->
--fc ->
--fflags ->
--flibs ->
--has-f90 -> no
--has-dap -> no
--has-nc2 -> yes
--has-nc4 -> no
--has-hdf5 -> no
--has-hdf4 -> no
--has-pnetcdf-> no
--prefix -> /usr/local
--includedir-> /usr/local/include
--version -> netCDF 4.3.2
So, yes the lnetcdff is missing here. Where am I supposed to specify the links?
In the build.bash or somewhere else? The make-file? Which make-file?
All the best!
//Pär
The thing invoking nc-config is the Makefile snippet for your system in the Compilers directory. For instance, ifort and Linux will have a file there. Please try nf-config instead of nc-config to see if that is working. If so, you can modify the file in the Compilers directory accordingly.
kapitzah
#5 Unread post by kapitzah »
I had a similar problem with a Debian system (Ubuntu is based on Debian).
The nc-config command should be able to find the fortran-related libs by invoking nf-config as long as that is in the path. There is a very subtle system related problem with the way nc-config is invoked: It is a script using /bin/sh (see first line). On my system /bin/sh is a link to /bin/dash and not /bin/bash as expected. dash and bash are NOT compatible. dash obviously has a problem with the if-clause in nc-config which checks for the presence of nf-config. On my Debian system I was able to change this behaviour with the help of "dpkg-reconfigure bash" which basically relinked /bin/sh to /bin/bash. Then it worked!
Check on your Ubuntu system what /bin/sh actually is (executable or link to something) and redirect the link if necessary. Maybe "dpkg-reconfigure bash" also works on your system!
PJ_CAGE
#6 Unread post by PJ_CAGE »
Thanks again!
I boldly (didn't exactly know what I was doing...)changed the Linux-gfrortran.mk by changing the line;
LIBS := -L$(NETCDF_LIBDIR) -lnetcdf
to;
LIBS := -L$(NETCDF_LIBDIR) -lnetcdff -lnetcdf #PJ
This solved my problem. The thing compiled without errors and now I have an "oceanM" file, which runs nicely on my 12 cores!!!!
Thats a huge step forward for me.
All the best!
//Pär
