error message when running build.bash for upwelling
LeaF_7
#1 Unread post by LeaF_7 »
This is a first time user of ROMS and I am trying to build the upwelling example but failed.
I am doing this with gfortran on MacOSX 10.9.4, netcdf-fortran-4.4.1rc installed
When I run ./build.bash the model finally end up with the problem below,
Undefined symbols for architecture x86_64:
  "___netcdf_MOD_nf90_close", referenced from:
      ___mod_netcdf_MOD_netcdf_close in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_create", referenced from:
      ___mod_netcdf_MOD_netcdf_create in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_put_var_text", referenced from:
      ___mod_netcdf_MOD_netcdf_put_svar_0d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_redef", referenced from:
      ___mod_netcdf_MOD_netcdf_redef in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_strerror", referenced from:
      _close_out_ in libUTIL.a(close_io.o)
  "___netcdf_MOD_nf90_sync", referenced from:
      ___mod_netcdf_MOD_netcdf_sync in libMODS.a(mod_netcdf.o)
ld: symbol(s) not found for architecture x86_64
make: *** [/Users/linfan/src/projects/upwelling/oceanM] Error 1
I am not quite sure what's wrong with my gfortran setup. Hope someone could help me figure this out.
And here is my nf-config --all output.
--cc        -> gcc
  --cflags    ->  -I/opt/local/include
  --fc        -> gfortran
  --fflags    -> -I/opt/local/include
  --flibs     -> -L/opt/local/lib -lnetcdff  -lnetcdf
  --has-f90   -> no
  --has-f03   -> yes
  --has-nc2   -> no
  --has-nc4   -> no
  --prefix    -> /opt/local
  --includedir-> /opt/local/include
  --version   -> netCDF-Fortran 4.4.1-rc1
Thanks a lot!
Fan Lin
Re: error message when running build.bash for upwelling
My husband asks where your gfortran came from. Was it from Macports or some other source?
Also, can you provide the output of the NetCDF-fortran configure step and its Makefile?
There's a lot that can go wrong on a Mac.
LeaF_7
#3 Unread post by LeaF_7 »
kate wrote:My husband asks where your gfortran came from. Was it from Macports or some other source?
Thanks for the reply, Kate.
My gfortran comes from the Macports with gcc48 I think.
The output of the configure step and the Makefile are attached in txt files, I hope I provide the right thing to you. I will find a Linux machine and try ROMS on that to see what happens... Agreed on your quote there...
Thanks a lot!
Makefile.txt
Makefile from netcdf-fortran
(33.14 KiB) Downloaded 703 times
output_configure_netcdf-fortran.rtf
out put from the ./configure in netcdf-fortran
(12.13 KiB) Downloaded 704 times
lvanroekel
#4 Unread post by lvanroekel »
Have you checked in your build.bash file to see if the line "export USE_NETCDF4=ON" is not commented out? If it is commented out, the Darwin-gfortran.mk file does not add
-lnetcdff to LIBS.
LeaF_7
#5 Unread post by LeaF_7 »
Hi Ivan,
I did comment that out but it doesn't work neither.
And something interesting happened after I desperately run make uninstall in the netcdf C and fortran source directory, and I run ./build.bash and it worked... I don't know why.
I got OceanS and OceanM after compiling build.bash.
Finally ROMS give me some output, looks it worked on my machine....
Thanks to all ~
cdibble
#6 Unread post by cdibble »
I am having this same error on the build.bash run for the Upwelling test case. I am running on Mac OSX Mavericks.
I have successfully built netcdf-c and netcdf-fortran libraries from source code (I did not use MacPorts).
I installed netcdf-4 but disabled hd-5. Nevertheless, I commented-out the "export USE_NETCDF4=on" section in the build.bash file because it cannot find the libraries if I do turn that on.
When I run ./build.bash I get a lot of apparently proper execution, terminating with this:
      ___mod_netcdf_MOD_netcdf_close.part.1 in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_def_dim", referenced from:
      _def_dim_ in libUTIL.a(def_dim.o)
  "___netcdf_MOD_nf90_def_var_manydims", referenced from:
      ___def_var_mod_MOD_def_var in libUTIL.a(def_var.o)
  "___netcdf_MOD_nf90_def_var_scalar", referenced from:
  "___netcdf_MOD_nf90_enddef", referenced from:
      ___mod_netcdf_MOD_netcdf_enddef in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_att_one_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_get_fatt in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_inq_var in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_att_one_fourbyteint", referenced from:
  "___netcdf_MOD_nf90_get_att_text", referenced from:
      _lbc_getatt_ in libUTIL.a(lbc.o)
  "___netcdf_MOD_nf90_get_var_1d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_get_fvar_0d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_get_fvar_1d in libMODS.a(mod_netcdf.o)
      ___nf_fread2d_mod_MOD_nf_fread2d in libUTIL.a(nf_fread2d.o)
      ___nf_fread3d_mod_MOD_nf_fread3d in libUTIL.a(nf_fread3d.o)
  "___netcdf_MOD_nf90_get_var_1d_fourbyteint", referenced from:
      ___mod_netcdf_MOD_netcdf_get_ivar_1d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_get_ivar_0d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_get_lvar_1d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_get_lvar_0d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_var_1d_text", referenced from:
      ___mod_netcdf_MOD_netcdf_get_svar_1d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_var_2d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_get_fvar_2d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_var_2d_fourbyteint", referenced from:
      ___mod_netcdf_MOD_netcdf_get_ivar_2d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_var_3d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_get_fvar_3d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_var_4d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_get_fvar_4d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_var_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_get_fvar_0d.constprop.3 in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_get_var_fourbyteint", referenced from:
  "___netcdf_MOD_nf90_get_var_text", referenced from:
      ___mod_netcdf_MOD_netcdf_get_svar_0d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_inq_attname", referenced from:
      ___mod_netcdf_MOD_netcdf_check_var in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_inq_varid", referenced from:
      ___mod_netcdf_MOD_netcdf_put_svar_1d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_put_lvar_2d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_put_lvar_1d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_put_lvar_0d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_put_ivar_2d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_inquire", referenced from:
      ___mod_netcdf_MOD_netcdf_get_dim in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_inquire_attribute", referenced from:
  "___netcdf_MOD_nf90_inquire_dimension", referenced from:
  "___netcdf_MOD_nf90_inquire_variable", referenced from:
  "___netcdf_MOD_nf90_open", referenced from:
      ___mod_netcdf_MOD_netcdf_open.part.0 in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_put_att_eightbytereal", referenced from:
  "___netcdf_MOD_nf90_put_att_fourbyteint", referenced from:
  "___netcdf_MOD_nf90_put_att_fourbytereal", referenced from:
  "___netcdf_MOD_nf90_put_att_one_eightbytereal", referenced from:
  "___netcdf_MOD_nf90_put_att_one_fourbyteint", referenced from:
  "___netcdf_MOD_nf90_put_att_one_fourbytereal", referenced from:
  "___netcdf_MOD_nf90_put_att_text", referenced from:
      _lbc_putatt_ in libUTIL.a(lbc.o)
      _def_info_ in libUTIL.a(def_info.o)
  "___netcdf_MOD_nf90_put_var_1d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_put_fvar_1d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_put_fvar_0d in libMODS.a(mod_netcdf.o)
      ___nf_fwrite2d_mod_MOD_nf_fwrite2d in libUTIL.a(nf_fwrite2d.o)
      ___nf_fwrite3d_mod_MOD_nf_fwrite3d in libUTIL.a(nf_fwrite3d.o)
  "___netcdf_MOD_nf90_put_var_1d_fourbyteint", referenced from:
      ___mod_netcdf_MOD_netcdf_put_ivar_1d in libMODS.a(mod_netcdf.o)
      ___mod_netcdf_MOD_netcdf_put_ivar_0d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_put_var_1d_text", referenced from:
  "___netcdf_MOD_nf90_put_var_2d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_put_fvar_2d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_put_var_2d_fourbyteint", referenced from:
  "___netcdf_MOD_nf90_put_var_3d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_put_fvar_3d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_put_var_4d_eightbytereal", referenced from:
      ___mod_netcdf_MOD_netcdf_put_fvar_4d in libMODS.a(mod_netcdf.o)
  "___netcdf_MOD_nf90_put_var_eightbytereal", referenced from:
  "___netcdf_MOD_nf90_put_var_fourbyteint", referenced from:
make: *** [/Users/Connor/ROMS/Projects/Upwelling/oceanS] Error 1
I am not sure how to deal with this error- uninstalling the netcdf libraries did not help me (I'm not sure how that fixed it for the other user here).
Any help or direction would be very much appreciated.
-Connor
LeaF_7
#7 Unread post by LeaF_7 »
Hi Connor,
If you are using the gfortran compiler, can you try to edit the Darwin-gfortran.mk under "~/yourdirectory/trunk/Compilers/" at line 51(maybe not exactly) to be:
LIBS := -L$(NETCDF_LIBDIR) -lnetcdf -lnetcdff
instead of
I am not sure this will work but try to see whether it helps. Remember to backup
cdibble
#8 Unread post by cdibble »
Wow- thank you so much for that tip. It seems to have worked- I have an oceanS file and ./build.bash ran to completion without error, anyway. I will work on running the model now and see it through. What was the function of the -lnetcdff argument added to that line?
Thank you again!
Connor
#9 Unread post by kate »
With modern Netcdf, the fortran part is in a separate library. That's what you are linking to with -lnetcdff.
prasanth
#10 Unread post by prasanth »
Hai,
While running build.bash for upwelling, I got the error.
mod_netcdf.f90:(.text+0x119ae): undefined reference to `__netcdf_MOD_nf90_inquire'
mod_netcdf.f90:(.text+0x11a5f): undefined reference to `__netcdf_MOD_nf90_inquire_dimension'
Master/Module.mk:22: recipe for target '/home/prasanth/ROMS_TRAIL/Projects/Upwelling/oceanS' failed
make: *** [/home/prasanth/ROMS_TRAIL/Projects/Upwelling/oceanS] Error 1
I hope someone could help me figure this out.
-Prasanth
#11 Unread post by kate »
Start with what's in the FAQ.
