error while adding NARR wind forcing to ROMS
youngstor
#1 Unread post by youngstor »
I have been running ROMS with tidal forcing only (no wind forcing and surface flux is defined as '#define ANA_SMFLUX'). Now I intend to add wind surface forcing to the model on top of the tidal forcing. I have created separate wind forcing netcdf files (Uwind, Vwind) from NARR data. How should I modify the .in file to include the wind forcing?
My old .in file has something like this (it's a case with grid nesting):
     NFFILES == 1
     FRCNAME == Projects/test_ca_refined/otps_wc.nc   \
I simply replaced above with:
   NFFILES == 2
    FRCNAME == Projects/test_ca_refined_real_wind/otps_wc.nc   \
                Projects/test_ca_refined_real_wind/roms_narr_Jan2009.nc   \
I also replaced ''
#define ANA_SMFLUX
' with '
#define BULK_FLUXES
', and re-compiled the program.
However, when I ran the model, I got the error saying '
GET_2DFLD   - unable to find requested variable: swrad
               in files:
I looked it up and found 'swrad' stands for 'short wave radiation'. How to get around this error without having to create a separate netcdf forcing file for 'swrad'?
Btw, is it ok to set all the other surface forcing (e.g. Pair, Tair, Qair, rain, swrad, lwrad) to zero if I only consider wind forcing for the surface?
Thanks a lot,
Xiufeng
Re: error while adding NARR wind forcing to ROMS
You can set ANA_SRFLUX as well as the other ANA_ options. Setting ANA_PAIR to 1000.0 is better than setting it to zero. Zero air pressure does funny things. You might instead opt for creating a new bulk_flux.F that computes stresses as a function of the winds only. I've got such a thing with BULK_FLUX2D in the attached file.
bulk_flux.F
Bulk flux routine with BULK_FLUX2D option.
(71.04 KiB) Downloaded 424 times
