force file
pooran
Location: Khoramshahr Marine Science and Technology Universi
force file
#1 Unread post by pooran »
dear
after doing
 cdo selvar
command to change lon and lat's names in Dimensions 's part to x and y, force file's header change to:
ncdisp('shflux.nc')
Source:
           /home/forcing/shflux.nc
Format:
           64bit
Global Attributes:
           CDI         = 'Climate Data Interface version 1.5.9 (http://code.zmaw.de/projects/cdi)'
           Conventions = 'CF-1.4'
           history     = 'Sun Jul 20 16:51:29 2014: cdo selvar shflux1_era.nc shflux.nc
                         Forcing file created with /home/forcing/d_ecmwf2roms.m on Sunday - July 20, 2014 - 4:24:11.3743 PM'
           type        = 'FORCING file'
           title       = 'ECMWF ERA-Interim Dataset, Gulf of Mexico Region'
           CDO         = 'Climate Data Operators version 1.5.9 (http://code.zmaw.de/projects/cdo)'
Dimensions:
           x        = 73
           y        = 94
           shf_time = 2920  (UNLIMITED)
Variables:
    lon
           Dimensions: x,y
           Datatype:   double
           Attributes:
                       standard_name       = 'longitude'
                       long_name           = 'longitude'
                       units               = 'degree_east'
                       _CoordinateAxisType = 'Lon'
    lat
           Dimensions: x,y
           Datatype:   double
           Attributes:
                       standard_name       = 'latitude'
                       long_name           = 'latitude'
                       units               = 'degree_north'
                       _CoordinateAxisType = 'Lat'
    shf_time
           Dimensions: shf_time
           Datatype:   double
           Attributes:
                       standard_name = 'time'
                       long_name     = 'surface net heat flux time'
                       units         = 'days since 2005-01-01 00:00:00'
                       calendar      = 'standard'
    shflux
           Dimensions: x,y,shf_time
           Datatype:   single
           Attributes:
                       long_name      = 'surface net heat flux'
                       units          = 'Watt meter-2'
                       coordinates    = 'lon lat'
                       positive_value = 'downward flux, heating'
                       negative_value = 'upward flux, cooling'
                       time           = 'shf_time'
as you can sea it does not have
spherical
           Dimensions:
           Datatype:   int32
           Attributes:
                       long_name     = 'grid type logical switch'
                       flag_values   = [0.00e+00 1.00e+00]
                       flag_meanings = 'Cartesian spherical'
as a variable. also its calender change from gregorian to standart and some other changes
would you please that it will make problem? in the other hand my force file in this shape is correct or not?
cheers
fot origin file:
ncdisp('shflux1.nc')
Format:
           64bit
Global Attributes:
           history = 'Forcing file created with /home/forcing/d_ecmwf2roms.m on Sunday - July 20, 2014 - 4:24:11.3743 PM'
Dimensions:
           lon      = 73
           lat      = 94
Variables:
    spherical
           Dimensions:
           Datatype:   int32
           Attributes:
    lon
           Dimensions: lon,lat
           Datatype:   double
           Attributes:
    lat
           Dimensions: lon,lat
           Datatype:   double
           Attributes:
    shf_time
           Datatype:   double
           Attributes:
                       calendar  = 'gregorian'
    shflux
           Dimensions: lon,lat,shf_time
           Datatype:   single
           Attributes:
                       time           = 'shf_time'
                       coordinates    = 'lon lat shf_time '
pooran
Re: force file
#2 Unread post by pooran »
dear friends
sorry to repeat my question but because i am a newbie with what ROMS need, i am worried that changed force file with mentioned header (in above post) have been damaged (after doing CDO command) and changed to incomplete format.
Would you please guide me that its new header is complete and correct or not?
Many thanks for any reply
cheers
pooran
Re: force file
#3 Unread post by kate »
I'm not familiar with the cdo command nor do I know what you hoped it would do. For ROMS, only the grid file needs the spherical flag (or not) to specify that we're dealing with a lat,lon grid (or an x,y grid). The real test is in how ROMS reads in the file - or fails to read it. Have you tried either the before or after file? What happens during the ROMS read?
pooran
Re: force file
#4 Unread post by pooran »
Before applying CDO command on force file, when i run model it gives following error:
NETCDF_INQ_VAR - requested variable: lat sms_time
not found in input file: /home/forcing/CS_sms_era.nc
call from: get_varcoords.F
after doing CDO command on force file, roms was able to read force file (which created by d_ecmwf2roms.m)
what about coordinates and time flags of shflux? They change form
time           = 'shf_time'
to
time           = 'shf_time'
and also calendar changed from Gregorian to standard
I would be appreciate that if these changes make problem please tell it to me.
Also if you have another recommend for solving that error please guide me.
cheers
Re: force file
#5 Unread post by kate »
The coordinates should be "lon lat". You might be able to change the original Matlab script to fix that. ROMS will ignore the calendar. It sounds like you found a working solution, so don't worry about it.
