I am trying to run the Dogbone refinement grid example, but it is having problems reading dogbone_ngc_refined.nc . If I do ncdump on the file I get
ncdump: v1hpg.c:190: v1h_get_nc_type: Assertion `type == NC_BYTE || type == NC_CHAR || type == NC_SHORT || type == NC_INT || type == NC_FLOAT || type == NC_DOUBLE' failed.
I get a similar error running ROMS.
Maybe i'm using the wrong version of the netcdf library (4.1.3)?
Steve Spall
Problem with netcdf file for Dogbone example
Re: Problem with netcdf file for Dogbone example
I'm having the same problem:
"ncdump -h dogbone_ngc_refined.nc" fails with the error message "ncdump: dogbone_ngc_refined.nc: Argument list too long".
The "file" command returns: "dogbone_ngc_refined.nc: data" while it should return something in the form of "...: NetCDF Data Format data"
So there is obviously something wrong with the file.
Cheers
Hartmut
Cheers
Hartmut
Does anyone have any ideas on this? I can try to figure it out myself, but i'd rather be testing my own refinement grids rather than troubleshooting the standard example.
I am having same problem. Is this file corrupted somehow? Any idea to run the doggone test case? It could be related with NetCDF version but i am not sure.
--ufuk
--ufuk
can you try this file?
- dogbone_contact_refined.nc
- (425.89 KiB) Downloaded 707 times
Thanks for your help. The file is okay now but dogbone_ngc_composite.nc has also same issue. If you don't mind could you regenerate that too. By the way, i could not see any difference in the definition of CPP flags in ticket 673
https://www.myroms.org/projects/src/ticket/673
Regards,
--ufuk
Regards,
--ufuk
Hi Again,
I am trying to generate 'dogbone_ngc_composite.nc' using Matlab toolbox using following Matlab commands
input = {'roms/Data/ROMS/Grid/dogbone_grd_left.nc'; ...
'roms/Data/ROMS/Grid/dogbone_grd_right.nc'};
output = 'dogbone_ngc_composite.nc'
[S,G] = contact(input, output);
but it gives errors as
output =
Summary of Contact Regions Processed:
Grid 01: roms/Data/ROMS/Grid/dogbone_grd_left.nc
Grid 02: roms/Data/ROMS/Grid/dogbone_grd_right.nc
Contact Donor Receiver
Region Grid Grid
01 01 02
02 02 01
Error using sub2ind (line 52)
Out of range subscript.
Error in contact>Hweights (line 2453)
RindexB = sub2ind([Ir, Jr], ...
Error in contact (line 352)
S = Hweights(G, S, ImposeMask);
Error in dogbone (line 5)
Do you have any idea bout it?
--ufuk
output =
Region Grid Grid
01 01 02
02 02 01
--ufuk
