error: globaldefs.h: No such file or directory
ac412
#1 Unread post by ac412 »
dear all,
I am new to ROMS.
I want to run a South China Sea case and I have prepared ncfiels.
But when I run ./build.bash I met the problem as below:
In file included from Compilers/../ROMS/Include/cppdefs.h:617,
                 from Compilers/make_macros.h:16:
/share/home/my/ROMS/myTest/wmscs/wmscs.h:73:24: error: globaldefs.h: No such file or directory
/share/home/my/make_macros.mk:1: *** missing separator.  Stop.
If I copy the golbaldefs.h to the current folder, the error will be like this:
Could anyone tell me why and how to solve it? Many thanks~~
Re: error: globaldefs.h: No such file or directory
Have you looked at that make_macros.mk file? Mine looks like:
  USE_ADJOINT :=
  USE_TANGENT :=
  USE_REPRESENTER :=
  USE_SEAICE := on
  USE_WRF :=
  USE_SWAN :=
  USE_REFDIF :=
  USE_ARPACK :=
  USE_MCT :=
  USE_ESMF :=
Don't worry if you don't have the SEAICE line. Which version of make are you using? I've got:
pacman3 710% make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for x86_64-redhat-linux-gnu
ac412
#3 Unread post by ac412 »
kate wrote:Have you looked at that make_macros.mk file? Mine looks like:
  USE_ADJOINT :=
  USE_TANGENT :=
  USE_REPRESENTER :=
  USE_SEAICE := on
  USE_WRF :=
  USE_SWAN :=
  USE_REFDIF :=
  USE_ARPACK :=
  USE_MCT :=
  USE_ESMF :=
GNU Make 3.81
PARTICULAR PURPOSE.
dear Kate,
thank you for your kindly reply.
I've got the same version of GNU as yours:
GNU Make 3.81
PARTICULAR PURPOSE.
but I don't have the build folder under the current folder. It also fails when I try to "make" or "make clean".
This is in your home directory, right? It has nothing to do with where your build directory is. If your file looks like mine, look for hidden characters in there.
ETA: a web search on that error brings up the make issue of spaces instead of tabs. However, there should be no tabs in that file.
ac412
#5 Unread post by ac412 »
dear Kate,
My mistake. I changed everything but the casename in the first line of *.h file. So the system didn't find this *.h. Now the problem has been solved.
But I still don't understand why my Makefile.config would be located at my home directory?
#6 Unread post by kate »
The makefile puts that file in your home directory, then copies it to the build directory:
MAKE_MACROS := $(shell echo ${HOME} | sed 's| |\\ |g')/make_macros.mk
ifneq "$(MAKECMDGOALS)" "clean"
 MACROS := $(shell cpp -P $(ROMS_CPPFLAGS) Compilers/make_macros.h > \
                $(MAKE_MACROS); $(CLEAN) $(MAKE_MACROS))
       cp -p $(MAKE_MACROS) $(SCRATCH_DIR)
