I have run roms smoothly at the first time,Now,i try add a certain coefficient to kpp scheme, the coefficient was stored as a forcing file which have variable,s_rho,time,lon_rho and lat_rho. I have modified five .f program and varinfo.dat file, as follows:
mod_forces.F :
# ifdef WAVE_MIXING
real(r8), pointer :: bv(:,:,:)
real(r8), pointer :: bvG(:,:,:,:)
mod_ncparam.F:
integer :: idBV ! BV
get_data.F
# ifdef WAVE_MIXING
CALL get_3dfld (ng, iNLM, idBV, ncFRCid(idBV,ng), &
& nFfiles(ng), FRC(1,ng), update(1), &
& LBi, UBi, LBj, UBj,1,N(ng), 2, 1, &
# ifdef MASKING
& GRID(ng) % rmask(LBi,LBj), &
& FORCES(ng) % bvG(LBi,LBj,1,1))
set_data.F
ifdef WAVE_MIXING
CALL set_3dfld_tile (ng, tile, iNLM, idBV, &
& LBi, UBi, LBj, UBj,1,N(ng), &
& FORCES(ng)%bvG, &
& FORCES(ng)%bv, &
& update)
but when i compile build.bash,the errors are
ROMS/Bin/cpp_clean /lustre/home/shiyongfangWKJ/roms/projects/roms_shi/Build/get_data.f90
cd /lustre/home/shiyongfangWKJ/roms/projects/roms_shi/Build; /lustre/inspur/mpi/openmpi-intel/bin/mpif90 -c -heap-arrays -fp-model precise -ip -O3 get_data.f90
get_data.f90(86): error #6404: This name does not have a type, and must have an explicit type. [IDBV]
get_data.f90(90): error #6460: This is not a field name that is defined in the encompassing structure. [BVG]
get_data.f90(90): error #6158: The structure-name is invalid or is missing. [FORCES]
compilation aborted for get_data.f90 (code 1)
make: *** [/lustre/home/shiyongfangWKJ/roms/projects/roms_shi/Build/get_data.o] Error 1
I am confused,could you give me some advice? Very grateful to you!
Re: get_data.f90(86): error #6404:
Did it attempt to recompile mod_forces first? If the makefile dependencies are correct, it should have. See if your build.bash is trying a "make clean" first for a fresh go at it.
You have only declared the variables in mod_forces. You also need to allocate and initialize them. Copy the example of some other field there such as Uwind.
Thank your very much,following your suggestion,I have made some modify,and compile smoothly,kate wrote:Did it attempt to recompile mod_forces first? If the makefile dependencies are correct, it should have. See if your build.bash is trying a "make clean" first for a fresh go at it.
the lmd_vmix.F have added some code:
# ifdef WAVE_MIXING
USE mod_forces
# ifdef WAVE_MIXING
& FORCES(ng) % bv, &
& MIXING(ng) % bvf, &
& MIXING(ng) % Akt, &
& MIXING(ng) % Akv)
# ifdef LMD_SKPP
CALL lmd_skpp (ng, tile)
SUBROUTINE lmd_vmix_tile (ng, tile, &
& LBi, UBi, LBj, UBj, &
& IminS, ImaxS, JminS, JmaxS, &
& nstp, &
& Hz, &
# ifndef SPLINES
& z_r, &
& rho, u, v, &
# ifdef LMD_DDMIX
& t, alfaobeta, &
# ifdef WAVE_MIXING
& bv, &
& bvf, Akt, Akv)
# ifdef WAVE_MIXING
real(r8), intent(in) :: bv(LBi:,LBj:,:)
# ifdef WAVE_MIXING
real(r8), intent(in) :: bv(LBi:UBi,LBj:UBj,1:N(ng))
# ifdef WAVE_MIXING
IF(bv(i,j,k).lt.9999)then
AKv(i,j,k)=AKv(i,j,k)+bv(i,j,k)
AKt(i,j,k,itemp)=AKt(i,j,k,itemp)+bv(i,j,k)
ENDIF
and the log file show that bv have been read.
GET_3DFLD - wave induced vertical mixing coefficient, t = 165 00:00:00
(Rec=0006, Index=1, File: bv_rho.nc)
(Min = 0.00000000E+00 Max = 2.67805239E-01)
however, my new result seems to be no change,from the top, I have defined wave_mixing in .h file. but it do not show in log file,
SHIYF SHIYF
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
LMD_SHAPIRO Shapiro filtering boundary layer depth.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
SCORRECTION Surface salinity flux correction.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
how I know if my bv coefficient added to AKv and AKt,could you give some advice? thanks a lot!!
Did you add a check for WAVE_MIXING in checkdefs.F? You can see how it's done there.
Thank you very much! it is ok!kate wrote:Did you add a check for WAVE_MIXING in checkdefs.F? You can see how it's done there.
