Question on Building COAWST
youngstor
#1 Unread post by youngstor »
I was trying to compile COAWST for the first time, and ran into some error:
cd ./Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math -I/etc/MCT/include -I/etc/MCT/include -I/usr/include/mpich2-x86_64/ -ffree-form -ffree-line-length-none waves_control.f90
waves_control.f90:131.14:
          IF (run_grid(ng).eq..TRUE.) THEN
              1
Error: Logicals at (1) must be compared with .eqv. instead of .eq.
make: *** [Build/waves_control.o] Error 1
Can someone help? Should I go into "waves_control.f90" and change ".eq." to ".eqv."? But I figure the code should be correct since it has already been tested? Did I compile it wrong?
I appreciate any help or comments!
Mike Y.
Re: Question on Building COAWST
we found this one a while ago. gfortran did not like the .eq. and wanted .eqv. I recoded this to use an integer 1/0 instead of T/F. So can you please do an svn update and see if it works?
thanks,
john
youngstor
#3 Unread post by youngstor »
jcwarner wrote:we found this one a while ago. gfortran did not like the .eq. and wanted .eqv. I recoded this to use an integer 1/0 instead of T/F. So can you please do an svn update and see if it works?
thanks,
john
Hey John,
Thanks for fast reply. Should I update the entire COAWST package or ROMS only?
I tried to use the following command to svn update COAWST, but I guess that host server is out of date?
svn checkout --username myusrname https://svn2.hosted-projects.com/coawst/COAWST
Another issue is that "svn" client is not installed on this machine that I am currently using, and I don't have the privilege to install software on it.
Is there any suggestions to install updates in spite of the above difficulties?
Thanks again.
Mike Y.
