some questions about the WET_DRY
panfeng291
#1 Unread post by panfeng291 »
If I use the WET_DRY simulation ,how to set the hc,hmin and the Tcline? My Vtransform == 1 and Vstretching == 1,so if the h is negative, the hc will be 0 and the model will blow up at the begin.
Thanks in advance
Re: some questions about the WET_DRY
we have modified the code to allow for this. I am not sure exactly what is in the Rutgers version but if you have troubles make another post. The hc and hmin and all those i usually just set to 0. the code should handle it.
-john
#3 Unread post by kate »
In the Rutgers code, we are now using Vstretching=4 and Vtransform=2, which will allow for any hc you like, independent of hmin.
panfeng291
#4 Unread post by panfeng291 »
kate wrote:In the Rutgers code, we are now using Vstretching=4 and Vtransform=2, which will allow for any hc you like, independent of hmin.
Thanks for your reply, Kate.And do you mean that I must using Vstretching=4 Vtransform=2,if I want to active the WET_DRY?
#5 Unread post by jcwarner »
i dont think she means that.
she means those setting may be more stable, but please try that and other settings for your particular application.
jivica
#6 Unread post by jivica »
Use the source Luke ;)
ROMS/Nonlinear/set_depth.F
there is all you need, you can invent even new function ;)
Ivica
