i am a new mode guy,when i run my application first,there are some errors:
error while writing variable: zeta;
the log file:
Thursday - November 21, 2013 - 7:42:55 PM
SHIYF
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /lustre/inspur/mpi/openmpi-intel/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script : ocean_shiyf.in
SVN Revision : Unversioned directory
Local Root : /lustre/home/shiyongfangWKJ/roms/trunk
Header Dir : /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
Header file : shiyf.h
Analytical Dir: /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
Resolution, Grid 01: 0449x0160x016, Parallel Nodes: 9, Tiling: 003x003
1440 ntimes Number of timesteps for 3-D equations.
300.000 dt Timestep size (s) for 3-D equations.
288 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
72 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1 lmd_Jwt Jerlov water type.
6.0000E+00 theta_s S-coordinate surface control parameter.
2.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
Input Grid File: shiyf_grd.nc
Input Nonlinear Initial File: shiyf_ini.nc
Input Forcing File 01: shiyf_frc.nc
Input Boundary File: shiyf_bry.nc
Tile partition information for Grid 01: 0449x0160x0016 tiling: 003x003
tile Istr Iend Jstr Jend Npts
0 1 150 1 53 127200
1 151 300 1 53 127200
2 301 449 1 53 126352
3 1 150 54 107 129600
4 151 300 54 107 129600
5 301 449 54 107 128736
6 1 150 108 160 127200
7 151 300 108 160 127200
8 301 449 108 160 126352
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 150.50 0.50 53.50 RHO-points
1 150.50 300.50 0.50 53.50 RHO-points
2 300.50 449.50 0.50 53.50 RHO-points
3 0.50 150.50 53.50 107.50 RHO-points
4 150.50 300.50 53.50 107.50 RHO-points
5 300.50 449.50 53.50 107.50 RHO-points
6 0.50 150.50 107.50 160.50 RHO-points
7 150.50 300.50 107.50 160.50 RHO-points
8 300.50 449.50 107.50 160.50 RHO-points
0 1.00 150.50 0.50 53.50 U-points
1 150.50 300.50 0.50 53.50 U-points
2 300.50 449.00 0.50 53.50 U-points
3 1.00 150.50 53.50 107.50 U-points
4 150.50 300.50 53.50 107.50 U-points
5 300.50 449.00 53.50 107.50 U-points
6 1.00 150.50 107.50 160.50 U-points
7 150.50 300.50 107.50 160.50 U-points
8 300.50 449.00 107.50 160.50 U-points
0 0.50 150.50 1.00 53.50 V-points
1 150.50 300.50 1.00 53.50 V-points
2 300.50 449.50 1.00 53.50 V-points
3 0.50 150.50 53.50 107.50 V-points
4 150.50 300.50 53.50 107.50 V-points
5 300.50 449.50 53.50 107.50 V-points
6 0.50 150.50 107.50 160.00 V-points
7 150.50 300.50 107.50 160.00 V-points
8 300.50 449.50 107.50 160.00 V-points
HaloSizeI(1) = 324
HaloSizeJ(1) = 132
TileSide(1) = 156
TileSize(1) = 9360
zeta 1 Closed Clamped Clamped Closed
ubar 1 Closed Clamped Clamped Closed
vbar 1 Closed Clamped Clamped Closed
u 1 Closed Clamped Clamped Closed
v 1 Closed Clamped Clamped Closed
temp 1 Closed Clamped Clamped Closed
salt 1 Closed Clamped Clamped Closed
tke 1 Closed Clamped Clamped Closed
SHIYF SHIYF
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 4 (pid= 963) is active.
Node # 8 (pid= 29422) is active.
Node # 3 (pid= 962) is active.
Node # 0 (pid= 27658) is active.
Node # 5 (pid= 964) is active.
Node # 2 (pid= 27660) is active.
Node # 1 (pid= 27659) is active.
Node # 6 (pid= 29420) is active.
Node # 7 (pid= 29421) is active.
Vertical S-coordinate System:
15 -0.0625000 -0.0019030 -0.891 -0.625 -5.506 -10.121
14 -0.1250000 -0.0040767 -1.821 -1.250 -11.707 -21.593
13 -0.1875000 -0.0068304 -2.831 -1.875 -19.395 -35.959
12 -0.2500000 -0.0105560 -3.978 -2.500 -29.576 -55.174
11 -0.3125000 -0.0157835 -5.335 -3.125 -43.610 -81.884
10 -0.3750000 -0.0232566 -7.006 -3.750 -63.403 -119.801
9 -0.4375000 -0.0340388 -9.140 -4.375 -91.684 -174.228
8 -0.5000000 -0.0496640 -11.953 -5.000 -132.388 -252.823
7 -0.5625000 -0.0723554 -15.755 -5.625 -191.217 -366.678
6 -0.6250000 -0.1053416 -20.998 -6.250 -276.451 -531.904
5 -0.6875000 -0.1533158 -28.339 -6.875 -400.130 -771.921
4 -0.7500000 -0.2231040 -38.735 -7.500 -579.762 -1120.789
3 -0.8125000 -0.3246355 -53.574 -8.125 -840.815 -1628.056
2 -0.8750000 -0.4723564 -74.880 -8.750 -1220.344 -2365.809
1 -0.9375000 -0.6872846 -105.595 -9.375 -1772.260 -3438.925
0 -1.0000000 -1.0000000 -150.000 -10.000 -2575.000 -5000.000
Time Splitting Weights: ndtfast = 30 nfast = 42
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 2.76948572E+01 km
Maximum X-grid spacing, DXmax = 5.55664201E+01 km
Minimum Y-grid spacing, DYmin = 2.80117339E+01 km
Maximum Y-grid spacing, DYmax = 5.55653933E+01 km
Minimum Z-grid spacing, DZmin = 8.91413705E-01 m
Maximum Z-grid spacing, DZmax = 1.56107504E+03 m
Minimum barotropic Courant Number = 9.76308271E-03
Maximum barotropic Courant Number = 9.47936129E-02
Maximum Coriolis Courant Number = 3.78274280E-02
Horizontal mixing scaled by grid size, GRDMAX = 5.55658756E+01 km
NLM: GET_STATE - Read state initial conditions, t = 0 00:00:01
(File: shiyf_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = 1.00000000E+37 Max = -1.00000000E+37)
- u-momentum component
- v-momentum component
- potential temperature
(Min = -2.82544277E+00 Max = 3.01532629E+01)
- salinity
(Min = 7.48295316E+00 Max = 4.41049689E+01)
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0012, Index=1, File: shiyf_frc.nc)
(Min = -6.73725163E+02 Max = 6.74438722E+02)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
(Min = -9.23820027E+02 Max = 3.91016607E+02)
GET_2DFLD - solar shortwave radiation flux, t = 345 00:00:00
(Min = 7.66000516E-07 Max = 6.73535484E-05)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -1.22467813E-04 Max = 3.12575784E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 345 00:00:00
(Min = -3.01846074E-07 Max = 1.15583962E-07)
GET_2DFLD - sea surface salinity climatology, t = 345 00:00:00
(Min = 1.65167007E+01 Max = 4.11551018E+01)
(Rec=0012, Index=2, File: shiyf_bry.nc)
(Min = -3.83470606E-01 Max = 7.99989567E+00)
(Min = -3.50685381E-01 Max = 7.99989567E+00)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -2.60444052E-02 Max = 1.37641049E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = -1.79761074E-03 Max = 1.07012369E-03)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -1.24812288E-03 Max = 9.84361104E-03)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -1.02250826E+00 Max = 9.09095033E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -3.66099335E-01 Max = 3.02597453E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = -1.07493064E-01 Max = 6.03430119E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -6.48846883E-02 Max = 6.44035122E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -1.08044189E+00 Max = 1.25793587E+00)
GET_NGFLD - temperature eastern boundary condition, t = 345 00:00:00
(Min = 1.67032195E+00 Max = 2.78780000E+01)
GET_NGFLD - salinity eastern boundary condition, t = 345 00:00:00
(Min = 3.33691664E+01 Max = 3.52194348E+01)
GET_NGFLD - temperature southern boundary condition, t = 345 00:00:00
(Min = 1.15385186E+00 Max = 2.97989341E+01)
GET_NGFLD - salinity southern boundary condition, t = 345 00:00:00
(Min = 3.20250773E+01 Max = 3.59597283E+01)
Maximum grid stiffness ratios: rx0 = 1.483417E-01 (Beckmann and Haidvogel)
rx1 = 8.076796E-01 (Haney)
Initial basin volumes: TotVolume = 3.7465697418E+17 m3
MinVolume = 6.9680682010E+08 m3
MaxVolume = 4.8199230429E+12 m3
Max/Min = 6.9171582479E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
(Rec=0001, Index=2, File: shiyf_frc.nc)
(Min = -5.63892333E+02 Max = 7.27163233E+02)
(Min = -9.21693244E+02 Max = 3.89433969E+02)
(Min = 1.56437748E-06 Max = 7.13031920E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
(Min = -1.28904424E-04 Max = 3.03673525E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 15 00:00:00
(Min = -2.56906815E-07 Max = 1.14237990E-07)
(Min = 1.77527008E+01 Max = 4.05689011E+01)
(Rec=0001, Index=1, File: shiyf_bry.nc)
(Min = -3.50845128E-01 Max = 8.00844646E+00)
(Min = -3.30109051E-01 Max = 8.00844646E+00)
(Min = -6.11860132E-03 Max = 2.18489387E-02)
(Min = -1.53135821E-03 Max = 1.14542320E-03)
(Min = -1.23071690E-03 Max = 2.52131175E-02)
(Min = -9.37649144E-01 Max = 9.63868906E-01)
(Min = -2.11111437E-01 Max = 2.42682754E-01)
(Min = -9.15717638E-02 Max = 6.30581806E-02)
(Min = -6.39798238E-02 Max = 7.41423366E-02)
(Min = -9.81503760E-01 Max = 1.40600143E+00)
(Min = 1.67032195E+00 Max = 2.74140332E+01)
(Min = 3.35107269E+01 Max = 3.50963225E+01)
(Min = 1.15385186E+00 Max = 2.98525752E+01)
(Min = 3.05486010E+01 Max = 3.58689762E+01)
0 0 00:00:01 1.567195E-06 2.153599E+04 2.153599E+04 3.828818E+17
(166,001,05) 0.000000E+00 3.603793E-03 0.000000E+00 9.407347E-01
DEF_HIS - creating history file: ocean_his.nc
DEF_AVG - creating average file: ocean_avg.nc
1 0 00:05:01 NaN NaN NaN NaN
(149,003,16) 2.419516E+01 3.961077E+00 0.000000E+00 0.000000E+00
WRT_RST - error while writing variable: zeta
into restart NetCDF file for time record: 1
Elapsed CPU time (seconds):
Node # 2 CPU: 1.219
Node # 1 CPU: 1.242
Node # 0 CPU: 1.211
Analytical header files used:
ROMS/Functionals/ana_btflux.h
Node # 7 CPU: 1.214
Node # 4 CPU: 1.231
Node # 8 CPU: 1.216
Node # 3 CPU: 1.212
Node # 6 CPU: 1.196
Node # 5 CPU: 1.202
How to do to avoid this kind of error?
