error while writing variable: zeta
shiyf
#1 Unread post by shiyf »
hi,
i am a new mode guy,when i run my application first,there are some errors:
error while writing variable: zeta;
the log file:
 Model Input Parameters:  ROMS/TOMS version 3.6
                          Thursday - November 21, 2013 -  7:42:55 PM
 SHIYF
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : ifort
 Compiler command : /lustre/inspur/mpi/openmpi-intel/bin/mpif90
 Compiler flags   : -heap-arrays -fp-model precise -ip -O3 -free -free -free
 Input Script  : ocean_shiyf.in
 SVN Revision  : Unversioned directory
 Local Root    : /lustre/home/shiyongfangWKJ/roms/trunk
 Header Dir    : /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
 Header file   : shiyf.h
 Analytical Dir: /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
 Resolution, Grid 01: 0449x0160x016,  Parallel Nodes:   9,  Tiling: 003x003
       1440  ntimes          Number of timesteps for 3-D equations.
    300.000  dt              Timestep size (s) for 3-D equations.
         30  ndtfast         Number of timesteps for 2-D equations between
        288  nRST            Number of timesteps between the writing of data
                               into restart fields.
                               to standard output.
         72  nHIS            Number of timesteps between the writing fields
                               into history file.
          1  ntsAVG          Starting timestep for the accumulation of output
                               time-averaged data.
         72  nAVG            Number of timesteps between the writing of
 0.0000E+00  nl_tnu2(01)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 01: temp
 0.0000E+00  nl_tnu2(02)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 02: salt
 5.0000E+00  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 1.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 1.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak         Background vertical mixing coefficient (m2/s)
                               for turbulent energy.
 5.0000E-06  Akp_bak         Background vertical mixing coefficient (m2/s)
      3.000  gls_p           GLS stability exponent.
      1.500  gls_m           GLS turbulent kinetic energy exponent.
     -1.000  gls_n           GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin        GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin        GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0        GLS stability coefficient.
 1.4400E+00  gls_c1          GLS shear production coefficient.
 1.9200E+00  gls_c2          GLS dissipation coefficient.
-4.0000E-01  gls_c3m         GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p         GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk        GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp        GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha   Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha  Factor for Zos calculation using Hsig(Awave).
      0.250  sz_alpha        Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw       Factor for Craig/Banner surface tke flux.
 2.0000E-02  Zob             Bottom roughness (m).
 2.0000E-02  Zos             Surface roughness (m).
          1  lmd_Jwt         Jerlov water type.
          1  Vtransform      S-coordinate transformation equation.
          1  Vstretching     S-coordinate stretching function.
 6.0000E+00  theta_s         S-coordinate surface control parameter.
 0.0000E+00  theta_b         S-coordinate bottom  control parameter.
     10.000  Tcline          S-coordinate surface/bottom layer width (m) used
       0.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 2.0000E+00  Tnudg(01)       Nudging/relaxation time scale (days)
 2.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
                               for 3D momentum.
          F  VolCons(1)      NLM western  edge boundary volume conservation.
          T  VolCons(2)      NLM southern edge boundary volume conservation.
          T  VolCons(3)      NLM eastern  edge boundary volume conservation.
          F  VolCons(4)      NLM northern edge boundary volume conservation.
     14.000  T0              Background potential temperature (C) constant.
     35.000  S0              Background salinity (PSU) constant.
          T  Aout(idFsur)    Write out averaged free-surface.
          T  Aout(idUbar)    Write out averaged 2D U-momentum component.
          T  Aout(idVbar)    Write out averaged 2D V-momentum component.
          T  Aout(idUvel)    Write out averaged 3D U-momentum component.
          T  Aout(idVvel)    Write out averaged 3D V-momentum component.
          T  Aout(idWvel)    Write out averaged W-momentum component.
          T  Aout(idOvel)    Write out averaged omega vertical velocity.
          T  Aout(idTvar)    Write out averaged tracer 01: temp
          T  Aout(idTvar)    Write out averaged tracer 02: salt
             Output History File:  ocean_his.nc
            Output Averages File:  ocean_avg.nc
                 Input Grid File:  shiyf_grd.nc
    Input Nonlinear Initial File:  shiyf_ini.nc
           Input Forcing File 01:  shiyf_frc.nc
             Input Boundary File:  shiyf_bry.nc
 Tile partition information for Grid 01:  0449x0160x0016  tiling: 003x003
        0        1      150        1       53   127200
        1      151      300        1       53   127200
        2      301      449        1       53   126352
        3        1      150       54      107   129600
        4      151      300       54      107   129600
        5      301      449       54      107   128736
        6        1      150      108      160   127200
        7      151      300      108      160   127200
        8      301      449      108      160   126352
   (interior points only)
        0     0.50   150.50     0.50    53.50  RHO-points
        1   150.50   300.50     0.50    53.50  RHO-points
        2   300.50   449.50     0.50    53.50  RHO-points
        3     0.50   150.50    53.50   107.50  RHO-points
        4   150.50   300.50    53.50   107.50  RHO-points
        5   300.50   449.50    53.50   107.50  RHO-points
        6     0.50   150.50   107.50   160.50  RHO-points
        7   150.50   300.50   107.50   160.50  RHO-points
        8   300.50   449.50   107.50   160.50  RHO-points
        0     1.00   150.50     0.50    53.50    U-points
        1   150.50   300.50     0.50    53.50    U-points
        2   300.50   449.00     0.50    53.50    U-points
        3     1.00   150.50    53.50   107.50    U-points
        4   150.50   300.50    53.50   107.50    U-points
        5   300.50   449.00    53.50   107.50    U-points
        6     1.00   150.50   107.50   160.50    U-points
        7   150.50   300.50   107.50   160.50    U-points
        8   300.50   449.00   107.50   160.50    U-points
        0     0.50   150.50     1.00    53.50    V-points
        1   150.50   300.50     1.00    53.50    V-points
        2   300.50   449.50     1.00    53.50    V-points
        3     0.50   150.50    53.50   107.50    V-points
        4   150.50   300.50    53.50   107.50    V-points
        5   300.50   449.50    53.50   107.50    V-points
        6     0.50   150.50   107.50   160.00    V-points
        7   150.50   300.50   107.50   160.00    V-points
        8   300.50   449.50   107.50   160.00    V-points
               HaloSizeI(1) =     324
               HaloSizeJ(1) =     132
                TileSide(1) =     156
                TileSize(1) =    9360
 Variable               Grid    West Edge   South Edge  East Edge   North Edge
 zeta                     1     Closed      Clamped     Clamped     Closed
 ubar                     1     Closed      Clamped     Clamped     Closed
 vbar                     1     Closed      Clamped     Clamped     Closed
 u                        1     Closed      Clamped     Clamped     Closed
 v                        1     Closed      Clamped     Clamped     Closed
 temp                     1     Closed      Clamped     Clamped     Closed
 salt                     1     Closed      Clamped     Clamped     Closed
 tke                      1     Closed      Clamped     Clamped     Closed
 SHIYF               SHIYF
 DIFF_GRID           Horizontal diffusion coefficient scaled by grid size.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 NO_WRITE_GRID       Not Writing grid arrays into NetCDF ouput files.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 RST_SINGLE          Single precision fields in restart NetCDF file.
 SCORRECTION         Surface salinity flux correction.
 SOLAR_SOURCE        Solar Radiation Source Term.
 UV_LDRAG            Linear bottom stress.
 VISC_GRID           Horizontal viscosity coefficient scaled by grid size.
 Process Information:
 Node #  4 (pid=     963) is active.
 Node #  8 (pid=   29422) is active.
 Node #  3 (pid=     962) is active.
 Node #  0 (pid=   27658) is active.
 Node #  5 (pid=     964) is active.
 Node #  2 (pid=   27660) is active.
 Node #  1 (pid=   27659) is active.
 Node #  6 (pid=   29420) is active.
 Node #  7 (pid=   29421) is active.
 Vertical S-coordinate System:
    16   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    15  -0.0625000  -0.0019030       -0.891      -0.625      -5.506     -10.121
    14  -0.1250000  -0.0040767       -1.821      -1.250     -11.707     -21.593
    13  -0.1875000  -0.0068304       -2.831      -1.875     -19.395     -35.959
    12  -0.2500000  -0.0105560       -3.978      -2.500     -29.576     -55.174
    11  -0.3125000  -0.0157835       -5.335      -3.125     -43.610     -81.884
    10  -0.3750000  -0.0232566       -7.006      -3.750     -63.403    -119.801
     9  -0.4375000  -0.0340388       -9.140      -4.375     -91.684    -174.228
     8  -0.5000000  -0.0496640      -11.953      -5.000    -132.388    -252.823
     7  -0.5625000  -0.0723554      -15.755      -5.625    -191.217    -366.678
     6  -0.6250000  -0.1053416      -20.998      -6.250    -276.451    -531.904
     5  -0.6875000  -0.1533158      -28.339      -6.875    -400.130    -771.921
     4  -0.7500000  -0.2231040      -38.735      -7.500    -579.762   -1120.789
     3  -0.8125000  -0.3246355      -53.574      -8.125    -840.815   -1628.056
     2  -0.8750000  -0.4723564      -74.880      -8.750   -1220.344   -2365.809
     1  -0.9375000  -0.6872846     -105.595      -9.375   -1772.260   -3438.925
     0  -1.0000000  -1.0000000     -150.000     -10.000   -2575.000   -5000.000
 Time Splitting Weights: ndtfast =  30    nfast =  42
 37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
 42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
 ndtfast, nfast =   30  42   nfast/ndtfast =  1.40000
 Power filter parameters, Fgamma, gamma =  0.28400   0.18933
 Minimum X-grid spacing, DXmin =  2.76948572E+01 km
 Maximum X-grid spacing, DXmax =  5.55664201E+01 km
 Minimum Y-grid spacing, DYmin =  2.80117339E+01 km
 Maximum Y-grid spacing, DYmax =  5.55653933E+01 km
 Minimum Z-grid spacing, DZmin =  8.91413705E-01 m
 Maximum Z-grid spacing, DZmax =  1.56107504E+03 m
 Minimum barotropic Courant Number =  9.76308271E-03
 Maximum barotropic Courant Number =  9.47936129E-02
 Maximum Coriolis   Courant Number =  3.78274280E-02
 Horizontal mixing scaled by grid size, GRDMAX =  5.55658756E+01 km
 NLM: GET_STATE - Read state initial conditions,             t =     0 00:00:01
                   (File: shiyf_ini.nc, Rec=0001, Index=1)
                - free-surface
                   (Min =  1.00000000E+37 Max = -1.00000000E+37)
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min = -2.82544277E+00 Max =  3.01532629E+01)
                - salinity
                   (Min =  7.48295316E+00 Max =  4.41049689E+01)
    GET_2DFLD   - surface u-momentum stress,                 t =   345 00:00:00
                   (Rec=0012, Index=1, File: shiyf_frc.nc)
                   (Tmin=         15.0000 Tmax=        345.0000)
                   (Min = -6.73725163E+02 Max =  6.74438722E+02)
    GET_2DFLD   - surface v-momentum stress,                 t =   345 00:00:00
                   (Min = -9.23820027E+02 Max =  3.91016607E+02)
    GET_2DFLD   - solar shortwave radiation flux,            t =   345 00:00:00
                   (Min =  7.66000516E-07 Max =  6.73535484E-05)
    GET_2DFLD   - surface net heat flux,                     t =   345 00:00:00
                   (Min = -1.22467813E-04 Max =  3.12575784E-05)
    GET_2DFLD   - surface net freswater flux, (E-P),         t =   345 00:00:00
                   (Min = -3.01846074E-07 Max =  1.15583962E-07)
    GET_2DFLD   - sea surface salinity climatology,          t =   345 00:00:00
                   (Min =  1.65167007E+01 Max =  4.11551018E+01)
    GET_NGFLD   - free-surface eastern boundary condition,   t =   345 00:00:00
                   (Rec=0012, Index=2, File: shiyf_bry.nc)
                   (Min = -3.83470606E-01 Max =  7.99989567E+00)
    GET_NGFLD   - free-surface southern boundary condition,  t =   345 00:00:00
                   (Min = -3.50685381E-01 Max =  7.99989567E+00)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -2.60444052E-02 Max =  1.37641049E-02)
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -1.79761074E-03 Max =  1.07012369E-03)
    GET_NGFLD   - 2D u-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -1.24812288E-03 Max =  9.84361104E-03)
    GET_NGFLD   - 2D v-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -1.02250826E+00 Max =  9.09095033E-01)
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -3.66099335E-01 Max =  3.02597453E-01)
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -1.07493064E-01 Max =  6.03430119E-02)
    GET_NGFLD   - 3D u-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -6.48846883E-02 Max =  6.44035122E-02)
    GET_NGFLD   - 3D v-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -1.08044189E+00 Max =  1.25793587E+00)
    GET_NGFLD   - temperature eastern boundary condition,    t =   345 00:00:00
                   (Min =  1.67032195E+00 Max =  2.78780000E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t =   345 00:00:00
                   (Min =  3.33691664E+01 Max =  3.52194348E+01)
    GET_NGFLD   - temperature southern boundary condition,   t =   345 00:00:00
                   (Min =  1.15385186E+00 Max =  2.97989341E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =   345 00:00:00
                   (Min =  3.20250773E+01 Max =  3.59597283E+01)
 Maximum grid stiffness ratios:  rx0 =   1.483417E-01 (Beckmann and Haidvogel)
                                 rx1 =   8.076796E-01 (Haney)
 Initial basin volumes: TotVolume =  3.7465697418E+17 m3
                        MinVolume =  6.9680682010E+08 m3
                        MaxVolume =  4.8199230429E+12 m3
                          Max/Min =  6.9171582479E+03
 NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
    GET_2DFLD   - surface u-momentum stress,                 t =    15 00:00:00
                   (Rec=0001, Index=2, File: shiyf_frc.nc)
                   (Min = -5.63892333E+02 Max =  7.27163233E+02)
    GET_2DFLD   - surface v-momentum stress,                 t =    15 00:00:00
                   (Min = -9.21693244E+02 Max =  3.89433969E+02)
    GET_2DFLD   - solar shortwave radiation flux,            t =    15 00:00:00
                   (Min =  1.56437748E-06 Max =  7.13031920E-05)
    GET_2DFLD   - surface net heat flux,                     t =    15 00:00:00
                   (Min = -1.28904424E-04 Max =  3.03673525E-05)
    GET_2DFLD   - surface net freswater flux, (E-P),         t =    15 00:00:00
                   (Min = -2.56906815E-07 Max =  1.14237990E-07)
    GET_2DFLD   - sea surface salinity climatology,          t =    15 00:00:00
                   (Min =  1.77527008E+01 Max =  4.05689011E+01)
    GET_NGFLD   - free-surface eastern boundary condition,   t =    15 00:00:00
                   (Rec=0001, Index=1, File: shiyf_bry.nc)
                   (Min = -3.50845128E-01 Max =  8.00844646E+00)
    GET_NGFLD   - free-surface southern boundary condition,  t =    15 00:00:00
                   (Min = -3.30109051E-01 Max =  8.00844646E+00)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -6.11860132E-03 Max =  2.18489387E-02)
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -1.53135821E-03 Max =  1.14542320E-03)
    GET_NGFLD   - 2D u-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -1.23071690E-03 Max =  2.52131175E-02)
    GET_NGFLD   - 2D v-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -9.37649144E-01 Max =  9.63868906E-01)
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -2.11111437E-01 Max =  2.42682754E-01)
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -9.15717638E-02 Max =  6.30581806E-02)
    GET_NGFLD   - 3D u-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -6.39798238E-02 Max =  7.41423366E-02)
    GET_NGFLD   - 3D v-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -9.81503760E-01 Max =  1.40600143E+00)
    GET_NGFLD   - temperature eastern boundary condition,    t =    15 00:00:00
                   (Min =  1.67032195E+00 Max =  2.74140332E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t =    15 00:00:00
                   (Min =  3.35107269E+01 Max =  3.50963225E+01)
    GET_NGFLD   - temperature southern boundary condition,   t =    15 00:00:00
                   (Min =  1.15385186E+00 Max =  2.98525752E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =    15 00:00:00
                   (Min =  3.05486010E+01 Max =  3.58689762E+01)
      0     0 00:00:01  1.567195E-06  2.153599E+04  2.153599E+04  3.828818E+17
          (166,001,05)  0.000000E+00  3.603793E-03  0.000000E+00  9.407347E-01
      DEF_HIS   - creating history file: ocean_his.nc
      DEF_AVG   - creating average file: ocean_avg.nc
      1     0 00:05:01 NaN           NaN           NaN           NaN
          (149,003,16)  2.419516E+01  3.961077E+00  0.000000E+00  0.000000E+00
 WRT_RST - error while writing variable: zeta
           into restart NetCDF file for time record:    1
 Node   #  2 CPU:       1.219
 Node   #  1 CPU:       1.242
 Node   #  0 CPU:       1.211
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     ROMS/Functionals/ana_hmixcoef.h
 ROMS/TOMS - Output error ............ exit_flag:   3
 Node   #  7 CPU:       1.214
 Node   #  4 CPU:       1.231
 Node   #  8 CPU:       1.216
 Node   #  3 CPU:       1.212
 Node   #  6 CPU:       1.196
 Node   #  5 CPU:       1.202
i get some messages from roms discussion,the above error may be result from Vertical S-coordinate System which have a zero value,is it? could you help me?
How to do to avoid this kind of error?
Re: error while writing variable: zeta
:idea: Please read all the errors message that ROMS is giving you. The information is all there :!: Many users fail at this. The model is blowing-up and it is very likely that it is a CFL violation (too large time-step) because ROMS blows-up right away and gives you NaNs. If you don't know what a CFL violation is, you can :arrow: Google it and you will be surprised how much information you can find by your own...
The error in the restart NetCDF file is secondary. The free-surface (zeta) has NaNs values because the model is blowing-up and the NetCDF library cannot handle such values.
shiyf
#3 Unread post by shiyf »
Thanks a lot!! the error have solved,but when the mode run a short period of time,then stop !! I can not find error message,could you help me!
log.in
(143.86 KiB) Downloaded 365 times
