Illegal model configuration
shiyf
#1 Unread post by shiyf »
Hello everyone, I have got an error as follow: ( I don't know the reason, I am confused. Anyone can tell me how to fix it?)
Friday - November 15, 2013 - 3:50:05 PM
SHIYF
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /lustre/inspur/mpi/openmpi-intel/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script : ocean_shiyf.in
SVN Revision : Unversioned directory
Local Root : /lustre/home/shiyongfangWKJ/roms/trunk
Header Dir : /lustre/home/shiyongfangWKJ/roms/projects/roms_test
Header file : shiyf.h
Analytical Dir: /lustre/home/shiyongfangWKJ/roms/projects/roms_test
Resolution, Grid 01: 0449x0160x016, Parallel Nodes: 9, Tiling: 003x003
into restart fields.
to standard output.
1 nSTA Number of timesteps between the writing of data
the stations file.
1 nFLT Number of timesteps between the writing of data
into floats file.
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1 lmd_Jwt Jerlov water type.
for tracer 02: salt
READ_PHYPAR - Invalid input parameter, Tnudg(isalt) = 0.0000E+00
Must be greater than zero for salt flux correction.
Re: Illegal model configuration
It says you can't have Tnudg(2) set to zero, yet you have it set to zero. Have you tried changing it in your ocean.in file?
shiyf
#3 Unread post by shiyf »
kate wrote:It says you can't have Tnudg(2) set to zero, yet you have it set to zero. Have you tried changing it in your ocean.in file?
Thank you very much!the error has been solved,But when I run again,it is shown that
Output Stations File: ocean_sta.nc
Output Floats File: ocean_flt.nc
Input Grid File: /lustre/home/shiyongfangWKJ/roms/projects/roms_test/shiyf_grd.nc
Input Nonlinear Initial File: /lustre/home/shiyongfangWKJ/roms/projects/roms_test/shiyf_ini.nc
Input Forcing File 01: /lustre/home/shiyongfangWKJ/roms/projects/roms_test/shiyf_frc.nc
Input Boundary File: /lustre/home/shiyongfangWKJ/roms/projects/roms_test/shiyf_bry.nc
READ_PHYPAR - could not find input file:
do you encounter such a problem,could you help me?
my *.h file is :
** Options for SHIYF.
** Application flag: SHIYF
** Input script: ocean_shiyf.in
#define NO_HIS
#undef NETCDF4
#undef PARALLEL_IO
#undef OFFLINE_FLOATS
#ifdef SOLVE3D
#define SPLINES
#define FLOATS
#define STATIONS
#undef WET_DRY
#undef T_PASSIVE
#ifdef T_PASSIVE
#define ANA_PASSIVE
#define TRC_PSOURCE
#define ANA_TRC_PSOURCE
#define AGE_PASSIVE
#define NO_WRITE_GRID
#undef OUT_DOUBLE
#define RST_SINGLE
#define AVERAGES2
#ifdef SOLVE3D
#undef AVERAGES_DETIDE
#undef DIAGNOSTICS_TS
#undef DIAGNOSTICS_UV
#ifdef SOLVE3D
#undef UV_SADVECTION
#ifdef SOLVE3D
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#undef TS_MPDATA
#undef UV_SMAGORINSKY
#undef VISC_3DCOEF
#define VISC_GRID
#undef SPONGE
#ifdef SOLVE3D
#define MIX_GEO_TS
#define DIFF_GRID
#ifdef SOLVE3D
#define SOLAR_SOURCE
#define WTYPE_GRID
#undef LMD_MIXING
#ifdef LMD_MIXING
#define LMD_RIMIX
#define LMD_CONVEC
#define LMD_SKPP
#undef LMD_BKPP
#define LMD_NONLOCAL
#define LMD_SHAPIRO
#undef LMD_DDMIX
#define GLS_MIXING
#undef MY25_MIXING
#define KANTHA_CLAYSON
#define N2S2_HORAVG
#ifdef SOLVE3D
#define NCEP_FLUXES
#ifdef SOLVE3D
#define SCORRECTION
#undef QCORRECTION
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#define RADIATION_2D
#ifdef SOLVE3D
#else
#define ANA_SMFLUX
That looks scarily like one of my cppdefs.h files. I see you have both floats and stations on. Do you have the floats and stations input files for it to read? I would debug this in a debugger to see where it's failing because it's not all that obvious from what you sent.
shiyf
#5 Unread post by shiyf »
kate wrote:That looks scarily like one of my cppdefs.h files. I see you have both floats and stations on. Do you have the floats and stations input files for it to read? I would debug this in a debugger to see where it's failing because it's not all that obvious from what you sent.
In fact,I only want to simulate the ocean temperature and salinity, Because i am a new user,I want to first be familiar with the process of the roms.As you suggest,I try to modify my shiyf.h file,Thank you very much !
could you help me have a look Whether the input files are correctly?
shiyf_ini.nc
(40.61 MiB) Downloaded 784 times
shiyf_grd.nc
(15.01 MiB) Downloaded 572 times
shiyf_bry.nc
(11.42 MiB) Downloaded 545 times
shiyf_frc.nc
(40.14 MiB) Downloaded 908 times
shiyf
#6 Unread post by shiyf »
hi, I delete the cpp options-' FLOATS and STATIONS'in my cppdefs file, and compile build.bash again,but i get anther error:
READ_PHYPAR - could not find input file: ROMS/External/stations.in
I am very confused,How to locate the source of the error?
I am greatly appreciated for your help!
ocean_shiyf.in
(104.15 KiB) Downloaded 596 times
shiyf.h
(1.8 KiB) Downloaded 536 times
#7 Unread post by kate »
Checking the read_phypar.F code shows that it will only try to read the stations file if STATIONS is defined. You can check the read_phypar.f90 intermediate file to check for the lines inside the #ifdef:
#ifdef STATIONS
          fname=sposnam
          IF (.not.find_file(ng, fname, 'SPOSNAM')) GO TO 30
          WRITE (out,230) '        Station positions File:  ',          &
     &                    TRIM(fname)
If it is still there, you haven't fully recompiled after changing your cppdefs.h file. Try "make clean" and a fresh build.
shiyf
#8 Unread post by shiyf »
kate wrote:Checking the read_phypar.F code shows that it will only try to read the stations file if STATIONS is defined. You can check the read_phypar.f90 intermediate file to check for the lines inside the #ifdef:
#ifdef STATIONS
          fname=sposnam
     &                    TRIM(fname)
thank you very much! the problem have solved,but there is anther error:CHECKDEFS - no bottom stress formulation is selected.
i am very confused,because i have defined UV_LDRAG,it is same as the above problem, when i delete the station options in cpp.h as you suggest,then compile build.bash again, the error is still,Until I delete all files, including roms code,and upload all files,compile build.bash again,Problem can be solved. I do not know why it is? Can you give me some advice?
checkdefs.F
the checkdefs.f file in roms code
(90.75 KiB) Downloaded 546 times
shiyf.h
(1.82 KiB) Downloaded 640 times
log.in
(13.69 KiB) Downloaded 578 times
#9 Unread post by kate »
You should not need to download ROMS all over again. When you build ROMS, it creates intermediate files in some $SCRATCH_DIR location. Do you know where that is? You want to find that location and investigate what those files look like when there are problems like your bottom drag problem.
Then when you modify your shiyf.h file, you want to restart the build. One way to do that is to delete the whole $SCRATCH_DIR directory and let build.bash recreate it. Also, the clean=1 in build.bash should be doing that for you automatically. Thirdly, if all the MakeDepend things are working, it should know to recompile almost everything when shiyf.h is modified.
As for the bottom drag, I don't know, but the place to investigate is in $SCRATCH_DIR/checkdefs.f90. Search it for "ibbl". Compare that to what's in checkdefs.F. Did it pick up any of your cpp options? If not, perhaps it's because your shiyf.h file is in dos format, I don't know.
shiyf
#10 Unread post by shiyf »
kate wrote:You should not need to download ROMS all over again. When you build ROMS, it creates intermediate files in some $SCRATCH_DIR location. Do you know where that is? You want to find that location and investigate what those files look like when there are problems like your bottom drag problem.
Thank you very much for your answer patiently,I found the cause of the error, it is because that i only modify my shiyf.h file under the projects file,but not modify the shiyf.h in trunk/ROMS/include path, I'm sorry to delay your time,but your advise is very useful for me!
