two errors in npzd_iron_inp.h
jpm
#1 Unread post by jpm »
In ROMS:
The current version (ROMS 696) of npzd_iron_inp.h contains 2 errors that cause a segmentation fault and a compilation failure, respectively.
In line 209 and line 219: There is a missing input argument in function call to load_lbc (this causes a segmentation fault while reading in the biological boundary conditions):
line 209:
              Npts=load_lbc(Nval, Cval, line, nline, ifield, igrid,     &
     &                      iTrcStr, iTrcEnd, LBC)
fix:
     &                      iTrcStr, iTrcEnd,                           &
     &                      Vname(1,idTvar(idbio(itracer))), LBC)
The same issue is present in line 219:
     &                      iTrcStr, iTrcEnd, ad_LBC)
In line 644: "END SELECT" instead of "END IF"; this one is pretty obvious:
!  Report input parameters.
      IF (Lwrite) THEN
        DO ng=1,Ngrids
          IF (Lbiology(ng)) THEN
          END SELECT
END SELECT in npzd_iron_inp.h
Jann Paul Mattern, Ocean Sciences Department, UCSC
Re: two errors in npzd_iron_inp.h
The load_lbc arguments in the current version of npzd_iron_inp.h in the repository were correct. Perhaps, you are using an older version of this routine. However, I have to correct the END SELECT statement to END IF. Thank you for bringing this to my attention.
jpm
#3 Unread post by jpm »
Great! In ROMS 696, I noticed the first bug was still present but having just updated to the latest version 697 I can confirm it is fixed. Thanks
