problem on netcdf4-python
wzf1984
#1 Unread post by wzf1984 »
I have problems on netcdf4-python. When I test, there are errors:
root@ubuntu:/opt/netCDF4-1.0.4/test# python run_all.py
E..............................................
ERROR: runTest (tst_dap.DapTestCase)
testing access of data over http using opendap
Traceback (most recent call last):
File "/opt/netCDF4-1.0.4/test/tst_dap.py", line 22, in runTest
file = netCDF4.Dataset(URL)
File "netCDF4.pyx", line 1386, in netCDF4.Dataset.__init__ (netCDF4.c:19148)
RuntimeError: NetCDF: Unknown file format
Ran 47 tests in 11.291s
FAILED (errors=1)
netcdf4-python version: 1.0.4
HDF5 lib version: 1.8.11
netcdf lib version: 4.3.0
I would appreciate your help !
Re: problem on netcdf4-python
OpenDAP is a way to share files over the network. When you compile the NetCDF library, you have the option of building for OpenDAP - or not. It seems that you did not. If you don't plan on using OpenDAP, I wouldn't worry about this.
