No file created though the job is running
papaya
#1 Unread post by papaya »
I submitted a job, but
(1) it shows the job is running,
(2) no error is reported,
(3) no file is created, such log file, history file, average file etc.
After hours, I check the status, it gives:
Job id Name User Time Use S Queue
3162475.repace ROSS fzhang76 00:00:00 R atlas-6
3162575.repace ROSS fzhang76 00:00:00 R atlas-6
The time used is always zero.
I changed the NtileI and NtileJ in the ross.in file. Still the same.
Attached are my header file and ocean.in.
Could anyone give some clues what may cause this situation?
Thanks in advance!
Fan
ross.h
(2.34 KiB) Downloaded 1272 times
ocean.in
(104.4 KiB) Downloaded 1281 times
Re: No file created though the job is running
Your email includes the information that this only happens with ICESHELF defined. It's not an option I've ever tried.
That said, I would run it in the debugger and see where it hangs. You can try gfortran in serial mode with gdb if you have nothing better, or you can instead try print statements everywhere if that is more your style.
