Different results for different configurations
jwn4548
#1 Unread post by jwn4548 »
Hi, I've been working with setting up ROMS for a few weeks now. I'm using builds with ifort/mpiifort (Intel 14) and gfortran/mpif90 (Intel 14) and they produced consistent tracer results for the BENCHMARK 1 and 3 test cases for various tile sizings, #'s of cpus, #'s of nodes.
However, when I attempt to run a forecast model that was given to me for the Chesapeake Bay the tracer results are different whenever I change anything: compiler, tile sizing, optimization setting ("-O2" or "-O3" FFLAG). I was hoping maybe someone could give me an idea of what may be the problem, as I did not make the grid myself and do not know much about whether it was done well or not.
I will include a log of a run on one node. Let me know if any other information would help.
 Model Input Parameters:  ROMS/TOMS version 3.6
                          Tuesday - July 9, 2013 -  3:46:40 PM
 cbofs nowcast RUN in operational mode
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : gfortran
 Compiler command : /tools/intel/clustersuite/2013/impi/4.1.0.024/intel64/bin/mpif90
 Compiler flags   : -frepack-arrays  -O3 -ffast-math  -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
 Input Script  : nos.cbofs.roms.nowcast.20120802.t00z.in
 SVN Revision  : exported
 Local Root    : /home/jwn4548/roms_rev648
 Header Dir    : /home/jwn4548/roms_rev648/ROMS/Include
 Header file   : cbofs_fwd.h
 Analytical Dir: /home/jwn4548/roms_rev648/ROMS/External
 Resolution, Grid 01: 0330x0289x020,  Parallel Nodes:  16,  Tiling: 008x002
       2160  ntimes          Number of timesteps for 3-D equations.
     10.000  dt              Timestep size (s) for 3-D equations.
         20  ndtfast         Number of timesteps for 2-D equations between
         -1  nrrec           Number of restart records to read from disk.
        360  nRST            Number of timesteps between the writing of data
                               into restart fields.
        240  ninfo           Number of timesteps between print of information
                               to standard output.
         36  nSTA            Number of timesteps between the writing of data
                               the stations file.
        360  nHIS            Number of timesteps between the writing fields
                               into history file.
 5.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 5.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak         Background vertical mixing coefficient (m2/s)
                               for turbulent energy.
 5.0000E-06  Akp_bak         Background vertical mixing coefficient (m2/s)
     -1.000  gls_p           GLS stability exponent.
      0.500  gls_m           GLS turbulent kinetic energy exponent.
     -1.000  gls_n           GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin        GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin        GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0        GLS stability coefficient.
 5.5500E-01  gls_c1          GLS shear production coefficient.
 8.3300E-01  gls_c2          GLS dissipation coefficient.
-6.0000E-01  gls_c3m         GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p         GLS unstable buoyancy production coefficient.
 2.0000E+00  gls_sigk        GLS constant Schmidt number for TKE.
 2.0000E+00  gls_sigp        GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha   Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha  Factor for Zos calculation using Hsig(Awave).
      0.250  sz_alpha        Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw       Factor for Craig/Banner surface tke flux.
 5.0000E-03  rdrg2           Quadratic bottom drag coefficient.
 5.0000E-04  Zob             Bottom roughness (m).
 5.0000E-03  Zos             Surface roughness (m).
 2.0000E+00  blk_ZQ          Height (m) of surface air humidity measurement.
 2.0000E+00  blk_ZT          Height (m) of surface air temperature measurement.
 1.0000E+01  blk_ZW          Height (m) of surface winds measurement.
          1  Vtransform      S-coordinate transformation equation.
          1  Vstretching     S-coordinate stretching function.
 4.5000E+00  theta_s         S-coordinate surface control parameter.
 9.5000E-01  theta_b         S-coordinate bottom  control parameter.
     10.000  Tcline          S-coordinate surface/bottom layer width (m) used
   1308.750  dstart          Time-stamp assigned to model initialization (days).
   1095.000  tide_start      Reference time origin for tidal forcing (days).
20090101.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
                               for 3D momentum.
          F  VolCons(1)      NLM western  edge boundary volume conservation.
          F  VolCons(2)      NLM southern edge boundary volume conservation.
          F  VolCons(3)      NLM eastern  edge boundary volume conservation.
          F  VolCons(4)      NLM northern edge boundary volume conservation.
     14.000  T0              Background potential temperature (C) constant.
     35.000  S0              Background salinity (PSU) constant.
          F  LtracerSrc(01)  Processing point sources/Sink on tracer 01: temp
          F  LtracerSrc(02)  Processing point sources/Sink on tracer 02: salt
          T  Hout(idPair)    Write out surface air pressure.
          T  Hout(idUair)    Write out surface U-wind component.
          T  Hout(idVair)    Write out surface V-wind component.
             Output Restart File:  nos.cbofs.rst.nowcast.20120802.t00z.nc
             Output History File:  nos.cbofs.fields.nowcast.20120802.t00z.nc
            Output Stations File:  nos.cbofs.stations.nowcast.20120802.t00z.nc
                 Input Grid File:  nos.cbofs.romsgrid.nc
    Input Nonlinear Initial File:  nos.cbofs.init.nowcast.20120802.t00z.nc
           Input Forcing File 01:  nos.cbofs.roms.tides.nc
           Input Forcing File 02:  nos.cbofs.river.20120802.t00z.nc
           Input Forcing File 03:  nos.cbofs.met.nowcast.20120802.t00z.nc
             Input Boundary File:  nos.cbofs.obc.20120802.t00z.nc
          Station positions File:  nos.cbofs.stations.in
 Tile partition information for Grid 01:  0330x0289x0020  tiling: 008x002
        0        1       39        1      145   113100
        1       40       81        1      145   121800
        2       82      123        1      145   121800
        3      124      165        1      145   121800
        4      166      207        1      145   121800
        5      208      249        1      145   121800
        6      250      291        1      145   121800
        7      292      330        1      145   113100
        8        1       39      146      289   112320
        9       40       81      146      289   120960
       10       82      123      146      289   120960
       11      124      165      146      289   120960
       12      166      207      146      289   120960
       13      208      249      146      289   120960
       14      250      291      146      289   120960
       15      292      330      146      289   112320
   (interior points only)
        0     0.50    39.50     0.50   145.50  RHO-points
        1    39.50    81.50     0.50   145.50  RHO-points
        2    81.50   123.50     0.50   145.50  RHO-points
        3   123.50   165.50     0.50   145.50  RHO-points
        4   165.50   207.50     0.50   145.50  RHO-points
        5   207.50   249.50     0.50   145.50  RHO-points
        6   249.50   291.50     0.50   145.50  RHO-points
        7   291.50   330.50     0.50   145.50  RHO-points
        8     0.50    39.50   145.50   289.50  RHO-points
        9    39.50    81.50   145.50   289.50  RHO-points
       10    81.50   123.50   145.50   289.50  RHO-points
       11   123.50   165.50   145.50   289.50  RHO-points
       12   165.50   207.50   145.50   289.50  RHO-points
       13   207.50   249.50   145.50   289.50  RHO-points
       14   249.50   291.50   145.50   289.50  RHO-points
       15   291.50   330.50   145.50   289.50  RHO-points
        0     1.00    39.50     0.50   145.50    U-points
        1    39.50    81.50     0.50   145.50    U-points
        2    81.50   123.50     0.50   145.50    U-points
        3   123.50   165.50     0.50   145.50    U-points
        4   165.50   207.50     0.50   145.50    U-points
        5   207.50   249.50     0.50   145.50    U-points
        6   249.50   291.50     0.50   145.50    U-points
        7   291.50   330.00     0.50   145.50    U-points
        8     1.00    39.50   145.50   289.50    U-points
        9    39.50    81.50   145.50   289.50    U-points
       10    81.50   123.50   145.50   289.50    U-points
       11   123.50   165.50   145.50   289.50    U-points
       12   165.50   207.50   145.50   289.50    U-points
       13   207.50   249.50   145.50   289.50    U-points
       14   249.50   291.50   145.50   289.50    U-points
       15   291.50   330.00   145.50   289.50    U-points
        0     0.50    39.50     1.00   145.50    V-points
        1    39.50    81.50     1.00   145.50    V-points
        2    81.50   123.50     1.00   145.50    V-points
        3   123.50   165.50     1.00   145.50    V-points
        4   165.50   207.50     1.00   145.50    V-points
        5   207.50   249.50     1.00   145.50    V-points
        6   249.50   291.50     1.00   145.50    V-points
        7   291.50   330.50     1.00   145.50    V-points
        8     0.50    39.50   145.50   289.00    V-points
        9    39.50    81.50   145.50   289.00    V-points
       10    81.50   123.50   145.50   289.00    V-points
       11   123.50   165.50   145.50   289.00    V-points
       12   165.50   207.50   145.50   289.00    V-points
       13   207.50   249.50   145.50   289.00    V-points
       14   249.50   291.50   145.50   289.00    V-points
       15   291.50   330.50   145.50   289.00    V-points
               HaloSizeI(1) =     108
               HaloSizeJ(1) =     312
                TileSide(1) =     150
                TileSize(1) =    7200
 Variable               Grid    West Edge   South Edge  East Edge   North Edge
 zeta                     1     Closed      Clamped     Chapman     Closed
 ubar                     1     Closed      Reduced     Flather     Closed
 vbar                     1     Closed      Reduced     Flather     Closed
 u                        1     Closed      Radiation   Radiation   Closed
 v                        1     Closed      Radiation   Radiation   Closed
 temp                     1     Closed      Rad + Nud   Rad + Nud   Closed
 salt                     1     Closed      Rad + Nud   Rad + Nud   Closed
 tke                      1     Closed      Gradient    Gradient    Closed
 mode                cbofs nowcast RUN in operational mode
 ADD_FSOBC           Adding tidal elevation to processed OBC data.
 ATM_PRESS           Impose atmospheric pressure onto sea surface.
 ANA_RAIN            Analytical rain fall rate.
 ANA_SSFLUX          Analytical kinematic surface salinity flux.
 BULK_FLUXES         Surface bulk fluxes parameterization.
 FSOBC_REDUCED       Using free-surface data in reduced physics conditions
 GLS_MIXING          Generic Length-Scale turbulence closure.
 LONGWAVE_OUT        Compute outgoing longwave radiation internally.
 NO_LBC_ATT          Not checking NetCDF global attribute NLM_LBC during restart.
 OUT_DOUBLE          Double precision output fields in NetCDF files.
 PERFECT_RESTART     Processing perfect restart variables.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 SSH_TIDES           Add tidal elevation to SSH climatology.
 STATIONS            Writing out station data.
 !STOCH_OPT_WHITE    Stochastic Optimals, red noise processes.
 TS_SVADVECTION      Parabolic splines vertical advection of tracers.
 TS_PSOURCE          Tracers point sources and sinks.
 UV_SADVECTION       Parabolic splines vertical advection of momentum.
 UV_PSOURCE          Mass point sources and sinks.
 UV_TIDES            Add tidal currents to 2D momentum climatologies.
 Process Information:
 Node #  2 (pid=   60674) is active.
 Node # 10 (pid=   60682) is active.
 Node #  0 (pid=   60672) is active.
 Node #  1 (pid=   60673) is active.
 Node #  3 (pid=   60675) is active.
 Node #  4 (pid=   60676) is active.
 Node #  5 (pid=   60677) is active.
 Node #  6 (pid=   60678) is active.
 Node #  7 (pid=   60679) is active.
 Node #  8 (pid=   60680) is active.
 Node #  9 (pid=   60681) is active.
 Node # 11 (pid=   60683) is active.
 Node # 12 (pid=   60684) is active.
 Node # 13 (pid=   60685) is active.
 Node # 14 (pid=   60686) is active.
 Node # 15 (pid=   60687) is active.
 Vertical S-coordinate System:
    20   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    19  -0.0500000  -0.0062133       -0.100      -0.100      -0.264      -0.428
    18  -0.1000000  -0.0156797       -0.200      -0.200      -0.614      -1.027
    17  -0.1500000  -0.0300499       -0.300      -0.300      -1.093      -1.886
    16  -0.2000000  -0.0516372       -0.400      -0.400      -1.762      -3.125
    15  -0.2500000  -0.0834758       -0.500      -0.500      -2.702      -4.905
    14  -0.3000000  -0.1291130       -0.600      -0.600      -4.006      -7.413
    13  -0.3500000  -0.1918675       -0.700      -0.700      -5.762     -10.824
    12  -0.4000000  -0.2733643       -0.800      -0.800      -8.012     -15.224
    11  -0.4500000  -0.3716666       -0.900      -0.900     -10.706     -20.511
    10  -0.5000000  -0.4802121       -1.000      -1.000     -13.669     -26.339
     9  -0.5500000  -0.5890225       -1.100      -1.100     -16.640     -32.180
     8  -0.6000000  -0.6881332       -1.200      -1.200     -19.355     -37.510
     7  -0.6500000  -0.7710230       -1.300      -1.300     -21.642     -41.984
     6  -0.7000000  -0.8358257       -1.400      -1.400     -23.452     -45.503
     5  -0.7500000  -0.8842706       -1.500      -1.500     -24.830     -48.159
     4  -0.8000000  -0.9198191       -1.600      -1.600     -25.868     -50.135
     3  -0.8500000  -0.9462072       -1.700      -1.700     -26.664     -51.627
     2  -0.9000000  -0.9667129       -1.800      -1.800     -27.305     -52.809
     1  -0.9500000  -0.9839618       -1.900      -1.900     -27.860     -53.820
     0  -1.0000000  -1.0000000       -2.000      -2.000     -28.383     -54.766
 Time Splitting Weights: ndtfast =  20    nfast =  29
  3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
  4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
  5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
  6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
  7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
  8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
  9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
 10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
 11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
 12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
 13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
 14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
 15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
 16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
 17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
 18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
 19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
 20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
 21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
 22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
 23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
 24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
 25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
 26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
 27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
 28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
 29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
 ndtfast, nfast =   20  29   nfast/ndtfast =  1.45000
 Power filter parameters, Fgamma, gamma =  0.28400   0.14200
 Minimum X-grid spacing, DXmin =  3.37602263E-02 km
 Maximum X-grid spacing, DXmax =  4.89459071E+00 km
 Minimum Y-grid spacing, DYmin =  2.93942428E-02 km
 Maximum Y-grid spacing, DYmax =  3.37982211E+00 km
 Minimum Z-grid spacing, DZmin =  1.00000000E-01 m
 Maximum Z-grid spacing, DZmax =  5.84147431E+00 m
 Minimum barotropic Courant Number =  1.38427552E-03
 Maximum barotropic Courant Number =  1.70679173E-01
 Maximum Coriolis   Courant Number =  9.27326735E-04
 NLM: GET_STATE - Warning - NetCDF global attribute: NLM_LBC
                  for lateral boundary conditions not checked
                  in restart file: nos.cbofs.init.nowcast.20120802.t00z.nc
 NLM: GET_STATE - Read state initial conditions,             t =  1308 18:00:00
                   (File: nos.cbofs.init.nowcast.20120802.t00z.nc, Rec=0002, Index=1)
                - free-surface
                   (Min = -6.29388171E-01 Max =  7.57128637E-01)
                - RHS of free-surface equation
                   (Min = -1.29177221E+03 Max =  1.45951565E+03)
                   (Min = -1.14864916E+00 Max =  8.38326440E-01)
                - RHS of vertically integrated u-momentum
                   (Min = -7.23545500E+04 Max =  8.23724057E+04)
                   (Min = -1.28498224E+00 Max =  7.70053035E-01)
                - RHS of vertically integrated v-momentum
                   (Min = -7.55631846E+04 Max =  5.13256775E+04)
                - u-momentum component
                   (Min = -1.30748521E+00 Max =  1.26974373E+00)
                - RHS of total u-momentum
                   (Min = -1.79595529E+04 Max =  1.01624298E+04)
                - v-momentum component
                   (Min = -1.89756223E+00 Max =  9.76519773E-01)
                - RHS of total v-momentum
                   (Min = -9.08851931E+03 Max =  9.29712219E+03)
                - potential temperature
                   (Min =  0.00000000E+00 Max =  3.14887468E+01)
                - salinity
                   (Min = -5.85534524E-02 Max =  3.49319870E+01)
                - vertical viscosity coefficient
                   (Min =  0.00000000E+00 Max =  1.15201445E+00)
                - temperature vertical diffusion coefficient
                   (Min =  0.00000000E+00 Max =  1.45531146E+00)
                - salinity vertical diffusion coefficient
                - turbulent kinetic energy
                   (Min =  0.00000000E+00 Max =  2.67643662E-01)
                - turbulent generic length scale
                   (Min =  0.00000000E+00 Max =  9.55409582E+02)
                - vertical mixing turbulent length scale
                   (Min =  0.00000000E+00 Max =  4.46783918E+00)
                - Turbulent kinetic energy vertical diffusion coefficient
                   (Min =  0.00000000E+00 Max =  5.75987224E-01)
                - Turbulent length scale vertical diffusion coefficient
    GET_NGFLD   - tidal period
                   (Min =  1.11785408E+04 Max =  3.15569848E+07)
    GET_2DFLD   - tidal elevation amplitude
                   (Min =  0.00000000E+00 Max =  7.86141038E-01)
    GET_2DFLD   - tidal elevation phase angle
                   (Min =  0.00000000E+00 Max =  6.28229528E+00)
    GET_2DFLD   - tidal current inclination angle
                   (Min =  0.00000000E+00 Max =  6.12710223E+00)
    GET_2DFLD   - tidal current phase angle
                   (Min =  0.00000000E+00 Max =  6.28290088E+00)
    GET_2DFLD   - maximum tidal current, ellipse major axis
                   (Min =  0.00000000E+00 Max =  5.49963117E-01)
    GET_2DFLD   - minimum tidal current, ellipse minor axis
                   (Min = -9.91174579E-02 Max =  2.97933165E-03)
    GET_NGFLD   - river runoff  XI-positions at RHO-points
                   (Min =  1.00000000E+00 Max =  2.96000000E+02)
    GET_NGFLD   - river runoff ETA-positions at RHO-points
                   (Min =  4.50000000E+01 Max =  2.90000000E+02)
    GET_NGFLD   - river runoff direction
                   (Min =  0.00000000E+00 Max =  1.00000000E+00)
    GET_NGFLD   - river runoff mass transport vertical profile
                   (Min =  0.00000000E+00 Max =  8.29700455E-02)
    GET_NGFLD   - river runoff mass transport,               t =  1308 18:00:00
                   (Rec=0002, Index=2, File: nos.cbofs.river.20120802.t00z.nc)
                   (Tmin=       1308.7084 Tmax=       1311.0000)
                   (Min = -2.46420011E-01 Max =  1.58533691E+02)
    GET_2DFLD   - surface u-wind component,                  t =  1308 18:00:00
                   (Rec=0003, Index=1, File: nos.cbofs.met.nowcast.20120802.t00z.nc)
                   (Tmin=       1308.5000 Tmax=       1309.1250)
                   (Min = -1.76184392E+00 Max =  3.81952527E+00)
    GET_2DFLD   - surface v-wind component,                  t =  1308 18:00:00
                   (Min = -2.11692076E+00 Max =  4.64075630E+00)
    GET_2DFLD   - surface air pressure,                      t =  1308 18:00:00
                   (Min =  1.01026001E+03 Max =  1.01251348E+03)
    GET_2DFLD   - solar shortwave radiation flux,            t =  1308 18:00:00
                   (Min =  2.39451782E-05 Max =  1.91947877E-04)
    GET_2DFLD   - downwelling longwave radiation flux,       t =  1308 18:00:00
                   (Min =  9.16339981E-05 Max =  1.11955502E-04)
    GET_2DFLD   - surface air temperature,                   t =  1308 18:00:00
                   (Min =  2.40315934E+01 Max =  3.36256860E+01)
    GET_2DFLD   - surface air relative humidity,             t =  1308 18:00:00
                   (Min =  4.50000000E-01 Max =  9.30000000E-01)
    GET_NGFLD   - free-surface eastern boundary condition,   t =  1308 18:00:00
                   (Rec=0001, Index=2, File: nos.cbofs.obc.20120802.t00z.nc)
                   (Tmin=       1308.7500 Tmax=       1311.0000)
                   (Min = -6.65592775E-02 Max =  0.00000000E+00)
    GET_NGFLD   - free-surface southern boundary condition,  t =  1308 18:00:00
                   (Min =  0.00000000E+00 Max =  3.21919352E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =  1308 18:00:00
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =  1308 18:00:00
    GET_NGFLD   - temperature eastern boundary condition,    t =  1308 18:00:00
                   (Min =  0.00000000E+00 Max =  2.81042595E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t =  1308 18:00:00
                   (Min =  0.00000000E+00 Max =  2.57540131E+00)
    GET_NGFLD   - temperature southern boundary condition,   t =  1308 18:00:00
                   (Min =  0.00000000E+00 Max =  2.80846691E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =  1308 18:00:00
                   (Min =  0.00000000E+00 Max =  3.49825706E+01)
 Maximum grid stiffness ratios:  rx0 =   8.072623E-01 (Beckmann and Haidvogel)
                                 rx1 =   8.168784E+01 (Haney)
 Initial basin volumes: TotVolume =  3.9791843348E+11 m3
                        MinVolume =  1.7635906897E+02 m3
                        MaxVolume =  7.5719729383E+07 m3
                          Max/Min =  4.2934979087E+05
 NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00002160)
    GET_NGFLD   - river runoff mass transport,               t =  1308 18:59:56
                   (Rec=0003, Index=1, File: nos.cbofs.river.20120802.t00z.nc)
    GET_2DFLD   - surface u-wind component,                  t =  1308 21:00:00
                   (Rec=0004, Index=2, File: nos.cbofs.met.nowcast.20120802.t00z.nc)
                   (Min = -3.25291882E+00 Max =  4.81658807E+00)
    GET_2DFLD   - surface v-wind component,                  t =  1308 21:00:00
                   (Min = -2.70355736E+00 Max =  4.91621582E+00)
    GET_2DFLD   - surface air pressure,                      t =  1308 21:00:00
                   (Min =  1.00774150E+03 Max =  1.01021740E+03)
    GET_2DFLD   - solar shortwave radiation flux,            t =  1308 21:00:00
                   (Min =  7.92467989E-06 Max =  1.24834423E-04)
    GET_2DFLD   - downwelling longwave radiation flux,       t =  1308 21:00:00
                   (Min =  9.25206855E-05 Max =  1.14888766E-04)
    GET_2DFLD   - surface air temperature,                   t =  1308 21:00:00
                   (Min =  2.41764803E+01 Max =  3.37390137E+01)
    GET_2DFLD   - surface air relative humidity,             t =  1308 21:00:00
                   (Min =  4.30000000E-01 Max =  8.68798388E-01)
    GET_NGFLD   - free-surface eastern boundary condition,   t =  1308 18:59:56
                   (Rec=0002, Index=1, File: nos.cbofs.obc.20120802.t00z.nc)
                   (Min = -6.70390874E-02 Max =  0.00000000E+00)
    GET_NGFLD   - free-surface southern boundary condition,  t =  1308 18:59:56
                   (Min =  0.00000000E+00 Max =  3.22146326E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =  1308 18:59:56
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =  1308 18:59:56
    GET_NGFLD   - temperature eastern boundary condition,    t =  1308 21:00:00
                   (Min =  0.00000000E+00 Max =  2.81041241E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t =  1308 21:00:00
                   (Min =  0.00000000E+00 Max =  2.57505417E+00)
    GET_NGFLD   - temperature southern boundary condition,   t =  1308 21:00:00
                   (Min =  0.00000000E+00 Max =  2.82472458E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =  1308 21:00:00
                   (Min =  0.00000000E+00 Max =  3.49828453E+01)
      0  1308 18:00:00  1.532607E-02  7.980870E+01  7.982403E+01  6.008443E+11
          (193,284,19)  6.884589E-02  1.026765E-03  0.000000E+00  1.888696E+00
      DEF_HIS   - creating history file: nos.cbofs.fields.nowcast.20120802.t00z.nc
    240  1308 18:40:00  1.850135E-02  8.047900E+01  8.049750E+01  6.030670E+11
          (225,207,03)  7.128165E-03  1.595518E-03  2.473909E-01  1.805154E+00
    GET_NGFLD   - river runoff mass transport,               t =  1308 20:00:03
                   (Rec=0004, Index=2, File: nos.cbofs.river.20120802.t00z.nc)
                   (Min = -2.48399988E-01 Max =  1.58533691E+02)
    GET_NGFLD   - free-surface eastern boundary condition,   t =  1308 20:00:03
                   (Rec=0003, Index=2, File: nos.cbofs.obc.20120802.t00z.nc)
                   (Min = -3.42374779E-02 Max =  0.00000000E+00)
    GET_NGFLD   - free-surface southern boundary condition,  t =  1308 20:00:03
                   (Min =  0.00000000E+00 Max =  3.66311520E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =  1308 20:00:03
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =  1308 20:00:03
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000002
      WRT_RST   - wrote re-start fields (Index=1,1) into time record = 0000001
    480  1308 19:20:00  1.991744E-02  8.116564E+01  8.118556E+01  6.056613E+11
          (225,207,03)  7.317850E-03  1.463469E-03  2.489511E-01  1.785739E+00
    720  1308 20:00:00  2.059823E-02  8.187251E+01  8.189311E+01  6.084253E+11
          (225,207,03)  7.238834E-03  1.306205E-03  2.518484E-01  1.648370E+00
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000003
      WRT_RST   - wrote re-start fields (Index=1,1) into time record = 0000002
    GET_NGFLD   - river runoff mass transport,               t =  1308 21:00:00
                   (Rec=0005, Index=1, File: nos.cbofs.river.20120802.t00z.nc)
    GET_NGFLD   - free-surface eastern boundary condition,   t =  1308 21:00:00
                   (Rec=0004, Index=1, File: nos.cbofs.obc.20120802.t00z.nc)
                   (Min =  0.00000000E+00 Max =  1.38042029E-02)
    GET_NGFLD   - free-surface southern boundary condition,  t =  1308 21:00:00
                   (Min =  0.00000000E+00 Max =  3.54353309E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =  1308 21:00:00
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =  1308 21:00:00
    960  1308 20:40:00  2.095143E-02  8.276275E+01  8.278370E+01  6.116504E+11
          (214,246,03)  1.216306E-02  3.318457E-04  2.745681E-01  1.724381E+00
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000004
    GET_NGFLD   - river runoff mass transport,               t =  1308 21:59:56
                   (Rec=0006, Index=2, File: nos.cbofs.river.20120802.t00z.nc)
                   (Min = -2.81519979E-01 Max =  1.58533691E+02)
    GET_2DFLD   - surface u-wind component,                  t =  1309 00:00:00
                   (Rec=0005, Index=1, File: nos.cbofs.met.nowcast.20120802.t00z.nc)
                   (Min = -2.07714868E+00 Max =  5.36907895E+00)
    GET_2DFLD   - surface v-wind component,                  t =  1309 00:00:00
                   (Min = -2.35278271E+00 Max =  5.68713153E+00)
    GET_2DFLD   - surface air pressure,                      t =  1309 00:00:00
                   (Min =  1.00929999E+03 Max =  1.01142043E+03)
    GET_2DFLD   - solar shortwave radiation flux,            t =  1309 00:00:00
                   (Min =  0.00000000E+00 Max =  8.67468250E-06)
    GET_2DFLD   - downwelling longwave radiation flux,       t =  1309 00:00:00
                   (Min =  9.25440829E-05 Max =  1.11534146E-04)
    GET_2DFLD   - surface air temperature,                   t =  1309 00:00:00
                   (Min =  2.24598452E+01 Max =  3.14160168E+01)
    GET_2DFLD   - surface air relative humidity,             t =  1309 00:00:00
                   (Min =  4.84200299E-01 Max =  9.19958376E-01)
    GET_NGFLD   - free-surface eastern boundary condition,   t =  1308 21:59:56
                   (Rec=0005, Index=2, File: nos.cbofs.obc.20120802.t00z.nc)
                   (Min =  0.00000000E+00 Max =  1.70076504E-01)
    GET_NGFLD   - free-surface southern boundary condition,  t =  1308 21:59:56
                   (Min =  0.00000000E+00 Max =  3.04128468E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =  1308 21:59:56
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =  1308 21:59:56
    GET_NGFLD   - temperature eastern boundary condition,    t =  1309 00:00:00
                   (Min =  0.00000000E+00 Max =  2.79794712E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t =  1309 00:00:00
                   (Min =  0.00000000E+00 Max =  2.58247566E+00)
    GET_NGFLD   - temperature southern boundary condition,   t =  1309 00:00:00
                   (Min =  0.00000000E+00 Max =  2.79698296E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =  1309 00:00:00
                   (Min =  0.00000000E+00 Max =  3.49907684E+01)
   1200  1308 21:20:00  2.061442E-02  8.347542E+01  8.349603E+01  6.145478E+11
          (214,246,03)  1.283886E-02  1.035408E-04  3.091656E-01  1.508388E+00
    GET_NGFLD   - river runoff mass transport,               t =  1308 23:00:03
                   (Rec=0007, Index=1, File: nos.cbofs.river.20120802.t00z.nc)
    GET_NGFLD   - free-surface eastern boundary condition,   t =  1308 23:00:03
                   (Rec=0006, Index=1, File: nos.cbofs.obc.20120802.t00z.nc)
                   (Min =  0.00000000E+00 Max =  4.12732095E-01)
    GET_NGFLD   - free-surface southern boundary condition,  t =  1308 23:00:03
                   (Min =  0.00000000E+00 Max =  2.41134226E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =  1308 23:00:03
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =  1308 23:00:03
   1440  1308 22:00:00  1.941662E-02  8.406465E+01  8.408406E+01  6.171368E+11
          (214,246,03)  1.460366E-02  4.180532E-04  3.767640E-01  1.582178E+00
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000005
   1680  1308 22:40:00  1.808256E-02  8.449723E+01  8.451531E+01  6.189489E+11
          (214,246,03)  1.440202E-02  1.116922E-03  3.721075E-01  1.550108E+00
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000006
    GET_NGFLD   - river runoff mass transport,               t =  1309 00:00:00
                   (Rec=0008, Index=2, File: nos.cbofs.river.20120802.t00z.nc)
    GET_NGFLD   - free-surface eastern boundary condition,   t =  1309 00:00:00
                   (Rec=0007, Index=2, File: nos.cbofs.obc.20120802.t00z.nc)
                   (Min =  0.00000000E+00 Max =  3.60008776E-01)
    GET_NGFLD   - free-surface southern boundary condition,  t =  1309 00:00:00
                   (Min =  0.00000000E+00 Max =  2.51255214E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =  1309 00:00:00
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =  1309 00:00:00
   1920  1308 23:20:00  1.745713E-02  8.453766E+01  8.455511E+01  6.194689E+11
          (214,246,03)  1.089607E-02  8.365183E-04  2.766033E-01  1.514540E+00
   2160  1309 00:00:00  1.771637E-02  8.446779E+01  8.448551E+01  6.195102E+11
          (210,120,03)  4.785873E-03  5.814729E-04  2.653967E-01  1.500824E+00
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000007
 Node   #  0 CPU:    1049.067
 Node   #  1 CPU:    1050.925
 Node   #  2 CPU:    1050.921
 Node   #  3 CPU:    1050.911
 Node   #  4 CPU:    1050.904
 Node   #  5 CPU:    1050.916
 Node   #  8 CPU:    1050.927
 Node   #  9 CPU:    1050.916
 Node   # 12 CPU:    1050.914
 Node   # 13 CPU:    1050.905
 Node   # 14 CPU:    1050.916
 Node   # 15 CPU:    1050.915
 Node   #  6 CPU:    1050.922
 Node   #  7 CPU:    1050.903
 Node   # 10 CPU:    1050.926
 Node   # 11 CPU:    1050.914
             number of time records written in HISTORY file = 00000007
             number of time records written in RESTART file = 00000002
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     ROMS/Functionals/ana_rain.h
     ROMS/Functionals/ana_stflux.h
 ROMS/TOMS: DONE... Tuesday - July 9, 2013 -  4:04:12 PM
