understanding of solar_source, diurnal_srflx,atm_press etc.
mashinde
#1 Unread post by mashinde »
I am confused with following keys in cppdefs.h and it's physical role in ROMS. Also the possible good combination of them.
solar_source, diurnal_srflx and atm_press. And what will be right choice of it for 6 hourly forcings.
currently, i am using for 6 hrly forcings.
#define BULK_FLUXES
#if defined BULK_FLUXES
#define LONGWAVE_OUT
#define EMINUSP
#define SOLAR_SOURCE
#undef DIURNAL_SRFLUX
can anybody tell about this and also what keys are good option.
thanks
carlosag
Re: understanding of solar_source, diurnal_srflx,atm_press etc.
#2 Unread post by carlosag »
Hi there Mashinde,
I am also confused about this. Did you manage to solve it? Can you please suggest me some place to read up?
Thank you
#3 Unread post by wilkin »
#define BULK_FLUXES uses the COARE3.0 algorithm of Fairall et al. (references are in the code bulk_flux.F) to compute air-sea heat and momentum flux (stress) on the basis of input marine atmospheric boundary layer conditions (air temp, wind etc.)
#define LONGWAVE_OUT computes the outgoing longwave radiation on the basis of ROMS SST. ROMS needs to read the downward longwave radiation from the atmosphere as an input (variable lwrad_down). If this is not defined then ROMS needs to reads net longwave radiation from variable lwrad.
#define EMINUSP computes evaporation from the latent heat flux and subtracts the user provided precipitation to get E-P. This is converted to an equivalent salt flux and imposed as a boundary conditions on vertical mixing of salinity.
#define SOLAR_SOURCE causes the net solar shortwave radiation (variable swrad) to penetrate into several vertical layers according to the water clarity specified with a Jerlov Water type (roms.in input variable WTYPE). If this is not defined, the solar radiation is all absorbed in the top most cell of the model.
#define DIURNAL_SRFLUX can be used if you don't have very well time resolved shortwave radiation. For example, 6-hourly instantaneous swrad very poorly resolves the diurnal cycle, but if those data are converted to daily averages, then DIURNAL_SRFLUX will read the daily value and distribute this over an idealized diurnal cycle (appropriate to latitude, longtide and day-of-year) so that peak heating occurs at the true solar noon, and there is no heating overnight. The user must pre-process the data to daily or longer time scale averages for this to work. DO NOT use this option with swrad given more frequently than once per day - that causes overestimation of the true heating.
