problems with using SeaGrid
kee
Location: Nanjing Uni. of Info. Sci. & Tech. (nanjing institute of meterology)
#1 Unread post by kee »
I downloaded Arango's Matlab packet, and tried to make my own grid file.
The MEX is also needed when using SeaGrid. As told by the instruction, I typed 'make_seagrid_mex' in matlab prompt, and errors came out like
>> make_seagrid_mex
Warning: You are using gcc version "4.4.6".  The earliest gcc version supported
         with mex is "4.1".  The latest version tested for use with mex is "4.2".
         To download a different version of gcc, visit http://gcc.gnu.org
wait for the figure to finish plotting, then hit any key to continue
-> options file specified on command line:
   FILE = ./mexrectopts.sh
->    MATLAB                = /gpfs/fs1/tools/matlab2009
->    CC                    =
->    CC flags:
         CFLAGS             =
         CDEBUGFLAGS        =
         COPTIMFLAGS        =
         CLIBS              =
         arguments          =  -DMX_COMPAT_32
->    CXX                   =
->    CXX flags:
         CXXFLAGS           =
         CXXDEBUGFLAGS      =
         CXXOPTIMFLAGS      =
         CXXLIBS            =
->    FC                    =
->    FC flags:
         FFLAGS             =
         FDEBUGFLAGS        =
         FOPTIMFLAGS        =
         FLIBS              =
->    LD                    =
->    Link flags:
         LDFLAGS            =
         LDDEBUGFLAGS       =
         LDOPTIMFLAGS       =
         LDEXTENSION        =
         arguments          =
->    LDCXX                 =
->    Link flags:
         LDCXXFLAGS         =
         LDCXXDEBUGFLAGS    =
         LDCXXOPTIMFLAGS    =
         LDCXXEXTENSION     =
         arguments          =
->  -c  -I/gpfs/fs1/tools/matlab2009/extern/include -I/gpfs/fs1/tools/matlab2009/simulink/include   -DMX_COMPAT_32   "mexrect.F"
/gpfs/fs1/tools/matlab2009/bin/mex: line 997: -c: command not found
    mex: compile of ' "mexrect.F"' failed.
??? Error using ==> mex at 221
Unable to complete successfully.
Error in ==> make_seagrid_mex at 8
mex -f ./mexrectopts.sh -v mexrect.F
Then I edit the mexrectopts.sh file by modifying the final part of it.
Namely, I set FC to gfortran since the machine I use doesnot have f77.
# Architecture independent lines:
#     Set and uncomment any lines which will apply to all architectures.
#           CC="$CC"
#           CFLAGS="$CFLAGS"
#           COPTIMFLAGS="$COPTIMFLAGS"
#           CDEBUGFLAGS="$CDEBUGFLAGS"
#           CLIBS="$CLIBS"
           FC="gfortran"
           FFLAGS="-g -fno-second-underscore $FFLAGS"
#           FOPTIMFLAGS="$FOPTIMFLAGS"
#           FDEBUGFLAGS="$FDEBUGFLAGS"
#           FLIBS="$FLIBS"
However, it was not right yet, and the errors now are
>> make_seagrid_mex
->    CC                    =
->    CC flags:
         CFLAGS             =
         CDEBUGFLAGS        =
         COPTIMFLAGS        =
         CLIBS              =
->    CXX                   =
->    CXX flags:
         CXXFLAGS           =
         CXXDEBUGFLAGS      =
         CXXOPTIMFLAGS      =
         CXXLIBS            =
->    FC                    = gfortran
->    FC flags:
         FFLAGS             = -g -fno-second-underscore -g -fno-second-underscore
         FDEBUGFLAGS        =
         FOPTIMFLAGS        =
         FLIBS              =
->    LD                    =
->    Link flags:
         LDFLAGS            =
         LDDEBUGFLAGS       =
         LDOPTIMFLAGS       =
         LDEXTENSION        =
         arguments          =
->    LDCXX                 =
->    Link flags:
         LDCXXFLAGS         =
         LDCXXDEBUGFLAGS    =
         LDCXXOPTIMFLAGS    =
         LDCXXEXTENSION     =
         arguments          =
-> gfortran -c  -I/gpfs/fs1/tools/matlab2009/extern/include -I/gpfs/fs1/tools/matlab2009/simulink/include -g -fno-second-underscore -g -fno-second-underscore   -DMX_COMPAT_32   "mexrect.F"
->    -o  "mexrect"  mexrect.o
/gpfs/fs1/tools/matlab2009/bin/mex: line 1056: -o: command not found
    mex: link of ' "mexrect"' failed.
My machine has gfortran/ifort/gcc/g++... except g77/g95 and the like.
Moreover it is a x86_64 but not 32.
can anyone give me some ideas?
zhao
kee
Re: problems with using SeaGrid
#2 Unread post by kee »
is there any suggestion?
