How to start my own case, such as to create input files?
Discussions, suggestions and corrections to ROMS/TOMS documentation currently under developement.
wzhu
#1 Unread post by wzhu »
Hello, everyone, How are you doing these days?
I have run the test case successfully, Now I am trying to start my own case, But I have no idea how to create input files? what software or toolkit should I use?
Any help will be highly appreciated!
Peter
Re: How to start my own case, such as to create input files?
This is coming up a lot so I just checked the FAQ: https://www.myroms.org/wiki/index.php/F ... or_ROMS.3F
wzhu
#3 Unread post by wzhu »
kate wrote:This is coming up a lot so I just checked the FAQ: https://www.myroms.org/wiki/index.php/F ... or_ROMS.3F
Thank you, kate.
Actually, I have downloaded the whole ROMS matlab repository, what's the next step? Do I need to use the python tool too? I am sorry I am a laymen.
No, you don't need both. If you like Matlab, go with it. As I said before:
I was intentionally vague because you need to build up some tools for manipulating netcdf files that you are comfortable with. I used to use some horrible fortran codes, I then switched to primarily NCL and NCO for these things. I am slowly learning to use Python. Others use Ferret. These are all just means to an end and the endpoint is clear from the CDL files.
wzhu
#5 Unread post by wzhu »
kate wrote:No, you don't need both. If you like Matlab, go with it. As I said before:
Hi kate,
I need help, please. I got the matlab scripts about creating input files. I am trying to create the boundary file, but I have no idea how to do it, how can i get the structure array, S?
I wonder if there are some templates to show how to create the input files using the matlab scripts step by step?
Any reply will be highly appreciated!
Wenwu
