Current model time exceeds ending value for variable: Pair
cflanary
#1 Unread post by cflanary »
While running my simulation, two days into my run I receive the following error message. I have it set to run 183 days.
SET_2DFLD - current model time exceeds ending value for variable: Pair
TDAYS = 2.0023
Data Tmin = 0.0000 Data Tmax = 183.7500
Data Tstr = 0.0000 Data Tend = 0.2500
TINTRP1 = 2.0000 TINTRP2 = 1.2500
FAC1 = -0.7523 FAC2 = 0.0023
I checked my forcing file pair_time and sms_time are the same length along with the variables Pair and my sustr and svstr. When I undefined ATM_PRESS, the model ran ~160 days and then blew up for another reason.
Any ideas as to why this is happening?
My second question, the ~160 day run I did with ATM_PRESS off had the results for my temp and salt as NaNs after the first time step, through all the layers.
I don't know where to start with this as an error. I've added my CPP options below.
Thank you,
/* Model Physics */
#define WET_DRY
#define UV_C4VADVECTION
#define TS_U3HADVECTION
#define TS_SVADVECTION
#define MIX_S_TS
#define MY25_MIXING
#define KANTHA_CLAYSON
#define N2S2_HORAVG
/* Pressure Gradient Algorithm */
#define ATM_PRESS
/* Grid and Initial Conditions */
#define PROFILING
/* Bottom Boundary Conditions */
#define SPHERICAL
#define UV_LDRAG
/* Forcing Conditions */
#define ANA_STFLUX
/* Climatology Options */
/* Options */
#define STATIONS
#define DIAGNOSTICS_TS
#define DIAGNOSTICS_UV
#ifdef PERFECT_RESTART
#undef AVERAGES
#undef DIAGNOSTICS_TS
#undef DIAGNOSTICS_UV
#define OUT_DOUBLE
