Sediment from river!
dhson
#1 Unread post by dhson »
I used to run ROMS with RIVER_SEDIMENT (of course with UV_PSOURSE and TS_PSOURCE). But in present version (revision 643), RIVER_SEDIMENT seems to be no longer valid. Consequently, I can run ROMS for S and T but not sediments (mud, sand) from rivers.
Any ideas, Thanks
Re: Sediment from river!
yes, as many other things this has been changed to accomodate individual source terms. You need to have the correct flags in your sediment.in file, such as
! Logical switches (TRUE/FALSE) to specify which variables to consider on
! tracers point Sources/Sinks (like river runoff). See glossary below for
! details.
MUD_Ltracer == T
and smae for sand.
dhson
#3 Unread post by dhson »
Thank,
I've got another problem that ROMS didn't read boundary sediment concentration if a number of classes > 2. For example, I've put 2 classes of non-cohensive mud in eastern and western boundaries both 0.1 mg/l. There are reasonable value for MUD_01 but nothing (zero) for MUD_02 in his, sta, rst files.
Sediment Parameters, Grid: 01
1 6.5000E-02 0.0000E+00 2.6500E+03 5.0000E-01 5.0000E-04 0.0000E+00
2 1.0000E-02 0.0000E+00 2.6500E+03 1.0000E-01 1.0000E-04 0.0000E+00
1 3.0000E+00 6.0000E-01 1.0000E-01 0.0000E+00 5.0000E-06 0.0000E+00
2 5.0000E-01 1.0000E-01 1.0000E-01 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+00
2 1.0000E+00
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idTvar) Write out sediment02: mud_02
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out bed fraction, sediment 02: mudfrac_02
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idfrac) Write out mass, sediment 02: mudmass_02
T Hout(idUbld) Write out U-bedload, sediment 01: bedload_Umud_01
T Hout(idVbld) Write out V-bedload, sediment 01: bedload_Vmud_01
T Hout(idUbld) Write out U-bedload, sediment 02: bedload_Umud_02
T Hout(idVbld) Write out V-bedload, sediment 02: bedload_Vmud_02
T Aout(idTvar) Write out averaged sediment01: mud_01
T Aout(idTvar) Write out averaged sediment02: mud_02
T Aout(idUbld) Write out U-bedload, sediment 01: bedload_Umud_01
T Aout(idVbld) Write out V-bedload, sediment 01: bedload_Vmud_01
T Aout(idUbld) Write out U-bedload, sediment 02: bedload_Umud_02
T Aout(idVbld) Write out V-bedload, sediment 02: bedload_Vmud_02
zeta 1 Chapman Chapman Chapman Chapman
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
u 1 Radiation Radiation Radiation Radiation
v 1 Radiation Radiation Radiation Radiation
temp 1 Gradient Gradient Gradient Gradient
mud_01 1 Clamped Gradient Clamped Gradient
mud_02 1 Clamped Gradient Clamped Gradient
tke 1 Gradient Gradient Gradient Gradient
GET_NGFLD - suspended cohesive sediment western boundart = 90 00:00:00class 01,
(Rec=0000001, Index=1, File: roms_bry.nc)
(Tmin= 90.0000 Tmax= 270.0000)
(Min = 1.00000000E-01 Max = 1.00000000E-01)
GET_NGFLD - suspended cohesive sediment eastern boundart = 90 00:00:00class 01,
Thanks for any suggestion
jande023
#4 Unread post by jande023 »
Would like to add suspended sediment from a river analytically using ana_psource.h. Have specified CSED value in input file and attempted to add ised value in ana_psource but neither appear to be introducing sediment. Salinity and temperature appear to be entering from the river as expected. Note MUD_Ltsrc is set to T in sediment input file.
FengZhou
#5 Unread post by FengZhou »
Hi, have you solved the problem?
Feng
jande023 wrote:Would like to add suspended sediment from a river analytically using ana_psource.h. Have specified CSED value in input file and attempted to add ised value in ana_psource but neither appear to be introducing sediment. Salinity and temperature appear to be entering from the river as expected. Note MUD_Ltsrc is set to T in sediment input file.
jande023
#6 Unread post by jande023 »
Unfortunately I have not. After reading a recent thread, I am running again with CSED specified as a very large value to see it there is any sediment being introduced.
#7 Unread post by jcwarner »
the csed is just the init value of sediment in the water column. to introduce sediment as a psource, you need to set that in ana_psource.
jande023
#8 Unread post by jande023 »
John,
Thank you for your prompt response as always. I had previously attempted to edit ana_psource as follows with no success. Would appreciate any additional guidance you could provide.
V/R
John
! Set tracers point Sources and/or Sinks.
TRACERS : IF (ANY(LtracerSrc(:,ng))) THEN
SOURCES(ng)%Tsrc=0.0_r8 ! initialize
! Set-up tracer (tracer units) point Sources/Sinks.
# elif defined YORK_ESTUARY
IF (DOMAIN(ng)%SouthWest_Test(tile)) THEN
DO k=1,N(ng)
DO is=1,Nsrc(ng)
SOURCES(ng)%Tsrc(is,k,itemp)=T0(ng)
SOURCES(ng)%Tsrc(is,k,isalt)=0.0_r8
! SOURCES(ng)%Tsrc(is,k,ised)=20.0_r8 JRA
jande023
#9 Unread post by jande023 »
John,
Note, the ised line was subsequently "commented out" but before doing so did not introduce any suspended sediment at the river boundary.
thanks again,
John
#10 Unread post by jcwarner »
well, i would need to see the whole routine. but a first look
"SOURCES(ng)%Tsrc(is,k,ised)=20.0_r8"
where is the value of ised set? looks like it needs a do ised=1,NST loop around it.
jande023
#11 Unread post by jande023 »
Thank you John,
I have attached the entire analytical script (ana_psource.h).
ised was defined as a local variable:
! Local variable declarations.
integer :: Npts, NSUB, is, i, j, k, ised
I intended a do loop for ised setting it =20 for all point sources along the western boundary (based on the direction set for sources) at all levels.
DO k=1,N(ng)
DO is=1,Nsrc(ng)
SOURCES(ng)%Tsrc(is,k,ised)=20.0_r8 ! JRA
Truly appreciate your assistance.
V/R
John
ana_psource.h
ana_psource.h
(17.46 KiB) Downloaded 660 times
#12 Unread post by jcwarner »
thanks for sending the whole thing.
But you did not understand my question, or in fact, i didn't ask my question in a good way.
I asked "where is the value of ised set"
I see ised is declared as an integer, but what value is set for the variable "ised". not the value of Tsrc, but ised itself.
You need to set
ised = _____
like a 1, 2, or 3 ....
Try this:
DO k=1,N(ng)
DO is=1,Nsrc(ng)
DO ised=1,NST(ng)
SOURCES(ng)%Tsrc(is,k,idsed(ised))=20.0_r8 ! JRA + JCW
jande023
#13 Unread post by jande023 »
Thanks John,
You probably asked the initial question in a manner that would have made sense to anyone but me. Please bare with an old man here. I added the ised DO loop and then got a I a build error:
analytical.f90(1024): error #6410: This name has not been declared as an array or a function. [NST]
DO ised=1,NST(ng)
So I attempted to declare as follows:
# ifdef SEDIMENT
USE mod_sediment
real(r8), intent(out) :: ised(LBi:UBi,LBj:UBj,Nbed,NST) ! JRA
Then it goes pretty far through the build process before getting really ugly:
analytical.f90(829): error #6278: This USE statement is not positioned correctly within the scoping unit.
USE mod_sources
analytical.f90(831): error #6278: This USE statement is not positioned correctly within the scoping unit.
USE distribute_mod, ONLY : mp_bcastf, mp_bcasti
analytical.f90(832): error #6278: This USE statement is not positioned correctly within the scoping unit.
USE distribute_mod, ONLY : mp_collect, mp_reduce
analytical.f90(828): error #6420: This array name is invalid in this context. [ISED]
analytical.f90(837): error #6415: This name cannot be assigned this data type because it conflicts with prior uses of the name. [UBI]
integer, intent(in) :: LBi, UBi, LBj, UBj
analytical.f90(837): error #6415: This name cannot be assigned this data type because it conflicts with prior uses of the name. [UBJ]
analytical.f90(939): error #6410: This name has not been declared as an array or a function. [NSRC]
Nsrc(ng)=5
analytical.f90(941): error #6458: This name must be the name of a variable with a derived type (structure type). [SOURCES]
SOURCES(ng)%Dsrc(is)=0.0_r8
analytical.f90(942): error #6458: This name must be the name of a variable with a derived type (structure type). [SOURCES]
SOURCES(ng)%Isrc(is)=1
analytical.f90(943): error #6458: This name must be the name of a variable with a derived type (structure type). [SOURCES]
SOURCES(ng)%Jsrc(is)=is+47
analytical.f90(950): error #6837: The leftmost part-ref in a data-ref can not be a function reference. [SOURCES]
CALL mp_bcasti (ng, iNLM, SOURCES(ng)%Isrc)
analytical.f90(950): error #6158: The structure-name is invalid or is missing. [SOURCES]
analytical.f90(951): error #6837: The leftmost part-ref in a data-ref can not be a function reference. [SOURCES]
CALL mp_bcasti (ng, iNLM, SOURCES(ng)%Jsrc)
analytical.f90(951): error #6158: The structure-name is invalid or is missing. [SOURCES]
analytical.f90(952): error #6837: The leftmost part-ref in a data-ref can not be a function reference. [SOURCES]
CALL mp_bcastf (ng, iNLM, SOURCES(ng)%Dsrc)
analytical.f90(952): error #6158: The structure-name is invalid or is missing. [SOURCES]
analytical.f90(964): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
SOURCES(ng)%Qshape=Pspv
analytical.f90(965): error #6404: This name does not have a type, and must have an explicit type. [MSRC]
Npts=Msrc(ng)*N(ng)
analytical.f90(970): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
SOURCES(ng)%Qshape(is,k)=1.0_r8/REAL(N(ng),r8)
analytical.f90(979): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
SOURCES(ng)%Qbar=Pspv
analytical.f90(987): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
SOURCES(ng)%Qbar(is)=fac*((71.0_r8)/5) !421, 71, 43.0_r8
analytical.f90(996): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
SOURCES(ng)%Qsrc(is,k)=SOURCES(ng)%Qbar(is)* &
analytical.f90(996): error #6837: The leftmost part-ref in a data-ref can not be a function reference. [SOURCES]
analytical.f90(996): error #6158: The structure-name is invalid or is missing. [SOURCES]
analytical.f90(997): error #6837: The leftmost part-ref in a data-ref can not be a function reference. [SOURCES]
& SOURCES(ng)%Qshape(is,k)
analytical.f90(997): error #6158: The structure-name is invalid or is missing. [SOURCES]
analytical.f90(1008): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
analytical.f90(1023): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
analytical.f90(1024): error #6515: This function, which is specified as the left side of an assignment statement, is invalid. [SOURCES]
analytical.f90(1025): error #6335: An array name is invalid in this context. [ISED]
DO ised=1,NST(ng)
analytical.f90(2061): catastrophic error: Too many errors, exiting
compilation aborted for analytical.f90 (code 1)
make: *** [Build/analytical.o] Error 1
[jande023@turing1 ~/2015ROMS]$
Again, built fine before the addition of the ised DO loop. Is the issue the placement of my declaration or the structure of the variable declaration itself? Or do I need to repeat all the USE statements within my ifdef SEDIMENT statement?
V/R
John
121,7 19%
#14 Unread post by kate »
You need two #ifdef SEDIMENT chunks, one for the USE up with all the other USE statements, one for the variable declaration down with the rest of them. Fortran has such weird syntax rules, but you do have to put all the USE stuff up before "implicit none".
jande023
#15 Unread post by jande023 »
Kate,
Thank you for your prompt reply. I wanted to give this an earnest try before responding, hence my delay. I attempted to add an additional #ifdef SEDIMENT, USE mod_sediment chunk upfront with the other USE statements. I also tried repeating earlier USE statements within the later #ifdef statement, where I attempted to clear the NST variable not defined error. However, I still get multiple errors and ultimately build failure as follows:
USE mod_sources
Nsrc(ng)=5
Npts=Msrc(ng)*N(ng)
DO ised=1,NST(ng)
Working with John Warner earlier, I added a do loop within the "Set Tracers point Sources and/or Sinks" area of ana_psource.h (where salinity and temperature are set), to this end. Thats when I started to encounter variable definition and other build errors. Backing up, I am slightly confused why I had to add the do loop in the first place when in the ocean.in file I specify: NCS == 1, LuvSrc == T, LtracerSrc == T and in the sediment.in file I specify: MUD_Ltsrc == T. Note, I am using the 2015 ROMS version prior to combining all sediment input into the sediment.in file. Shouldn't my input file switches introduce suspended sediment into the point source without having to modify ana_psource file?
Would like to understand the purpose of these switches if not to introduce sediment via a river and would value any recommendations to achieve a successful build and ultimately introduce suspended sediment via my river into my estuary model.
thank you,
John
ana_psource.h
(18.01 KiB) Downloaded 672 times
#16 Unread post by kate »
#ifdef SEDIMENT
      USE mod_sediment                                           ! JRA
      USE mod_sources
What did I say about making sure all the use statements happen before the other stuff? The ised line *has* to be after USE mod_sources.
jande023
#17 Unread post by jande023 »
Thank you Kate,
I missed the last USE in my multiple trials, or in other words I failed to follow directions. Cleaned up errors significantly. However, the original errors related to definition of the variable NST remain.
To resolve, I Have defined (or attempted to defined) NST (Number of Sediment Tracers) as an input variable (comes from ocean.in file) as follows:
Imported variable declarations.
integer, intent(in) :: NST ! JRA
integer, intent(in) :: ng, tile, model
integer, intent(in) :: IminS, ImaxS, JminS, JmaxS
integer, intent(in) :: nnew, knew
However, I am still getting fatal build errors:
analytical.f90(836): error #6401: The attributes of this name conflict with those made accessible by a USE statement. [NST]
analytical.f90(836): error #6445: A dummy argument is required in this context. [NST]
Assume the "conflict" is with the intent(in) because NST is clearly an integer. However, the value of NST comes from the ocean.in file NCS+NNS. Is this error related to the absence of a "dummy argument." Assume the dummy argument is needed to pass the value of NST to the psource subroutine?
Still interested to know the utility of the switches in the ocean and sediment input files if not to introduce sediment through the psource subroutine?
Thank you again.
V/R
John
#18 Unread post by kate »
There's an NST from mod_param.F. Since your routine has a "USE mod_param" you do not want to be passing in NST in the argument list. You weren't doing so in the last version you showed us. Is there some reason you decided to add it?
jande023
#19 Unread post by jande023 »
NST was in the original do loop that jcw recommended early on. In the version I attached earlier, I changed NST to NCS (# of cohesive sediments). Because I was getting the same errors with NST and NCS, I changed back to NST because I wasn't certain if it would cause problems in future runs.
jande023
#20 Unread post by jande023 »
Kate,
Figured out the build error.... ROMS didn't like the (ng) after NST in the do loop that was added in the psource analytical.... defined as an array.
Will pass the benefit of the run for the benefit of other followers.
thanks,
John
