Create a 3D mask as a new input file
thomas.roc
#1 Unread post by thomas.roc »
Hi ROMS community,
I would like to create something like a 3D mask which I could use as an input file in order to turn on and off my custom momentum and turbulence source terms.
What is the best approach to achieve such thing?
FYI, I have successfully implemented these custom source terms yet I use ugly if-loops to spatially define/apply them which implies recompiling each time I want to move them around and, potentially, slowing-down the computation.
Thanks in advance and happy new year to you all,
-T-
Re: Create a 3D mask as a new input file
can you just modify AKv or AKt in gls_corstep or whatever closure you are using?
thomas.roc
#3 Unread post by thomas.roc »
Unfortunately, it is a bit more complex than that. During my PhD, I have developed a methodology for representing hydrodynamic effects induced by individual tidal current turbine within ROMS (i.e. http://mhk.pnnl.gov/wiki/images/1/1b/Ro ... ._2013.pdf).
Now I am investigating the hydrodynamics induced by large arrays of those devices and therefore need something more efficient than if-loops to activate/localise my devices within my 3D domain.
I am thinking, developing an input file following the example of the station.in and/or float.in might sort me out. Do you guys think it is a sensible approach.
-T-
You could do it that way or you could make a 3-D NetCDF field to read in, which ever you think is better. I've added 2-D fields to the grid file, but you could make a new file to read from a new input routine. Whatever you think makes the most sense.
