Out-of-bounds error in mod_ncparam.F, variable idTTav
m.hadfield
When I run the UPWELLING case with ECOSIM defined and with bounds-checking enabled, I get the following error
0: Subscript out of range for array idttav (mod_ncparam.f90: 1938)
    subscript=3, lower bound=1, upper bound=2, dimension=1
The error arises in this section of code:
            SELECT CASE (Vinfo(1))
              CASE ('tracer2')
                varid=varid-1
                DO i=1,MT
                  varid=varid+1
                  idTTav(i)=varid
Array idTTav is described as "<t*t> for active tracers" and has been allocated with an upper bound of NAT
      allocate ( idTTav(NAT) )
The solution seems to be to allocate idTTav (and similar variables iHUTav, iHVTav, idUTav & idVTav) with an upper bound of MT.
Re: Out-of-bounds error in mod_ncparam.F, variable idTTav
Oops, I missed that one. It is amazing what compilers allow nowadays. I did ran the upwelling test case with biology inside of TotalView with ifort. The TotalView and ifort have a lot of problems due to multiple directives in the assemble code. I have been struggling with this for two years. Each one is blaming the other. I think that it is TotalView fault. I haven't being able to run TotalView and PGI on the iMac.
Thank you for reporting this bug :oops: The code is now corrected.
