I wanna be sure my model is non-linear.
MROCIO
#1 Unread post by MROCIO »
Hello ROMS users;
Well my doubt is, if my model is really non-linear because in the file .h I'm specifying
The model is compiling and running without problems, but my file log says the next (red are my doubts):
Friday - November 2, 2012 - 2:20:10 PM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler flags : -frepack-arrays -fopenmp -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 631M
Local Root : /home/rocio/ROMS_SOURCE
Header Dir : /home/rocio/my_model
Header file : panuco.h
Analytical Dir: /home/rocio/my_model
Resolution, Grid 01: 0209x0327x030, Parallel Threads: 16, Tiling: 008x008
262800 ntimes Number of timesteps for 3-D equations.
120.000 dt Timestep size (s) for 3-D equations.
200000000 nRST Number of timesteps between the writing of data
into restart fields.
90 ninfo Number of timesteps between print of information
to standard output.
90 nHIS Number of timesteps between the writing fields
into history file.
90 ndefHIS Number of timesteps between creation of new
history files.
1.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
1.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
20.000 Tcline S-coordinate surface/bottom layer width (m) used
5.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
5.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
5.0000E+00 Znudg Nudging/relaxation time scale (days)
5.0000E+00 M2nudg Nudging/relaxation time scale (days)
5.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
7.2000E+01 obcfac Factor between passive and active
T LtracerSrc(01) Processing point sources/Sink on tracer 01: temp
T LtracerSrc(02) Processing point sources/Sink on tracer 02: salt
Output Restart File: /home/rocio/my_model/Outrst/RST00.nc
Prefix for History Files: /home/rocio/my_model/Output/HIS00
Input Grid File: /home/rocio/my_model/DATA/DATA2004/TAMVERN30_grd.nc
Input Nonlinear Initial File: /home/rocio/my_model/DATA/DATA2004/TAMVERN30_ini.nc
Input Forcing File 01: /home/rocio/my_model/DATA/DATA2004/TAMVERN30_2004_panuS15_frc.nc
Input Boundary File: /home/rocio/my_model/DATA/DATA2004/TAMVERN30_TOPAZ2004_bry.nc
zeta 1 Closed Chapman Chapman Chapman
ubar 1 Closed Flather Flather Flather
vbar 1 Closed Flather Flather Flather
u 1 Closed Rad + Nud Rad + Nud Rad + Nud
v 1 Closed Rad + Nud Rad + Nud Rad + Nud
temp 1 Closed Rad + Nud Rad + Nud Rad + Nud
salt 1 Closed Rad + Nud Rad + Nud Rad + Nud
tke 1 Closed Gradient Gradient Gradient
/home/rocio/my_model Continental shelf of Tams-North of Ver with Panuco River
MASKING Land/Sea masking.
MIX_ISO_TS Mixing of tracers along isopycnal surfaces.
MIX_GEO_UV Mixing of momentum along geopotential surfaces.
NONLINEAR Nonlinear Model.
_OPENMP OpenMP parallel shared-memory directives.
SALINITY Using salinity.
TCLM_NUDGING Nudging toward tracer climatology.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_PSOURCE Mass point sources and sinks.
I don't understand why is using:
If these data are in my log file is because the model are using it, right???
Or do I have to turn off something else in my ocean.in file??
Thanks in abvance!!!
Rocio
Re: I wanna be sure my model is non-linear.
You are OK - it is using the nonlinear equation of state. You can tell that from the second of your blue lines. The first of the blue lines means you are using the forward model, as opposed to the tangent linear or adjoint or anything like that.
MROCIO
#3 Unread post by MROCIO »
Thanks Kate,
Then my model is non-linear and it is not using;
That's great!!!!
