HI
I've gotten a version of the code that runs on a Linux Opteron-based cluster, but can not get it to run on our solaris Opteron-based cluster.
Does anyone have success running ROMS 2.2 on Solaris with MPI. If so, which FFLAGS do you use?
We are using the Sun compiler, mpif90 (on our system under /opt/mpichtest/bin/mpif90).
It runs for about a timestep and then gives me a floating point error. When I play with the floating point flags, then it runs for a timestep and gives me NaNs.
thanks
Courtney Harris
Running version 2.2 on Solaris with MPI?
Courtney Harris
Professor
Virginia Institute of Marine Sciences
http://www.vims.edu/about/directory/fac ... ris_ck.php
Professor
