Blowing up problem
dhd_1979
Blowing up problem
#1 Unread post by dhd_1979 »
I have a succesful modelling of an area using a grid of 116x156x32, but when I changes the grid size of the same area to 0378x0358x032, It blows up just at the beginging, Could any one help me? the following is the output the model:
 Model Input Parameters:  ROMS/TOMS version 3.5
                          Thursday - August 23, 2012 -  8:05:16 AM
 South_Sea
 Operating system : Darwin
 CPU/hardware     : i386
 Compiler system  : ifort
 Compiler command : /usr/local/mpich-intel/bin//mpif90
 Compiler flags   : -heap-arrays -fp-model precise -ip -O3 -axP -free
 Input Script  : para.ini
 SVN Root URL  : https:://myroms.org/svn/src
 SVN Revision  : 564M
 Local Root    : /Users/hd/roms/myroms34/trunk
 Header Dir    : /Users/hd/roms/myroms34/southsea
 Header file   : southsea.h
 Analytical Dir: /Users/hd/roms/myroms34/southsea
 Resolution, Grid 01: 0378x0358x032,  Parallel Nodes:   2,  Tiling: 001x002
      72000  ntimes          Number of timesteps for 3-D equations.
     90.000  dt              Timestep size (s) for 3-D equations.
          9  ndtfast         Number of timesteps for 2-D equations between
          1  nrrec           Number of restart records to read from disk.
        240  nRST            Number of timesteps between the writing of data
                               into restart fields.
                               to standard output.
        600  nHIS            Number of timesteps between the writing fields
                               into history file.
 0.0000E+00  nl_tnu2(01)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 01: temp
 0.0000E+00  nl_tnu2(02)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 02: salt
 0.0000E+00  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 1.0000E-05  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 1.0000E-05  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 1.0000E-04  Akv_bak         Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak         Background vertical mixing coefficient (m2/s)
                               for turbulent energy.
 5.0000E-06  Akp_bak         Background vertical mixing coefficient (m2/s)
      3.000  gls_p           GLS stability exponent.
      1.500  gls_m           GLS turbulent kinetic energy exponent.
     -1.000  gls_n           GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin        GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin        GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0        GLS stability coefficient.
 1.4400E+00  gls_c1          GLS shear production coefficient.
 1.9200E+00  gls_c2          GLS dissipation coefficient.
-4.0000E-01  gls_c3m         GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p         GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk        GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp        GLS constant Schmidt number for PSI.
      0.000  charnok_alpha   Charnok factor for Zos calculation.
      0.000  zos_hsig_alpha  Factor for Zos calculation using Hsig(Awave).
      0.000  sz_alpha        Factor for Wave dissipation surface tke flux .
      0.000  crgban_cw       Factor for Craig/Banner surface tke flux.
 0.0000E+00  Zob             Bottom roughness (m).
 0.0000E+00  Zos             Surface roughness (m).
 1.0000E+01  blk_ZQ          Height (m) of surface air humidity measurement.
 1.0000E+01  blk_ZT          Height (m) of surface air temperature measurement.
 1.0000E+01  blk_ZW          Height (m) of surface winds measurement.
          1  lmd_Jwt         Jerlov water type.
          2  Vtransform      S-coordinate transformation equation.
          1  Vstretching     S-coordinate stretching function.
 5.0000E+00  theta_s         S-coordinate surface control parameter.
 4.0000E-01  theta_b         S-coordinate bottom  control parameter.
     10.000  Tcline          S-coordinate surface/bottom layer width (m) used
   1000.000  rho0            Mean density (kg/m3) for Boussinesq approximation.
       0.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
                               for 3D momentum.
      0.000  T0              Background potential temperature (C) constant.
      0.000  S0              Background salinity (PSU) constant.
          T  Hout(idDano)    Write out density anomaly.
          T  Hout(idVvis)    Write out vertical viscosity: AKv.
             Output Restart File:  ocean_rst2.nc
             Output History File:  ocean_his2.nc
                 Input Grid File:  southsea2012_grd.nc
    Input Nonlinear Initial File:  southsea2012_ini.nc
           Input Forcing File 01:  southsea2012_frc.nc
             Input Boundary File:  rnt/southsea2012_bry.nc
 Tile partition information for Grid 01:  0378x0358x0032  tiling: 001x002
        0        1      378        1      179  2165184
        1        1      378      180      358  2165184
   (interior points only)
        0     0.50   378.50     0.50   179.50  RHO-points
        1     0.50   378.50   179.50   358.50  RHO-points
        0     1.00   378.00     0.50   179.50    U-points
        1     1.00   378.00   179.50   358.50    U-points
        0     0.50   378.50     1.00   179.50    V-points
        1     0.50   378.50   179.50   358.00    V-points
               HaloSizeI(1) =     778
               HaloSizeJ(1) =     382
                TileSide(1) =     383
                TileSize(1) =   70855
 southSEA            South_Sea
 BULK_FLUXES         Surface bulk fluxes parametererization.
 DIURNAL_SRFLUX      Modulate shortwave radiation by the local diurnal cycle.
 EAST_FSCHAPMAN      Eastern edge, free-surface, Chapman condition.
 EAST_M2FLATHER      Eastern edge, 2D momentum, Flather condition.
 EAST_M3CLAMPED      Eastern edge, 3D momentum, Clamped condition.
 EAST_TCLAMPED       Eastern edge, tracers, Clamped condition.
 EMINUSP             Compute Salt Flux using E-P.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 LONGWAVE_OUT        Compute outgoing longwave radiation internally.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 NORTH_FSCHAPMAN     Northern edge, free-surface, Chapman condition.
 NORTH_M2FLATHER     Northern edge, 2D momentum, Flather condition.
 NORTH_M3CLAMPED     Northern edge, 3D momentum, Clamped condition.
 NORTH_TCLAMPED      Northern edge, tracers, Clamped condition.
 SOLAR_SOURCE        Solar Radiation Source Term.
 SOUTH_FSCHAPMAN     Southern edge, free-surface, Chapman condition.
 SOUTH_M2FLATHER     Southern edge, 2D momentum, Flather condition.
 SOUTH_M3CLAMPED     Southern edge, 3D momentum, Clamped condition.
 SOUTH_TCLAMPED      Southern edge, tracers, Clamped condition.
 SPHERICAL           Spherical grid configuration.
 SPONGE              Enhanced horizontal mixing in the sponge areas.
 Process Information:
 Node #  0 (pid=   22488) is active.
 Node #  1 (pid=   19760) is active.
 Vertical S-coordinate System:
    32   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    31  -0.0312500  -0.0022549       -0.168      -0.168      -6.350     -12.388
    30  -0.0625000  -0.0048948       -0.337      -0.337     -13.730     -26.839
    29  -0.0937500  -0.0080749       -0.509      -0.509     -22.557     -44.182
    28  -0.1250000  -0.0119914       -0.685      -0.685     -33.356     -65.469
    27  -0.1562500  -0.0168927       -0.866      -0.866     -46.793     -92.031
    26  -0.1875000  -0.0230908       -1.053      -1.053     -63.702    -125.538
    25  -0.2187500  -0.0309708       -1.249      -1.249     -85.114    -168.052
    24  -0.2500000  -0.0409944       -1.455      -1.455    -112.268    -222.047
    23  -0.2812500  -0.0536924       -1.675      -1.675    -146.582    -290.365
    22  -0.3125000  -0.0696342       -1.911      -1.911    -189.583    -376.055
    21  -0.3437500  -0.0893672       -2.166      -2.166    -242.736    -482.049
    20  -0.3750000  -0.1133185       -2.442      -2.442    -307.186    -610.636
    19  -0.4062500  -0.1416675       -2.740      -2.740    -383.411    -762.775
    18  -0.4375000  -0.1742175       -3.059      -3.059    -470.887    -937.413
    17  -0.4687500  -0.2103218       -3.395      -3.395    -567.880   -1131.086
    16  -0.5000000  -0.2489214       -3.745      -3.745    -671.555   -1338.123
    15  -0.5312500  -0.2887177       -4.100      -4.100    -778.435   -1551.570
    14  -0.5625000  -0.3284417       -4.455      -4.455    -885.121   -1764.630
    13  -0.5937500  -0.3671228       -4.804      -4.804    -989.014   -1972.103
    12  -0.6250000  -0.4042644       -5.146      -5.146   -1088.785   -2171.332
    11  -0.6562500  -0.4398848       -5.481      -5.481   -1184.482   -2362.414
    10  -0.6875000  -0.4744488       -5.810      -5.810   -1277.351   -2547.838
     9  -0.7187500  -0.5087464       -6.137      -6.137   -1369.506   -2731.836
     8  -0.7500000  -0.5437741       -6.469      -6.469   -1463.616   -2919.743
     7  -0.7812500  -0.5806477       -6.809      -6.809   -1562.669   -3117.537
     6  -0.8125000  -0.6205544       -7.165      -7.165   -1669.845   -3331.575
     5  -0.8437500  -0.6647399       -7.542      -7.542   -1788.478   -3568.528
     4  -0.8750000  -0.7145184       -7.948      -7.948   -1922.088   -3835.436
     3  -0.9062500  -0.7712996       -8.388      -8.388   -2074.451   -4139.847
     2  -0.9375000  -0.8366254       -8.871      -8.871   -2249.695   -4490.021
     1  -0.9687500  -0.9122123       -9.405      -9.405   -2452.416   -4895.149
     0  -1.0000000  -1.0000000      -10.000     -10.000   -2687.810   -5365.620
 Time Splitting Weights: ndtfast =   9    nfast =  13
  1 0.0020364543700987 0.1111111111111111 0.0020364543700987 0.1111111111111111
  2 0.0081423516807323 0.1108848384033223 0.0101788060508311 0.2219959495144335
  3 0.0182864997349408 0.1099801326610188 0.0284653057857719 0.3319760821754522
  4 0.0323475955445464 0.1079482993571365 0.0608129013303183 0.4399243815325887
  5 0.0500102513402867 0.1043541220744091 0.1108231526706050 0.5442785036069977
  6 0.0706194309860016 0.0987974274810439 0.1814425836566066 0.6430759310880416
  7 0.0929932967968730 0.0909508240381548 0.2744358804534797 0.7340267551261964
  8 0.1151944667617182 0.0806182355051689 0.3896303472151979 0.8146449906313653
  9 0.1342596821693365 0.0678188503094224 0.5238900293845344 0.8824638409407878
 10 0.1458878856389088 0.0529011078461628 0.6697779150234432 0.9353649487869506
 11 0.1440867095544515 0.0366913427751730 0.8138646245778947 0.9720562915621236
 12 0.1207773749033226 0.0206817083802339 0.9346419994812172 0.9927379999423575
 13 0.0653580005187826 0.0072620000576425 0.9999999999999998 1.0000000000000000
 ndtfast, nfast =    9  13   nfast/ndtfast =  1.44444
    1.000000000000 1.083631825329 0.541815912665 1.000000000000 1.000000000000
 Power filter parameters, Fgamma, gamma =  0.28400   0.00000
 Minimum X-grid spacing, DXmin =  2.38424540E+00 km
 Maximum X-grid spacing, DXmax =  8.53876089E+00 km
 Minimum Y-grid spacing, DYmin =  3.08795992E+00 km
 Maximum Y-grid spacing, DYmax =  9.94775766E+00 km
 Minimum Z-grid spacing, DZmin =  1.67524434E-01 m
 Maximum Z-grid spacing, DZmax =  4.70470903E+02 m
 Minimum barotropic Courant Number =  1.59192139E-02
 Maximum barotropic Courant Number =  4.27050946E-01
 Maximum Coriolis   Courant Number =  5.16361271E-03
                   (File: southsea2012_ini.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min =  1.00998491E+00 Max =  2.96956050E+01)
                - salinity
                   (Min =  2.94033954E+01 Max =  3.50299926E+01)
    GET_2DFLD   - surface u-wind component,                  t =   345 00:00:00
                   (Rec=0012, Index=1, File: southsea2012_frc.nc)
                   (Tmin=         15.0000 Tmax=        345.0000)
                   (Min = -9.51582279E+00 Max =  3.39370625E+00)
    GET_2DFLD   - surface v-wind component,                  t =   345 00:00:00
                   (Min = -9.12874444E+00 Max = -1.51403108E-01)
    GET_2DFLD   - surface air pressure,                      t =   345 00:00:00
                   (Min =  1.00918056E+03 Max =  1.01960408E+03)
    GET_2DFLD   - solar shortwave radiation flux,            t =   345 00:00:00
                   (Min =  2.64019335E-05 Max =  4.98503556E-05)
    GET_2DFLD   - downwelling longwave radiation flux,       t =   345 00:00:00
                   (Min =  8.13027358E-05 Max =  1.04959257E-04)
    GET_2DFLD   - surface air temperature,                   t =   345 00:00:00
                   (Min =  1.81269569E+01 Max =  2.82614824E+01)
    GET_2DFLD   - surface air relative humidity,             t =   345 00:00:00
                   (Min =  7.37835999E-01 Max =  8.49440016E-01)
    GET_2DFLD   - rain fall rate,                            t =   345 00:00:00
                   (Min = -1.65831263E-06 Max =  1.19896346E-04)
    GET_NGFLD   - free-surface eastern boundary condition,   t =   345 00:00:00
                   (Rec=0012, Index=2, File: southsea2012_bry.nc)
                   (Min = -1.04938970E-01 Max =  5.39443795E-02)
    GET_NGFLD   - free-surface southern boundary condition,  t =   345 00:00:00
                   (Min =  0.00000000E+00 Max =  3.45140437E-01)
    GET_NGFLD   - free-surface northern boundary condition,  t =   345 00:00:00
                   (Min = -8.46820972E-02 Max =  2.37409635E-02)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -1.05745179E-01 Max =  1.12963062E-01)
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -1.64431079E-01 Max =  1.32986371E-01)
    GET_NGFLD   - 2D u-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -4.25512775E-02 Max =  1.02525889E-02)
    GET_NGFLD   - 2D v-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -6.61152090E-02 Max =  5.38647064E-02)
    GET_NGFLD   - 2D u-momentum northern boundary condition, t =   345 00:00:00
                   (Min =  0.00000000E+00 Max =  1.20633476E-02)
    GET_NGFLD   - 2D v-momentum northern boundary condition, t =   345 00:00:00
                   (Min = -1.54876184E-03 Max =  1.80039973E-02)
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -2.36025823E-01 Max =  1.93699978E-01)
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t =   345 00:00:00
                   (Min = -2.84188818E-01 Max =  4.79846932E-01)
    GET_NGFLD   - 3D u-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -7.41717477E-02 Max =  2.05983589E-02)
    GET_NGFLD   - 3D v-momentum southern boundary condition, t =   345 00:00:00
                   (Min = -1.40678430E-01 Max =  1.19201540E-01)
    GET_NGFLD   - 3D u-momentum northern boundary condition, t =   345 00:00:00
                   (Min = -2.04374539E-03 Max =  3.01733123E-02)
    GET_NGFLD   - 3D v-momentum northern boundary condition, t =   345 00:00:00
                   (Min = -5.39660018E-03 Max =  4.06704033E-02)
    GET_NGFLD   - temperature eastern boundary condition,    t =   345 00:00:00
                   (Min =  2.26234973E+00 Max =  2.92821597E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t =   345 00:00:00
                   (Min =  3.31653714E+01 Max =  3.47828366E+01)
    GET_NGFLD   - temperature southern boundary condition,   t =   345 00:00:00
                   (Min =  3.58342220E+00 Max =  2.93760120E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =   345 00:00:00
                   (Min =  3.03248198E+01 Max =  3.48744274E+01)
    GET_NGFLD   - temperature northern boundary condition,   t =   345 00:00:00
                   (Min =  2.08878426E+01 Max =  2.42159190E+01)
    GET_NGFLD   - salinity northern boundary condition,      t =   345 00:00:00
                   (Min =  2.68756965E+01 Max =  3.47764573E+01)
 Maximum grid stiffness ratios:  rx0 =   3.069334E-01 (Beckmann and Haidvogel)
                                 rx1 =   9.416266E+00 (Haney)
 Initial basin volumes: TotVolume =  4.1073132888E+15 m3
                        MinVolume =  6.4173169552E+06 m3
                        MaxVolume =  2.5091605958E+10 m3
                          Max/Min =  3.9099838972E+03
 NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00072000)
    GET_2DFLD   - surface u-wind component,                  t =    15 00:00:00
                   (Rec=0001, Index=2, File: southsea2012_frc.nc)
                   (Min = -8.47976738E+00 Max =  5.14942244E+00)
    GET_2DFLD   - surface v-wind component,                  t =    15 00:00:00
                   (Min = -8.60785679E+00 Max =  1.70728176E-01)
    GET_2DFLD   - surface air pressure,                      t =    15 00:00:00
                   (Min =  1.00913328E+03 Max =  1.01991374E+03)
    GET_2DFLD   - solar shortwave radiation flux,            t =    15 00:00:00
                   (Min =  2.74973133E-05 Max =  5.20150240E-05)
    GET_2DFLD   - downwelling longwave radiation flux,       t =    15 00:00:00
                   (Min =  8.29663275E-05 Max =  1.03522925E-04)
    GET_2DFLD   - surface air temperature,                   t =    15 00:00:00
                   (Min =  1.60999184E+01 Max =  2.80809454E+01)
    GET_2DFLD   - surface air relative humidity,             t =    15 00:00:00
                   (Min =  7.40901947E-01 Max =  8.58145370E-01)
    GET_2DFLD   - rain fall rate,                            t =    15 00:00:00
                   (Min = -9.55106197E-06 Max =  1.38071025E-04)
    GET_NGFLD   - free-surface eastern boundary condition,   t =    15 00:00:00
                   (Rec=0001, Index=1, File: southsea2012_bry.nc)
                   (Min = -1.96120652E-01 Max =  5.08092590E-02)
    GET_NGFLD   - free-surface southern boundary condition,  t =    15 00:00:00
                   (Min =  0.00000000E+00 Max =  4.25729693E-01)
    GET_NGFLD   - free-surface northern boundary condition,  t =    15 00:00:00
                   (Min = -9.79222626E-02 Max =  3.13438820E-02)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -1.77855057E-01 Max =  2.26948792E-01)
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -4.29227736E-01 Max =  1.60314516E-01)
    GET_NGFLD   - 2D u-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -3.89490618E-02 Max =  1.88929858E-02)
    GET_NGFLD   - 2D v-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -8.35157011E-02 Max =  8.53220221E-02)
    GET_NGFLD   - 2D u-momentum northern boundary condition, t =    15 00:00:00
                   (Min =  0.00000000E+00 Max =  2.13904517E-02)
    GET_NGFLD   - 2D v-momentum northern boundary condition, t =    15 00:00:00
                   (Min = -1.48704332E-03 Max =  2.96492477E-02)
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -3.16814478E-01 Max =  4.92955030E-01)
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t =    15 00:00:00
                   (Min = -7.32225337E-01 Max =  5.33770588E-01)
    GET_NGFLD   - 3D u-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -7.74111031E-02 Max =  2.98046285E-02)
    GET_NGFLD   - 3D v-momentum southern boundary condition, t =    15 00:00:00
                   (Min = -1.78695627E-01 Max =  1.84854131E-01)
    GET_NGFLD   - 3D u-momentum northern boundary condition, t =    15 00:00:00
                   (Min = -2.21232575E-03 Max =  5.21252952E-02)
    GET_NGFLD   - 3D v-momentum northern boundary condition, t =    15 00:00:00
                   (Min = -9.54543610E-03 Max =  6.74086822E-02)
    GET_NGFLD   - temperature eastern boundary condition,    t =    15 00:00:00
                   (Min =  2.26078187E+00 Max =  2.93209212E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t =    15 00:00:00
                   (Min =  3.33929114E+01 Max =  3.48432600E+01)
    GET_NGFLD   - temperature southern boundary condition,   t =    15 00:00:00
                   (Min =  3.59805859E+00 Max =  2.93209212E+01)
    GET_NGFLD   - salinity southern boundary condition,      t =    15 00:00:00
                   (Min =  3.10507369E+01 Max =  3.47537850E+01)
    GET_NGFLD   - temperature northern boundary condition,   t =    15 00:00:00
                   (Min =  1.78687857E+01 Max =  2.32269094E+01)
    GET_NGFLD   - salinity northern boundary condition,      t =    15 00:00:00
                   (Min =  3.19560246E+01 Max =  3.45651214E+01)
 volume =   4.924104978081719E+015 avgpe =   6.267835317610791E+019
      0     0 00:00:00  6.711673E-07  1.272888E+04  1.272888E+04  4.924105E+15
          (378,303,06)  2.006515E-03  0.000000E+00  0.000000E+00  2.028955E-01
      DEF_HIS   - creating history file: ocean_his2.nc
 volume =   4.924105294627492E+015 avgpe =  NaN
      1     0 00:01:30  1.245361E-06           NaN           NaN  4.924105E+15
          (378,322,11)  9.248940E-04  2.067024E-04  1.258541E-02  2.703812E-01
      WRT_RST   - wrote re-start fields (Index=2,2) into time record = 0000001
 Node   #  0 CPU:      20.938
 Node   #  1 CPU:      17.828
 Total:                38.766
  Allocation and array initialization ..............         1.672  ( 4.3128 %)
  Ocean state initialization .......................         0.391  ( 1.0077 %)
  Reading of input data ............................         0.281  ( 0.7255 %)
  Processing of input data .........................         0.062  ( 0.1612 %)
  Computation of global information integrals ......         9.484  (24.4659 %)
  Writing of output data ...........................         3.266  ( 8.4240 %)
  Model 2D kernel ..................................         2.531  ( 6.5296 %)
  2D/3D coupling, vertical metrics .................         0.734  ( 1.8944 %)
  Omega vertical velocity ..........................         0.219  ( 0.5643 %)
  Equation of state for seawater ...................         1.547  ( 3.9903 %)
  Atmosphere-Ocean bulk flux parameterization ......         0.375  ( 0.9674 %)
  GLS vertical mixing parameterization .............         5.188  (13.3817 %)
  3D equations right-side terms ....................         1.250  ( 3.2245 %)
  3D equations predictor step ......................         1.375  ( 3.5470 %)
  Pressure gradient ................................         0.734  ( 1.8944 %)
  Harmonic mixing of tracers, geopotentials ........         1.641  ( 4.2322 %)
  Harmonic stress tensor, S-surfaces ...............         0.672  ( 1.7332 %)
  Corrector time-step for 3D momentum ..............         0.766  ( 1.9750 %)
  Corrector time-step for tracers ..................         1.031  ( 2.6602 %)
                                              Total:        33.219   85.6913
  Message Passage: 2D halo exchanges ...............         0.047  ( 0.1209 %)
  Message Passage: 3D halo exchanges ...............         0.047  ( 0.1209 %)
  Message Passage: 4D halo exchanges ...............         0.016  ( 0.0403 %)
  Message Passage: data broadcast ..................         0.188  ( 0.4837 %)
  Message Passage: data reduction ..................         0.016  ( 0.0403 %)
  Message Passage: data gathering ..................         2.750  ( 7.0939 %)
  Message Passage: data scattering..................         1.094  ( 2.8214 %)
                                              Total:         4.156   10.7215
 All percentages are with respect to total time =           38.766
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     ROMS/Functionals/ana_hmixcoef.h
     ROMS/Functionals/ana_srflux.h
 ROMS/TOMS: DONE... Thursday - August 23, 2012 -  8:06:29 AM
Re: Blowing up problem
Did you change the timestep when you changed the resolution? How about the bathymetry steepness factors - did they change? You can also adjust the horizontal viscosity and diffusion coefficients.
dhd_1979
#3 Unread post by dhd_1979 »
Thanks Kate!
I have change the time step from 720s to 90s, and the Maximum grid stiffness ratios: rx0 = 3.069334E-01 (Beckmann and Haidvogel) rx1 = 9.416266E+00 (Haney).
The SST and speed at the beginging is
屏幕快照 2012-08-24 下午10.58.48.png (26.52 KiB) Viewed 9796 times
at time record 2 (the total time = 2*90s)is:
屏幕快照 2012-08-24 下午10.55.17.png (29.58 KiB) Viewed 9796 times
at time record 3 (the total time = 4*90s)is:
屏幕快照 2012-08-24 下午10.59.02.png (11.2 KiB) Viewed 9796 times
It seems that the NaN propagates from the east to west, so I have test the east boundary for both close and open conditions, but the result not changed.
I also change the depth of the bathymetry to a constant 800m, the result still not changed much.
You also have trouble moving west to east. The trouble is moving as a barotropic wave, in the depth-integrated equations. At least it is happening early, which makes it easier to investigate. I don't know what it is - perhaps you can let us know when you fix it.
LiuZHQ
#5 Unread post by LiuZHQ »
Did you smooth your bathymetry?
dhd_1979
#6 Unread post by dhd_1979 »
LiuZHQ wrote:Did you smooth your bathymetry?
Thanks LiuZHQ!
I smoothed the bathymetry with rfac=0.35(maximum slope of topography allowed in smoothing), and I have a test with the bathymetry to be a constant 800m, it is no useful.
I changed the initial state from levitas climate data to hycom exp08, but still no useful.
