Model indicates infinite grid size, but pm, pn are non-zero
wjschulz
#1 Unread post by wjschulz »
Using a grid file created from scratch in matlab, am attempting to run a straight channel with an embayment along the northern shore, and only the east boundary open (forced by M2 tide.) The model blows up prior to run, indicating that "DXMax (and DYmax, and max volume) = Infinity, with Courant numbers = 0. I've checked that pm, pn are non-zero. (These are written into 'grid.nc' during execution of the create_grids.m, which calls c_grid, uvp_masks.m and write_mask.m from the repository.) I cannot find where to ensure max grid size is computed by or inputted to the model. Appreciate any help!
Model Input Parameters: ROMS/TOMS version 3.5
Sunday - June 10, 2012 - 2:32:11 PM
POTOMAC
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/local/openmpi/openmpi-1.4.3/x86_64/ib/intel2011/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script : ./External/ocean.in
SVN Revision : 564M
Local Root : /usr/local/roms
Header Dir : /home/schulz/Projects/MRIVER
Header file : potomac.h
Analytical Dir: /home/schulz/Projects/MRIVER/Functionals
Resolution, Grid 01: 0498x0198x005, Parallel Nodes: 8, Tiling: 002x004
401 ntimes Number of timesteps for 3-D equations.
20.000 dt Timestep size (s) for 3-D equations.
45 ndtfast Number of timesteps for 2-D equations between
3600 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
10 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
for turbulent energy.
2.6500E-04 rdrg Linear bottom drag coefficient (m/s).
1.000 Tcline S-coordinate surface/bottom layer width (m) used
5.0000E-01 Tnudg(01) Nudging/relaxation time scale (days)
for 3D momentum.
3.0000E+01 obcfac Factor between passive and active
5.000 T0 Background potential temperature (C) constant.
Input Grid File: Forcing/grid.nc
Input Nonlinear Initial File: Initial/init.nc
Input Forcing File 01: Forcing/frc_surface.nc
Input Forcing File 02: Forcing/frc_tides.nc
Input Boundary File: Boundary/boundary.nc
Tile partition information for Grid 01: 0498x0198x0005 tiling: 002x004
tile Istr Iend Jstr Jend Npts
0 1 249 1 49 61005
1 250 498 1 49 61005
2 1 249 50 99 62250
3 250 498 50 99 62250
4 1 249 100 149 62250
5 250 498 100 149 62250
6 1 249 150 198 61005
7 250 498 150 198 61005
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 249.50 0.50 49.50 RHO-points
1 249.50 498.50 0.50 49.50 RHO-points
2 0.50 249.50 49.50 99.50 RHO-points
3 249.50 498.50 49.50 99.50 RHO-points
4 0.50 249.50 99.50 149.50 RHO-points
5 249.50 498.50 99.50 149.50 RHO-points
6 0.50 249.50 149.50 198.50 RHO-points
7 249.50 498.50 149.50 198.50 RHO-points
0 1.00 249.50 0.50 49.50 U-points
1 249.50 498.00 0.50 49.50 U-points
2 1.00 249.50 49.50 99.50 U-points
3 249.50 498.00 49.50 99.50 U-points
4 1.00 249.50 99.50 149.50 U-points
5 249.50 498.00 99.50 149.50 U-points
6 1.00 249.50 149.50 198.50 U-points
7 249.50 498.00 149.50 198.50 U-points
0 0.50 249.50 1.00 49.50 V-points
1 249.50 498.50 1.00 49.50 V-points
2 0.50 249.50 49.50 99.50 V-points
3 249.50 498.50 49.50 99.50 V-points
4 0.50 249.50 99.50 149.50 V-points
5 249.50 498.50 99.50 149.50 V-points
6 0.50 249.50 149.50 198.00 V-points
7 249.50 498.50 149.50 198.00 V-points
HaloSizeI(1) = 522
HaloSizeJ(1) = 124
TileSide(1) = 255
TileSize(1) = 14280
POTOMAC POTOMAC
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
EAST_FSCHAPMAN Eastern edge, free-surface, Chapman condition.
EAST_M2FLATHER Eastern edge, 2D momentum, Flather condition.
EAST_M3RADIATION Eastern edge, 3D momentum, radiation condition.
EAST_TRADIATION Eastern edge, tracers, radiation condition.
INLINE_2DIO Processing 3D IO level by level to reduce memory needs.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
RAMP_TIDES Ramping tidal forcing for one day.
SOUTHERN_WALL Wall boundary at Southern edge.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WESTERN_WALL Wall boundary at Western edge.
Process Information:
Node # 0 (pid= 27652) is active.
Node # 7 (pid= 27659) is active.
Node # 4 (pid= 27656) is active.
Node # 2 (pid= 27654) is active.
Node # 5 (pid= 27657) is active.
Node # 6 (pid= 27658) is active.
Node # 3 (pid= 27655) is active.
Node # 1 (pid= 27653) is active.
Vertical S-coordinate System:
5 0.0000000 0.0000000 0.000 0.000 0.000 0.000
4 -0.2000000 -0.0260168 -0.100 -0.100 -0.438 -0.776
3 -0.4000000 -0.1356491 -0.200 -0.200 -1.964 -3.727
2 -0.6000000 -0.3746809 -0.300 -0.300 -5.171 -10.042
1 -0.8000000 -0.6041494 -0.400 -0.400 -8.254 -16.109
0 -1.0000000 -1.0000000 -0.500 -0.500 -13.501 -26.502
Time Splitting Weights: ndtfast = 45 nfast = 63
1-0.0005234147293094 0.0222222222222222-0.0005234147293094 0.0222222222222222
2-0.0009714664692682 0.0222338536606513-0.0014948811985777 0.0444560758828736
3-0.0013441562052106 0.0222554418044128-0.0028390374037882 0.0667115176872864
4-0.0016414877689917 0.0222853119423064-0.0044805251727799 0.0889968296295928
5-0.0018634711234351 0.0223217894482840-0.0063439962962150 0.1113186190778769
6-0.0020101269605588 0.0223631999176937-0.0083541232567738 0.1336818189955705
7-0.0020814926135807 0.0224078694057061-0.0104356158703545 0.1560896884012766
8-0.0020776292827024 0.0224541247971190-0.0125132451530569 0.1785438131983956
9-0.0019986305746722 0.0225002943367346-0.0145118757277291 0.2010441075351302
10-0.0018446323561274 0.0225447083495051-0.0163565080838566 0.2235888158846354
11-0.0016158239207149 0.0225857001796413-0.0179723320045715 0.2461745160642766
12-0.0013124604699909 0.0226216073778794-0.0192847924745624 0.2687961234421560
13-0.0009348769080999 0.0226507731661014-0.0202196693826623 0.2914468966082574
14-0.0004835029502319 0.0226715482085036-0.0207031723328942 0.3141184448167610
15 0.0000411204551404 0.0226822927185088-0.0206620518777537 0.3368007375352697
16 0.0006383233902467 0.0226813789306168-0.0200237284875071 0.3594821164658865
17 0.0013072879182242 0.0226671939663891-0.0187164405692829 0.3821493104322756
18 0.0020470277195447 0.0226381431237619-0.0166694128497381 0.4047874535560374
19 0.0028563664146621 0.0225926536188831-0.0138130464350760 0.4273801071749205
20 0.0037339145728811 0.0225291788096684-0.0100791318621949 0.4499092859845888
21 0.0046780454074473 0.0224462029302710-0.0054010864547475 0.4723554889148598
22 0.0056868691568581 0.0223422463656611 0.0002857827021106 0.4946977352805209
23 0.0067582061523945 0.0222158714955087 0.0070439888545051 0.5169136067760296
24 0.0078895585718746 0.0220656891365666 0.0149335474263797 0.5389792959125962
25 0.0090780808796274 0.0218903656127471 0.0240116283060071 0.5608696615253433
26 0.0103205489526884 0.0216886304820887 0.0343321772586955 0.5825582920074320
27 0.0116133278932156 0.0214592849498068 0.0459455051519111 0.6040175769572388
28 0.0129523385271270 0.0212012109966242 0.0588978436790381 0.6252187879538630
29 0.0143330225889594 0.0209133812515769 0.0732308662679975 0.6461321692054399
30 0.0157503065929473 0.0205948696384890 0.0889811728609449 0.6667270388439289
31 0.0171985643903243 0.0202448628253123 0.1061797372512691 0.6869719016692413
32 0.0186715784128440 0.0198626725055274 0.1248513156641131 0.7068345741747686
33 0.0201624996025234 0.0194477485407975 0.1450138152666365 0.7262823227155660
34 0.0216638060276065 0.0189996929940748 0.1666776212942430 0.7452820157096408
35 0.0231672601847493 0.0185182750823502 0.1898448814789924 0.7638002907919910
36 0.0246638649874256 0.0180034470782446 0.2145087464664180 0.7818037378702356
37 0.0261438184405543 0.0174553611896352 0.2406525649069723 0.7992590990598708
38 0.0275964670013474 0.0168743874465117 0.2682490319083198 0.8161334865063825
39 0.0290102576263795 0.0162611326242596 0.2972592895346993 0.8323946191306421
40 0.0303726885048774 0.0156164602325623 0.3276319780395767 0.8480110793632043
41 0.0316702584782326 0.0149415115991205 0.3593022365178093 0.8629525909623248
42 0.0328884151457325 0.0142377280773820 0.3921906516635418 0.8771903190397068
43 0.0340115016565149 0.0135068744074769 0.4262021533200568 0.8906971934471837
44 0.0350227021877421 0.0127510632595543 0.4612248555077989 0.9034482567067380
45 0.0359039861089966 0.0119727809887156 0.4971288416167955 0.9154210376954536
46 0.0366360508328980 0.0111749146307379 0.5337648924496935 0.9265959523261915
47 0.0371982633519407 0.0103607801677846 0.5709631558016341 0.9369567324939762
48 0.0375686004615529 0.0095341520932970 0.6085317562631870 0.9464908845872732
49 0.0377235876693763 0.0086992943052625 0.6462553439325633 0.9551901788925357
50 0.0376382367907677 0.0078609923570542 0.6838935807233311 0.9630511712495898
51 0.0372859822305206 0.0070245870950371 0.7211795629538517 0.9700757583446269
52 0.0366386159508082 0.0061960097121366 0.7578181789046599 0.9762717680567635
53 0.0356662211253486 0.0053818182465631 0.7934844000300084 0.9816535863033267
54 0.0343371044797891 0.0045892355548887 0.8278215045097975 0.9862428218582153
55 0.0326177273183132 0.0038261887886712 0.8604392318281108 0.9900690106468865
56 0.0304726352364682 0.0031013504038198 0.8909118670645790 0.9931703610507062
57 0.0278643865202132 0.0024241807318983 0.9187762535847923 0.9955945417826044
58 0.0247534792311892 0.0018049721425602 0.9435297328159815 0.9973995139251646
59 0.0210982769782096 0.0012548948263115 0.9646280097941911 0.9986544087514762
60 0.0168549333749721 0.0007860442267958 0.9814829431691632 0.9994404529782719
61 0.0119773151839916 0.0004114901517964 0.9934602583531548 0.9998519431300683
62 0.0064169241467539 0.0001453275921521 0.9998771824999086 0.9999972707222204
63 0.0001228175000916 0.0000027292777798 1.0000000000000002 1.0000000000000002
ndtfast, nfast = 45 63 nfast/ndtfast = 1.40000
1.000000000000 1.036028576182 0.518014288091 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.22089
Minimum X-grid spacing, DXmin = 1.00000000E-01 km
Maximum X-grid spacing, DXmax = Infinity km
Minimum Y-grid spacing, DYmin = 1.00000000E-01 km
Maximum Y-grid spacing, DYmax = Infinity km
Minimum Z-grid spacing, DZmin = 1.00000000E-01 m
Maximum Z-grid spacing, DZmax = 1.03927543E+01 m
Minimum barotropic Courant Number = 0.00000000E+00
Maximum barotropic Courant Number = 0.00000000E+00
Maximum Coriolis Courant Number = 0.00000000E+00
NLM: GET_STATE - Read state initial conditions, t = 30 00:00:00
(File: init.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 1.00000000E+01 Max = 1.00000000E+01)
GET_NGFLD - tidal period
(Min = 4.47141600E+04 Max = 4.47141600E+04)
(Min = 1.00000000E+00 Max = 1.00000000E+00)
(Min = 7.85398163E-01 Max = 7.85398163E-01)
(Min = 2.35619449E+00 Max = 2.35619449E+00)
(Min = 5.00000000E-01 Max = 5.00000000E-01)
GET_2DFLD - surface u-momentum stress, t = 30 00:00:00
(Rec=0002, Index=1, File: frc_surface.nc)
(Tmin= 0.0000 Tmax= 330.0000)
(Min = 4.87804878E-04 Max = 4.87804878E-04)
GET_2DFLD - surface v-momentum stress, t = 30 00:00:00
GET_NGFLD - free-surface eastern boundary condition, t = ***** **:**:**
(Rec=0200, Index=2, File: boundary.nc)
(Tmin= 0.0000 Tmax= 0.0000)
Maximum grid stiffness ratios: rx0 = 3.692595E-01 (Beckmann and Haidvogel)
rx1 = 1.678067E+00 (Haney)
Initial basin volumes: TotVolume = Infinity m3
MinVolume = 1.0000000000E+20 m3
MaxVolume = Infinity m3
Max/Min = Infinity
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00129601 - 00000401)
GET_2DFLD - surface u-momentum stress, t = 60 00:00:00
(Rec=0003, Index=2, File: frc_surface.nc)
GET_2DFLD - surface v-momentum stress, t = 60 00:00:00
129600 30 00:00:00 NaN NaN NaN Infinity
(000,000,0) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
Node # 3 CPU: 0.455
Node # 7 CPU: 0.460
Node # 0 CPU: 0.440
Node # 4 CPU: 0.455
Node # 6 CPU: 0.452
Node # 2 CPU: 0.460
Node # 5 CPU: 0.452
Node # 1 CPU: 0.459
Total: 3.632
Allocation and array initialization .............. 0.234 ( 6.4409 %)
Ocean state initialization ....................... 0.068 ( 1.8716 %)
Reading of input data ............................ 0.660 (18.1669 %)
Processing of input data ......................... 0.003 ( 0.0826 %)
Computation of global information integrals ...... 0.032 ( 0.8808 %)
2D/3D coupling, vertical metrics ................. 0.056 ( 1.5414 %)
Omega vertical velocity .......................... 0.014 ( 0.3854 %)
Equation of state for seawater ................... 0.074 ( 2.0368 %)
Total: 1.141 31.4065
Message Passage: 2D halo exchanges ............... 0.051 ( 1.4038 %)
Message Passage: 3D halo exchanges ............... 0.045 ( 1.2386 %)
Message Passage: 4D halo exchanges ............... 0.005 ( 0.1376 %)
Message Passage: data broadcast .................. 1.154 (31.7646 %)
Message Passage: data reduction .................. 0.012 ( 0.3302 %)
Message Passage: data scattering.................. 1.510 (41.5630 %)
Total: 2.777 76.4379
All percentages are with respect to total time = 3.632
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_stflux.h
Re: Model indicates infinite grid size, but pm, pn are non-z
#2 Unread post by wilkin »
You say you've checked that pm, pn are non-zero, but ROMS appears to insist otherwise.
Can you share your grid file through an http web service, ftp, google docs or whatever, so the community can take a look at it?
I suspect there is some issue with appropriate dimensions of the rho, u and v coordinates, or a netcdf FillValue or missingvalue.
John.
wjschulz
#3 Unread post by wjschulz »
John - Thanks for the response. I went back and traced pn and pm inputs and found the problem - I was feeding incorrect dimensions for pn and pm in my matlab grid generation code. Seems to be working well now. Thanks again! - Bill
