Hello ROMS Forum,
I am attempting to run a coupled WRF/ROMS model simulation with open boundary conditions, but I am experiencing problems initializing ROMS, not related to WRF. Currently, I have ROMS fully compiled and I have already generated ROMS model grid, initialization, climatology, and boundary files. When I attempt to run the coupled system WRF initializes correctly, but ROMS fails because it is missing a file ocean_frc.nc. If I assume closed-boundary conditions, all my input files feed into ROMS correctly, but the run fails after 3 hours due to model instability associated with the closed boundaries. Is there any way to modify my configuration to allow for open boundary conditions yet work around this forcing condition file? Otherwise, if I must generate it, are there tools available when I can generate these files and from where may I find the need data?
roms.error output file
Coupled Input File name = Projects/NOREASTER/coupling_coawst.in
Model Coupling:
Ocean Model MPI nodes: 000 - 007
Atmos Model MPI nodes: 008 - 059
Process Information:
Node # 0 (pid= 20114) is active.
Node # 3 (pid= 20118) is active.
Node # 2 (pid= 20113) is active.
Model Input Parameters: ROMS/TOMS version 3.4
Wednesday - June 6, 2012 - 6:35:23 PM
Node # 1 (pid= 20108) is active.
Node # 5 (pid= 20117) is active.
Node # 4 (pid= 20119) is active.
Node # 7 (pid= 20116) is active.
Node # 6 (pid= 20115) is active.
Idealized Coastal shelf
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/local/intel/mpi/3.2.2.006/bin64/mpif90
Compiler flags : -heap-arrays -fp-model precise -m64 -ip -O3 -xW -I/usr/local/other/SLES11/MCT/include -I/usr/local/other/SLES11/MCT/include -free
Input Script : Projects/NOREASTER/roms.namelist.in
SVN Root URL : https://www.myroms.org/svn/omlab/branches/jcwarner
SVN Revision : 583M
Local Root : /gpfsm/dnb32/snicholl/WRF_COAWST/WRF_ROMS_open/COAWST
Header Dir : /discover/nobackup/snicholl/WRF_COAWST/WRF_ROMS_open/COAWST/Projects/NOREASTER
Header file : noreaster.h
Analytical Dir: /discover/nobackup/snicholl/WRF_COAWST/WRF_ROMS_open/COAWST/Projects/NOREASTER
Resolution, Grid 01: 0158x0338x016, Parallel Nodes: 8, Tiling: 002x004
64800 ntimes Number of timesteps for 3-D equations.
10.000 dt Timestep size (s) for 3-D equations.
600.000 TI_ATM_OCN Time interval (s) between coupling ATM-OCN models.
60 nOCN_ATM Number of OCN timesteps between coupling to ATM.
1 WRF_CPLG_GRID WRF grid number that roms/swan will couple to.
2160 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
2160 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
2160 nAVG Number of timesteps between the writing of
2160 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
5.0000E-02 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
50.000 Tcline S-coordinate surface/bottom layer width (m) used
54058.000 dstart Time-stamp assigned to model initialization (days).
20061119.50 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
18.000 T0 Background potential temperature (C) constant.
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idSrad) Write out shortwave radiation flux.
Output History File: ocean_noreaster_his.nc
Output Diagnostics File: ocean_dia.nc
Physical parameters File: Projects/NOREASTER/roms.namelist.in
Input Grid File: Projects/NOREASTER/ROMS_coawst_grd_final.nc
Input Nonlinear Initial File: Projects/NOREASTER/ROMS_coawst_ini_final.nc
Tile partition information for Grid 01: 0158x0338x0016 tiling: 002x004
tile Istr Iend Jstr Jend Npts
0 1 79 1 84 106176
1 80 158 1 84 106176
2 1 79 85 169 107440
3 80 158 85 169 107440
4 1 79 170 254 107440
5 80 158 170 254 107440
6 1 79 255 338 106176
7 80 158 255 338 106176
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 79.50 0.50 84.50 RHO-points
1 79.50 158.50 0.50 84.50 RHO-points
2 0.50 79.50 84.50 169.50 RHO-points
3 79.50 158.50 84.50 169.50 RHO-points
4 0.50 79.50 169.50 254.50 RHO-points
5 79.50 158.50 169.50 254.50 RHO-points
6 0.50 79.50 254.50 338.50 RHO-points
7 79.50 158.50 254.50 338.50 RHO-points
0 1.00 79.50 0.50 84.50 U-points
1 79.50 158.00 0.50 84.50 U-points
2 1.00 79.50 84.50 169.50 U-points
3 79.50 158.00 84.50 169.50 U-points
4 1.00 79.50 169.50 254.50 U-points
5 79.50 158.00 169.50 254.50 U-points
6 1.00 79.50 254.50 338.50 U-points
7 79.50 158.00 254.50 338.50 U-points
0 0.50 79.50 1.00 84.50 V-points
1 79.50 158.50 1.00 84.50 V-points
2 0.50 79.50 84.50 169.50 V-points
3 79.50 158.50 84.50 169.50 V-points
4 0.50 79.50 169.50 254.50 V-points
5 79.50 158.50 169.50 254.50 V-points
6 0.50 79.50 254.50 338.00 V-points
7 79.50 158.50 254.50 338.00 V-points
HaloSizeI(1) = 182
HaloSizeJ(1) = 194
TileSide(1) = 91
TileSize(1) = 7735
NOREASTER Idealized Coastal shelf
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
ADD_M2OBC Adding tidal currents to proccesed OBC data.
ATM_PRESS Impose atmospheric pressure onto sea surface.
ATM2OCN_FLUXES Surface fluxes from ATM Model.
AVERAGES Writing out time-averaged fields.
EAST_FSCHAPMAN Eastern edge, free-surface, Chapman condition.
EAST_M2FLATHER Eastern edge, 2D momentum, Flather condition.
EAST_M3RADIATION Eastern edge, 3D momentum, radiation condition.
EAST_TRADIATION Eastern edge, tracers, radiation condition.
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SOUTH_FSCHAPMAN Southern edge, free-surface, Chapman condition.
SOUTH_M2FLATHER Southern edge, 2D momentum, Flather condition.
SOUTH_M3RADIATION Southern edge, 3D momentum, radiation condition.
SOUTH_TRADIATION Southern edge, tracers, radiation condition.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WESTERN_WALL Wall boundary at Western edge.
WRF_COUPLING WRF model coupling.
ocean_frc.nc
call from:
rank 6 in job 1 borg01v021_48088 caused collective abort of all ranks
exit status of rank 6: killed by signal 9
