When I try to add a river input, I add to the header file: UV_PSOURCE, TS_PSOURCE ans ANA_PSOURCE. I've read previous problems.
In the ANA_PSOURCE I let the variables like this:
Nsrc=1
Dsrc=0
Isrc=1
Jsrc=6
Qshape= 1.0_r8/REAL(N(ng),r8)
Qbar=fac*1500.0_r8
Tsrc(is,k,itemp)=TO(ng)
Tsrc(is,k,isalt)=S0(ng)
As you can see, the values are the same as in the RIVERPLUME1 case.
With these values it compiles and it runs the model, but what I don't get it, is that Jsrc is supposed to be the location of j index, right? Well, I defined my grid analitically with Mm=4, so it shouldn't be more than 5 points, and when I put Jsrc=1 or 2 or 3 or 4 or 5, it compiles but blows up when I run the model. I don't understand why. Does somebody know?
Many thanks in advanced.
PROBLEM WITH ANA_PSOURCE
Re: PROBLEM WITH ANA_PSOURCE
Does ROMS give any kind of message on blowing up? That may or may not help us figure it out. Sometimes compiling with USE_DEBUG gives a little more information because the object files retain the line number information.
Thank you Kate, this is what I get with Jsrc(Nsrc)=4 for example, I've checked the USE_DEBUG and I have it on:
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler flags : -frepack-arrays -g -fbounds-check -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 575M
Local Root : /home/sergi/src
Header Dir : /home/sergi/Projects/CASPRACTIC
Header file : caspractic.h
Analytical Dir: /home/sergi/Projects/CASPRACTIC
Resolution, Grid 01: 0100x0004x010, Parallel Threads: 1, Tiling: 001x001
4032 ntimes Number of timesteps for 3-D equations.
into restart fields.
to standard output.
288 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
576 nAVG Number of timesteps between the writing of
576 nDIA Number of timesteps between the writing of
5.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
4.000 Tcline S-coordinate surface/bottom layer width (m) used
5.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
5.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T LtracerSrc(01) Processing point sources/Sink on tracer 01: temp
T LtracerSrc(02) Processing point sources/Sink on tracer 02: salt
T Dout(M2rate) Write out 2D momentun acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentun acceleration.
Output Diagnostics File: ocean_dia.nc
Tile partition information for Grid 01: 0100x0004x0010 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 100 1 4 4000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -1.50 102.50 0.50 5.50 RHO-points
0 -2.00 102.00 0.50 5.50 U-points
0 -1.50 102.50 0.00 5.00 V-points
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
CASPRACTIC CASPRACTIC
ANA_PSOURCE Analytical point sources and sinks.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_PSOURCE Mass point sources and sinks.
Process Information:
Thread # 0 (pid= 21489) is active.
Vertical S-coordinate System:
10 0.0000000 0.0000000 0.000 0.000 0.000 0.000
9 -0.1000000 -0.0050000 -0.321 -0.210 -0.321 -0.321
8 -0.2000000 -0.0204535 -0.718 -0.441 -0.718 -0.718
7 -0.3000000 -0.0477616 -1.198 -0.696 -1.198 -1.198
6 -0.4000000 -0.0894007 -1.781 -0.979 -1.781 -1.781
5 -0.5000000 -0.1491465 -2.494 -1.298 -2.494 -2.494
4 -0.6000000 -0.2324164 -3.374 -1.665 -3.374 -3.374
3 -0.7000000 -0.3467612 -4.477 -2.094 -4.477 -4.477
2 -0.8000000 -0.5025493 -5.875 -2.605 -5.875 -5.875
1 -0.9000000 -0.7139071 -7.671 -3.228 -7.671 -7.671
0 -1.0000000 -1.0000000 -10.000 -4.000 -10.000 -10.000
Time Splitting Weights: ndtfast = 30 nfast = 42
7-0.0011849025289723 0.0336508794757796-0.0107112868023601 0.2343461315221332
8-0.0005032751608632 0.0336903762267453-0.0112145619632232 0.2680365077488785
9 0.0003887272597151 0.0337071520654408-0.0108258347035082 0.3017436598143193
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325832
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801077
14 0.0079087469427945 0.0332075372104522 0.0116826306292293 0.4692492050905599
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029189
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429149
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276979
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780106
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489551
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976139
21 0.0256737146312911 0.0297153720153352 0.1342125541712343 0.6900486906129492
22 0.0286498597812017 0.0288595815276255 0.1628624139524359 0.7189082721405747
23 0.0316613792205220 0.0279045862015855 0.1945237931729579 0.7468128583421602
24 0.0346736416507075 0.0268492068942347 0.2291974348236654 0.7736620652363949
25 0.0376471948657328 0.0256934188392112 0.2668446296893983 0.7993554840756061
26 0.0405373376992233 0.0244385123436867 0.3073819673886216 0.8237939964192929
27 0.0432936737565711 0.0230872677537126 0.3506756411451927 0.8468812641730055
28 0.0458596469320356 0.0216441452951603 0.3965352880772283 0.8685254094681657
29 0.0481720587108285 0.0201154903974257 0.4447073467880568 0.8886408998655915
30 0.0501605672561820 0.0185097551070648 0.4948679140442388 0.9071506549726562
31 0.0517471682814031 0.0168377361985254 0.5466150823256418 0.9239883911711816
32 0.0528456577069106 0.0151128305891453 0.5994607400325525 0.9391012217603268
33 0.0533610761022577 0.0133513086655816 0.6528218161348102 0.9524525304259084
34 0.0531891349131380 0.0115726061288397 0.7060109510479481 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213241 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232271 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079425 0.9882658063583314
38 0.0431818225418188 0.0048034616164019 0.8990779740497613 0.9930692679747333
39 0.0376397765791563 0.0033640675316746 0.9367177506289176 0.9964333355064079
40 0.0305543017255205 0.0021094083123694 0.9672720523544381 0.9985427438187773
41 0.0217382098544503 0.0010909315881854 0.9890102622088884 0.9996336754069627
42 0.0109897377911117 0.0003663245930371 1.0000000000000000 0.9999999999999998
Minimum X-grid spacing, DXmin = 1.00000000E-01 km
Maximum X-grid spacing, DXmax = 1.00000000E-01 km
Minimum Y-grid spacing, DYmin = 2.50000000E-01 km
Maximum Y-grid spacing, DYmax = 2.50000000E-01 km
Minimum Z-grid spacing, DZmin = 3.21428732E-01 m
Maximum Z-grid spacing, DZmax = 2.32923473E+00 m
Minimum barotropic Courant Number = 1.06675208E+00
Maximum barotropic Courant Number = 1.06675208E+00
Maximum Coriolis Courant Number = 3.00037500E-02
Maximum grid stiffness ratios: rx0 = 0.000000E+00 (Beckmann and Haidvogel)
rx1 = 0.000000E+00 (Haney)
Initial basin volumes: TotVolume = 1.0000000000E+08 m3
MinVolume = 8.0357183061E+03 m3
MaxVolume = 5.8230868312E+04 m3
Max/Min = 7.2465044311E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00004032)
0 0 00:00:00 8.750000E-01 1.236683E+02 1.245433E+02 2.000000E+08
(001,2,10) 3.000000E+00 1.200000E+00 0.000000E+00 1.414214E+00
DEF_AVG - creating average file: ocean_avg.nc
DEF_DIAGS - creating diagnostics file: ocean_dia.nc
1 0 00:05:00 NaN NaN NaN NaN
(000,0,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Thread # 0 CPU: 1.372
Total: 1.372
Allocation and array initialization .............. 0.064 ( 4.6647 %)
Ocean state initialization ....................... 0.016 ( 1.1662 %)
Computation of vertical boundary conditions ...... 0.004 ( 0.2915 %)
Computation of global information integrals ...... 0.016 ( 1.1662 %)
Writing of output data ........................... 0.024 ( 1.7492 %)
Model 2D kernel .................................. 0.976 (71.1371 %)
2D/3D coupling, vertical metrics ................. 0.020 ( 1.4577 %)
Omega vertical velocity .......................... 0.004 ( 0.2915 %)
Equation of state for seawater ................... 0.040 ( 2.9155 %)
KPP vertical mixing parameterization ............. 0.004 ( 0.2916 %)
3D equations right-side terms .................... 0.008 ( 0.5831 %)
3D equations predictor step ...................... 0.012 ( 0.8747 %)
Pressure gradient ................................ 0.004 ( 0.2915 %)
Harmonic mixing of tracers, S-surfaces ........... 0.004 ( 0.2915 %)
Harmonic stress tensor, S-surfaces ............... 0.004 ( 0.2915 %)
Corrector time-step for 3D momentum .............. 0.096 ( 6.9971 %)
Corrector time-step for tracers .................. 0.076 ( 5.5394 %)
Total: 1.372 100.0001
All percentages are with respect to total time = 1.372
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_psource.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
CPU/hardware : i686
SVN Revision : 575M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 100 1 4 4000
Total: 1.372
Do not use ANA_PSOURCE. This option is extremely difficult to code in parallel. It requires a lot of expertise. I don't think that it is a good idea for users learning about ROMS to start coding the ANA_PSOURCE option. This option is very deceiving. It may look trivial but it is actually very difficult even for me. Build a NetCDF file instead. I have mentioned this several times in this forum
The cause of your blowup could be here:
You want these numbers to all be less than one. Try a shorter timestep - like say half as long.
