tides forcing on a flat bottom
asujrpv
#1 Unread post by asujrpv »
Hello everybody,
I am experiencing problems with the boundaries in a test case that is not realistic, but I think should give me kinetic turbulence generated only at the bottom. First let me explain the real problem I am analyzing: It is a small area with shallow water. I applied tide forcing to the area and gave me some results that seem reasonable (please see attached figures of a cross-section at day = 3). Then, in order to investigate whether my forcing was correct, I set the bottom as flat and put no stratification. In the first (realistic case) the file attached is Ysec_real.gif, the next two files Ysec.gif and Xsec.gif are cases with the bottom almost flat and same forcing as in the realistic case.
Seems obvious that I have problems with the boundary. My *.h file is as follows: I will appreciate your help!
CDW CDW modeling
EAST_FSCHAPMAN Eastern edge, free-surface, Chapman condition.
EAST_M2FLATHER Eastern edge, 2D momentum, Flather condition.
EAST_M3RADIATION Eastern edge, 3D momentum, radiation condition.
EAST_KRADIATION Eastern edge, TKE fields, radiation condition.
EAST_TRADIATION Eastern edge, tracers, radiation condition.
MIX_GEO_UV Mixing of momentum along geopotential surfaces.
NONLINEAR Nonlinear Model.
NORTH_FSCHAPMAN Northern edge, free-surface, Chapman condition.
NORTH_M2FLATHER Northern edge, 2D momentum, Flather condition.
NORTH_M3RADIATION Northern edge, 3D momentum, radiation condition.
NORTH_KRADIATION Northern edge, TKE fields, radiation condition.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SOUTH_FSCHAPMAN Southern edge, free-surface, Chapman condition.
SOUTH_M2FLATHER Southern edge, 2D momentum, Flather condition.
SOUTH_M3RADIATION Southern edge, 3D momentum, radiation condition.
SOUTH_KRADIATION Southern edge, TKE fields, radiation condition.
SOUTH_TRADIATION Southern edge, tracers, radiation condition.
TS_A4HADVECTION Fourth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WEST_FSCHAPMAN Western edge, free-surface, Chapman condition.
WEST_M2FLATHER Western edge, 2D momentum, Flather condition.
WEST_M3RADIATION Western edge, 3D momentum, radiation condition.
WEST_KRADIATION Western edge, TKE fields, radiation condition.
WEST_TRADIATION Western edge, tracers, radiation condition.
real case
real case
Y-section TKE flat bottom
X-cross-section TKE flat bottom
