ROMS Revision 564 Parallel I/O problem
lmkli
#1 Unread post by lmkli »
I compiled ROMS 564 with PGI fortran and netcdf4.4.1, and tried to active CPP definition HDF5 and PARALLEL_IO.
The compilation is ok, but when I ran the executable by 6 CPUs, I got error message:
REASON: Parallel operation on file opened for non-parallel access
I tried both openmpi and mvapich2 and got same result. The case I tested is UPWELLING.
Any hint?
Thanks.
The output details are listed below.
Model Input Parameters: ROMS/TOMS version 3.5
Friday - July 1, 2011 - 11:56:13 AM
Wind-Driven Upwelling/Downwelling over a Periodic Channel Node # 1 (pid= 30525) is active.
Node # 4 (pid= 30528) is active. Node # 3 (pid= 30527) is active.
Operating system : Linux
CPU/hardware : x86_64
Compiler system : pgi
Compiler command : /public/soft/mvapich215-pgi102/bin/mpif90
Compiler flags : -O3 -Mfree
Input Script : ./ocean_upwelling.in
SVN Revision :
Local Root : /public/home/lmkli/romspac/roms201106
Header Dir : /public/home/lmkli/romspac/roms201106/ROMS/Include
Header file : upwelling.h
Analytical Dir: /public/home/lmkli/romspac/roms201106/ROMS/Functionals
Resolution, Grid 01: 0401x0800x016, Parallel Nodes: 6, Tiling: 002x003
1 ERend Ending ensemb Node # 2 (pid= 30526) is active. Node # 5 (pid= 30529) is active.
le/perturbation run number.
into restart fields.
to standard output.
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
T Dout(M2rate) Write out 2D momentun acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentun acceleration.
Output Diagnostics File: ocean_dia.nc
Tile partition information for Grid 01: 0401x0800x0016 tiling: 002x003
tile Istr Iend Jstr Jend Npts
0 1 201 1 267 858672
1 202 401 1 267 854400
2 1 201 268 534 858672
3 202 401 268 534 854400
4 1 201 535 800 855456
5 202 401 535 800 851200
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 201.50 0.50 267.50 RHO-points
1 201.50 401.50 0.50 267.50 RHO-points
2 0.50 201.50 267.50 534.50 RHO-points
3 201.50 401.50 267.50 534.50 RHO-points
4 0.50 201.50 534.50 800.50 RHO-points
5 201.50 401.50 534.50 800.50 RHO-points
0 1.00 201.50 0.50 267.50 U-points
1 201.50 401.00 0.50 267.50 U-points
2 1.00 201.50 267.50 534.50 U-points
3 201.50 401.00 267.50 534.50 U-points
4 1.00 201.50 534.50 800.50 U-points
5 201.50 401.00 534.50 800.50 U-points
0 0.50 201.50 1.00 267.50 V-points
1 201.50 401.50 1.00 267.50 V-points
2 0.50 201.50 267.50 534.50 V-points
3 201.50 401.50 267.50 534.50 V-points
4 0.50 201.50 534.50 800.00 V-points
5 201.50 401.50 534.50 800.00 V-points
HaloSizeI(1) = 642
HaloSizeJ(1) = 837
TileSide(1) = 273
TileSize(1) = 56784
ANA_VMIX Analytical vertical mixing coefficients.
EW_PERIODIC East-West periodic boundaries.
HDF5 Creating NetCDF-4/HDF5 format files.
NONLINEAR Nonlinear Model.
PARALLEL_IO Parallel I/O processing.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 30530) is active.
Vertical S-coordinate System:
16 0.0000000 0.0000000 0.000 0.000 0.000 0.000
15 -0.0625000 -0.0019442 -0.809 -0.806 -1.348 -1.589
14 -0.1250000 -0.0078455 -1.668 -1.661 -2.966 -3.687
13 -0.1875000 -0.0179119 -2.580 -2.568 -4.867 -6.321
12 -0.2500000 -0.0324983 -3.549 -3.531 -7.077 -9.535
11 -0.3125000 -0.0521190 -4.581 -4.558 -9.630 -13.397
10 -0.3750000 -0.0774659 -5.686 -5.656 -12.573 -17.996
9 -0.4375000 -0.1094327 -6.875 -6.837 -15.967 -23.445
8 -0.5000000 -0.1491465 -8.162 -8.114 -19.889 -29.890
7 -0.5625000 -0.1980075 -9.564 -9.506 -24.435 -37.512
6 -0.6250000 -0.2577387 -11.104 -11.034 -29.721 -46.531
5 -0.6875000 -0.3304460 -12.808 -12.724 -35.892 -57.218
4 -0.7500000 -0.4186931 -14.709 -14.609 -43.121 -69.903
3 -0.8125000 -0.5255915 -16.846 -16.726 -51.622 -84.987
2 -0.8750000 -0.6549105 -19.266 -19.124 -61.651 -102.953
1 -0.9375000 -0.8112096 -22.028 -21.859 -73.518 -124.388
0 -1.0000000 -1.0000000 -25.200 -25.000 -87.600 -150.000
Time Splitting Weights: ndtfast = 30 nfast = 42
7-0.0011849025289723 0.0336508794757796-0.0107112868023601 0.2343461315221331
8-0.0005032751608632 0.0336903762267453-0.0112145619632232 0.2680365077488784
9 0.0003887272597151 0.0337071520654408-0.0108258347035082 0.3017436598143192
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524358 0.7189082721405745
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421599
24 0.0346736416507075 0.0268492068942347 0.2291974348236652 0.7736620652363947
25 0.0376471948657328 0.0256934188392112 0.2668446296893980 0.7993554840756059
26 0.0405373376992233 0.0244385123436867 0.3073819673886213 0.8237939964192926
27 0.0432936737565710 0.0230872677537126 0.3506756411451923 0.8468812641730052
28 0.0458596469320356 0.0216441452951603 0.3965352880772279 0.8685254094681655
29 0.0481720587108285 0.0201154903974257 0.4447073467880564 0.8886408998655912
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726560
31 0.0517471682814031 0.0168377361985254 0.5466150823256414 0.9239883911711814
32 0.0528456577069106 0.0151128305891453 0.5994607400325520 0.9391012217603266
33 0.0533610761022577 0.0133513086655816 0.6528218161348097 0.9524525304259083
34 0.0531891349131380 0.0115726061288397 0.7060109510479476 0.9640251365547480
35 0.0522156244733761 0.0097996349650684 0.7582265755213237 0.9738247715198164
36 0.0503158038019030 0.0080591141492892 0.8085423793232267 0.9818838856691056
37 0.0473537721847154 0.0063819206892258 0.8558961515079421 0.9882658063583314
38 0.0431818225418188 0.0048034616164019 0.8990779740497609 0.9930692679747333
39 0.0376397765791564 0.0033640675316746 0.9367177506289173 0.9964333355064079
40 0.0305543017255206 0.0021094083123694 0.9672720523544379 0.9985427438187773
41 0.0217382098544504 0.0010909315881854 0.9890102622088883 0.9996336754069627
42 0.0109897377911118 0.0003663245930371 1.0000000000000000 0.9999999999999998
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 8.08965824E-01 m
Maximum Z-grid spacing, DZmax = 2.56123321E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 8.661243E-01 (Haney)
Initial basin volumes: TotVolume = 4.7107108807E+13 m3
MinVolume = 8.4521383562E+05 m3
MaxVolume = 2.5612332106E+07 m3
Max/Min = 3.0302783777E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
0 0 00:00:00 0.000000E+00 7.333540E+02 7.333540E+02 4.710711E+13
DEF_VAR - error while setting parallel access flag for variable: ntimes
in NetCDF file: ocean_his.nc
Node # 0 CPU: 1.283
Node # 2 CPU: 1.283
Node # 3 CPU: 1.267
Node # 1 CPU: 1.282
Node # 4 CPU: 1.283
Total: 7.681
Allocation and array initialization .............. 6.194 (80.6433 %)
Ocean state initialization ....................... 0.834 (10.8605 %)
Reading of input data ............................ 0.000 ( 0.0002 %)
Processing of input data ......................... 0.005 ( 0.0625 %)
Processing of output time averaged data .......... 0.001 ( 0.0139 %)
Computation of vertical boundary conditions ...... 0.005 ( 0.0686 %)
Computation of global information integrals ...... 0.064 ( 0.8353 %)
2D/3D coupling, vertical metrics ................. 0.323 ( 4.2037 %)
Omega vertical velocity .......................... 0.081 ( 1.0587 %)
Equation of state for seawater ................... 0.128 ( 1.6677 %)
Total: 7.636 99.4143
Message Passage: 2D halo exchanges ............... 0.095 ( 1.2370 %)
Message Passage: 3D halo exchanges ............... 0.104 ( 1.3563 %)
Message Passage: 4D halo exchanges ............... 0.024 ( 0.3148 %)
Message Passage: data broadcast .................. 0.000 ( 0.0003 %)
Message Passage: data reduction .................. 0.002 ( 0.0300 %)
Total: 0.226 2.9384
All percentages are with respect to total time = 7.681
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_smflux.h
Node # 5 CPU: 1.282
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_vmix.h
lmkli
Re: ROMS Revision 564 Parallel I/O problem
#2 Unread post by lmkli »
Any body/help here?
#3 Unread post by arango »
I mentioned in the release that ROMS parellel I/O is broken with the latest versions of the NetCDF library. It works with NetCDF version 4.1.x. Unidata changed the parallel library again and they seem to have problems with collective and independent operations when writing ROMS header file. We are investigating this. I don't have the time to debug the NetCDF library again. The C-code is recursive and a complete nightmare. David will be at Unidata this week, at the NetCDF workshops, and he is going to bring this to their attention.
:idea: I recommend you to use serial I/O. It is more efficient anyway. Parallel I/O requires special computer architecture to be efficient.
lmkli
#4 Unread post by lmkli »
Sorry, Arango. I think I must misunderstood something about the parallel I/O options and missed some information about the release news. Hope this feature can be ready to test.
Thank you anyway, and sorry for bothering everyone here.
