Headland test case hanging
m.hadfield
When I run the test_head case here
https://www.myroms.org/svn/src/test/test_head/
it hangs indefinitely with the following output
          T  Hout(idU3rs)    Write out total 3D u-radiation stress.
          T  Hout(idV3rs)    Write out total 3D v-radiation stress.
          T  Hout(idU3Sd)    Write out 3D u-momentum stokes velocity.
          T  Hout(idV3Sd)    Write out 3D v-momentum stokes velocity.
          T  Hout(idWamp)    Write out wave height.
          T  Hout(idWlen)    Write out wavelength.
          T  Hout(idWdir)    Write out wave direction.
          T
This occurs at the same place on a couple of different machines. The inlet test case (which also involves ROMS-SWAN coupling via MPI) runs fine on the same machines, apart from the blow-up issue.
Has anyone else encountered this problem?
m.hadfield
Re: Headland test case hanging
Never mind. I killed one of the jobs with Ctrl-C, at which point it emitted some additional, more helpful output:
             Output History File:  ocean_his.nc
              Output Floats File:  ocean_flt.nc
        Physical parameters File:  ocean_test_head.in
                 Input Grid File:  Data/test_head_curv_grd.nc
    Input Nonlinear Initial File:  Data/test_head_ini.nc
 READ_PHYPAR - could not find input file:  floats.in
 ROMS/TOMS - I/O error ............... exit_flag:   4
 ERROR: I/O related problem.
Buffering, eh?
OK, so now the questions are:
  • The FLOATS option is enabled in build.bash. Is this intentional?
  • If so, where can I get a floats input file?
#3 Unread post by jcwarner »
I am not able to keep up with all the changes. I stopped doing the "monday update to see what still works" part of my life. maybe someone else can do this.
mmahone
#4 Unread post by mmahone »
Hello: here the file floats.in I have been using in this test case. Can't remember how I got it, but it looks like the job has been through. Best,
floats.in
(9.21 KiB) Downloaded 627 times
